strods
Winbox 3.10 released!
Mon Jan 23, 2017 4:07 pm
What's new in v3.10:
*) fixed crash on latest Windows developer builds;
*) fixed crash on disconnect;
If you experience version related issues, then please report them to support@mikrotik.com.
Winbox is available here:
http://www.mikrotik.com/download
If you try to upgrade directly from Winbox loader and version is not available, then you might need to wait for a while until cache in path between your device and our servers is refreshed.
WalidMorsi
Re: Winbox 3.10 released!
Mon Jan 23, 2017 4:37 pm
Is this version of winbox fixes "has stopped working" message at windows 10 insider preview build 15014 ?
raffav
Re: RE: Re: Winbox 3.10 released!
Mon Jan 23, 2017 4:38 pm
Yes
Just try yourself
Enviado de meu XT1580 usando Tapatalk
WalidMorsi
Mon Jan 23, 2017 4:44 pm
Yes
Just try yourself
Many thanks for you, I will upgrade to the new build.
radpi
Mon Jan 23, 2017 5:50 pm
Yes
Just try yourself
I can confirm this build of winbox works with windows 10 build 15014
w0lt
Mon Jan 23, 2017 6:33 pm
So Far..So Good.. Works correctly using "MacOSX Crossover !! :D :D
-tp
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
juliokato
Mon Jan 23, 2017 7:03 pm
UAU, four releases in 10 days!!!
I apologize my grammatical errors, my english not so good, I am not a native speaker.
Wiki is maintained in English. I use Google translator. 8)
Njumaen
Mon Jan 23, 2017 8:19 pm
No "disconnect/close"-issue on MacOS with wine-1.9.23 or wine-2.0-rc6
Good work!
MostafaAta
Tue Jan 24, 2017 5:54 am
Still crashing.
Windows 10 Insider Preview Build 15014.
nishadul
Tue Jan 24, 2017 6:10 am
When I click check for update of winbox then message show "There are no new versions", My current winbox version is 3.9
macgaiver
Tue Jan 24, 2017 7:33 am
you can download it from webpage directly. Check-for-update delays are usually down to proxies (cloud) - ether yours or ones that MikroTIk uses for version discribution.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
WalidMorsi
Tue Jan 24, 2017 1:24 pm
Still crashing.
Are you sure ?
strods
Tue Jan 24, 2017 4:34 pm
MostafaAta - If Winbox is crashing it does not necessary mean that this is the same problem. Please try to reproduce crash and then send supout file from router to which you were connected to support@mikrotik.com
WalidMorsi
Tue Jan 24, 2017 4:42 pm
I had upgrade to Windows 10 Insider Preview build 15014 now and Winbox 3.10 is working good.
thanks.
w0lt
Tue Jan 24, 2017 6:47 pm
WinBox 10 has been working great for me..Kudos to the MikroTik Team that worked on it. :D
Future request: Please preserve the state of the "Torch" collect blocks when exiting Winbox so I don't have to keep reselecting them each time? 8)
Thanks !!
-tp
MTCNA - 2011
juliokato
Tue Jan 24, 2017 7:33 pm
Drag and drop is not working! (for upload files)
bajodel
Long time Member
Long time Member
Tue Jan 24, 2017 7:41 pm
+11 :lol:
conrad
Tue Jan 24, 2017 8:15 pm
I will ask once again.....
This problem can be solved?
It seems it was promised in version 3.0
null31
Tue Jan 24, 2017 8:31 pm
Good work!
Also, was solved the problem after close the winbox, which left a dead process running on the Arch Linux using wine 2.0rc6-1 or wine 2.0rc5-1.
Greak work!!
aditrodostress
Tue Jan 24, 2017 9:25 pm
WInbox 3.10 running perfect without appcrash notice again. thank u team,
chechito
Wed Jan 25, 2017 11:37 pm
winbox 3.10 solved my issue with 3.9 thank you very much mikrotik !!!
Basdno
Thu Jan 26, 2017 2:08 pm
When will new Winbox support that I keep working in the window while uploading new ROS files to a unit?
It is terrible annoying if I am upgrading a client and drag and drop the ROS files into file menu, then I have to sit there waiting till upload is complete to even do simple things!
How come this worked flawlessly in old Winbox, but is impossible in New Winbox???
Also I hate the "Pop up" window created when logging into new units!
If you are unlucky and click somewhere inside winbox window before you make the choice in the remove/keep option window that pops up in start, you have to search through running windows to be able to refind it and click it away. If you have many windows open that can be really annoying while configuring a lot of units simoultanioucly! This also was no problem in the Old Winbox!
