normis
Re: v6.38rc [release candidate] is released
Tue Nov 22, 2016 2:14 pm
No!
6.37.1 and 6.37.2 have separate changelogs. Please read carefully.
raffav
Tue Nov 22, 2016 2:24 pm
Hello i think maybe is better talk about 6.37.1/6.37.2 on the 6.37.x Topic
strods
Tue Nov 22, 2016 3:28 pm
Version 6.38rc34 has been released.
Changes since 6.38rc31:
!) ipsec - added IKEv1 xauth user authentication with RADIUS "/ip ipsec user settings set xauth-use-radius=yes" (cli only);
!) ipsec - added IKEv2 EAP RADIUS passthrough authentication for responder (cli only);
!) ipsec - added IKEv2 experimental support with pre-shared-key and rsa-signature authentication methods (cli only);
!) ipsec - added support unique policy generation (cli only);
!) tr069-client - initial implementation (as separate package);
*) bonding - added "forced-mac-address" option;
*) certificates - added support for PKCS#12 export;
*) chr - fixed crash on "/interface print" (introduced in 6.36.4);
*) chr - fixed crash on "/system shutdown" and "/system shutdown";
*) dude - (changes discussed here: http://forum.mikrotik.com/viewtopic.php?f=8&t=112599);
*) firewall - new faster "connection-limit" option implementation;
*) ospf - fixed route crash caused by memory corruption when there are multiple active interfaces;
*) smb - fixed crash on connect (introduced in 6.38rc1);
*) tile - fixed rare kernel failure when IPv6 neighbor discovery packet is received;
*) traceroute - fixed crash when too many sessions are active;
*) winbox - recognize properly tcp in traffic-generator packet-template header type;
*) winbox - show HT MCS tab if 2GHz-G/N band is used;
*) wireless - added CRL checking for eap-tls;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
MartijnVdS
Tue Nov 22, 2016 4:52 pm
This will make deployment so much easier! Thanks :)
Kindis
Tue Nov 22, 2016 7:26 pm
I think this may have solved my issues with my CHR in Hyper-V. :-)
I can boot a fresh copy now without issues. Will try to upgrade my CHR asap to verify.
Kindis
Tue Nov 22, 2016 8:29 pm
Yepp this have solved my issues with CHR on Hyper-V (2012 R2). Upgrade went just fine from 6.36.3 and tested several reboots without any hickup.
So good work Mikrotik :-)
strods
Wed Nov 23, 2016 2:44 pm
Version 6.38rc35 has been released.
Changes since previous version:
*) disk - fixed issue when disk was renamed after reboot on devices with flash disks;
*) tunnel - allow to force mtu value when actual-mtu is already the same;
*) tunnel - fixed transmit packets occasionally not going through fastpath;
hechz
Thu Nov 24, 2016 5:01 am
Hi All,
I've just updated to rc35 and would like to report that the ipsec multi session behind a single NAT seems a bit buggy. While both sessions work for a few moments, as soon as traffic is passed, the session that connected first eventually becomes unuseable. I'm new to Mikrotik reporting, so if you'd like me to collect client side, and server side pcaps or anything, let me know.
/ppp profile
set *0 address-list="" !bridge !bridge-path-cost !bridge-port-priority \
    change-tcp-mss=yes !dns-server !idle-timeout !incoming-filter \
    !insert-queue-before !local-address name=default on-down="" on-up="" \
    only-one=default !outgoing-filter !parent-queue !queue-type !rate-limit \
    !remote-address remote-ipv6-prefix-pool=none !session-timeout \
    use-compression=default use-encryption=default use-ipv6=yes use-mpls=\
    default use-upnp=default !wins-server
/ppp profile
add address-list="" bridge=bridge-local !bridge-path-cost \
    !bridge-port-priority change-tcp-mss=yes dns-server=\
    192.168.88.2,192.168.88.20 !idle-timeout !incoming-filter \
    !insert-queue-before local-address=192.168.99.1 name=\
    L2TP-IPSec-VPN-Mobile on-down="" on-up="" only-one=default \
    !outgoing-filter !parent-queue !queue-type !rate-limit remote-address=\
    vpnClients !session-timeout use-compression=no use-encryption=required \
    use-ipv6=yes use-mpls=no use-upnp=yes wins-server=\
    192.168.88.20,192.168.88.5
/interface l2tp-server server
set allow-fast-path=no authentication=mschap2 default-profile=\
    L2TP-IPSec-VPN-Mobile enabled=yes keepalive-timeout=30 max-mru=1460 \
    max-mtu=1460 max-sessions=unlimited mrru=disabled use-ipsec=yes
/interface ovpn-server server
set auth=sha1 certificate=1_vpn.photosphere.net_bundle.crt_0 cipher=aes256 \
    default-profile=L2TP-IPSec-VPN-Mobile enabled=yes keepalive-timeout=60 \
    mac-address=x:x:x:x:x:x max-mtu=1500 mode=ip netmask=24 port=1194 \
    require-client-certificate=no
add address=0.0.0.0/0 auth-method=pre-shared-key comment=\
    "L2TP/IPSEC Dial-in Mobile Clients" dh-group=modp1024 disabled=no \
    dpd-interval=2m dpd-maximum-failures=5 enc-algorithm=aes-128,3des \
    exchange-mode=main-l2tp generate-policy=port-strict hash-algorithm=sha1 \
    lifetime=1d local-address=:: mode-config=pdn-vpn-split nat-traversal=yes \
    passive=no policy-template-group=default proposal-check=obey \
    send-initial-contact=yes
    "L2TP/IPSEC Dial-in Laptop Clients" dh-group=modp1024 disabled=no \
    passive=no policy-template-group=pdn-vpn proposal-check=obey \
/ip ipsec peer
/ip ipsec policy
set 0 disabled=no dst-address=0.0.0.0/0 group=default level=require proposal=\
    L2TP-VPN-IPsec protocol=all src-address=0.0.0.0/0 template=yes
add disabled=no dst-address=0.0.0.0/0 group=pdn-vpn level=require proposal=\
    "L2TP/IPSEC Dial-in Laptop Clients" protocol=all src-address=0.0.0.0/0 \
    template=yes
add action=encrypt comment=MARS-PDN<->ADMS-DUB disabled=yes dst-address=\
    0.0.0.0/0 dst-port=any ipsec-protocols=esp level=require priority=0 \
    proposal="L2TP/IPSEC Dial-in Laptop Clients" protocol=all sa-dst-address=\
    185.58.18.243 sa-src-address=x.x.x.x src-address=0.0.0.0/0 src-port=\
    any tunnel=yes
strods
Thu Nov 24, 2016 11:51 am
Version 6.38rc36 has been released.
Changes since 6.38rc35:
*) file - fixed file manager crash when file transfer gets cancelled;
*) mipsbe - improved memory allocation on devices with nand when file transfer and tcp traffic processing is on progress;
*) ppp - significantly improved shutdown speed on servers with many active tunnels;
alexspils
Thu Nov 24, 2016 3:01 pm
bug:
Reset TR-069 data? [y/N]:
y
/pckg/tr069-client/home/TR069-reset.sh: 3: pkill: not found
done
barracuda
Thu Nov 24, 2016 10:20 pm
I have a problem with latest 6.38rc build when I try to update Mikrotik hAP lite (RB941-2nD).When the upgrade is finish and router reboot I can't connect to the router anymore.
No wireles signal and no neighbors mac address.The only way is netinstall.Does anyone have the same problems because I never before have the same problem?
Gennadiy51
Thu Nov 24, 2016 10:49 pm
+1 with two RouterBoards hAP lite (RB941-2nD) on v6.38rc35. On v6.38rc36 all OK.
pyjamasam
Fri Nov 25, 2016 3:54 am
Attempting to upgrade a CHR install of 6.38rc31 to 6.38rc36 results in the following log entries:
licence does not permit to upgrade routeros-x86-6.38rc36
licence does not permit to upgrade dude-6.38rc36
open /dev/panics failed
I have the dude package installed as well (this is my dude test install).
This is a system running a P1 level licence as its a test system.
Next Renewal is listed as November 25th 2016, Deadline is listed as November 18th 2016.
Limited upgrades is checked.
I just tried renewing the licence and there was no change to the next renewal date or the deadline date.
So the upgrade seams to be limited by my licence, though looking at the dates shown in the licence dialog it would seem to me that things are still ok...
Just curious for some clarification to my understanding, or if this is a bug.
chris.
bajodel
Long time Member
Long time Member
Fri Nov 25, 2016 12:35 pm
.. [CUT]..
CRS125-24G-1S upgraded from 6.38rc34 (or 6.38rc35) to 6.38rc36 went in 'dead state' (probable kernel panic, I had no possibility to check with console cable). After manually power cycling two times it came back alive correctly on 6.38rc36 and now seems to work normally. Probably this is an isolated/local issue but maybe someone has the same problem and go directly to netinstall; try to power cycle the device a couple of time before netinstall.
No problem noticed instead on upgrading a hEX (gr3) and a hAP lite (lab devices). Conversely, from rc34 on, the new hEX (gr3) seems has definitely more stable ethernet interfaces ..they sometimes were flapping in a strange way > links down counters increasing without notices in log , Gbit links flapping and going 100M after half dozen negotiation tries (linked to CRS125)
normis
Fri Nov 25, 2016 1:28 pm
bug:
y
done
Fix included in next built, but in general, this command should not be used. We will remove it. It was meant to completely reset the TR069 program, if it is completely crashed. Not needed in normal use.
horza
Fri Nov 25, 2016 1:55 pm
After upgrading to rc36 from the previous rc, my RB2011UAS-2HnD went to 100% CPU usage. It used to be under 15%.
It doesn't crash, just runs at 100%. Routing is noticeably slow, so it's not a CPU usage reading error, but a real 100% usage.
I haven't seen this problem with any of the previous RCs (I upgrade this router as soon as there's an RC update).
I'm not seeing any problems on x86_64, so I'm guessing it might be related to the latest memory allocation update for mipsbe :)
Here's a screenshot: https://dl.horza.org/routeros/routeros- ... -usage.png
Update: I've rebooted it and it's fine now. Will keep monitoring.
strods
Fri Nov 25, 2016 2:51 pm
Version 6.38rc37 has been released.
Changes since 6.38rc36:
*) firewall - fixed filter rule "limit" parameter by making it visible again;
*) hAP lite - fixed bootup (broken in v6.38rc35);
nescafe2002
Forum Veteran
Forum Veteran
Fri Nov 25, 2016 3:51 pm
Please report to support; i've had similar issue with RB2011 which could not be reproduced.
In my case the router spiked to 100% cpu after upgrade from 6.38rc25 to 6.38rc31 with a certificate bundle present.
Ticket#2016110822001251
BorislavTP
Fri Nov 25, 2016 4:06 pm
I have installed this version as I already want to connect Vodafone K4201-Z LTE USB Modem in RB2011UAS-IN router.
I have tried to configure it, but without any success.
Could someone help me?
Thank you in advance.
irico
Fri Nov 25, 2016 4:26 pm
IPSEC IKEv2 not working in latest RCs.
In version 6.38rc31 was working fine. Updated to 6.38rc35 IPsec cannot establish tunnel. Update to 6.38rc37 same problem.
This is a test environment.
