Jeanluck
CRS & Bonding LACP
Sat Aug 01, 2015 8:06 pm
I need bonding LACP under CRS at wire speed (without CPU usage).
Is this posible actually? exists some web with examples?
I need a simple usage, for example:
input in ether1 and output in a ether2/ether3 bonding interface
savage
Re: CRS & Bonding LACP
Mon Aug 03, 2015 1:14 am
/interface bonding
add mode=802.3ad name=EtherChannel slaves="ether1 - SW1/0/17,ether2 - SW2/0/17,ether3 - SW1/0/18,ether4 - SW2/0/18,ether5 - SW1/0/19,ether6 - SW2/0/19,ether7 - SW1/0/20,ether8 - SW2/0/20" transmit-hash-policy=\
    layer-2-and-3
Works great to my Ciscos... Seems (to my surprise) to balance out rather evenly as well. My CCR's hardly breaking a sweat CPU wise.
Regards,
Chris
Jeanluck
Mon Aug 03, 2015 5:10 pm
ok!, thanks!
doneware
Trainer
Trainer
Mon Aug 03, 2015 7:01 pm
to my best knowledge, LACP is not supported by hw on the crs. to use /interface bonding, the packet must traverse the 1Gig link between the cpu and the switch chip, so you lose a lot more what you could possibly gain. CRS is limited PPS-wise on the CPU to max 240kpps, which tops around 300Mbps...
all you can do is bonding w/o any protocol (e.g ether-channel mode on), somewhere at /inter ethernet switch trunk
#TR0359
savage
Mon Aug 03, 2015 7:20 pm
Uh-huh...
Port-channel5 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 0026.52e8.f994 (bia 0026.52e8.f994)
Description: *
MTU 1500 bytes, BW 4000000 Kbit, DLY 10 usec,
reliability 255/255, txload 94/255, rxload 90/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is unknown
input flow-control is off, output flow-control is unsupported
Members in this channel: Gi1/0/17 Gi1/0/18 Gi1/0/19 Gi1/0/20
ARP type: ARPA, ARP Timeout 04:00:00
Last input never, output 00:00:01, output hang never
Last clearing of "show interface" counters never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 1419901000 bits/sec, 183610 packets/sec
30 second output rate 1440288000 bits/sec, 185085 packets/sec
19160524199 packets input, 19054657271244 bytes, 0 no buffer
Received 23684 broadcasts (61588 multicasts)
0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 61588 multicast, 0 pause input
0 input packets with dribble condition detected
19333201452 packets output, 19397019454673 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 PAUSE output
0 output buffer failures, 0 output buffers swapped out
Regards,
Chris
Jeanluck
Mon Aug 03, 2015 8:27 pm
I need hw support on CRS.... I need wire speed.
honestly, I am not clear if possible after read the posts....
CRS has hw support for LACP?
doneware
Trainer
Trainer
Tue Aug 04, 2015 12:28 pm
[quote="savage"]Uh-huh...
[quote]
crs =/= ccr
#TR0359
Jeanluck
Wed Aug 05, 2015 5:32 pm
I do not understand :( ,sorry
CRS has hw support for LACP? (yes/no is enough)
mpreissner
Wed Aug 05, 2015 6:07 pm
The CRS hardware CAN support LACP, but the functionality has not been implemented through the RouterOS software, so there's no way to configure/control it.
Michael Preissner
CISSP, CCSP, CEH, PMP
tomaskir
Trainer
Trainer
Wed Aug 05, 2015 6:12 pm
No, CRS does NOT have hw support for bonding nor LACP.
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
Jeanluck
Wed Aug 05, 2015 6:55 pm
thank you!
It has become very clear.
chubbs596
Mon Mar 20, 2017 8:55 am
This is quite a big failing.
IF the chipset supports it mikrotik should implement the support in either routeros or swos.
Another very welcome feature would be virtual chassis and support for MCLAG.
Users browsing this forum: No registered users and 102 guests
