omidkosari
Trainer
Trainer
queuing 100% cpu usage on CCR sometimes!
Mon Jul 27, 2015 10:38 am
Everything from packet counts, bandwidth , number of users , etc are same as before but sometimes tool > profiler shows "queuing" uses very high cpu usage which makes the router 100% for several minutes .
Router is CCR1036 v6.29.1 with ~110 static simple queues . The routers job is only queuing and nothing more .
Normally queuing uses 10~20% cpu usage and router's cpu usage is 20~30%
There is an open Ticket#2015063066000326 but staffs suggestions was not useful for me .
Start by running this command:
"/queue interface set [find] queue=default-small"
Check performance after that.
Regards,
Martins S.
I think that problem is caused because few queues have very many packet marks
specified for them. I suggest that you either merge packet marks or divide queue
in parts.
Regards,
Martins S.
MTCNA , MTCRE, MTCWE, Mikrotik Certified Trainer
9939781
Re: queuing 100% cpu usage on CCR sometimes!
Mon Jul 27, 2015 11:57 am
/queue interface set [find] queue=only-hardware-queue
I need a about mikrotik job
Welcome to my blog:http://www.cat-home.org
omidkosari
Trainer
Trainer
Mon Jul 27, 2015 12:21 pm
Thanks,
It is already only-hw-queue
raminmalek
Wed Aug 14, 2019 12:49 pm
Hi Dear I do this
But iF add Simple Queue and Set Target Ip address or Subnet My CPU become to 70 Percent
I Use Rouer-OS 6.44.5
When Set Target VLAN of user Cpu is normal
Ho fix this
This is BUG of router -OS ????
In the old version i donnot have this problem
Users browsing this forum: Bing [Bot], haakonn, halacs, jpguerra87, nbctcp, Znevna and 79 guests