R1:
Logs:
Nov/25/2016 14:08:39 ipsec,debug ==========
Nov/25/2016 14:08:39 ipsec,debug 268 bytes message received from 10.1.0.1[500] to 10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet e58e1a2e bdaa3dc0 00000000 00000000 29202208 00000000 0000010c 28000008
Nov/25/2016 14:08:39 ipsec,debug,packet 00004000 2200001c 2f303127 c4ca221f 0a3f66de 303a3904 ce77e2d8 14c1b8e9
Nov/25/2016 14:08:39 ipsec,debug,packet 21000088 00020000 be28d5e3 63b9b4f1 0270204c 3a25fe10 ce529482 d2a42f81
Nov/25/2016 14:08:39 ipsec,debug,packet 4bd1caf9 1dbecd12 6afcbf51 71b11f3b 02152329 6e15a0e2 c9d743f9 893b2835
Nov/25/2016 14:08:39 ipsec,debug,packet 250741df ad128056 b3d4c9e1 4d38d551 8a5993e5 75eb4eec cae195d3 7c36470c
Nov/25/2016 14:08:39 ipsec,debug,packet 7c27a5ea 40fe6f87 0add9e36 839bf114 42ba3794 470df073 0b24263f ec96e130
Nov/25/2016 14:08:39 ipsec,debug,packet b4e8c55e 7412a936 00000044 00000040 01010006 0300000c 0100000c 800e0100
Nov/25/2016 14:08:39 ipsec,debug,packet 0300000c 0100000c 800e0080 03000008 01000003 03000008 02000005 03000008
Nov/25/2016 14:08:39 ipsec,debug,packet 03000003 00000008 04000002
Nov/25/2016 14:08:39 ipsec,debug ike2 request exchange: SA_INIT id: 0
Nov/25/2016 14:08:39 ipsec,debug ike2 respond
Nov/25/2016 14:08:39 ipsec,debug payload seen: NOTIFY
Nov/25/2016 14:08:39 ipsec,debug payload seen: NONCE
Nov/25/2016 14:08:39 ipsec,debug payload seen: KE
Nov/25/2016 14:08:39 ipsec,debug payload seen: SA
Nov/25/2016 14:08:39 ipsec,debug processing payload: NONCE
Nov/25/2016 14:08:39 ipsec,debug processing payload: SA
Nov/25/2016 14:08:39 ipsec,debug IKE Protocol: IKE
Nov/25/2016 14:08:39 ipsec,debug  proposal #1
Nov/25/2016 14:08:39 ipsec,debug   enc: aes256-cbc
Nov/25/2016 14:08:39 ipsec,debug   enc: aes128-cbc
Nov/25/2016 14:08:39 ipsec,debug   enc: 3des-cbc
Nov/25/2016 14:08:39 ipsec,debug   prf: hmac-sha256
Nov/25/2016 14:08:39 ipsec,debug   auth: sha256
Nov/25/2016 14:08:39 ipsec,debug   dh: modp1024
Nov/25/2016 14:08:39 ipsec,debug matched proposal:
Nov/25/2016 14:08:39 ipsec,debug processing payload: KE
Nov/25/2016 14:08:39 ipsec,debug => shared secret (size 0x80)
Nov/25/2016 14:08:39 ipsec,debug ea813706 7c9cb1c4 b6cdaf4c 73158754 df387020 4d154f95 7bbd26e7 4c14159e
Nov/25/2016 14:08:39 ipsec,debug ac2a98eb 6fbc5eb0 6c78b12b a784e89b d7f59b31 9b9f8bcb b6cd9b84 4a1d6e1e
Nov/25/2016 14:08:39 ipsec,debug 707023d1 45d7b35f 78b6c342 f967894d 784ea3ea 7d9ced9d ceb909f8 67e1c99a
Nov/25/2016 14:08:39 ipsec,debug fe2bdd3d 80bfb5a2 f69f8f1a 6d0fa025 08571c3c 0d197aa9 72fc6f96 7b674e68
Nov/25/2016 14:08:39 ipsec,debug adding payload: SA
Nov/25/2016 14:08:39 ipsec,debug => (size 0x30)
Nov/25/2016 14:08:39 ipsec,debug 00000030 0000002c 01010004 0300000c 0100000c 800e0100 03000008 02000005
Nov/25/2016 14:08:39 ipsec,debug 03000008 03000003 00000008 04000002
Nov/25/2016 14:08:39 ipsec,debug adding payload: KE
Nov/25/2016 14:08:39 ipsec,debug => (size 0x88)
Nov/25/2016 14:08:39 ipsec,debug 00000088 00020000 414aaee4 22891380 c2743b6e f2441419 d8bcf44b c88ce7f0
Nov/25/2016 14:08:39 ipsec,debug 09481773 cff0e6ca f69867bc 724fab65 d8aea6a7 88e5febe 05c2079e 9b319632
Nov/25/2016 14:08:39 ipsec,debug 4ca94d42 63a8811f 4a21e1d9 cdeb9d31 b9176be7 c390ceee 057db503 d81f9055
Nov/25/2016 14:08:39 ipsec,debug 4164b805 0e5afa77 e9ed3f91 9e047fee 64e2acc1 c9f28a5b b8e63853 15b1ca07
Nov/25/2016 14:08:39 ipsec,debug 63a442df b4d8da49
Nov/25/2016 14:08:39 ipsec,debug adding payload: NONCE
Nov/25/2016 14:08:39 ipsec,debug => (size 0x1c)
Nov/25/2016 14:08:39 ipsec,debug 0000001c 8b24f42f aada2a63 b1d521de 55c5e635 450f145c 1e79b6cc
Nov/25/2016 14:08:39 ipsec,debug adding payload: NOTIFY
Nov/25/2016 14:08:39 ipsec,debug => (size 0x8)
Nov/25/2016 14:08:39 ipsec,debug 00000008 00004000
Nov/25/2016 14:08:39 ipsec,debug sending 248 bytes from 10.0.0.1[500] to 10.1.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet sockname 10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet send packet from 10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet send packet to 10.1.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet src4 10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet dst4 10.1.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet 1 times of 248 bytes message will be sent to 10.1.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet e58e1a2e bdaa3dc0 b26151ae a98a503f 21202220 00000000 000000f8 22000030
Nov/25/2016 14:08:39 ipsec,debug,packet 0000002c 01010004 0300000c 0100000c 800e0100 03000008 02000005 03000008
Nov/25/2016 14:08:39 ipsec,debug,packet 03000003 00000008 04000002 28000088 00020000 414aaee4 22891380 c2743b6e
Nov/25/2016 14:08:39 ipsec,debug,packet f2441419 d8bcf44b c88ce7f0 09481773 cff0e6ca f69867bc 724fab65 d8aea6a7
Nov/25/2016 14:08:39 ipsec,debug,packet 88e5febe 05c2079e 9b319632 4ca94d42 63a8811f 4a21e1d9 cdeb9d31 b9176be7
Nov/25/2016 14:08:39 ipsec,debug,packet c390ceee 057db503 d81f9055 4164b805 0e5afa77 e9ed3f91 9e047fee 64e2acc1
Nov/25/2016 14:08:39 ipsec,debug,packet c9f28a5b b8e63853 15b1ca07 63a442df b4d8da49 2900001c 8b24f42f aada2a63
Nov/25/2016 14:08:39 ipsec,debug,packet b1d521de 55c5e635 450f145c 1e79b6cc 00000008 00004000
Nov/25/2016 14:08:39 ipsec,debug => skeyseed (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug e4140415 f6c44305 b00e772f 2466e965 bd5a5c9f f88cc90f a8e2e020 f978fffb
Nov/25/2016 14:08:39 ipsec,debug => keymat (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug 42bcaf55 017ee579 f0cf1406 ae2804f2 2053defe 36bac9b5 8c047b64 8c8b26c1
Nov/25/2016 14:08:39 ipsec,debug => SK_ai (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug 5b6ba7eb 373defbd 5833af59 d361276d 0540c19f 32e71f1c b9e26b21 435e2a06
Nov/25/2016 14:08:39 ipsec,debug => SK_ar (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug a094c725 7da338e8 ce4c92fd e9121181 8545e8fd 5a669f98 cd3d06ac 5fad4592
Nov/25/2016 14:08:39 ipsec,debug => SK_ei (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug 3394c436 817ff745 0222fd60 ef8fe617 afb60465 56be2644 237d496e c63274ff
Nov/25/2016 14:08:39 ipsec,debug => SK_er (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug 22038ce2 fe68beaa db466833 42d47dd7 79cf05ea e761d595 f5f8b33b 57790d5f
Nov/25/2016 14:08:39 ipsec,debug => SK_pi (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug 495a755b 48b30049 bf76c375 b1e01717 69f17677 1f995bf9 4ab7ab04 e89fe417
Nov/25/2016 14:08:39 ipsec,debug => SK_pr (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug 83695fe0 bf978030 63483518 38c7b456 1546dfbc 17f56c56 c31ba125 2035315f
Nov/25/2016 14:08:39 ipsec,debug processing payloads: NOTIFY
Nov/25/2016 14:08:39 ipsec,debug new ph1 responder connection established
Nov/25/2016 14:08:39 ipsec,info new ike2 responder connection: 10.0.0.1[4500]<->10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug child negitiation timeout in state 0
Nov/25/2016 14:09:09 ipsec,info killing connection: 10.0.0.1[4500]<->10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug ==========
Nov/25/2016 14:09:09 ipsec,debug 260 bytes message received from 10.1.0.1[500] to 10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet 08533b26 8e569ae1 00000000 00000000 28202208 00000000 00000104 2200001c
Nov/25/2016 14:09:09 ipsec,debug,packet e9fcdb31 8ef511b8 4e5cf796 a155c900 8f4bbc9d 0e584fde 21000088 00020000
Nov/25/2016 14:09:09 ipsec,debug,packet 3535e12f bb56e239 39d369f0 e6766003 afdfa3f2 c71523d1 919bf021 02226348
Nov/25/2016 14:09:09 ipsec,debug,packet c18f9279 ef1d1c31 0a94b87a 9ad02c67 2034e9c8 8c9605e6 14af48f7 e215c8fd
Nov/25/2016 14:09:09 ipsec,debug,packet 2626d63e 32a5f288 8cc3897d 6cdf73e2 6bb9bed6 b5e161a7 2d7d5d15 d5d48abd
Nov/25/2016 14:09:09 ipsec,debug,packet 946cf3bd 2b5ee323 ca76cc4c 9c8fb360 f3d226ad 2d68cee9 f9852e1a e044d755
Nov/25/2016 14:09:09 ipsec,debug,packet 00000044 00000040 01010006 0300000c 0100000c 800e0100 0300000c 0100000c
Nov/25/2016 14:09:09 ipsec,debug,packet 800e0080 03000008 01000003 03000008 02000005 03000008 03000003 00000008
Nov/25/2016 14:09:09 ipsec,debug,packet 04000002
Nov/25/2016 14:09:09 ipsec,debug ike2 request exchange: SA_INIT id: 0
Nov/25/2016 14:09:09 ipsec,debug ike2 respond
Nov/25/2016 14:09:09 ipsec,debug payload seen: NONCE
Nov/25/2016 14:09:09 ipsec,debug payload seen: KE
Nov/25/2016 14:09:09 ipsec,debug payload seen: SA
Nov/25/2016 14:09:09 ipsec,debug processing payload: NONCE
Nov/25/2016 14:09:09 ipsec,debug processing payload: SA
Nov/25/2016 14:09:09 ipsec,debug IKE Protocol: IKE
Nov/25/2016 14:09:09 ipsec,debug  proposal #1
Nov/25/2016 14:09:09 ipsec,debug   enc: aes256-cbc
Nov/25/2016 14:09:09 ipsec,debug   enc: aes128-cbc
Nov/25/2016 14:09:09 ipsec,debug   enc: 3des-cbc
Nov/25/2016 14:09:09 ipsec,debug   prf: hmac-sha256
Nov/25/2016 14:09:09 ipsec,debug   auth: sha256
Nov/25/2016 14:09:09 ipsec,debug   dh: modp1024
Nov/25/2016 14:09:09 ipsec,debug matched proposal:
Nov/25/2016 14:09:09 ipsec,debug processing payload: KE
Nov/25/2016 14:09:09 ipsec,debug => shared secret (size 0x80)
Nov/25/2016 14:09:09 ipsec,debug 9afb5527 4cafbb2e d54bceb4 8f6c0456 2622a823 febd9a56 27d12929 e0b10668
Nov/25/2016 14:09:09 ipsec,debug d0b9e0fa 149f33c6 9e27a0c0 27370b9f 5628f91c 485c6969 039a3dfd 210e72f2
Nov/25/2016 14:09:09 ipsec,debug 156393e0 da565391 bf7a93ea 17eed1a3 e0cb643c f57638a8 b6034a6c 726c60a3
Nov/25/2016 14:09:09 ipsec,debug 97cb47d5 2376dfbc e6b11b4e 9b42ca8b 2e7b1b3c 11f44b05 79d2e373 ef1e10c9
Nov/25/2016 14:09:09 ipsec,debug adding payload: SA
Nov/25/2016 14:09:09 ipsec,debug => (size 0x30)
Nov/25/2016 14:09:09 ipsec,debug 00000030 0000002c 01010004 0300000c 0100000c 800e0100 03000008 02000005
Nov/25/2016 14:09:09 ipsec,debug 03000008 03000003 00000008 04000002
Nov/25/2016 14:09:09 ipsec,debug adding payload: KE
Nov/25/2016 14:09:09 ipsec,debug => (size 0x88)
Nov/25/2016 14:09:09 ipsec,debug 00000088 00020000 81d9a1a9 70eaef1f f42a0eb5 8040e55e 7733abf4 5ff4370c
Nov/25/2016 14:09:09 ipsec,debug c1554259 afef4c14 4eef9d9b 40ff484c 81418660 a56d311c a0c4e99a 5d52365e
Nov/25/2016 14:09:09 ipsec,debug f99e3492 efad4281 d441f7a9 4032ce8a 1b69f2f8 30a6573d cada7ada 9cedc372
Nov/25/2016 14:09:09 ipsec,debug 85dc22e9 519b2ede a5c000ee c932ca6e 8110e8c0 9fbe3edb e19d4a0d 52b861c3
Nov/25/2016 14:09:09 ipsec,debug e5f7b8b4 eb3215d2
Nov/25/2016 14:09:09 ipsec,debug adding payload: NONCE
Nov/25/2016 14:09:09 ipsec,debug => (size 0x1c)
Nov/25/2016 14:09:09 ipsec,debug 0000001c 649ccbf5 fc6dedcb ab685964 6981c266 640942fa 1e48d13a
Nov/25/2016 14:09:09 ipsec,debug sending 240 bytes from 10.0.0.1[500] to 10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet sockname 10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet send packet from 10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet send packet to 10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet src4 10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet dst4 10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet 1 times of 240 bytes message will be sent to 10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet 08533b26 8e569ae1 2867bb59 b21566a3 21202220 00000000 000000f0 22000030
Nov/25/2016 14:09:09 ipsec,debug,packet 0000002c 01010004 0300000c 0100000c 800e0100 03000008 02000005 03000008
Nov/25/2016 14:09:09 ipsec,debug,packet 03000003 00000008 04000002 28000088 00020000 81d9a1a9 70eaef1f f42a0eb5
Nov/25/2016 14:09:09 ipsec,debug,packet 8040e55e 7733abf4 5ff4370c c1554259 afef4c14 4eef9d9b 40ff484c 81418660
Nov/25/2016 14:09:09 ipsec,debug,packet a56d311c a0c4e99a 5d52365e f99e3492 efad4281 d441f7a9 4032ce8a 1b69f2f8
Nov/25/2016 14:09:09 ipsec,debug,packet 30a6573d cada7ada 9cedc372 85dc22e9 519b2ede a5c000ee c932ca6e 8110e8c0
Nov/25/2016 14:09:09 ipsec,debug,packet 9fbe3edb e19d4a0d 52b861c3 e5f7b8b4 eb3215d2 0000001c 649ccbf5 fc6dedcb
Nov/25/2016 14:09:09 ipsec,debug,packet ab685964 6981c266 640942fa 1e48d13a
Nov/25/2016 14:09:09 ipsec,debug => skeyseed (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug 6fa0aa32 750b1ef1 8eb224c6 dd61cf88 6d387e37 3156c620 0a747f71 87ff6603
Nov/25/2016 14:09:09 ipsec,debug => keymat (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug d7d2ed58 f4df921d 752a7a7a 843c19ee c3f739bd 13f4b887 d4efc8fd 2be5fb07
Nov/25/2016 14:09:09 ipsec,debug => SK_ai (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug b14d5740 de4f8e9d 3ca9e169 e11f01a7 6ed882a3 58c2aede 50edf2de 3d9cefcf
Nov/25/2016 14:09:09 ipsec,debug => SK_ar (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug 089c8f67 f8f6355a 82e3307b c0f71b52 c5af09fd 4ec0f978 4cfd8b83 aed91574
Nov/25/2016 14:09:09 ipsec,debug => SK_ei (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug 5830aa26 cd8feaec c13e1e82 db08986e c74f66fa d9028500 9e6b7e09 96913fa7
Nov/25/2016 14:09:09 ipsec,debug => SK_er (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug 908529fd 65bd352b 27077fba 1ff189a5 420f46cf 22e65764 ab1454ec c39c215d
Nov/25/2016 14:09:09 ipsec,debug => SK_pi (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug 4a8407ff f9d596ae d280d852 f640c3fe e5dd4dda 09113595 fe702fa7 b98f1b4f
Nov/25/2016 14:09:09 ipsec,debug => SK_pr (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug 108fd66f cce6c2f8 f1219c9a c1da7f0e 3fe9cba0 b8002026 42cbdd90 41ab0b61
Nov/25/2016 14:09:09 ipsec,debug processing payloads: NOTIFY
Nov/25/2016 14:09:09 ipsec,debug none payloads found!
Nov/25/2016 14:09:09 ipsec,debug new ph1 responder connection established
Nov/25/2016 14:09:09 ipsec,info new ike2 responder connection: 10.0.0.1[4500]<->10.1.0.1[500]
Nov/25/2016 14:09:29 ipsec,info killing connection: 10.0.0.1[4500]<->10.1.0.1[500]
IPsec export:
# nov/25/2016 14:22:17 by RouterOS 6.38rc37
# software id =
/ip ipsec proposal
add enc-algorithms=aes-256-cbc,aes-128-cbc,3des name=VPN pfs-group=none
/ip ipsec peer
add address=10.1.0.1/32 disabled=yes dpd-interval=disable-dpd enc-algorithm=aes-256,aes-128,3des exchange-mode=ike2 hash-algorithm=sha256 \
    nat-traversal=no passive=yes secret=TEST
/ip ipsec policy
add dst-address=192.168.170.0/24 proposal=VPN sa-dst-address=10.1.0.1 sa-src-address=10.0.0.1 src-address=192.168.160.0/24 tunnel=yes
R2:
Logs:
Nov/25/2016 14:08:39 ipsec,debug ike2 initialize send for: 10.0.0.1
Nov/25/2016 14:08:39 ipsec,debug 0000001c 2f303127 c4ca221f 0a3f66de 303a3904 ce77e2d8 14c1b8e9
Nov/25/2016 14:08:39 ipsec,debug 00000088 00020000 be28d5e3 63b9b4f1 0270204c 3a25fe10 ce529482 d2a42f81
Nov/25/2016 14:08:39 ipsec,debug 4bd1caf9 1dbecd12 6afcbf51 71b11f3b 02152329 6e15a0e2 c9d743f9 893b2835
Nov/25/2016 14:08:39 ipsec,debug 250741df ad128056 b3d4c9e1 4d38d551 8a5993e5 75eb4eec cae195d3 7c36470c
Nov/25/2016 14:08:39 ipsec,debug 7c27a5ea 40fe6f87 0add9e36 839bf114 42ba3794 470df073 0b24263f ec96e130
Nov/25/2016 14:08:39 ipsec,debug b4e8c55e 7412a936
Nov/25/2016 14:08:39 ipsec,debug => (size 0x44)
Nov/25/2016 14:08:39 ipsec,debug 00000044 00000040 01010006 0300000c 0100000c 800e0100 0300000c 0100000c
Nov/25/2016 14:08:39 ipsec,debug 800e0080 03000008 01000003 03000008 02000005 03000008 03000003 00000008
Nov/25/2016 14:08:39 ipsec,debug 04000002
Nov/25/2016 14:08:39 ipsec,debug sending 268 bytes from 10.1.0.1[500] to 10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet sockname 10.1.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet send packet from 10.1.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet send packet to 10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet src4 10.1.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet dst4 10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug,packet 1 times of 268 bytes message will be sent to 10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug 248 bytes message received from 10.0.0.1[500] to 10.1.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug ike2 answer exchange: SA_INIT id: 0
Nov/25/2016 14:08:39 ipsec,debug ike2 initialize recv
Nov/25/2016 14:08:39 ipsec,debug new ph1 initiator connection established
Nov/25/2016 14:08:39 ipsec,info new ike2 initiator connection: 10.1.0.1[4500]<->10.0.0.1[500]
Nov/25/2016 14:08:39 ipsec,debug init child for policy: 192.168.170.0/24/24:0 <=> 192.168.160.0/24/24:0 ipproto:255
Nov/25/2016 14:08:39 ipsec,debug GETSPI sent: 10.0.0.1->10.1.0.1
Nov/25/2016 14:08:39 ipsec,debug ikev2 got spi 0xb7705da
Nov/25/2016 14:08:39 ipsec,debug init child continue
Nov/25/2016 14:08:39 ipsec,debug offering proto: 3
Nov/25/2016 14:08:39 ipsec,debug   auth: sha512
Nov/25/2016 14:08:39 ipsec,debug   auth: sha1
Nov/25/2016 14:08:39 ipsec,debug   auth: md5
Nov/25/2016 14:08:39 ipsec,debug   esn: off
Nov/25/2016 14:08:39 ipsec,debug initiator selector: 192.168.170.0/24/24 ipproto:0
Nov/25/2016 14:08:39 ipsec,debug => selector created (size 0x18)
Nov/25/2016 14:08:39 ipsec,debug 00000018 01000000 07000010 0000ffff c0a8aa00 c0a8aaff
Nov/25/2016 14:08:39 ipsec,debug responder selector: 192.168.160.0/24/24 ipproto:0
Nov/25/2016 14:08:39 ipsec,debug 00000018 01000000 07000010 0000ffff c0a8a000 c0a8a0ff
Nov/25/2016 14:08:39 ipsec,debug my ID (ADDR): 10.1.0.1
Nov/25/2016 14:08:39 ipsec,debug => auth nonce (size 0x18)
Nov/25/2016 14:08:39 ipsec,debug 8b24f42f aada2a63 b1d521de 55c5e635 450f145c 1e79b6cc
Nov/25/2016 14:08:39 ipsec,debug => SK_p (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug => idhash (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug 210cb837 b8674af3 9816ad00 6507ff08 52ed8dac 178c368a 5ec94589 a8fcc964
Nov/25/2016 14:08:39 ipsec,debug => my auth (size 0x20)
Nov/25/2016 14:08:39 ipsec,debug 6b080158 8bbdd7ce 600b89dc 2bc0a967 a8bb4183 16d4c066 9bd42eb3 54a29d5b
Nov/25/2016 14:08:39 ipsec,debug adding payload: ID_I
Nov/25/2016 14:08:39 ipsec,debug => (size 0xc)
Nov/25/2016 14:08:39 ipsec,debug 0000000c 01000000 0a010001
