marrold
Any plan to increase 4096 byte variable limit in ROS 7?
Sun Jul 12, 2015 10:39 pm
I find the current 4096 byte variable limit crippling, is there any plans to increase this?
I'm a SIP / VoIP engineer. Feel free to ask questions...
23q
Re: Any plan to increase 4096 byte variable limit in ROS 7?
Fri Sep 18, 2015 11:11 pm
jeroenp
Sat May 21, 2016 12:41 pm
pe1chl
Sat May 21, 2016 1:08 pm
In my opinion a more sensible approach would be to introduce the concept of file open (with resulting file handle)
and read line from open file (from filehandle, to variable) so a loop can be written that reads a file line by line
and it can be processed line by line.
With this construct the 4096 byte limit will normally not be any problem.
jarda
Sun May 22, 2016 1:31 pm
This is very good approach. I would like it too.
jeroenp
Sun May 22, 2016 2:24 pm
That would only help if the handle approach:
1. was abstracted to any form of streaming (be it a file, network or memory stream, the latter for instance to allow for a varDump function to work)
2. could be specified the line termination (Windows, Mac, Unix, and others)
3. could write as well as read from a handle
--jeroen
Users browsing this forum: Baidu [Spider] and 91 guests
