Update from 6.33.1 to 6.33.5
CCR1036, CCR1016, 2xCRS226 and have this:
on CCR1016 and CCR1036
Also have trouble with trunk on CRS226, after i create 7 gropus (2nic in group) switch have drop packets.
I believe the 00:00:00:00:00:00 ARP entries are the incomplete ARP entries mentioned in the changelog.
*) arp - show incomplete ARP entries;
I just tested it on an old RB450 and I can confirm that.On hAP on several routers all running 6.33.5 we are seeing a problem with the /tool e-mail settings.
If you set the server in Winbox to 1.1.1.1 (say) and then go to the CLI and execute /tool e-mail pring the address entry is blank.
You can only seem to enter the e-mail server address via the CLI. This then displays correctly in Winbox and CLI and it then works
Then comes my Switches are defective or faulty settings on them . Which section is best to create a theme ?I believe the 00:00:00:00:00:00 ARP entries are the incomplete ARP entries mentioned in the changelog.
6.33 is not a "bugfix only" branch yet.In addition, mikrotik say that it will not add new features to bug fix?
Wrong. Please check download page, where it is clearly indicated that currently 6.32.3 is "Bugfix only", while 6.33.5 is "Current". The presence of Y in the version number does not mean anything special on its own.6.XX.Y – only bug fixes
6.XX – fixes and feature changes
#newbieQ So.... I sawed off the branch I was sitting on. remotely removed previous wireless package and lost link a few days ago. Now on site with new packages downloaded to my macbook. connected with ethernet but unit does not resond on the webfig page. How do I best connect and upload the new wireless packages? Which are available locally. I can see unit is up and using its fixed ip address. ip-connectivity but obviously no internet access since link is down.For those getting the "ERROR: missing wireless-6.33.5-mipsbe.npk"
This pack have been replaced by the wireless-fp
You need to uninstall the old pack and install the new.
Why we start to get this now i domt know my 435 was on 6.30.2 and it just now i got it
Doing it this wayover the wireless is gonna break you wifi so there must be a bether way
What's new in 6.30 (2015-Jul-08 09:07):
*) removed wireless package from routeros bundle package,
new wireless-fp is left in place and wireless-cm2 added as option
if you got physical access to the board on site, do a port-check on the device to see what actually is open and then you might be able to narrow the problem (e.g. maybe the port you try to connect on isn't reachable at all)#newbieQ So.... I sawed off the branch I was sitting on. remotely removed previous wireless package and lost link a few days ago. Now on site with new packages downloaded to my macbook. connected with ethernet but unit does not resond on the webfig page. How do I best connect and upload the new wireless packages? Which are available locally. I can see unit is up and using its fixed ip address. ip-connectivity but obviously no internet access since link is down.For those getting the "ERROR: missing wireless-6.33.5-mipsbe.npk"
don't have a pc, have to use web fig to config?
/peter
zenmap on MacOSX (https://nmap.org/dist/nmap-7.01.dmg)
Any future hope for Windows clients picking up v6 DNS via ND or v6 DHCP-Server or even auto-magic? I still need to set v6 DNS servers manually in Windows. Windows 10 does seem to use v4 DNS server to get v6 resolution. In previous versions of Windows, I noticed it only used v6 DNS servers to get v6 addresses.dhcpv6-client - fix DNS address assignement;
I have open ticket about this. It should be already supported, if you just add DHCPv6 server without any pool, but it was broken in 6.34rc39 (confirmed by support) and who knows how long before that. In 6.34rc45 it's a little better, DHCPv6 server now accepts the info request packet and sends a reply, but it does not contain DNS. I'm waiting for confirmation if it's still bug or if it needs some configuration I didn't find.Any future hope for Windows clients picking up v6 DNS via ND or v6 DHCP-Server or even auto-magic?
What's new in 6.33.6 (2016-Jan-28 12:06):
*) winbox - show properly route-distinguisher for bgp vpn4;
*) winbox - show dhcp server name in dhcp leases;
*) ppp - make CoA work correctly with address-lists;
*) winbox - fixed tab names to correspond to console;
*) winbox - show only actual switch-cpu ports in switch setting combobox;
*) winbox/webfig - fixed version column ordering in ip neighbors list;
*) webfig - fixed switch port "default vlan id" has missing "auto" value;
*) webfig - fixed firewall connection-bytes option;
*) ipsec - fixed kernel failure after underlying tunnel has been disabled/enabled;
*) romon - allow to see device identity if it is longer than 31 character;
*) fastpath - show fp counters in /interface monitor aggregate;
*) bridge firewall - fix chain check (broken since 6.33.2);
*) bridge firewall - fixed crash when jump rule points to disabled custom chain;
*) smb - fix crash when changing user which has open session;
*) address-list - properly remove unused address-lists from drop-downs;
*) fetch - fixed closure after 30 seconds;
*) capsman - fix radius accounting stop message;
*) log - reopen log file if deleted;
*) packing - fix tcp/udp checksums when simple packing is used;
*) tile - fix ipsec freeze after SA updates;
*) upnp - fixed missing in-interface option for dynamic dst-nat rules;
*) tunnel - fix complaining about loop after ~248 days;
*) vrrp - make sure that VRRP gets state on bootup;
*) ppp - fixed rare kernel crash (introduced in v6.33);
*) ppp - do not allow empty name ppp secrets;
*) ssh - fix active user accounting.