Nov/25/2016 14:08:39 ipsec,debug adding payload: AUTH
Nov/25/2016 14:08:39 ipsec,debug => (size 0x28)
Nov/25/2016 14:08:39 ipsec,debug 00000028 02000000 6b080158 8bbdd7ce 600b89dc 2bc0a967 a8bb4183 16d4c066
Nov/25/2016 14:08:39 ipsec,debug 9bd42eb3 54a29d5b
Nov/25/2016 14:08:39 ipsec,debug => (size 0x58)
Nov/25/2016 14:08:39 ipsec,debug 00000058 00000054 01030408 0b7705da 0300000c 0100000c 800e0100 0300000c
Nov/25/2016 14:08:39 ipsec,debug 0100000c 800e0080 03000008 01000003 03000008 03000004 03000008 03000003
Nov/25/2016 14:08:39 ipsec,debug 03000008 03000002 03000008 03000001 00000008 05000000
Nov/25/2016 14:08:39 ipsec,debug adding payload: TS_I
Nov/25/2016 14:08:39 ipsec,debug => (size 0x18)
Nov/25/2016 14:08:39 ipsec,debug adding payload: TS_R
Nov/25/2016 14:08:39 ipsec,debug,packet => outgoing plain packet (size 0x200)
Nov/25/2016 14:08:39 ipsec,debug,packet e58e1a2e bdaa3dc0 b26151ae a98a503f 23202308 00000001 00000000 2700000c
Nov/25/2016 14:08:39 ipsec,debug,packet 01000000 0a010001 21000028 02000000 6b080158 8bbdd7ce 600b89dc 2bc0a967
Nov/25/2016 14:08:39 ipsec,debug,packet a8bb4183 16d4c066 9bd42eb3 54a29d5b 2c000058 00000054 01030408 0b7705da
Nov/25/2016 14:08:39 ipsec,debug,packet 0300000c 0100000c 800e0100 0300000c 0100000c 800e0080 03000008 01000003
Nov/25/2016 14:08:39 ipsec,debug,packet 03000008 03000004 03000008 03000003 03000008 03000002 03000008 03000001
Nov/25/2016 14:08:39 ipsec,debug,packet 00000008 05000000 2d000018 01000000 07000010 0000ffff c0a8aa00 c0a8aaff
Nov/25/2016 14:08:39 ipsec,debug,packet 00000018 01000000 07000010 0000ffff c0a8a000 c0a8a0ff dbf5102c 496786a6
Nov/25/2016 14:08:39 ipsec,debug,packet b7c9dcf0 051b324a 637d98b4 d1ef0e2e 3f516478 8da3bad2 eb05203c 597796b6
Nov/25/2016 14:08:39 ipsec,debug,packet c7d9ec00 152b425a 738da8c4 e1ff1e3e 4f617488 9db3cae2 fb15304c 6987a6c6
Nov/25/2016 14:08:39 ipsec,debug,packet d7e9fc10 253b526a 839db8d4 f10f2e4e 5f718498 adc3daf2 0b25405c 7997b6d6
Nov/25/2016 14:08:39 ipsec,debug,packet e7f90c20 354b627a 93adc8e4 011f3e5e 6f8194a8 bdd3ea02 1b35506c 89a7c6e6
Nov/25/2016 14:08:39 ipsec,debug,packet f7091c30 455b728a a3bdd8f4 112f4e6e 7f91a4b8 cde3fa12 2b45607c 99b7d6f6
Nov/25/2016 14:08:39 ipsec,debug,packet 07192c40 556b829a b3cde804 213f5e7e 8fa1b4c8 ddf30a22 3b55708c a9c7e606
Nov/25/2016 14:08:39 ipsec,debug,packet 17293c50 657b92aa c3ddf814 314f6e8e 9fb1c4d8 ed031a32 4b65809c b9d7f616
Nov/25/2016 14:08:39 ipsec,debug,packet 27394c60 758ba2ba d3ed0824 415f7e9e afc1d4e8 fd132a42 5b7590ac c9e70626
Nov/25/2016 14:08:39 ipsec,debug,packet 37495c70 859bb2ca e3fd1834 516f8eae bfd1e4f8 0d233a52 6b85a0bc d9f71636
Nov/25/2016 14:08:39 ipsec,debug adding payload: ENC
Nov/25/2016 14:08:39 ipsec,debug => (first 0x100 of 0x154)
Nov/25/2016 14:08:39 ipsec,debug 23000154 8716500b 1b9c3166 219dddfc 7bc4e2ac 81be62c3 6ff2529b 93f7350f
Nov/25/2016 14:08:39 ipsec,debug 842c8e51 f636b245 2859d1ac 1cf432e7 8bbcd520 a6bdd963 7e65b952 cba1cbbe
Nov/25/2016 14:08:39 ipsec,debug 25c21978 80e6d469 01a025d2 3e713b18 d9f3e9da 84e211f5 f3224ff2 5b50c32c
Nov/25/2016 14:08:39 ipsec,debug 5140dda4 47c96401 79066910 e9e0331b d3fb1edd 555c5e94 147a5662 e86d2560
Nov/25/2016 14:08:39 ipsec,debug 7d062cdc a9f43c03 29635238 8e91f410 58af94d5 6eddebf8 fb067e2a d61679e1
Nov/25/2016 14:08:39 ipsec,debug 540fb62f 04cde8de bb8de40b 39ccc1fa 4a7226bd 91578454 0bd5f5af d393c41d
Nov/25/2016 14:08:39 ipsec,debug c4c6545e 687f9ce0 3a079396 aa4e6ebf 7900b5f7 7e3c593d 41374cc4 3a42c60a
Nov/25/2016 14:08:39 ipsec,debug 9c86e189 7566385f ef610851 aa60afca 52e441ab 0cbcb744 6f830417 cd11bac7
Nov/25/2016 14:08:39 ipsec,debug unknown socket
Nov/25/2016 14:08:44 ipsec,debug retransmit
Nov/25/2016 14:08:44 ipsec,debug unknown socket
Nov/25/2016 14:08:49 ipsec,debug retransmit
Nov/25/2016 14:08:49 ipsec,debug unknown socket
Nov/25/2016 14:08:54 ipsec,debug retransmit
Nov/25/2016 14:08:54 ipsec,debug unknown socket
Nov/25/2016 14:08:59 ipsec,debug retransmit
Nov/25/2016 14:08:59 ipsec,debug unknown socket
Nov/25/2016 14:09:04 ipsec,debug retransmit
Nov/25/2016 14:09:04 ipsec,info killing connection: 10.1.0.1[4500]<->10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug ike2 initialize send for: 10.0.0.1
Nov/25/2016 14:09:09 ipsec,debug 0000001c e9fcdb31 8ef511b8 4e5cf796 a155c900 8f4bbc9d 0e584fde
Nov/25/2016 14:09:09 ipsec,debug 00000088 00020000 3535e12f bb56e239 39d369f0 e6766003 afdfa3f2 c71523d1
Nov/25/2016 14:09:09 ipsec,debug 919bf021 02226348 c18f9279 ef1d1c31 0a94b87a 9ad02c67 2034e9c8 8c9605e6
Nov/25/2016 14:09:09 ipsec,debug 14af48f7 e215c8fd 2626d63e 32a5f288 8cc3897d 6cdf73e2 6bb9bed6 b5e161a7
Nov/25/2016 14:09:09 ipsec,debug 2d7d5d15 d5d48abd 946cf3bd 2b5ee323 ca76cc4c 9c8fb360 f3d226ad 2d68cee9
Nov/25/2016 14:09:09 ipsec,debug f9852e1a e044d755
Nov/25/2016 14:09:09 ipsec,debug => (size 0x44)
Nov/25/2016 14:09:09 ipsec,debug 00000044 00000040 01010006 0300000c 0100000c 800e0100 0300000c 0100000c
Nov/25/2016 14:09:09 ipsec,debug 800e0080 03000008 01000003 03000008 02000005 03000008 03000003 00000008
Nov/25/2016 14:09:09 ipsec,debug 04000002
Nov/25/2016 14:09:09 ipsec,debug sending 260 bytes from 10.1.0.1[500] to 10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet sockname 10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet send packet from 10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet send packet to 10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet src4 10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet dst4 10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug,packet 1 times of 260 bytes message will be sent to 10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug 240 bytes message received from 10.0.0.1[500] to 10.1.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug ike2 answer exchange: SA_INIT id: 0
Nov/25/2016 14:09:09 ipsec,debug ike2 initialize recv
Nov/25/2016 14:09:09 ipsec,debug new ph1 initiator connection established
Nov/25/2016 14:09:09 ipsec,info new ike2 initiator connection: 10.1.0.1[4500]<->10.0.0.1[500]
Nov/25/2016 14:09:09 ipsec,debug init child for policy: 192.168.170.0/24/24:0 <=> 192.168.160.0/24/24:0 ipproto:255
Nov/25/2016 14:09:09 ipsec,debug GETSPI sent: 10.0.0.1->10.1.0.1
Nov/25/2016 14:09:09 ipsec,debug ikev2 got spi 0x1bdbd32
Nov/25/2016 14:09:09 ipsec,debug init child continue
Nov/25/2016 14:09:09 ipsec,debug offering proto: 3
Nov/25/2016 14:09:09 ipsec,debug   auth: sha512
Nov/25/2016 14:09:09 ipsec,debug   auth: sha1
Nov/25/2016 14:09:09 ipsec,debug   auth: md5
Nov/25/2016 14:09:09 ipsec,debug   esn: off
Nov/25/2016 14:09:09 ipsec,debug initiator selector: 192.168.170.0/24/24 ipproto:0
Nov/25/2016 14:09:09 ipsec,debug => selector created (size 0x18)
Nov/25/2016 14:09:09 ipsec,debug 00000018 01000000 07000010 0000ffff c0a8aa00 c0a8aaff
Nov/25/2016 14:09:09 ipsec,debug responder selector: 192.168.160.0/24/24 ipproto:0
Nov/25/2016 14:09:09 ipsec,debug 00000018 01000000 07000010 0000ffff c0a8a000 c0a8a0ff
Nov/25/2016 14:09:09 ipsec,debug my ID (ADDR): 10.1.0.1
Nov/25/2016 14:09:09 ipsec,debug => auth nonce (size 0x18)
Nov/25/2016 14:09:09 ipsec,debug 649ccbf5 fc6dedcb ab685964 6981c266 640942fa 1e48d13a
Nov/25/2016 14:09:09 ipsec,debug => SK_p (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug => idhash (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug cbb46cdb 333a3830 8a1918a0 eebe09c0 51d9a97c 84486288 85088b75 5284b9c3
Nov/25/2016 14:09:09 ipsec,debug => my auth (size 0x20)
Nov/25/2016 14:09:09 ipsec,debug d8ba1466 584647a5 e4167ec2 8015b2e7 5a3ee807 2121d4d7 e1deb6f7 83676146
Nov/25/2016 14:09:09 ipsec,debug adding payload: ID_I
Nov/25/2016 14:09:09 ipsec,debug => (size 0xc)
Nov/25/2016 14:09:09 ipsec,debug 0000000c 01000000 0a010001
Nov/25/2016 14:09:09 ipsec,debug adding payload: AUTH
Nov/25/2016 14:09:09 ipsec,debug => (size 0x28)
Nov/25/2016 14:09:09 ipsec,debug 00000028 02000000 d8ba1466 584647a5 e4167ec2 8015b2e7 5a3ee807 2121d4d7
Nov/25/2016 14:09:09 ipsec,debug e1deb6f7 83676146
Nov/25/2016 14:09:09 ipsec,debug => (size 0x58)
Nov/25/2016 14:09:09 ipsec,debug 00000058 00000054 01030408 01bdbd32 0300000c 0100000c 800e0100 0300000c
Nov/25/2016 14:09:09 ipsec,debug 0100000c 800e0080 03000008 01000003 03000008 03000004 03000008 03000003
Nov/25/2016 14:09:09 ipsec,debug 03000008 03000002 03000008 03000001 00000008 05000000
Nov/25/2016 14:09:09 ipsec,debug adding payload: TS_I
Nov/25/2016 14:09:09 ipsec,debug => (size 0x18)
Nov/25/2016 14:09:09 ipsec,debug adding payload: TS_R
Nov/25/2016 14:09:09 ipsec,debug,packet => outgoing plain packet (size 0x200)
Nov/25/2016 14:09:09 ipsec,debug,packet 08533b26 8e569ae1 2867bb59 b21566a3 23202308 00000001 00000000 2700000c
Nov/25/2016 14:09:09 ipsec,debug,packet 01000000 0a010001 21000028 02000000 d8ba1466 584647a5 e4167ec2 8015b2e7
Nov/25/2016 14:09:09 ipsec,debug,packet 5a3ee807 2121d4d7 e1deb6f7 83676146 2c000058 00000054 01030408 01bdbd32
