strods
Winbox 3.9 released!
Mon Jan 16, 2017 5:05 pm
What's new in v3.9:
*) fixed problem - some item disable did not work;
*) fixed problem - port numbers & related info could not be specified in firewall after tcp protocol was selected;
If you experience version related issues, then please report them to support@mikrotik.com.
Winbox is available here:
http://www.mikrotik.com/download
If you try to upgrade directly from Winbox loader and version is not available, then you might need to wait for a while until cache in path between your device and our servers is refreshed.
parham
Re: Winbox 3.9 released!
Mon Jan 16, 2017 5:11 pm
Thanks guys for Fix.
Can we have MacOS version of WinBox instead of wine wrapper or ... emulators.
Cheers
normis
Mon Jan 16, 2017 5:24 pm
Cheers
Use Webfig.
parham
Mon Jan 16, 2017 5:55 pm
Cheers
Use Webfig.
It is not a WinBox and never be. with win box you can do way more stuff in few sec and compare and check in web your view is very limited to one page. ROS have a lot good feature compare to 2.97 since I was started with ROS, just hope one day I see WinBox for Mac and Linux, which is 100% missing it.
ptr727
Mon Jan 16, 2017 6:02 pm
Still crashes on Win10 Insider, please get that heap corruption bug fixed.
raffav
Re: RE: Re: Winbox 3.9 released!
Mon Jan 16, 2017 6:08 pm
It is a Windows problem, it was already reported on feedback hub
Enviado de meu XT1580 usando Tapatalk
majestic
Mon Jan 16, 2017 6:11 pm
I agree having a native version for MacOS would be really nice to have as I am sure if you do a poll to see how many OSX users there are more then you think. Meanwhile the Wine version which is floating around works quite well, most of the time.
You have to remember a lot of us and organisations do not run Winblows operating systems, we either use Linux, MacOS, ChromeOS or something else. I know this comapny I am working for right now only uses Mac's, Windows is banned.
parham
Mon Jan 16, 2017 6:21 pm
It is very necessary to have a MacOS and most of Mikrotik staff using MacOS too, most of the networking guys I just now which is a lot they all using Mac.
lets hope they going to change they mind and ask one of the developer to easily develop one for MacOS then Im totally going to wipe my Mac and clean Install the OS without any footprint of Windows. :D
majestic
Mon Jan 16, 2017 6:23 pm
Aye :)
pyjamasam
Mon Jan 16, 2017 9:26 pm
Noticed this in 3.8 but now I see 3.9 is out and it still occurs.
When quitting winbox wine is left running. (OS X 10.12.2, app built with winebottler 1.8-rc4 - resulting in wine 1.8-rc4)
Steps to reproduce:
- launch winbox
- connect to a device
- click on the session menu and then select exit (or click on the exit button on the left menu)
Expected result: Winbox closes and completely exits.
Observed result: Winbox's windows closes but the process is still left running. Running killall wine will close any outstanding processes. Right clicking on the icon in the dock and picking quit doesn't actually quit things. Also using force close to terminate the wine process works.
If you just open winbox and don't connect to a device and then click either the os x menu close button, or pick the file menu and select exit, winbox closes as expected and wine doesn't leave any extra processes running.
I realize this is a bit outside normal support (I am attempting to run winbox on a mac) but since it was working in 3.7 it seems there is a regression in 3.8 (and 3.9) to a state where it no longer closes completely.
If any assistance is required testing please feel free to let me know.
chris.
pyjamasam
Mon Jan 16, 2017 9:30 pm
When selecting multiple entries in the neighbors tab you can't connect to all.
On the manage tab you can select multiple devices and the connect button changes to connet to all and functions as expected.
Not sure if this is something new, or if I just never realised which tab I was on when connecting to devices.
So if it isn't a bug, then consider it a feature request :-)
chris.
Kevo
Tue Jan 17, 2017 3:00 am
Steps to reproduce:
- launch winbox
Exact same problem occurring here as well. Made a new wrapper to test in Winery and the same problem occurs.
w0lt
Long time Member
Long time Member
Tue Jan 17, 2017 3:39 am
Steps to reproduce:
- launch winbox
chris.
