becs
SwOS version 2.2 released
Wed May 03, 2017 11:30 am
http://www.mikrotik.com/download
What's new in v2.2:
*) fixed CSS326 & CRS317 switch MAC address;
*) fixed CRS317 lockup;
*) make CSS326 & CRS317 10G links more stable;
*) fixed CRS317 temperature reading;
*) fixed problem where big ACL, VLAN or static hosts lists kept only couple of first entries;
*) made "Save Backup" work on CSS106;
*) SNMP: report always 0 in IF-MIB:ifOutQLen;
*) CSS106: report correct speed for SFP port via SNMP;
What's new in v2.1:
*) added support for per port and ACL ingress rate limitation to CSS326 & CRS317;
*) added support for LACP in CSS326 & CRS317;
*) fixed CSS106 accessing over VLAN;
*) fixed CSS106 ACL rules that change VLANs;
*) added tx/rx rates per port to CSS106;
*) SNMP: added support for BRIDGE MIB;
*) SNMP: added support for GetBulkRequest;
Phaere
Re: SwOS version 2.2 released
Thu May 04, 2017 2:54 pm
Working great on CSS326, all previous bugs seems to be fixed, thanks
brwainer
Fri May 05, 2017 11:28 pm
Is this supported on an original RB260GS? The release notes don't indicate anything, and the download page says "version 2.2 for new RB260GS(CSS106-5G-1S), new RB260GSP(CSS106-1G-4P-1S)" - so is there a different hardware that is the "new RB260GS" which is different from the "old RB260GS"?
andriys
Sat May 06, 2017 4:16 pm
Yes, the hardware is different. And this new SwOS release appears to be for the new boards only.
sterling
Tue May 09, 2017 12:16 am
Upgraded a new RB260GS hardware to 2.2 and set VLAN management ID.
I can ping the unit over VLAN, but I cannot access the web page.
Did something change where we need to make an additional change to some other page to enable VLAN web page management from default settings?
Alestrix
Mon May 15, 2017 11:06 pm
Can the CSS326 max out a Link Aggregation Group or is link aggregation only implemented in the CPU?
One other thing: From the wiki it seems that the switch doesn't support balance-rr as an aggregation algorithm, but maybe it will in the future?
Alestrix
Re: SwOS version 2.2 released -> BUG related to Management VLAN
Wed May 24, 2017 8:40 pm
on CSS326 runing SwOS2.2, when I set Management VLAN to 1 and connect computer to a port which
- has VLAN set to "optional" (i.e. not "disabled")
- may accept any (tagged and untagged)
- has default VLAN ID 1
- is member of VLAN 1 (among others)
Then I cannot access the management interface anymore.
The comuter's NIC sends out traffic untagged, so should be put into VLAN 1 by the switch and be able to access the management interface.
Cheers
Alex
Alestrix
SwOS version 2.3rc2?
Wed May 31, 2017 11:46 am
The "Upgrade" tab on my CSS326 (SwOS 2.2) sais "Latest Available Version: 2.3rc2 (built at Wed May 24 2017 13:36:36 GMT+0200 (Mitteleuropäische Sommerzeit))". There is neither a link to a changelog nor to a firmware image download.
Where can I find information about 2.3rc2?
Cheers
Alex
strods
Tue Jun 06, 2017 3:12 pm
Version 2.3 has been released:
viewtopic.php?f=21&t=122214
Users browsing this forum: Mazutti, xvo and 12 guests