Nov/25/2016 14:09:09 ipsec,debug,packet 0300000c 0100000c 800e0100 0300000c 0100000c 800e0080 03000008 01000003
Nov/25/2016 14:09:09 ipsec,debug,packet 03000008 03000004 03000008 03000003 03000008 03000002 03000008 03000001
Nov/25/2016 14:09:09 ipsec,debug,packet 00000008 05000000 2d000018 01000000 07000010 0000ffff c0a8aa00 c0a8aaff
Nov/25/2016 14:09:09 ipsec,debug,packet 00000018 01000000 07000010 0000ffff c0a8a000 c0a8a0ff 859fbad6 f3113050
Nov/25/2016 14:09:09 ipsec,debug,packet 6173869a afc5dcf4 0d27425e 7b99b8d8 e9fb0e22 374d647c 95afcae6 03214060
Nov/25/2016 14:09:09 ipsec,debug,packet 718396aa bfd5ec04 1d37526e 8ba9c8e8 f90b1e32 475d748c a5bfdaf6 13315070
Nov/25/2016 14:09:09 ipsec,debug,packet 8193a6ba cfe5fc14 2d47627e 9bb9d8f8 091b2e42 576d849c b5cfea06 23416080
Nov/25/2016 14:09:09 ipsec,debug,packet 91a3b6ca dff50c24 3d57728e abc9e808 192b3e52 677d94ac c5dffa16 33517090
Nov/25/2016 14:09:09 ipsec,debug,packet a1b3c6da ef051c34 4d67829e bbd9f818 293b4e62 778da4bc d5ef0a26 436180a0
Nov/25/2016 14:09:09 ipsec,debug,packet b1c3d6ea ff152c44 5d7792ae cbe90828 394b5e72 879db4cc e5ff1a36 537190b0
Nov/25/2016 14:09:09 ipsec,debug,packet c1d3e6fa 0f253c54 6d87a2be dbf91838 495b6e82 97adc4dc f50f2a46 6381a0c0
Nov/25/2016 14:09:09 ipsec,debug,packet d1e3f60a 1f354c64 7d97b2ce eb092848 596b7e92 a7bdd4ec 051f3a56 7391b0d0
Nov/25/2016 14:09:09 ipsec,debug,packet e1f3061a 2f455c74 8da7c2de fb193858 697b8ea2 b7cde4fc 152f4a66 83a1c0e0
Nov/25/2016 14:09:09 ipsec,debug adding payload: ENC
Nov/25/2016 14:09:09 ipsec,debug => (first 0x100 of 0x134)
Nov/25/2016 14:09:09 ipsec,debug 23000134 e0412176 e401d02c fc492bf1 50ce4f78 205394f5 9842d44f d1bbb9a8
Nov/25/2016 14:09:09 ipsec,debug 5c448d6d d8e3a74e bd0cd642 9431d62c 9f0257ba c4d60b70 eee1e367 9c275630
Nov/25/2016 14:09:09 ipsec,debug eef2455a 801acd6f b6bd5e03 d1c7fcc9 f728be73 35f8aae3 8071ee82 8d86e708
Nov/25/2016 14:09:09 ipsec,debug 915245e3 4c8bf018 742e3383 6067ff61 eb3e4134 320ac273 e81eb7a0 9a188078
Nov/25/2016 14:09:09 ipsec,debug 9c0f22fb 4a8ebfbe 16fa42c6 66ebe0d6 ee33e38b e67c620c 9dd0a4aa ae3d5485
Nov/25/2016 14:09:09 ipsec,debug c1ad6ea5 a33a00dd ad7ada68 5dd515aa d60888ec 4a4942b3 928cc526 4a8216e9
Nov/25/2016 14:09:09 ipsec,debug fcf13c1f b4635757 7ad1b56b bffbb916 beb79170 e382692d 18b54be4 aaf29355
Nov/25/2016 14:09:09 ipsec,debug 946d7338 c3d72725 e93c697e 32442f7f 3fc4983c 9bb3e593 7984fb50 b2d93355
Nov/25/2016 14:09:09 ipsec,debug unknown socket
Nov/25/2016 14:09:14 ipsec,debug retransmit
Nov/25/2016 14:09:14 ipsec,debug unknown socket
Nov/25/2016 14:09:19 ipsec,debug retransmit
Nov/25/2016 14:09:19 ipsec,debug unknown socket
Nov/25/2016 14:09:24 ipsec,debug retransmit
Nov/25/2016 14:09:24 ipsec,debug unknown socket
Nov/25/2016 14:09:26 ipsec,info killing connection: 10.1.0.1[4500]<->10.0.0.1[500]
IPsec export:
# nov/25/2016 14:23:12 by RouterOS 6.38rc37
# software id =
/ip ipsec proposal
add auth-algorithms=sha512,sha256,sha1,md5 enc-algorithms=aes-256-cbc,aes-128-cbc,3des name=VPN pfs-group=none
/ip ipsec peer
add address=10.0.0.1/32 disabled=yes dpd-interval=disable-dpd enc-algorithm=aes-256,aes-128,3des exchange-mode=ike2 hash-algorithm=
    nat-traversal=no secret=TEST
/ip ipsec policy
add dst-address=192.168.160.0/24 proposal=VPN sa-dst-address=10.0.0.1 sa-src-address=10.1.0.1 src-address=192.168.170.0/24 tunnel=y
alexjhart
Fri Nov 25, 2016 7:37 pm
For folks having trouble with IPsec in latest RCs, change your peer generate policy from port-strict to port-override. Support says they are working on a fix for this, but that was enough to get it working for me.
huntermic
Fri Nov 25, 2016 7:47 pm
Thanks, this works for me!
barracuda
Fri Nov 25, 2016 8:24 pm
Today I upgrade to Version 6.38rc37 and the problem gone.. :)
Thank you to fix bootup bug!
nescafe2002
Forum Veteran
Forum Veteran
Sat Nov 26, 2016 5:13 pm
hEX RB750Gr3 got in a bootloop after upgrade from 6.37.2 to 6.38rc37 via system package update install. Netinstall to 6.38rc37 fixed it.
colanderman
Sun Nov 27, 2016 8:09 am
At the risk of straying off-topic…
We are having a lot of problems here with Mikrotik Queues X Windows 10 Updates. When a customer have one PC downloading Windows 10 updates, his queue is 100% used, most of the time is impossible to do anything else, even open an web page.
I have fought this problem in my home network for a long time. This is Windows's fault; it opens hundreds of TCP connections to flout TCP link sharing. I solved it with the following:
add action=reject chain=forward comment="limit MS BITS" connection-bytes=0-1500 connection-limit=8,0 content=\
    "User-Agent: Microsoft BITS" dst-port=80 out-interface=ether1-gateway protocol=tcp reject-with=tcp-reset
add action=reject chain=forward comment="limit Windows Update" connection-bytes=0-1500 connection-limit=8,0 content=\
    "User-Agent: Microsoft-Delivery-Optimization" dst-port=80 out-interface=ether1-gateway protocol=tcp reject-with=\
    tcp-reset
colanderman
Sun Nov 27, 2016 8:27 am
*) bridge - fixed filter Ingress Priority option (broken in v6.38rc16);
I haven't been able to get bridge filtering on Ingress Priority to work since at least 6.25 (e.g. while ingress-priority=!0 matches packets in IP firewall, it matches nothing in bridge firewall; and new-priority=from-ingress does nothing; see ticket #2016042566000016). Is this fix for a different problem than what I've described?
Borizo
Wed Nov 30, 2016 1:39 am
Cannot enter into settings of Virtual wireless adapter through WinBox: WinBox silently closes.
Chupaka
Wed Nov 30, 2016 1:52 am
Huh... Needed to shape one link and noticed that I cannot set max-limit more than 4,295G:
[admin@TestPlace] > /queue simple add max-limit=?
MaxLimit ::= UploadMaxLimit/DownloadMaxLimit
  UploadMaxLimit,DownloadMaxLimit ::= 0..4294967295    (integer number)
[admin@TestPlace] > /queue simple add max-limit=4295M/0
value of upload-max-limit out of range (0..4294967295)
[admin@TestPlace] > /queue simple add max-limit=4294M/0
[admin@TestPlace] >
Please fix this limitation of limit :)
savage
Wed Nov 30, 2016 6:55 am
[admin@TestPlace] >
Has long since been an issue. I reported it a few years ago already I think :) There's quite a few places where 32 bit counters are still very much active and enforced :(
toto99303
Wed Nov 30, 2016 2:52 pm
v6.38rc37 and I'm still having trouble with L2TP/IPSec VPN. Policy is "port override" and I'm getting "...failed to pre-process ph2 packet." Anyone with the same issue?
ThomasLevering
Wed Nov 30, 2016 3:41 pm
v6.38rc37 RB750Gr3
L2TP/IPSec is working with port override (I need to open the Port 1701 in Firewall) (Windows, iPhone)
IPSec from iPhone ist not working, previous Version OK
IKEv2 wait for Stable Version...
One CPU Core is 100%
strods
Thu Dec 01, 2016 10:36 am
Version 6.38rc38 has been released.
Changes since previous rc:
*) fastpath - fixed x86 bridge fast-path status shown as active even if it is manually disabled;
*) firewall - added sctp/dccp/udp-lite support for "src-port", "dst-port", "port" and "to-ports" firewall options;
*) lcd - improved performance, causes less cpu load;
*) rb3011 - fixed lcd and health (broken in v6.38rc35);
hubber
Thu Dec 01, 2016 1:27 pm
Hello.
I have not worked on version 6.38.24 and 6.38.38
what am I doing wrong?
add arp=proxy-arp name=bridge1
/ip ipsec policy group
add name=group1
add name=l2tpUSERS ranges=192.168.100.129-192.168.100.140
/ppp profile
add bridge=bridge1 change-tcp-mss=yes local-address=192.168.100.3 name=outsideEncryption only-one=yes remote-address=l2tpUSERS use-encryption=yes
set authentication=mschap2 default-profile=outsideEncryption enabled=yes ipsec-secret=***** use-ipsec=yes
add action=accept chain=input comment=estebl connection-state=established,related in-interface=ether1
add action=accept chain=input dst-port=1701,500,4500 protocol=udp
add action=accept chain=input protocol=ipsec-esp
add action=drop chain=input in-interface=ether1
/ip ipsec peer
add enc-algorithm=aes-256,aes-128,3des exchange-mode=main-l2tp generate-policy=port-override passive=yes secret=********
mducharme
Trainer
Trainer
Thu Dec 01, 2016 9:42 pm
Great, is there any info as to what has changed in the tr-069 client in this new RC? Is it just bug fixes, or are there new features? It would be nice to get a little bit more info in the changelog between rc's in regards to what changes were made.
alexjhart
Thu Dec 01, 2016 9:48 pm
Hello.
add name=group1
/ppp profile
/ip ipsec peer
Currently, this won't work. You will need to do this:
/interface l2tp-server server set use-ipsec=no
Otherwise, your connection won't use your custom /ip ipsec peer entry with port-override, rather it will use a dynamic entry that uses port-strict. I believe Mikrotik is working to fix this per my ticket with them.
strods
Fri Dec 02, 2016 12:07 pm
Version 6.38rc40 has been released!