I am still seeing the same thing using "Crossover", remaining Winbox processes after exiting. Downgrading to Winbox 3.7 solves the problem.
-tp
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
infused
Tue Jan 17, 2017 10:33 pm
Guys. Can you add thew shortcut keys back in? Specifically enable, disable, delete. I don't understand why this has been removed.
raffav
Wed Jan 18, 2017 12:35 am
Hi
All windows 10 insider preview user that is getting winbox crash.
I was thinking about
Maybe we get to work using a weird work around
If we install the the Linux that Windows is offering and inside we run wine?
Maybe it works
Zorro
Long time Member
Long time Member
Wed Jan 18, 2017 1:26 am
both 3.8 and 3.9 do random crashes on win10 x64 home and 100% crash at exiting(instead of correctly closing session). 3.7(and earlier versions) works just fine.
pyjamasam
Wed Jan 18, 2017 1:51 am
...When quitting winbox wine is left running. (OS X 10.12.2, app built with winebottler 1.8-rc4 - resulting in wine 1.8-rc4)...
A workaround seems to be click on the session menu and pick disconnect. Then when back at the connect window pick file and then exit. Winbox and wine then close as expected.
chris.
w0lt
Long time Member
Long time Member
Wed Jan 18, 2017 2:28 am
chris.
My workaround is to revert back to Winbox v3.7 :?
Maybe they'll figure it out eventually... 8)
MTCNA - 2011
x7007
Wed Jan 18, 2017 5:53 pm
chris.
Same, 3.7 when closing the window doesn't show crash error anymore. 3.8 and 3.9 crashes on exit
Faulting application name: winbox 3.8.exe, version: 0.0.0.0, time stamp: 0x382f3815
Faulting module name: winbox 3.8.exe, version: 0.0.0.0, time stamp: 0x382f3815
Exception code: 0xc000041d
Fault offset: 0x000957b8
Faulting process id: 0x1228
Faulting application start time: 0x01d271a2d29c0109
Faulting application path: C:\Users\x7007\Desktop\1\winbox 3.8.exe
Faulting module path: C:\Users\x7007\Desktop\1\winbox 3.8.exe
Report Id: fabc11a8-e8de-4cfb-96c4-4e518a3c03f3
Faulting package full name:
Faulting package-relative application ID:
HiltonT
Wed Jan 18, 2017 10:37 pm
I just wish WinBox would use a more standard Window than the one they use - in regular Windows apps you can double-click on a divider between columns and it will expand to the size needed to display the contents of that column - in WinBox we need to click and drag each column divider.
Also, WinBox needs a way to allow the possibility of a template to be used (and modified) so that the same columns are displayed on any MikroTik router that is connected to - especially new ones, so that we don't have to go through all the column options on each and every router we connect to.
Regards,
Hilton Travis
macsrwe
Forum Veteran
Forum Veteran
Wed Jan 18, 2017 11:32 pm
That's exactly what "Session:" is. Does it not do some detail you want?
HiltonT
Thu Jan 19, 2017 12:50 am
Aha - yes! So, "sessions" are not really the current connection that's open, but are more like views? Right - now this makes sense. I can create a view I need, save it as a session and then use that "view" on various clients. AWESOME!
Regards,
Hilton Travis
MostafaAta
Thu Jan 19, 2017 4:54 pm
I'v my winbox 3.7,3.8 & 3.9 getting crashed after updating my OS (Win 10 pro x64) to release # "15007.100" insider preview release.
JimmyNyholm
Thu Jan 19, 2017 8:42 pm
On WIndows Server 2012R2 as well
JanezFord
Thu Jan 19, 2017 9:20 pm
I can also confirm WinBox 3.9 not exiting properly on mac os X ... it is annoying but winbox has an option to connect to mac address which have proven to be lifesaving for me manny times. Webfig of course does not have this option. Also I like to have my windows and sessions as I left them for different routers I manage. A native macos app would be very welcome in the future... also ios app, not just android. I am not an apple fanboy, but I just find apple ecosystem more suitable for my needs at this moment
JF.