Other then these annoyances, I think the NEW Winbox really starts working out well!
Cheers
bratislav
Thu Jan 26, 2017 6:20 pm
You should check your display settings, custom screen font or similar, it works fine for the rest of us ...
normis
Fri Jan 27, 2017 11:10 am
hmmmm, same here, works ok
Tonda
Fri Jan 27, 2017 11:40 am
Normis, it seems from screenshots, that conrad uses other than default text size setting (which in fact works with font DPI). So if application is not able to use current text DPI in text width calculations, results are not correct.
This setting can be changed here: https://technet.microsoft.com/en-us/lib ... 29368.aspx
It is especially useful for example when notebook has large display with very high resolution, because it helps to increase text size.
normis
Fri Jan 27, 2017 11:48 am
Yes, Winbox does not play well with non standard DPI.
Chupaka
Fri Jan 27, 2017 12:23 pm
Suddenly: that's what he's asking to fix =)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
conrad
Fri Jan 27, 2017 2:07 pm
Resolution of the display 2560 x 1440
Font very small and I am forced to put the scale of 125%
After that a part of information isn't displayed in winbox log
The problem can be solved, having given the chance to users to move apart fields
Разрешение дисплея 2560 х 1440
Шрифт очень мелкий и я вынужден ставить масштаб 125%
После этого часть информации не отображается в winbox log
Проблему можно решить, дав возможность пользователям раздвигать поля )
normis
Fri Jan 27, 2017 2:10 pm
Sorry, using Webfig is the only option right now. It is not trivial to fix.
P.S: side note. isn't it a bit strange, that a laptop at it's native resolution shows too small text?
conrad
Fri Jan 27, 2017 4:52 pm
It is difficult to make fields more?
Or to give the chance to change them. (especially in one of versions 3.0b you already lay it, and then in the final version have removed)
mbfound
Fri Jan 27, 2017 9:09 pm
Anyone else get this error message when rebooting a board when logged into ROMON? Have to delete all sessions/cache to get Winbox working again.
bratislav
Sat Jan 28, 2017 5:35 pm
Actually there is one small annoyance in the latest versions of winbox ...
If I click on a new session (menu/session/new) it does more or less nothing except deleting the IP address from the session text box and I stay connected to the same router but I am unable to close winbox any more ... or exit session ... or anything ... I have to kill the process using task manager ...
MostafaAta
Sun Jan 29, 2017 1:19 am
strods- How Can i get support file from router?
sebastiii
Sun Jan 29, 2017 11:10 am
It fix the crash on windows 2012R2 and WIN10 latest insider build from 15002 to 15019 :P
JB172
Sun Jan 29, 2017 12:07 pm
From Winbox or from Webfig, from the left menu, press "Make supout.rif
The file supout.rif will be created in files.
WalidMorsi
Sun Jan 29, 2017 3:41 pm
I've a problem at winbox 3.10, when i make user bypassed it is marked letter B not P and users regular it was marked letter P, please how can i resolve this problem.
I apologized about my poor english language :)
strods
Mon Jan 30, 2017 9:41 am
mbfound - If you get disconnected also from RoMON agent, then Winbox jumps to state where you have to connect to RoMON agent first. It is saved in Winbox loader from previous session. If it is not saved in Managed list, then Winbox does not know RoMON username/password and you can not connect. You have to go Tools/Advanced Mode and delete RoMON manager IP address from RoMON Agent field and then conenct to Agent and to other device afterwards
bratislav - Thank you. We managed to reproduce this problem and will try to fix it as soon as possible.
WalidMorsi - I can not seem to reproduce such issue. Please provide an example.
fposavec
Mon Jan 30, 2017 10:03 am
Wine on debian testing.
On right click on some item , which have ADD menu, and drag mouse over pop menu, and when you point to ADD option, pop menu is closed.
strods
Mon Jan 30, 2017 10:13 am
fposavec - Thank you. Managed to reproduce. Actual only when there is Add function with another drop list available. For example, in Interface menu, but no in IP/Address menu.
WalidMorsi
Mon Jan 30, 2017 5:03 pm
Please, How can i upload a photo here to provide example ?
Trezona
Mon Jan 30, 2017 5:29 pm
Hi guys,
Is it possible to run Winbox from my Dropbox folder?
I have 58 highsites and it would be great if i could sync my winbox between my office and my laptop.
If so, which files would i need to copy to my Dropbox folder?
Clive.
WalidMorsi
Mon Jan 30, 2017 5:34 pm
In fact it is bypassed, and look blocked.