*) certificate - remove invalid CRLs after upgrade; (broken since v6.38rc32);
*) export - updated default values to clean up export compact;
*) firewall - fixed "time" option by recognizing weekday properly (broken in 6.37.2);
*) firewall - fixed dynamic raw rule behaviour;
*) ike1 - fixed natted transport mode port-strict policy generation;
*) ipsec - fixed camellia crypto algorithm module loading;
*) ipsec - load ipv6 related modules only when ipv6 package is enabled;
*) ipsec - various additional work in IKEv2 support;
*) lte - added support for novatel USB620L;
*) queue - fixed "time" option by recognizing weekday properly (broken in 6.37.2);
*) rb750Gr3 - fixed ipsec with 3des+md5 to work on this board;
arnis128
Fri Dec 02, 2016 2:27 pm
Hello!
I think - something is broken LTE connection to LMT mobile network after upgrade from 6.37.3 to 6.38.rc40. Last version, where it works fine, was 6.38.rc24 (or 25) - if i remember correct.
Routerboard - 922UAGS-5HPacD
modem - HUAWEI Mobile, vendor = 0x12d1, device = 0x1573
Symptoms - router gets its ip address from mobile operator, as usual, but no traffic flows to any reachable public host. After downgrade back to 6.37.3 everything works well.
Support files will be sent.
Thanks, Arnis.
irghost
Fri Dec 02, 2016 3:48 pm
 system,error,critical failed to enable panics driver
X86 vmware
jondavy
Sat Dec 03, 2016 4:33 am
How can I see how many sectors on the nand have already been written and if there are bad blocks on the Cloud Core Router?
nicecloud
Sat Dec 03, 2016 10:52 am
It doesn't work against Azure since version rc29 on my RB751G-2HnD
maxkrok
Sat Dec 03, 2016 12:45 pm
Dude 6.38rc40 again adding custom files on 750gr3 MMIPS is not possible AT ALL.... Please repair...
nescafe2002
Forum Veteran
Forum Veteran
Sun Dec 04, 2016 3:45 pm
I have added routes for all ipsec tunnels to a bogus interface for local outgoing data to ipsec, especially for netwatch to work.
6.38rc40 seems to require explicit /ip route pref-src address to be set to correctly ping these ipsec tunnelled hosts.
Config:
add address=192.168.88.1/24 interface=ether2-lan network=192.168.88.0
/tool netwatch
add host=10.0.0.254 interval=30s
This worked correctly before rc40:
add comment=netwatch distance=50 dst-address=10.0.0.0/24 gateway=ether2-lan
In rc40 I need to add pref-src:
add comment=netwatch distance=50 dst-address=10.0.0.0/24 gateway=ether2-lan \
    pref-src=192.168.88.1
andriys
Sun Dec 04, 2016 5:47 pm
I think a better solution would be to explicitly specify a correct local-address in your IPsec peer configuration instead of (or in addition to) specifying pref-src in the route.
PS. If you read through this whole thread you will see that this behavior is constantly changing from one rc to another.
nescafe2002
Forum Veteran
Forum Veteran
Sun Dec 04, 2016 5:55 pm
I have set specific local-address in /ip ipsec peer and specific sa-src-address in /ip ipsec policy.
This routing issue is a new issue (for me) in rc40.
(Not really an issue but more of an observation)
strods
Mon Dec 05, 2016 3:28 pm
Version 6.38rc41 has been released.
*) bridge - ignore dynamic switch ports when selecting bridge MAC address (introduced in v6.38rc7);
*) dns - added max-concurrent-queries and max-concurrent-tcp-sessions settings (CLI only);
*) firewall - fixed rule activation if "time" option is used and no other active rules are present;
*) ppp - fixed packet size calculation when MRRU is set (was 2 bytes bigger than MTU allows);
*) ppp - significantly improved tunnel termination process on servers with many active tunnels;
*) ssh - added routing-table setting (CLI only);
*) x86 - fixed "system,error,critical failed to enable panics driver" (introduced in v6.38rc30);
nz_monkey
Mon Dec 05, 2016 8:11 pm
Thanks for adding this!
maznu
Mon Dec 05, 2016 10:37 pm
I will admit that I've not kept up with how quickly the IKEv2 support has moved in these RCs. Well done to MikroTik's developers for doing this so fast!
My question is whether or not it is possible to create an IKEv2 configuration on RouterOS which will support iOS road-warriors using username/password authentication. I'm guessing that is EAP and XAuth (with RADIUS), but haven't found the correct incantation of commands to get it to work. I'm left staring at ipsec debugging logs which say "EAP neeeds certificate if EAP-only is not used" and "reply notify: AUTHENTICATION_FAILED" (no RADIUS packet is emitted?). I'm also puzzled by what auth settings iOS is using in some of its proposals that the debug logs show "auth: unknown".
Any clues would be gratefully received — we've got several end users who would love to test this :-)
NBspeedworks
Tue Dec 06, 2016 2:40 am
Dude client error
Error 10061 Connect failed because the target machine actively refused it.
Re started router
re installed the dude on a win 10 machine
Any other Ideas ?
strods
Tue Dec 06, 2016 9:18 am
Version 6.38rc43 has been released.
*) dhcp - fixed issue when dhcp-client was still possible on interfaces with "slave" flag and using slave interface MAC address;
*) firewall - significantly improved large firewall rule set import performance;
*) time - updated time zones;
hubber
Tue Dec 06, 2016 2:09 pm
Hello.
add name=group1
/ppp profile
/ip ipsec peer
i'm do this.
But second client behind the same NAT don't connect.
error 638
in log -
ipsec-sa established: ESP/transport *.*.*.*[4500]->*.*.*.*[4500] spi=0x91d071a2
purged ISAKMP-SA *.*.*.*<=>*.*.*.* spi=*******
someone's work?
on what version rc?
mrz
Tue Dec 06, 2016 3:07 pm
L2TP/ipsec is not going to work behind the same NAT, but Ikev2 and ikev1 in tunnel mode will.
strods
Wed Dec 07, 2016 11:45 am
Version 6.38rc44 has been released.
*) crs - added comment ability in more switch menus;
*) dns - added "max-concurrent-queries" and "max-concurrent-tcp-sessions" settings;
*) ipsec - split "mode-config" "send-dns" argument;
*) ipsec - various additional work in IKEv1/IKEv2 support;
*) routerboot - show log message if router CPU/RAM is overclocked;
*) tr069-client - various additional work;
*) traceroute - fixed memory leak;
*) users - added minimal required permission set for full user group;
*) webfig - fixed preview of values bigger than 2 billion and lower than 4 billion (introduced in v6.38rc);
*) webfig - show ipv6 addresses correctly;
*) winbox - added "Complete" flag to arp table;
*) winbox - added "untracked" option to firewall "connection-state" setting;
*) winbox - added Dude icon to Dude menu;
*) winbox - allow to enable/disable traffic flow targets;
*) winbox - fixed default values for interface "loop-protect-disable-time" & "loop-protect-send-interval";
*) winbox - fixed missing "ipv6/settings" menu;
*) winbox - fixed typo in "propagate-ttl" setting;
*) winbox - make cert signing include provided ca-crl-host;
*) winbox - show proper ipv6 connection timeout;
drees
Wed Dec 07, 2016 12:21 pm
I just updated to rc44 and the first message after router rebooted is "memory overclocked". This is on a 951G-2HnD.
[admin@MikroTik-router] > /system routerboard settings print
                   ;;; Warning: memory overclocked
           init-delay: 0s
          boot-device: nand-if-fail-then-ethernet
        cpu-frequency: 600MHz
        boot-protocol: bootp
  force-backup-booter: no
          silent-boot: no
nescafe2002
Forum Veteran
Forum Veteran
Wed Dec 07, 2016 2:41 pm
Just had an unexpected reboot on 6.38rc40. Timeline:
winbox with ip firewall rules and interfaces open but not active
30 seconds before crash: <sstp-user>: terminating... - terminated by remote peer
on crash (from another RB): ether2-lan link down
after crash: system,error,critical router was rebooted without proper shutdown
There is no auto supout, perhaps auto supout is stored in RAM and gone on reboot?
strods
Wed Dec 07, 2016 3:00 pm
drees - Do not worry if you have not overclocked it manually. We are still fixing these false messages.
nescafe2002 - Reboot without proper shutdown is not caused by software. It could be powering or hardware issue. In most cases kernel failure, out of memory or watchdog reboots ar caused by software, power outage and without proper shutdown is caused by hardware or wires, etc.
blingblouw
Wed Dec 07, 2016 5:53 pm
Could you elaborate on the TR-069 additional work? Can we add/modify PPPoE now?
mducharme
Trainer
Trainer
Thu Dec 08, 2016 3:49 am
I am wondering the same, has PPPoE support been added?
pe1chl
Thu Dec 08, 2016 11:24 am
Hopefully, work on security.
As you can see in the security news, TR-069 has become a major nightmare.
Suggestions:
- use a low TTL on responses from the TR-069 software so attackers "on the wide internet" cannot reach the TR-069 service.
- have a list of allowed source addresses for TR-069 similar to SNMP.
- quality programming that rules out any buffer overflows from the start.
strods
Thu Dec 08, 2016 1:56 pm
Version 6.38rc45 has been released.
*) certificates - fixed pkcs12 export crash;
*) ipsec - fixed peer configuration my-id IPv4 address endianness;
*) ipsec - various additional work on IKEv1/IKEv2 support;
*) winbox - added new ipsec feature (IKEv1/IKEv2/etc.) support (introduced in v6.38rc);
*) winbox - fixed crash when legacy Winbox version was used;
*) winbox - fixed icons in disabled state (introduced in v6.38rc44);
raffav
Thu Dec 08, 2016 2:34 pm
lol, very nice the news tabs on peer and policy now is more clear
good work
rzirzi
Thu Dec 08, 2016 5:59 pm
MikroTik RouterOS version 6.38 will be THE BEST VERSION EVER!? :)
23q
Thu Dec 08, 2016 9:39 pm
not timeout
Nissarin
Thu Dec 08, 2016 10:15 pm
I see no change on my system (linux/wine), when I tried removing current winbox config/cache I noticed there were no files for rc45 and it seems winbox (re)creates "6.38rc44-763096560" instead.
On another note, I've been testing local-proxy-arp and it seems it still sends icmp redirects, it would be nice if it was disabled automatically on interface running it.
Chupaka
Thu Dec 08, 2016 11:51 pm
not timeout
timeout in Terminal is on the right on 'Creation time'. make the window wider or use 'print detail'
23q
Fri Dec 09, 2016 12:06 pm
not timeout
ip firewall address-list print file=22222
timeout miss
alfonzz
Fri Dec 09, 2016 12:27 pm
"winbox - fixed crash when legacy Winbox version was used"
realy? from dude rc45 "tool>winbox>loaded" but if i doubleclick to wlan then winbox crash - no message, nothing
strods
Fri Dec 09, 2016 12:31 pm
alfonzz - Is 6.38rc45 installed on router to which you connect?
alfonzz
Fri Dec 09, 2016 12:59 pm
no, there is 6.37.3 but until 6.37.2 it works... i know that i may downgrade...
ExibiTT
Fri Dec 09, 2016 2:49 pm
Hi!
v6.38rc10, v6.38rc45:
In the DUDE when I create a new notification with the following parameters:
Type - execute on server
Command - /interface disable vlan5
press test - OK (vlan off on mikrotik).
But if command: /tool fetch url="https://api.telegram.org/bot30(...)4/se ... xt=Service [Probe.Name] on [Device.Name] is now [Service.Status]" keep-result=no
Nothing happens and do not appear in the log entry.
the command should look like this:
:execute {/tool fetch url="https://api.telegram.org/bot30(...)4/sendMessage\?chat_id=-1(...)2&text=Service [Probe.Name] on [Device.Name] is now [Service.Status]" keep-result=no}
strods
Fri Dec 09, 2016 4:36 pm
6.38rc46 has been released.