ada
Fri Jan 20, 2017 10:32 am
The same problem winbox 3.6-3.9 do no save import hosts, do not see hosts
windows 10 (3 PC)
windows 2008 server (1 server)
only work winbox 2.2.18
strods
Fri Jan 20, 2017 10:38 am
Windows Insider crashes and crashes on Exit will be fixed in next Winbox release. Thank you to those who reported these issues to support and sent supout files.
aditrodostress
Fri Jan 20, 2017 3:29 pm
same problem here Windows 7 64-bit when exit winbox app
Problem signature:
  Problem Event Name:	APPCRASH
  Application Name:	winbox.exe
  Application Version:	0.0.0.0
  Application Timestamp:	382f3815
  Fault Module Name:	StackHash_32d6
  Fault Module Version:	6.1.7601.23569
  Fault Module Timestamp:	57f7bb79
  Exception Code:	c0000374
  Exception Offset:	000ce8fb
  OS Version:	6.1.7601.2.1.0.256.1
  Locale ID:	1033
  Additional Information 1:	32d6
  Additional Information 2:	32d6e2e1eb7016a26cfaadb32c99e841
  Additional Information 3:	9277
  Additional Information 4:	92778b60cb7b5a3b1e999db567f3c95b
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
solution using back winbox 3.7
Last edited by aditrodostress on Fri Jan 20, 2017 4:01 pm, edited 1 time in total.
raffav
Fri Jan 20, 2017 3:44 pm
Any idea when will be released?
radpi
Today Microsoft published new build 15014 of Windows 10. Winbox is still crashing down.
MischaBoender
Sat Jan 21, 2017 3:37 am
Also running insider previews and I'm just realizing now how attached I am to Winbox!
Mayby it's time for a Winbox Insider program?  :D
chechito
Sat Jan 21, 2017 4:44 am
Problem signature:
  Locale ID:	1033
same here
Problem signature:
Application Name: winbox 3-9.exe
Fault Module Name: StackHash_3be9
Fault Module Version: 6.1.7601.18869
Fault Module Timestamp: 55636317
Exception Offset: 000cea5f
Locale ID: 9226
Additional Information 1: 3be9
Additional Information 2: 3be99e5a1f435c5c13f706cf2df994e0
Additional Information 3: c2ef
Additional Information 4: c2efffb2b4619e880e7930dc930de719
i deletede cache and winbox session folder, problem persists, y cannot rollback to 3.7 because some of routers i admin are on 6.38.1
mtecuy
Sun Jan 22, 2017 1:42 am
Hi, im using the 3.9 version.
Sadly im not able to access throw cloud service.
Can you guys recomend me any topic for setup the remote access?
My primary router is a Mikrotik Rb2011 UIAS-RM conected for PPPOE to my ISP (Dynamic IP service).
Have some Ubiquiti antenas and ip cameras... its all working good in my local network my problem is to access from my office.
aditrodostress
Sun Jan 22, 2017 7:34 pm
same here
Problem signature:
  Locale ID:	9226
what happen if i remote router on 6.38.1 using winbox 3.7 ? any problem in there ? all router i admin use 6.38.1
This I've done: trying disable windows DEP , delete folder on appdata, run ccleaner. still nothing change anything.
but when i'm trying reinstalling fresh windows , winbox 3.9 app running ok without app crash notice hmmm
Basdno
Sun Jan 22, 2017 11:11 pm
When will new Winbox support that I keep working in the window while uploading new ROS files to a unit?
It is terrible annoying if I am upgrading a client and drag and drop the ROS files into file menu, then I have to sit there waiting till upload is complete to even do simple things!
How come this worked flawlessly in old Winbox, but is impossible in New Winbox???
Also I hate the "Pop up" window created when logging into new units!
If you are unlucky and click somewhere inside winbox window before you make the choice in the remove/keep option window that pops up in start, you have to search through running windows to be able to refind it and click it away. If you have many windows open that can be really annoying while configuring a lot of units simoultanioucly! This also was no problem in the Old Winbox!
Other then these annoyances, I think the NEW Winbox really starts working out well!
Cheers
strods
Mon Jan 23, 2017 4:08 pm
Users browsing this forum: Chupaka, eworm, SatireWolf and 14 guests
