Znuff
RB750 - High latency on LAN
Thu Aug 20, 2015 1:46 pm
Is anyone seeing this issue?
I have 2 x RB750 (legacy stuff) running either 6.29-6.31+ that show the same problem: after 1 or 2 hours, local latency is incredibly variable, anything from 10ms to 100ms.
I've tried resetting the board to defaults. I've downgraded from 6.31 to 6.29 but the problem still appears.
What could be causing this? I can't seem to find any configuration similarities between the 2 boards, except both using NAT.
I don't use Queues, I tried removing/disabling all firewall rules (except NAT). I tried disabling all virtual interfaces and VLANs. None made a difference.
If I reboot the board, it works just fine for a few hours.
Help?
Caci99
Re: RB750 - High latency on LAN
Thu Aug 20, 2015 2:17 pm
What is the CPU value at the moment when this happens?
When you say latency is high, you do ping from LAN to the router or from the router to LAN?
I suspect there might be another device with the same IP of the router on the network which is responding to the ping, causing conflict.
-Toni-
Don't crash the ambulance, whatever you do
Znuff
Fri Aug 21, 2015 12:39 am
It's not an "ip conflict". CPU Usage is low (10-15% tops).
I ping from router to lan and lan to router, same results. Like I said, this happens on 2 of the same boards (RB750), but in completely different setups (one is at home, one is at one of my clients). I am very much aware of what is behind them, so it's really not a conflict.
This is after a few hours:
http://i.imgur.com/D5zkCzH.png
I tried reconnecting the cables when it happens, I tried disabling/enabling the switch ports. I tried almost everything i could think of. The only thing fixing it is a router reboot.
dfc643
Fri Jul 01, 2016 12:08 pm
Users browsing this forum: MSN [Bot] and 109 guests