*) dhcp-server - fixed when wizard was unable to create pool >dhcp_pool99;
*) ipsec - allow empty policy SA dst-address in tunnel mode;
*) ipsec - always listen to port TCP/4500 (fixes some IKEv2 setups without NAT-T);
*) vrrp - do not show unrelated log warning messages about version mismatch;
*) webfig - added extra protection against XSS exploits;
*) webfig - show properly interface last-link-up/down times;
pe1chl
Fri Dec 09, 2016 5:03 pm
Any chance that support for WPA2-EAP with username/password/anonymous_id can be added in station(client) mode?
It has been requested in several threads on the forum, and I think it is on the "nice to have" list, but still not present.
It is working on the access point, with password validation via RADIUS, and Ubiquiti stations can connect to it,
but now that the MikroTik LHG5 is such an attractive option for users we really miss this capability in station mode.
(we need to give all the users the common WPA2-PSK key instead of having separate user/password per user)
w32pamela
Fri Dec 09, 2016 8:18 pm
v6.38rc46, Groove 52Hpn factory default configuration; Scan window in webfig page cannot be used to make connection to a WPA/WPA2 AP. "Default" security profile mode remains at "none" when wifi password entered and Connect button clicked.
I'm not sure when this began but it has been the case in the last few rc versions I've tried. Winbox works fine.
Zorro
Long time Member
Long time Member
Sat Dec 10, 2016 1:13 am
would also like to have "anti-bruteforce" feats in Wireless package (eg in WPA2/CCM within/inside)with blocking on L1/L2 levels,eg like made PSD for generic traffic on L3.
and then in future - same against bruteforcing to winbox, webfig and telnet, API interfaces.
Chupaka
Re: v6.38rc [release candidate] is released
Sat Dec 10, 2016 7:33 pm
timeout miss
confirming (seems like 'print file=' uses narrow terminal). that's why I asked you to do some other actions which definitely work (yes, I tested it first ;))
patrick7
Sun Dec 11, 2016 7:24 pm
Please also fix "use-dns=yes" in IPv6 traceroute. Overdue for a long time now (both reverse and forward)
strods
Mon Dec 12, 2016 12:10 pm
Version 6.38rc47 has been released.
*) bridge - require admin-mac to be specified if auto-mac is disabled;
*) ipsec - ensure generated policy refers to valid proposal;
*) ipsec - always listen to port IPv6 UDP/4500;
*) metarouter - fixed startup process (introduced in 6.37.2);
*) profiler - make profiler work on mmips devices;
*) snmp - fixed rare crash when incorrectly formatted packet was received;
janisk
Mon Dec 12, 2016 12:23 pm
timeout miss
print file=
will always be narrow. That is the limitation of the console in RouterOS. It is not going to change soon.
edit: even if you log into the console with wider login-parameters set - print to file will not get these values.
Drakh
Tue Dec 13, 2016 2:58 am
About metarouter on MIPSBE:
When booting a child ROS or OpenWRT, the host networking process CPU usage goes high; for example, if I do a bandwidth test to the host router (let's say 10Mb both ways) with all child VMs off CPU usage is around 0-2% (normal behaviour) whereas if I do the same bandwidth test with any VM booted ( it doesn't matter if there is a virtual network attached to the VM) the networking process CPU usage goes to 50-60% and network connectivity becomes unstable.
There is a direct relation between running a child ROS or OpenWRT and huge network degradation on the host router when there is some network traffic, I tested on hEX lite and RB2011UiAS.
Let me know if that expected and ditch metarouter altogether, I can understand some overhead if It were traffic to the child OS because of some translation but traffic to the host shouldn't be affected.
strods
Tue Dec 13, 2016 10:23 am
Version 6.38rc48 has been released.
*) dude - (changes discussed here: http://forum.mikrotik.com/viewtopic.php?f=8&t=112599);
*) profile - added ability to monitor cpu usage per core;
*) profile - added "bfd" and "remote-access" processes;
*) profile - make profile work on mmips devices;
*) profile - properly classify "wireless" processes;
*) winbox - allow to specify interface for leds with "interface-speed" trigger;
*) winbox - do not allow to set "loop-protect-send-interval" to 0s;
*) winbox - do not show ph2-state on policy templates;
*) winbox - moved ipsec peer "exchange-mode" to General tab;
*) winbox - show all related HT tab settings in 2GHz-g/n mode;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
janisk
Tue Dec 13, 2016 10:42 am
BTest causes very high load on the CPU, if you are running it on the same router you are checking the load in. Also, CPU load is not working very precisely if you have a virtual guest
MartijnVdS
Tue Dec 13, 2016 11:51 am
I assume this is a typo, and it's actually rc48? Or did the number go down?
HarBenly
Tue Dec 13, 2016 12:24 pm
Woah! LLDD support added. Thanks1
pe1chl
Tue Dec 13, 2016 12:38 pm
Although I do not see it mentioned in release notes, IPv6 configuration is finally working again in WebFig!!
Hooray!
strods
Tue Dec 13, 2016 12:52 pm
MartijnVdS - Yes, sorry about that. It was a typo;
pe1chl - Fixed in 6.38rc44 - http://forum.mikrotik.com/viewtopic.php ... 50#p571674
pe1chl
Tue Dec 13, 2016 2:29 pm
Ah I overlooked that and this time updated from rc41 to rc48 - releases are coming out quick these days :-)
Thanks!
Nissarin
Tue Dec 13, 2016 6:31 pm
IMHO it would be better to change current drop down list with standard filter, at least it would make much more sense on CCRs, where I would be able to tell how specific task (like firewall) is spread among the cores.
expert
Wed Dec 14, 2016 3:06 pm
Does it solve the following Metarouter issue? http://forum.mikrotik.com/viewtopic.php?f=15&t=115422
strods
Wed Dec 14, 2016 5:13 pm
expert - Yes, it should.
didomir
Wed Dec 14, 2016 6:01 pm
Is that issue related with some underlying technology (Kernel , IP stack) ?
AFAIK, Cisco/Juniper/CP hasn’t got similar issues.
When is planned a fix ?
mrz
Wed Dec 14, 2016 6:05 pm
Since every vendor is already switching to ikev2, there is no practical benefit to invest development time for old l2tp/ipsec setups.
parham
Wed Dec 14, 2016 7:43 pm
I have just managed to stablished 3x l2tp over ipse behind a IP address to my vpn server router, thanks guys
request time out was because I disconnected the vpn.
parham
Wed Dec 14, 2016 7:51 pm
This is a SpeedTest.net run over 3x device over L2TP+IPSec
CPU was increased by %24
drees
Thu Dec 15, 2016 10:04 am
I had my 951G-2HnD running v6.38rc44 with two 941-2nDs running in station bridge mode.
Under moderate wireless traffic, I would occasionally get brief WiFi disconnects - the bridges would report "no beacons received".
On the AP 951G-2HnD, it would report a management protection error, but after disabling management protection the connection would still briefly disconnect.
Flashing 6.37.3 to the AP and have had no disconnects in a few days now when they were occurring at least daily.
Anyone else seeing this and/or have any suggestions?
notToNew
Thu Dec 15, 2016 10:08 am
On the AP 951G-2HnD, it would report a management protection error, but after disabling management protection the connection would still brief disconnects.
I ssee the same on 6.36.4, so i wonder why 6.37.3 is working... didn' test this version.
So please report if you find a solution!
strods
Thu Dec 15, 2016 10:54 am
Version 6.38rc49 has been released.
Changes since previous version:
*) bridge - show bridge port name in port monitor;
*) capsman - added "group-key-update" parameter;
*) capsman - use correct source address in reply to unicast discovery requests;
*) discovery - fixed crash on sending LLDP packet over IPv6 (introduced in 6.38rc3);
*) graphing - fixed queue graphs showing up in web interface if aggregate name size >57840 symbols;
*) ipsec - fixed IPv6 remote prefix;
*) ipsec - fixed larval SA state update;
*) ipsec - optimized logging under ipsec topic;
*) ipsec - show SA "enc-key-size";
*) trafficgen - fixed compact export when "header-stack" includes tcp;
*) wireless - fixed upgrade from older wireless packages when AP interface had empty SSID by changing it to router identity;
*) wireless - use vlan ID 0 in RADIUS message to disable vlan tagging;
notToNew
Thu Dec 15, 2016 10:57 am
*) wireless - fixed upgrade from older wireless packages when AP interface had empty SSID;
How? Ist it now allowed again?
strods
Thu Dec 15, 2016 2:05 pm
notToNew - We edited changelog entry. Now it is more precise.
bajodel
Long time Member
Long time Member
Thu Dec 15, 2016 8:44 pm
finally! ..great news!
Zorro
Long time Member
Long time Member
Sat Dec 17, 2016 5:41 am
as for TR-069 - we're struggled more than 3 years with some DOCSIS and EPON and VDSL vendors with hardwired TR-69/64 and its a NIGHTMARE !!!
its not only partially-implemented, hardwired and extremely insecure(and to some extend cannot be shielded at all, because of implementation. and failure in approach to), but totally %@!@ to use. one of vendors did showl mild interests in improvements(but at say 12x-16x slower rates than NECESSARY even from "purely security viewpoint"), rest was simply not giving !@$ about, so we're finally give up and ditched it ~ALL.
separate TR-69 package may be viable palliative to those who cannot live w/o it w/o compromising rest of customers a lot.
as for LT2P traversabiliy as generic NAT-T didn't take off (and carrier grade nat with hole punching lack some things) and Port Control Protocol didn't matured yet, perhas(some say otherwise) not much options.
since early ROS6 versions - MT remove SSTP feats, but generally its good(yet with Huge latency)option to user-cases where traversability was Major priority.
personally i would like PCP support in ROS too.
https://tools.ietf.org/html/rfc6887
(not sure about NAT-T, but plenty of "legacy" projects still use it and will in future, perhaps).
moep
Sat Dec 17, 2016 11:40 pm
IPsec with xAuth seems to be broken with v6.38rc49 as responder and v6.37.3 as initiator
CCR is responder and several other routerboards (RB3011, RB750Gr3, RB951G, hAPac lite, etc.) are initators.
When I upgrade the CCR to the RC the initators cannot log on anymore with "xauth login failed for xyz"
Furthermore, when I downgraqde back to v6.37 the IPsec configuration on the initiators is "gone" and the CPU is at 100% (one core if more than one) until the IPsec process is (seems to be) forcefully terminated.
I tried to change the xauth passwords, but this did not work. I even upgraded an initiator (RB3011) to v6.38rc49, this did not work either.
After downgrading the responder to v6.37.3 an leaving the remote side at v6.38rc49 the connection worked again
It seems that the xauth user DB on responder side gets broken with the upgrade.
Off-Topic: I have another thread regading dual WAN IPIP over IPsec single connection TCP performance. Will this get any better with v6.38?
UPDATE to Off-Topic: does not seem to get better (with RC)
UPDATE2 to Off-Topic: Speed problem seems to be related to the provider of WAN2, if is directly connect a notebook to wan2 (thus diconnecting the router) and testing single stream tcp to btest server, the speed value is exactly the same
UPDATE3 to Off-Topic: the problem ist not provider related. When I connect a RB1100AH to WAN2 exclusivly and make a btest. I can get 25Mbit/s upstream. now I have no idea anymore
UPDATE:
there seems to be a bug in xauth password length
If I crop the password in xauth DB on responder side to max. 31 characters, the connection is okay. it is irrelevant if the password of initiator side is longer
UPDATE2:
uploaded supout.rif
mrz
Mon Dec 19, 2016 2:32 pm
@moep please contact support and attach supout files from rc version and supout file from downgraded router where ipsec is crashing.
