Ryan207
Re: v6.41rc [release candidate] is released! New bridge implementation!
Sun Dec 10, 2017 3:51 pm
Looking at the connection marking this morning --- if I delete the connection from tracking, it will get tracked and marked properly. It seems with rc61 it allows the connections to start being tracked before it checks for marking after reboot. I should be able to temporarily fix this with a script but curious if this is a bug in rc61 or there is another way to implement marking now?
uldis
Mon Dec 11, 2017 9:00 am
My static ports in all bridges just disappear after reboot on CAPsMAN controller router.
RB2011UAS-2HnD ROS 6.41rc61.
Also on SXT ac, clients are diconnected from time to time (every few minutes). In rc56 was perfect.
New bugs?
Do you have support output files from older RC where the static bridge ports were working ok? Did you make a new support output file after the upgrade where the bridge ports disappeared?
About wireless disconnection Only the AP was upgraded the to the newest RC version or also the Clients as well? What are the disconnect messages? Do you have a support output files?
Send all that info to support@mikrotik.com
alexvdbaan
Trainer
Trainer
Mon Dec 11, 2017 1:29 pm
Hi Guys,
I have been playing around with the CRS326 and the new bridge implementation. I am quite happy with the direction of the new bridge, everything should become a lot easier. However as a few people before me have posted, getting it all to work with the current info on the wiki is challenging.
My network
The trunking from the CCR1009 comes in nicely at the 3 CRS326 switches. All my vlans turn nicely into access ports. My management vlan (666) is getting an IP address through DHCP. When connecting from the CCR1009, I can manage my switches through that IP. However when trying to mac winbox or ip winbox to my swithes from devices behind accessport vlan 666 this doesnt work. I have tried many different options. I was wondering is someone would be able to look at my config and suggest a possible solution. I can manage all my other devices behind the switches (caps/routers/etc)
Config CRS326
add admin-mac=64:D1:54:DA:33:50 auto-mac=no name=#master protocol-mode=none \
    pvid=666 vlan-filtering=yes
set [ find default-name=ether2 ] comment="1-10 Cust1 7/8/9/10"
set [ find default-name=ether3 ] comment="1-09 untagged 250 voice proper"
set [ find default-name=ether4 ] comment="reserved Cust1"
set [ find default-name=ether5 ] comment="1-05 Cust2"
set [ find default-name=ether6 ] comment="Reserved Cust2"
set [ find default-name=ether7 ] comment="1-11 Cust3"
set [ find default-name=ether8 ] comment="1-12 Cust3"
set [ find default-name=ether9 ] comment="1-13 Cust3"
set [ find default-name=ether10 ] comment="1-14 Cust3"
set [ find default-name=ether11 ] comment="1-17 Cust3"
set [ find default-name=ether12 ] comment="1-18 Cust3"
set [ find default-name=ether13 ] comment="2-1 Cust4"
set [ find default-name=ether14 ] comment="2-3 Cust4"
set [ find default-name=ether15 ] comment="2-7 Cust4"
set [ find default-name=ether16 ] comment="2-11 Cust4"
set [ find default-name=ether17 ] comment="2-13 Cust4"
set [ find default-name=sfp-sfpplus1 ] speed=1Gbps
/interface vlan
add interface=sfp-sfpplus1 name=s1.250 vlan-id=250
add interface=sfp-sfpplus1 name=s1.550 vlan-id=550
add interface=sfp-sfpplus1 name=s1.552 vlan-id=552
add interface=sfp-sfpplus1 name=s1.553 vlan-id=553
add interface=sfp-sfpplus1 name=s1.554 vlan-id=554
add interface=sfp-sfpplus1 name=s1.666 vlan-id=666
add name=MAN
add bridge=#master interface=ether2 pvid=552
add bridge=#master interface=ether3 pvid=250
add bridge=#master interface=ether4 pvid=552
add bridge=#master interface=ether5 pvid=550
