Code: Select all
oct/07 03:08:07 system,error,critical System rebooted because of kernel failure
oct/07 03:08:07 system,error,critical router was rebooted without proper shutdown
can you ping that IP? is http://IP working?When I want to enter the IP Winbox shows me a message "ERROR: could not connect to" ip "
try empty password (and 'admin' user with empty password)When I want to enter the MAC winbox shows me the message "Incorrect user or password" is strange because no one has changed the user or password.
How this feature actually works?*) vrrp - fix arp=reply-only;
*) vrrp - do not warn about version mismatch if VRID does not match;
*) vrrp - allow VRRP to work behind firewall and NAT rules;
Just for the record - I finally managed to resolve this issue on router with ~20 IPsec tunnels (same router, same configuration with disabled tunnel never encountered this problem). tl;dr version: Guess what... by turning the cache back on.Problem with router cache owerflow caused by sending traffic over IPsec tunnels (even if the router cache is turned off in the settings) still persists in this release
Ticket number #2015081766000633
