strods
Winbox 3.6 released!
Thu Sep 29, 2016 3:43 pm
What's new in v3.6:
*) fixed problem where some of the choice fields were in red even if proper value was selected;
*) fixed problem where initial configuration window was shown twice on first connect;
If you experience version related issues, then please report them to support@mikrotik.com.
Winbox is available here:
http://www.mikrotik.com/download
If you try to upgrade directly from Winbox loader and version is not available, then you might need to wait for a while until cache in path between your device and our servers is refreshed.
codered1983
Re: Winbox 3.6 released!
Thu Sep 29, 2016 10:45 pm
When this happens so close the application.
infused
Fri Sep 30, 2016 3:18 am
It really sucks, and crashes all the time.
crashes on close, on new window. hot keys for disabling, commenting etc dont work.
strods
Fri Sep 30, 2016 9:46 am
codered1983 - What steps do you execute to receive this error?
infused - This is not a global issue. Hotkeys, close, etc. works in general. It must be something specific. Please write to support@mikrotik.com and provide information about OS, RouterOS version, steps which you did execute, etc.
Deantwo
Fri Sep 30, 2016 12:00 pm
THANK YOU!
This will make mass configuration so much easier next time. ^^
I wish my FTP was FTL.
notToNew
Fri Sep 30, 2016 1:49 pm
removed. wrong
CCR1036-12G-4S, several 952Ui-5ac2nD, ...
alibalalo
Sat Oct 01, 2016 4:02 pm
add suppert lan arabic
conrad
Sat Oct 01, 2016 9:43 pm
Very inconveniently, all information isn't visible
It is difficult to make it?
acypkob
Sun Oct 02, 2016 9:53 am
and still it doesn't fit to my "road warrior" netbook 1024x600 display
some menus and lines are out of borders, see pic Image
Siona
Sun Oct 02, 2016 10:55 am
That's true! I have problems even on ThinkPad x220 with 1366x768 screen.
Cha0s
Forum Veteran
Forum Veteran
Sun Oct 02, 2016 2:59 pm
Yeap. Same here.
notToNew
Tue Oct 04, 2016 5:50 pm
Yeap. Same here.
Same here. Had to attach an bigger external monitor
Siona
Tue Oct 04, 2016 6:12 pm
I really can't understand why there are no side sliders in subwindows...
infused
Wed Oct 05, 2016 3:48 am
I have this on any machine I test from. All Windows 10 Pro, x64
Rudios
Forum Veteran
Forum Veteran
Wed Oct 05, 2016 8:21 am
I have found an issue when using inline comments.
On initial opening at least the interfaces or firewall windows (maybe other as well, didn't check) the comments column is not there.
I have to disable and re-enable the inline comments option in order to let it be shown.
And after checking more, I found out that only have to to this re-enabling once.
So if I disconnect and reconnect again after re-enabling inline comments, the comments column does show up directly
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
strods
Wed Oct 05, 2016 10:06 am
Rudios - We can not reproduce this. I connect to router with new session, enable "Inline comments", close session and when I re-connect I see comments column.
infused - I am also using Windows 10 x64, but it is working without any issues. Please write to support@mikrotik.com and provide precise steps which you follow to reproduce this issue (best would be video where we can see the problem).
raffav
Wed Oct 05, 2016 6:06 pm
Strods
me to have this problem with in line comments
i open a ticket time ago (Ticket#2016080466001351
PS: How i can upload the img directly to the forum ?
strods
Thu Oct 06, 2016 1:49 pm
raffav - I can not reproduce this in any way. Does it happen on multiple devices or on this particular one?
raffav
Thu Oct 06, 2016 2:32 pm
@strods
on that device(x86) i get 100% the time, but i already get it on another device (450g maybe)
PS: got it on another one (on CHR)
ps2: if you want i can give you a read access to my device (CHR-lab) to try to reproduce it , PM me!
edit, maybe i found a workaround: just make sure the auto save on close is checked, after that the comment filed will always show up
ditonet
Forum Veteran
Forum Veteran
Fri Oct 07, 2016 10:31 am
I've CHR (demo) hosted on VirtualBox as my testing enviroment for Dude.
CHR version is 6.38rc10, Winbox is ver. 3.6
When I try to connect to CHR, Winbox crashes during 'Downloading plugins...' and Winbox process terminates.
Does anybody noticed similar problem?
For other devices (more than 50) everything is OK.
Regards, Grzegorz.
EDIT: I forgot to mention that CHR is only device with 6.38rc10
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
vacari
Fri Oct 07, 2016 12:41 pm
I have a CCR1009 (6.38.rc 10), 2 CRS 24G and a RB3011 (6.38.rc10).
Only in the CCR1009 the Winbox (3.6) crash on login process and the application closes. (Since 6.38.rc9 version)
Access only the web.
raffav
Re: RE: Re: Winbox 3.6 released!
Fri Oct 07, 2016 12:54 pm
Please confirm
Rb3011 won't crash?
I had report that CHR and 3011 are having this problem.
Enviado do Moto X Force
ditonet
Forum Veteran
Forum Veteran
Fri Oct 07, 2016 5:46 pm
It seems that Winbox 3.7 solved my problem :)
Regards,
freemannnn
Long time Member
Long time Member
Fri Oct 07, 2016 9:18 pm
changelog for 3.7?
ivarmv
Sat Oct 08, 2016 6:03 am
infused is rigth, crash trying to start any option...there are someone working to fix it?
strods
Mon Oct 10, 2016 10:22 am
Users browsing this forum: No registered users and 6 guests