add bridge=#master interface=ether6 pvid=550
add bridge=#master interface=ether7 pvid=553
add bridge=#master interface=ether8 pvid=553
add bridge=#master interface=ether9 pvid=553
add bridge=#master interface=ether10 pvid=553
add bridge=#master interface=ether11 pvid=553
add bridge=#master interface=ether12 pvid=553
add bridge=#master interface=ether13 pvid=554
add bridge=#master interface=ether14 pvid=554
add bridge=#master interface=ether15 pvid=554
add bridge=#master interface=ether16 pvid=554
add bridge=#master interface=ether17 pvid=554
add bridge=#master interface=ether18
add bridge=#master interface=ether19
add bridge=#master interface=ether20 pvid=666
add bridge=#master interface=ether21 pvid=666
add bridge=#master interface=ether22 pvid=666
add bridge=#master interface=ether23 pvid=666
add bridge=#master interface=ether24 pvid=666
add bridge=#master interface=sfp-sfpplus2
add bridge=#master interface=ether1 pvid=552
add bridge=#master interface=sfp-sfpplus1
/interface bridge vlan
add bridge=#master tagged=sfp-sfpplus1,sfp-sfpplus2 untagged=ether2,ether4 \
    vlan-ids=552
add bridge=#master tagged=sfp-sfpplus1,sfp-sfpplus2 untagged=ether3 vlan-ids=\
    250
add bridge=#master tagged=sfp-sfpplus1,sfp-sfpplus2 untagged=ether5,ether6 \
    vlan-ids=550
add bridge=#master tagged=sfp-sfpplus1,sfp-sfpplus2 untagged=\
    ether7,ether8,ether9,ether10,ether11,ether12 vlan-ids=553
    ether13,ether14,ether15,ether16,ether17 vlan-ids=554
add bridge=#master tagged=sfp-sfpplus1 untagged=\
    ether20,ether21,ether22,ether23,ether24 vlan-ids=666
add interface=s1.666 list=MAN
add interface=s1.552 list=MAN
Cheers, Alex
bjornr
Mon Dec 11, 2017 1:42 pm
I was under the impression that one of the benefits of the new setup is being able to apply VLANs to the bridge and not to a physical interface without loss of speed. For what it's worth, a config similar to viewtopic.php?t=125251#p616970 works quite OK in my lab network.
alexvdbaan
Trainer
Trainer
Mon Dec 11, 2017 2:35 pm
Hi bjornr,
If I look at your setup it seems that the primary difference is that you also list your bridge as tagged in the vlan port settings. Could you share your bridge default vlan setting?
Mine is:
add admin-mac=64:D1:54:DA:33:50 auto-mac=no name=#master protocol-mode=none pvid=666 vlan-filtering=yes
Thanks, Alex
bjornr
Mon Dec 11, 2017 2:52 pm
Sure thing!
add fast-forward=no igmp-snooping=no name=bridge priority=0x1000 protocol-mode=none vlan-filtering=yes
The docs I referenced uses pvid=1 for the bridge and for holding the VLANs, so my bridge sets no pvid. Instead, I've assigned the IP directly to a VLAN:
/interface vlan
add interface=bridge name=vlan4 vlan-id=4
and
add address=192.168.0.4/24 interface=vlan4 network=192.168.0.0
Also note that the docs I referenced sets pvid 1 untagged on all trunk interfaces.
(Edit: Fixed BBCode markup)
RafGan
Tue Dec 12, 2017 12:57 am
New bugs?
Uldis, sorry, I have not support files. Right now I'm trying do several reboot with disappeared ports after another upgrade to rc61, but ports still exists. I have made suppout files with working configurations on both versions. Maybe time of working is to short. Next reboot will be done tomorrow.
SXT ac have actual this same problem on rc56 - maybe channel overlapping with diffrent networks - I will give a feedback.
alexvdbaan
Trainer
Trainer
Tue Dec 12, 2017 11:54 am
Sure thing!
Thanks bjornr,
Yesterday I played around with your example, it looks like you have VLAN's originating in the ROS641.rc61 and pushing them forward. In my usecase I have the VLAN's originating in a previous hop. In the updated diagram below I have further clarified. I have tried to play with two scenarios's.
