well, this part should be fixed somehow you may write to support@ with this inconsistencyIf there are specific IPv6 related interfaces to be created, why are there no tabs on the interface window for these IPv6 tunnels?
If you would go the EoIP tunnel tab on the interfaces window, you could only add 'normal' IPv4 tunnels, no IPv6. The only way to add such IPv6 tunnel is via the main interface tab