Password size was limited, in next RC this limitation will be removed.
strods
Tue Dec 20, 2016 1:38 pm
Version 6.38rc51 has been released.
!) switch - added hardware STP functionality for CRS devices and small Atheros switch chips (http://wiki.mikrotik.com/wiki/Manual:CR ... e_Protocol);
*) bridge - fixed VLAN BPDU rx and tx when connected to non-RouterOS device with STP functionality;
*) capsman - fixed CAP upgrade when separate wireless package is used (introduced in 6.37);
*) console - fixed multi argument value unset;
*) dhcp - fixed DNS server assignment to client if dynamic server exists and is from another IP family;
*) hotspot - fixed nat rule port setting in hs-unauth-to chain by changing it from dst-port to src-port on Walled Garden ip return rules;
*) ipsec - do not auto-negotiate more SAs than needed;
*) ipsec - make generated policies always as unique;
*) ipsec - show active flag when policy has active SA;
*) ipv6 - moved empty IPv6 pool error message to error topic;
*) radius - added IPSec service to console;
*) snmp - always report bonding speed as speed from first bonding slave;
*) wireless - fixed action frame handling for WDS nodes;
*) wireless - fixed full "spectral-history" header print on AP modes;
MartijnVdS
Tue Dec 20, 2016 3:07 pm
Those RCs just keep coming and coming :)
This is going to be the biggest release ever.
didomir
Tue Dec 20, 2016 4:22 pm
I hope to be one of the best releases ... Bug free and stable Christmas gift,for all Mikrotik fans.
macgaiver
Tue Dec 20, 2016 6:28 pm
Seems that IKE polishing is taking some hard time and effort, to my memory this is first time RC have reached 50+ EVER!!!
Note: hardware RSTP is finally working as expected, thanks!
nz_monkey
Tue Dec 20, 2016 8:31 pm
This is going to be one of the biggest RouterOS releases.
Thanks to Mikrotik support and developers for all the hard work they are putting in.
patrick7
Tue Dec 20, 2016 8:54 pm
Can anyone confirm that STP only works with master/slave port and no additional "/interface ethernet switch vlan" config?
strods
Wed Dec 21, 2016 3:41 pm
Version 6.38rc52 has been released.
*) bonding - fixed "tx-drop" on VLAN over bonding on x86;
*) bonding - fixed kernel failure when bonding slave interface receives BPDU (introduced in 6.38rc51);
*) ethernet - fixed "tx-fcs-error" on SFP+ interfaces when loop-protect is enabled ;
*) ipsec - fixed kernel failure on tile with sha256 when hardware encryption is not being used;
*) ipsec - fixed ph2 auto-negotiation by checking policies in correct order;
*) ipv6 - fixed "accept-router-advertisements" behaviour;
Bergante
Thu Dec 22, 2016 11:03 am
Just sent one report. I tried upgrading from rc48 to rc52 on a point to point link using two SXT-ac units. The wlan interface associated correctly to the AP but it stopped moving packets.
Downgrading the station SXT-AC to rc48 made it work again.
zyzelis
Thu Dec 22, 2016 11:23 am
Just tried RB2011 upgrade from 6.37.2 to 6.38.rc52. Router did not returned after upgrade.
After visual inspection is clear that system is in boot loop (on startup are lighting up 3 port leds and after 3s everything goes down). At the boot the LCD display shows, that system is loading kernel, then it stops and after 1s it try again.....
Support guys what you can advice? netinst? or i can get some info whats happening via serial console?
rzirzi
Thu Dec 22, 2016 12:07 pm
At the log console MT6.38rc52:
"package channel changed by admin" - wtat's that?!
I have never seen that log before. I hav NO wireless package at this RB493G.
So - what does mean that log info? It's "system,info" category message.
macgaiver
Thu Dec 22, 2016 12:24 pm
you changed channel in "/system package update set channel=" or in winbox choose different item in dropdown
docmarius
Thu Dec 22, 2016 3:39 pm
I found a strange behavior with 6.38rc52 vs. 6.38rc48.
Here the architecture:
Additional info:
- EdgeSwitch has STP disabled
- hEX POE has its ports in bridge mode acting as a managed POE switch
- hAP is also bridged and runs a NTP Server with GPS, with its wireless interface disabled
- RB922 has 2 wireless interfaces, using VLANs and BGP with the RB1100
Now there is a strange behavior when trying to access the components from a machine connected to the Edgeswitch.
- The moment I upgrade the RB922 to 6.38rc52, the access to the hEX POE and the connected camera will fail.
- If I reset the RB260GSP, the hEX and the camera will come on line for some 30 sec and then be inaccessible again.
- The system behaved correctly when both 922 and hAP used 6.38rc48 (hEX and RB1100 had 6.37.3)
- The RB922 behaves correctly in both instances
- Downgrading the RB622 to 6.37.3 brings normal behavior back
pe1chl
Thu Dec 22, 2016 5:59 pm
Hi Marius,
Do you have STP enabled on any of the bridges inside MikroTik routers?
It appears that there is new functionality in this area. I read that STP is now supported on switch chips with
the trick (?) of providing it from a connected bridge. I often set the STP protocol to "none" on bridges in cases
where there is no danger of loops, did you try that?
docmarius
Thu Dec 22, 2016 8:03 pm
Thank you Rob for the suggestion.
I disabled STP on the hEX POE and on the hAP and it seems to work now.
But I still did not expect this to happen...
pe1chl
Thu Dec 22, 2016 8:20 pm
It is not correct but maybe it can be explained from the new functions in 38rc.
Did you also try to enable STP everywhere?
When there is no bridge in the RB260 it could be required to add one.
(I did not really investigate the "STP for switch provided by bridge" function yet)
docmarius
Thu Dec 22, 2016 9:58 pm
In non working conditions, all routers had RTSP enabled on the connected bridges, including on VLAN bridges.
Just the Edgeswitch has STP/RTSP disabled, because I did not get it to work on VLANs with it enabled.
lotnybartek
Fri Dec 23, 2016 12:12 pm
Can someone tell how is CPU usage with site 2 site VPN connection using IKEv2?
mrz
Fri Dec 23, 2016 12:38 pm
Ike is phase1 protocol so in terms of forward speed over the tunnel ike2 does not differ from ikev1.
ziegenberg
Sat Dec 24, 2016 5:12 am
Anybody had a look at the latest v6.38rc changelogs? Seriously guys, what's up? 165 changes since v6.37.3? :shock:
Never ever has a changelog been so huge. That's going to be the biggest release for MikroTik ever. Looking forward to it, can't await v6.38 showing up in channel bugfix only. :D
dannym
Sat Dec 24, 2016 10:05 am
*) nand - implemented once a week nand refresh to improve stored data integrity *) nand - improved nand refresh feature to enhance stored data integrity
Why dont you add an option to turn on/ off those features introduced in 6.35 rc 43 and 6.36 rc 7?
Merry Christmas!
jarda
Sat Dec 24, 2016 11:12 am
Wasn't such feature implemented some time ago already? Reinventing a wheel....
dannym
Sat Dec 24, 2016 12:08 pm
Exactly! :)
bajodel
Long time Member
Long time Member
Sat Dec 24, 2016 4:43 pm
..[cut]..
..[cut]..
Can I have more info about that ? Thank you.
Mazutti
Wed Dec 28, 2016 3:55 pm
Anyone experiencing mangle problems on 6.38rc52? I'll elaborate:
Problem started approximately one day after I replaced some configuration on a RB2011 to a hEX v3. Mangle is pretty simple, chain prerouting from a vlan with action mark routing. Today it stopped working and I can't seem to find the problem, double checked NAT/Firewall/routes and nothing, only strange thing is I find lots of "time wait" TCP States on connections. Testing speed, latency and upload is ok, but download shows error.
Interesting thing is that the error occurs in this network where I have a route to the ISP modem, but If I route it to a PPPoE connection, it works fine. Can't put that modem in bridge though, and tested connection directly to the modem, or without the mangle and works fine.
Let me know if I haven't made myself clear, but any help is appreciated.
nescafe2002
Forum Veteran
Forum Veteran
Wed Dec 28, 2016 4:20 pm
Well, I've had a similar issue somewhere in this RC at 2016-12-02.
The following NAT rules were passed.
This was fixed by disabling and enabling the concerend rules a single time.
(As the firewall rules filter on connection state dstnat, the traffic couldn't get through)
add action=dst-nat chain=dstnat comment="Translate Exchange" dst-address=10.0.0.32 \
    protocol=tcp src-address=192.168.89.0/24 to-ports=444
add action=dst-nat chain=dstnat comment="Translate WWW" dst-address=10.0.0.5 \
    protocol=tcp src-address=192.168.89.0/24 to-ports=80
I've downgraded and re-upgraded several times but couldn't reproduce the issue therefore did not report it.
This is not mangle related, but also concerns connection tracking. Could you try disabling / enabling the mangle rules and check the outcome? Perhaps create a backup and/or supout.rif before if it has effect for support ticket purposes.
Mazutti
Wed Dec 28, 2016 4:33 pm
Thanks for the quick response. I've certainly disabled and enabled the rules during the troubleshooting, but not sure if tested without altering anything else. Will do first thing on the afternoon and send the supout to support anyway, since I'm not the first with similar issues, maybe it's not something I'm doing wrong.
Will try disabling the related nat and firewall rules too, just in case.
pe1chl
Wed Dec 28, 2016 6:59 pm
When you add NAT rules for traffic that is already flowing, the NAT rule will not be triggered anymore
because the established session will pre-empt that. Same reason why the NAT rule onlu counts
the first packet of every session (some people wonder why the counters on NAT rules are so low).
When this leads to confusing situations, it is best to reboot the router.
timtasse
Fri Dec 30, 2016 5:16 pm
are there plans to add NAT for IPv6 ?
at home i have dynamic ipv6 from the provider and a static ipv6 net with no flatrate at tunnelprovider.
the simplest solution is to NAT unknown networks und known networks without NAT for static firewall config.
pe1chl
Sat Dec 31, 2016 12:36 pm
Now that I installed the 6.38rc on my home router, I notice a new problem in the WebFig:
The AS number for a BGP peer is displayed as a signed value. AS values that are near to the 32-bit unsigned limit (i.e. the Private AS range 4200000000 - 4294967294) are incorrectly displayed as negative numbers.
This is unfortunate as we widely use these AS numbers in our HAMNET network.
This is the third bug in WebFig in 6.38RC that I encounter and that appears to be related to signed/unsigned handling.
I think an investigation into possible further issues similar to this is in order. It appears some datatype change has been made that is not correct or not well tested for consequences.
pe1chl
Sat Dec 31, 2016 12:43 pm
As mentioned in other threads there still is an issue with DHCPv6 PD in certain scenarios.
My provider uses DHCPv6 PD to assign IPv6 addresses, the lease has a 2 hour lifetime but it becomes invalid when the PPPoE session is closed.
While everything works OK in RouterOS with a DHCPv6 client configured on the PPPoE interface, unfortunately the router stores the obtained
lease and does not track the down-status of PPPoE. When the link has been reset or the modem is rebooted, the existing lease is used but
the provider does not route IPv6 until a new lease is obtained. It recovers at the end of the 2 hour lifetime period or when a RELEASE is done,
but it would be preferable when a new lease is requested automatically whenever:
- the router is rebooted
- the underlying PPPoE link goes down
As I understand that in some other cases this behavior may not be optimal or be considered nonstandard, maybe an option could be
added to the DHCPv6 client such that it:
- does not store the lease on disk
- deletes the lease whenever the link goes down
Or alternatively: provide a mechanism to run a script whenever a PPPoE link comes up, so I can put this command into that:
/ipv6 dhcp-client release [find status=bound]
That fixes the problem immediately...
strods
Mon Jan 02, 2017 4:52 pm
Users browsing this forum: infabo, JL2000, rpingar, seriosha, w0lt and 57 guests
