johnsilver
DNS assign for L2TP/IPSEC... bug?
Mon Aug 10, 2015 5:14 pm
Hi.
When i set DNS server (in PPP -> Profiles) L2TP connection can't be established. When i clear DNS server parameter then i can connect. Is it normal behavior?
In L2TP logs from router i can see that client in first case asked for ms-dns parameters and didn't get it and then trying again multiple times and then stopped with error "No network protocols running". In second case ms-dns parameter recieved router's ip as ms-dns parameter and second ms-dns from IP -> DNS.
So i can't set my dns server in PPP profile. Is it normal behavior?
johnsilver
Re: DNS assign for L2TP/IPSEC... bug?
Mon Aug 10, 2015 5:34 pm
Here is screenshot with ConfReq/ConfAck/ConfRef
johnsilver
Tue Aug 11, 2015 9:29 am
So i guess this is a bug. If i put two DNS servers in PPP profile than everything works OK. If one then no connection at all.
SN2015
Tue Aug 11, 2015 11:29 am
L2tp over IPsec will not be able to receive DNS suffix.
johnsilver
Thu Aug 13, 2015 10:53 am
Yes, I know. Thank you.
The bug described here fixed in 6.30.2 firmware upgrade.
What's new in 6.30.2 (2015-Jul-22 11:17):
*) pptp & l2tp - fixed problem where android client could not connect if
both dns names were not provided (was broken since v6.30);
Users browsing this forum: alexteg, Bing [Bot], Google [Bot], mktkRB, sindy and 197 guests