WalidMorsi
Mon Jan 30, 2017 5:35 pm
strods
Tue Jan 31, 2017 9:39 am
WalidMorsi - Image can not be opened without registered account. Please provide commands how we can add problematic entry or send screen shot to support@mikrotik.com
fposavec
Tue Jan 31, 2017 9:51 am
Hi guys,
Clive.
You can move sesion folder to dopbox and then synced with many pc-s.
On winbox tools -> Move session folder ...
I use ownclod and works like charm
WalidMorsi
Tue Jan 31, 2017 7:26 pm
Chupaka
Tue Jan 31, 2017 10:29 pm
it says "Your session has either timed out or has not been correctly established. Please login again."
use 'Attachments' tab when editing message to attach a picture to your post
nmt1900
Wed Feb 01, 2017 12:43 am
Big problem!
Compatibility problems with older RouterOS versions. I had one CRS226 with v.6.30 and was not able to configure VLANs in switch mode.
It works with WinBox 3.7, but with 3.10 it looked like switch was in router mode i.e. there was no VLAN menu under 'Switch'. I was unable to understand what was wrong until I tried this with older WinBox.
These things necessitate the need for keeping multiple versions of WinBox to be able to work. Fortunately it is technically possible...
strods
Wed Feb 01, 2017 9:39 am
nmt1900 - I can not seem to reproduce such problem. Does it persist if in 3.10 Winbox loader you go to Tools/Clear Cache and only then connect to device?
Zorro
Long time Member
Long time Member
Wed Feb 01, 2017 11:19 am
not crashed, yet both on "Stable", eg 1607/RS1 version and "legacy" retail build(august 2016) of Win10.
can't say anything bout "insider preview" branch, yet(not time to test this wave).
stefanov
Re: Winbox 3.10 crashes on Windows 10 build 10.0.15019.1000
Wed Feb 01, 2017 4:14 pm
Log Name: Application
Source: Application Error
Date: 2/1/2017 15:55:37
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: DESKTOP-VIET79P
Description:
Faulting application name: winbox.exe, version: 0.0.0.0, time stamp: 0x382f3815
Faulting module name: USER32.dll, version: 10.0.15019.1000, time stamp: 0xb2624dbc
Exception code: 0xc000041d
Fault offset: 0x00062c01
Faulting process id: 0x20d0
Faulting application start time: 0x01d27c92dc694edb
Faulting application path: D:\install\winbox.exe
Faulting module path: C:\WINDOWS\System32\USER32.dll
Report Id: 226f1173-69d8-4f0a-9d37-092e40aa8eb7
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2017-02-01T13:55:37.683152500Z" />
<EventRecordID>1178</EventRecordID>
<Channel>Application</Channel>
<Computer>DESKTOP-VIET79P</Computer>
<Security />
</System>
<EventData>
<Data>winbox.exe</Data>
<Data>0.0.0.0</Data>
<Data>382f3815</Data>
<Data>USER32.dll</Data>
<Data>10.0.15019.1000</Data>
<Data>b2624dbc</Data>
<Data>c000041d</Data>
<Data>00062c01</Data>
<Data>20d0</Data>
<Data>01d27c92dc694edb</Data>
<Data>D:\install\winbox.exe</Data>
<Data>C:\WINDOWS\System32\USER32.dll</Data>
<Data>226f1173-69d8-4f0a-9d37-092e40aa8eb7</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
Cha0s
Forum Veteran
Forum Veteran
Thu Feb 02, 2017 11:14 am
Hipsters may use whatever they want, we don't care. But reasonable admins with working brain use 2.2.18.
I am glad that I am not the only one using v2.2.18 :D
normis
Thu Feb 02, 2017 11:17 am
Can you give any reason why? Very surprised about this. I use only newest Winbox, it works excellent and has so many neat features, that were not possible before.
BTW by the widely accepted definition of "hipster", it would be quite opposite. Hipsters would use any older and less popular version (words associated with hipsters are indie, alternative, vintage, ironic) ;)
Cha0s
Forum Veteran
Forum Veteran
Thu Feb 02, 2017 11:42 am
Some new features don't make up for the lost productivity that v3 imposes.
I've mentioned my problems with winbox 3 many times since v3.0 (~2015).
http://forum.mikrotik.com/viewtopic.php ... 66#p570666
http://forum.mikrotik.com/viewtopic.php ... ox#p543538
http://forum.mikrotik.com/viewtopic.php ... ox#p523127
http://forum.mikrotik.com/viewtopic.php ... ox#p518630
http://forum.mikrotik.com/viewtopic.php ... ox#p506559
Cha0s
Forum Veteran
Forum Veteran
Thu Feb 02, 2017 11:46 am
And to me it seems that you don't care about your customers. I see no interest taking into account your customer's feedback.
normis
Thu Feb 02, 2017 11:50 am
What is your offer, to make selectable behavior? Most of these were done because of other user requests. You know how it is. We will fix your issues but all the others will complain.