In scenario 1 I have added the interface vlans to the physical port that carries the VLAN's from the previous hop. In this configuration, devices in my management lan can see the gateway at CCR1009 and mac winbox and ip winbox. I can set a dhcpclient on the vlan interface 666 on crs326. From the management vlan I cannot see mac winbox, cannot access mac winbox or ip winbox the dhcp received IP. I can only manage through Romon to the CCR1009 and connect back to the CRS326
In scenario 2 I have added the vlans as you said, to the bridge and removed them from sfp1. In this scenario my management vlan hosts can access a fixed ip set on vlan 666 interface and mac winbox. The dhcp client does not work anymore, there is no communication with CCR1009. If I try to add vlan 666 to sfp1 I stil l cannot access CCR1009. However in IP neigbors I do see the CCR1009.
For now that leaves me with scenario 1 since that I a usable scanario with Romon. Am wondering is others also have experience here with this problem?
Here you can find my updated diagram: https://superyupkent.stackstorage.com/s/IA9etV8NMlY70Wy
Thanks Alex
bjornr
Tue Dec 12, 2017 12:00 pm
Sure thing!
Thanks bjornr,
No, my VLANs (and their IP addresses) are defined on an RB850G connected to the CRS326.
idlemind
Tue Dec 12, 2017 4:46 pm
Sure thing!
Thanks bjornr,
Thanks Alex
Your CCR1009 running 6.40 should be configured with either software based bridges for VLANs or the Ethernet switch per normal methods.
Your CRS326 should be configured with the new VLAN aware bridges. This means:
  • A single bridge
  • All VLAN interfaces created with interface equal to the bridge
By default spanning-tree operates over the native VLAN on a port. You'll want to ensure the CCR1009 is configured for STP on the ports connecting to the CRS326 switches. I prefer a priority of 4096 on my root bridge and higher on my non-root bridges but to each his own there. In either case you want the PVID to match across the board. In the CCR1009 you'll want VLAN1 as the untagged port for all 3 downstream ports with STP on. In the CRS326, set PVID to 1 on the bridge and add the bridge as untagged to /interface bridge vlan for VLAN 1. Ensure STP is also enabled with protocol-mode on the bridge.
Because I don't like the Ethernet switch interface, it was poo poo. I'll give you an example with software bridges on your CCR1009:
/interface bridge add name=br1 protocol-mode=stp priority=0x1000
/interface vlan add interface=br1 vlan-id=552 name=br1-vlan552
/interface vlan add interface=br1 vlan-id=666 name=br1-vlan666
/ip address interface=br1-vlan552 address=10.5.52.1/24
/ip address interface=br1-vlan666 address=172.25.20.1/24
/interface bridge port add bridge=br1 interface=eth-crs326-1
/interface bridge port add bridge=br1 interface=eth-crs326-2
/interface bridge port add bridge=br1 interface=eth-crs326-3
For the CRS side:
/interface bridge add name=br1 vlan-filtering=yes priority=0x3000 protocol-mode=stp pvid=1
/interface bridge vlan set [ find where vlan-ids=1 and bridge=br1 ] untagged=br1 tagged=""
/interface bridge vlan add bridge=br1 vlan-ids=552 tagged=br1,sfp1 untagged=""
/interface bridge vlan add bridge=br1 vlan-ids=666 tagged=br1,sfp1 untagged=""
# ^^ add your dhcp client or ip address to the VLAN interface of br1-vlan552
Wrote this from memory w/o plugging the commands in so might be a typo or two.
KBV
Tue Dec 12, 2017 8:51 pm
Hi!
I have a simple configuration of the router rb3011 - two software bridges and do not use the master port (there are vlans on ethernet interfaces).
The update to version 6.41rc62 is done correctly, but in one of the networks packet loss starts.
Communication with the nodes of this network arbitrarily disappears and appears again.
There are no changes in the bridge settings - but the problem appears.
Using or not using the hw-offload does not affect the situation.
In the previous version 6.41rc56 was the same.
I read the thread and did not find the description of a similar problem. It surprises me.
