MUM Europe 2020
gabrielpike
CCR 1036-12G4S Fans dont spin on ROS 6.30 and up
Mon Aug 24, 2015 9:05 pm
I have noticed on a CCR 1036-12G-4s that when I try to update to the newest ROS my fans stop working. I revert to 6.29.1 and fans resume. Is this a known problem or is anyone else experiencing this?
Gabriel Pike
MTCNA
marting
Re: CCR 1036-12G4S Fans dont spin on ROS 6.30 and up
Tue Aug 25, 2015 12:53 pm
Fans of my CCR1036-12G-4S are spinning at 6.30.2 if it is necessary.
Perhaps temperature is too low? I´m currently connected to the CCR and is on auto/main
Temp is at 40C and CPU at 54C.
Sometimes both are at 0RPM, sometimes only the second one is at about 3800RPM, sometimes both are beteween 3700 and 4200 RPM.
gabrielpike
Tue Aug 25, 2015 2:54 pm
No. Temperature is not the problem. I watch the temperature rise to 99C and the router reboots from overheating. I revert to old ROS and hardware resumes like normal or the fans engage at 50-55C.
Gabriel Pike
MTCNA
marting
Tue Aug 25, 2015 4:08 pm
Did you also upgrade the Firmware? I´m on 3.27
gabrielpike
Tue Aug 25, 2015 4:30 pm
yes...
Gabriel Pike
MTCNA
marting
Tue Aug 25, 2015 4:40 pm
Mhmmm, strange. As I don´t have this issue, it seems not be a general problem and I would suggest to contact the support with an autosupout.rif attached.
gabrielpike
Tue Aug 25, 2015 5:04 pm
Alright then. I will do this next.
Gabriel Pike
MTCNA
vipe
Fri Aug 28, 2015 3:56 pm
So am i
Users browsing this forum: baumie and 43 guests
