bryans2k
Re: v6.34.3 [current] is released!
Sun Mar 20, 2016 9:46 am
I don't know when it broke but in 6.34.3 netwatch reports everything as down and never comes up unless I disable/enable all netwatch's.
bryans2k
Sun Mar 20, 2016 9:51 am
Also, the following was posted on 6.32.4:
vrrp - make sure that VRRP gets state on bootup;
It isn't verifying state on boot in 6.34.3. I have an Ethernet interface VRRP with preemption disabled/default 100 priority on both which attempts to take master unless I disable it in a startup script and enable it a few seconds after boot.
kam66be
Wed Mar 23, 2016 6:04 am
After update to v6.34.3 (x86) , PPP coming crazy, connections either ovpn or pptp unable disconnect as expect,
No matter idle timeout or session timeout set, not working,
Even I do try remove selected active connections from winbox, it will come back after refresh!
Please focus on this issue!
strods
Wed Mar 23, 2016 8:26 am
As far as we know all problems with PPP should be fixed in latest 6.35rc version. If you upgrade and still experience issues, then please send supout file from your device (6.35rc) to support@mikrotik.com
Manfred
Thu Mar 24, 2016 1:10 pm
Hello
Still having Problems with the OVPN - Server with the V6.3x.x Versions connecting non Mikrotik OVPN - Clients.
Problem 1:
After connect, there is always a for me unexplainable Erromessage appearing in the Routerlog.
Problem 2:
The "Local Address" defined in the Secret for the Client is no more attached to the OVPN - Client as Gateway.
As You can see, the P-t-P Address at the Client is the same as the "Remote Address".
As this worked without any problems with f.e. ROS V6.27 the question is,
what has been changed to the OVPN - Server to make this going wrong ?
Btw,
the problems exist with any non Mikrotik ( Linux, Windows, ... ) OVPN - Clients !
Manfred
ufm
Thu Mar 24, 2016 11:31 pm
Do you plan to release 6.34.4 with this bugfix?
grusu
Mon Mar 28, 2016 9:05 am
On 2011UAS v6.34.3:
[admin@MikroTik-VF] > /system health print
voltage: 1106.5V
Same value in winbox.
Same after reboot.
bartjoo
Mon Mar 28, 2016 4:54 pm
Hello, i got a problem with this latest version (6.34.3) and x86.
I work with proxmox and mikrotik x86 installed. Never got problems until i updated to this version.
Every night the Mikrotik server reboot the system at 6 am for a fresh new start ;)
With this version (6.34.3) the ether1 is not always coming up after a scheduled restart.
not with dhcp client (he didnt got a ip adress,) and not with a static IP.
But its not always a problem. thats the strange thing of it.
i restart the server 10 times and 2 times he fails, 8 times it goes right.
When i cant connect to the server with ip, i reset the virtual machine and works again.
someone knows what this could be?
Greetz
Bart
strods
Tue Mar 29, 2016 10:10 am
Users browsing this forum: tgcnet and 52 guests