I see that you have the following complaints:
1. Shortcut keys are different, because CTRL was added (this was done to avoid accidental problems)
2. Winbox (not loader) always opens on Main monitor, not where it was open before (this was done to solve problems on laptops, Winbox 2 often got lost because external screen was disconnected)
3. Escape key does not quit loader. (no other Windows program does this. ALT+F4 is the normal key combo)
honzam
Thu Feb 02, 2017 2:40 pm
Winbox 3.x is OK, only one problem which I have is - durig upload file (for example new Router OS) is not posible working in active window.
After file is uploaded, then is possible working.
In winbox 2.2.18 this works. Can you fix it?
LAN, FTTx, Wireless. ISP operator
Sob
Thu Feb 02, 2017 5:46 pm
That's a good idea. Even though I personally don't care about these specific shortcuts, I can definitely appreciate how annoying it is when you lose ability to use shortcuts you were used to. I had that experience myself when WinBox 3 at first didn't understand Ctrl+Ins and friends for clipboard operations and I didn't like it a bit. To have program remember its position on right monitor is reasonable request too. If it's undesired or dangerous behaviour for some (or most), then an off by default option is a solution that can make everyone happy.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
karlisi
Fri Feb 03, 2017 9:41 am
+1
This is very annoying on slow connections.
Karlis
Amoralez
Sat Feb 04, 2017 12:32 am
Could you please add a scroll bar to some windows? For example firewall rule window as on screenshot. It's very annoying, I'm used to winbox, but now I have to use terminal to change something. Already saw same request long time ago, but it's still unimplemented for some reason.
I'm using a notebook with 1366*768 resolution.
Mikrotik 951G-2HnD
pcunite
Sat Feb 04, 2017 3:26 am
I have this problem also. Windows 10, using a 24" monitor with DPI set to 125. The Log display seems to be the only one with an issue.
teknogrezz
Sun Feb 05, 2017 12:39 pm
good works, is so kagoi
bratislav
Mon Feb 06, 2017 6:56 pm
It is unusable on smaller screens ... You could use WebFig for now ...
normis
Tue Feb 07, 2017 9:00 am
How small is that screen? What resolution? We have tested using standard sizes, like 11" and 1200x720 for example.
Amoralez
Tue Feb 07, 2017 9:47 am
Hi, normis, actually it's not that small, as I wrote in my post, it's a laptop with 1366*768, 15.6"
I'm not sure, but I think this problem appeared on latest winbox/routeros version.
Mikrotik 951G-2HnD
bajodel
Long time Member
Long time Member
Tue Feb 07, 2017 4:27 pm
( http://forum.mikrotik.com/viewtopic.php ... 09#p581808 )
Note: Sorry for crossposting, but probably I've wrong posted earlier and this is a winbox problem.
"/ip accounting" settings are not correctly shown by winbox (current/lastest 3.10), testing on board CRS125.
Steps to reproduce:
1) Try to configure/enable ip accounting via winbox > all seems to be fine (service works)
2) Exit winbox and relogin, you will see ip accounting disabled and web-access settings are not shown (despite service is working)
3) If you check via CLI, settings are there, only winbox ignore them.
Also "/ip traffic-flow" have the same behaviour (winbox 3.10, tested on board RB3011).
Anyone can confirm, please ?
dragon2611
Tue Feb 07, 2017 5:04 pm
Some manufacturers seem to like putting 2k-4k panels in 13 -15" laptops, not really sure the point to be honest.
Also windows 10 defaults to 125% scaling on some 15" 1080p laptops, I usually change it to 100% and it's about the smallest I'd like to go before things get uncomfortable.
Tried windows on a 13" retina mac once, that's fun on a app that doesn't do scaling.
strods
Tue Feb 07, 2017 5:10 pm
bajodel - We will try to fix accounting issue as soon as possible, however I can not reproduce same issue with Traffic Flow settings.
pcunite
Tue Feb 07, 2017 7:07 pm
1366x768 is quite common. I've had this issue too. I need to scroll, especially when I turn on "Advanced" options in the Wifi menus.
dgnevans
Tue Feb 14, 2017 4:06 pm
Winbox is not displaying correct information for Ip accounting. Winbox 3.10 CCR1009-8G-1S-1s+ V6.37.4
strods
Fri Feb 17, 2017 12:44 pm
Users browsing this forum: No registered users and 32 guests