KBV
Wed Dec 13, 2017 10:16 am
I'm sorry. It seems the problem only occurs when I turn on the hw-offload.
anuser
Long time Member
Long time Member
Wed Dec 13, 2017 10:38 am
I use CAPSMAN based forwarding with around 80 WAP AC / HAP AC devices. I updated the access points to v6.41rc61 and now all access points disconnect concurrently from the controller from time to time: "lost connection, send timeout"
pe1chl
Wed Dec 13, 2017 12:10 pm
I have described my efforts and I have problems as well, also in a configuration where different VLANs are in different bridges in the 6.40 version and I tried migration to 6.41RC.
For me it works just after the migration but it falls apart when I convert it to the 6.41 solution (all the VLANs in a single bridge, and with HW acceleration).
I went back to 6.40 and found I had issues there as well with HW acceleration, but only on switch2.
lemointernet
Wed Dec 13, 2017 5:34 pm
Any final version release date ?
planetcoop
Wed Dec 13, 2017 5:36 pm
Support,
I have found an issue with v6.41rc61 and DHCP. I have several networks and ip pools configured but have found that upgrading to the rc61 build the dhcp server is handing out DNS server that the ccr1036 is using. This is not the same list of DNS server client should use. I have test reverted to rc58 and 6.40.5 to correct the issue. Loading rc61 will recreate the issue.
Thank you,
Planetcoop
Samot
Wed Dec 13, 2017 6:21 pm
Support,
Thank you,
Planetcoop
So is this list of DNS servers configured in the DHCP Networks for this DHCP Server/Pool? I'm running a couple systems on 6.41rc61 and have DHCP Servers on two interfaces that assign DNS to the clients. I'm not having an issue with it.
RafGan
Wed Dec 13, 2017 10:12 pm
Support,
Thank you,
Planetcoop
See topic at link viewtopic.php?f=1&t=128454
alexjhart
Thu Dec 14, 2017 2:28 am
New bugs?
I believe I also have run into this behavior. I had two different routers (configured similarly) both have several (but not all) ports disappear (not in print or export) from the bridge on system reboot. Though after adding them back and rebooting again, they were in there.
For me, the ports in the first switch chip that I had configured remained (2 and 3) but those in the second went away (5-9) on a 3011. Not sure if that is helpful information for you Uldis?
planetcoop
Thu Dec 14, 2017 2:32 am
Support,
Thank you,
Planetcoop
yup, that is the issue....
kait
Thu Dec 14, 2017 5:17 pm
I have a router CCR1036 directly connected to a switch CRS226 via vlan trunk on bridge1 (with rstp) through sfpplus1 port. There is a IP device connected to ether1 access port on CRS226. WAN is ether8 port on CCR1036. I can do ping from both, CCR1036 and CRS226, to IP device.
I succesfully run L2TP/IPsec and OVPN services, both are working, but I can't ping from both to IP device when connected from VPN client. I tried to setup proxy-arp on bridge1, sfpplus1, vlan10 and ether8 interfaces, but nothing helped me to rich IP device from VPN client.
### CCR1036 ###
add name=bridge1 vlan-filtering=no
add bridge=bridge1 interface=sfpplus1
add bridge=bridge1 tagged=bridge1,sfpplus1 vlan-ids=10
/interface vlan
add interface=bridge1 vlan-id=10 name=vlan10
set bridge1 vlan-filtering=yes
### CRS226 ###
/interface ethernet switch ingress-vlan-translation
add ports=ether1 customer-vid=0 new-customer-vid=10 sa-learning=yes
/interface ethernet switch egress-vlan-tag
add tagged-ports=switch1-cpu,sfpplus1 vlan-id=10
add ports=switch1-cpu,sfpplus1,ether1 vlan-id=10 learn=yes
set drop-if-invalid-or-src-port-not-member-of-vlan-on-ports=ether1
/interface vlan
Where should be problem please? Running v6.41rc61
Pavel
idlemind
Thu Dec 14, 2017 8:31 pm
is proxy-arp on v6.41rc61 working? I have CCR1036 directly connected to CRS226. I have vlan trunk on bridge between them. On CRS226 I have acces port and connected device with IP, i can ping IP from router and switch.
