dunga
RB912UAG-2HPnD-OUT: Setup and configuration with intergrated mini pci-e sim
Tue Jun 30, 2015 12:33 pm
Hello All,
I have been trying to see if someone can help me configure or setup this device to use internal SIM.
I want to make use of the internal sim in the mini pci-e so that it can connect with the GSM provider in my area, so that instead of using the attaching my USB dongle on the usb slot, I can make use of the internal sim.
Your help and suggestions will be appreciated.
Dunga
pukkita
Trainer
Trainer
Re: RB912UAG-2HPnD-OUT: Setup and configuration with intergrated mini pci-e sim
Tue Jun 30, 2015 12:37 pm
To use the internal SIM you have to add a mini-PCIe modem to the mini PCIe slot. (This disables USB)
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
dunga
Fri Jul 03, 2015 11:05 am
I had done such but cant see the interface or the SIM interface in the router board. Is there any other way to enable the mini-PCIe card to be detected in the routerboard.
Thanks for your reply
pukkita
Trainer
Trainer
Fri Jul 03, 2015 11:24 am
Does modem appear in System > Resources > PCI? Did you use a compatible modem?
w32pamela
Sat Jul 04, 2015 1:05 am
Be sure to go into System->Routerboard, select USB and change the setting from USB typeA to Mini PCIe
dunga
Wed Jul 08, 2015 11:39 am
will see to it and give you feedback.
dunga
Tue Jul 14, 2015 7:19 pm
have made the changes as instructed but did not see how to make the sim card work or the interface for the sim configuration appears anywhere.
See attached picture here:
Where else could i go to get it done.
pukkita
Trainer
Trainer
Wed Jul 15, 2015 2:03 am
A ppp or LTE interface should have appeared, what modem brand/model are you using?
dunga
Wed Jul 15, 2015 12:29 pm
Nothing like ppp or LTE appeared on the interface.
The modem brand is Atheros communication, version1. see attached picture. Thanks
w32pamela
Wed Jul 15, 2015 7:24 pm
That is not a cellular GSM card. It is a 2.4/5ghz wifi card used for connecting to hotspots. I doubt there are any drivers in routerOS for this type of card.
Users browsing this forum: No registered users and 102 guests