I configured L2TP/IPsec and OVPN services, both are working, but I can't ping the device IP from VPN client. Where should be problem? I tried to setup proxy-arp on bridge, on vlan interfaces on router and also on switch, but nothing helped.
Pavel
While not directly answering your question. Please do not use overlapping IP space for your VPN. I know some of the wiki articles set it up that way. By changing to a non overlapping IP space it will just work, no Proxy-ARP magic needed.
kait
Thu Dec 14, 2017 8:42 pm
Pavel
Hi idlemind,
I modified my post to make it clearer. I use, for example: ppp 10.10.10.0/24, vlan10 192.168.10.0/24.
Pavel
kait
Fri Dec 15, 2017 11:18 am
### CCR1036 ###
/interface vlan
### CRS226 ###
/interface vlan
Pavel
My ppp subnet is, let's say, 10.10.10.0/24 and vlan10 subnet is 192.168.10.0/24.
ppp local: 10.10.10.1/24
ppp remote: 10.10.10.2/24
vlan10 on CCR1036: 192.168.10.1/24
IP device on access port on CRS226: 192.168.10.2/24
### ping from CCR1036 to IP device on CRS226 through vlan10 interface ###
[user@CCR1036] > ping 192.168.10.2 src-address=192.168.10.1
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 192.168.10.2                               56  64 0ms
    sent=1 received=1 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
### ping from CCR1036 to IP device on CRS226 through ppp local interface ###
[user@CCR1036] > ping 192.168.10.2 src-address=10.10.10.1
    0 192.168.10.2                                            timeout
    sent=1 received=0 packet-loss=100%
So I'm not surprised I can't ping from ppp remote 10.10.10.2 to IP device, when ping from ppp local to IP device is not working. Do I miss something?
strods
Fri Dec 15, 2017 1:55 pm
What's new in 6.41rc66 (2017-Dec-14 13:53):
Important note!!! Backup before upgrade!
RouterOS (v6.40rc36-rc40 and) v6.41rc1+ contains new bridge implementation that supports hardware offloading (hw-offload).
This update will convert all interface "master-port" configuration into new bridge configuration, and eliminate "master-port" option as such.
Bridge will handle all Layer2 forwarding and the use of switch-chip (hw-offload) will be automatically turned on based on appropriate conditions.
The rest of RouterOS Switch specific configuration remains untouched in usual menus for now.
Please, note that downgrading to previous RouterOS versions will not restore "master-port" configuration, so use backups to restore configuration on downgrade.
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
Changes since previous 6.41rc release:
!) routerboot - RouterBOOT version numbering system merged with RouterOS;
*) capsman - added possibility to downgrade CAP with upgrade command from CAPsMAN;
*) crs326 - improved transmit performance from SFP+ to Ethernet ports;
*) dhcp-server - added basic RADIUS accounting;
*) ike1 - disallow peer creation using base mode;
*) ike2 - added support for multiple split networks;
*) ike2 - do not allow to configure nat-traversal;
*) ipsec - improved hardware accelerated IPSec performance on 750Gr3;
*) ppp - fixed "change-mss" functionality when MSS option is missing on forwarded packets;
*) ppp - fixed L2TP and PPTP encryption negotiation process on configuration changes;
*) pppoe-client - properly re-establish MLPPP session when one of the lines stopped transmitting packets;
*) quickset - fixed LTE quickset mode APN field;
*) route - improved reliability on routing table update;
*) snmp - fixed bulk requests when non-repeaters are used;
*) wireless - added support for CHARGEABLE_USER_ID in EAP Accounting;
*) wireless - updated "UK 5.8 Fixed" and "Australia" regulatory domain information;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
Chupaka
Fri Dec 15, 2017 2:03 pm
Wow!.. What does it account?
msatter
Fri Dec 15, 2017 4:06 pm
Today I put rc66 on my 750Gr3, it was the first time I used this reiteration of 6.41RC.
After reboot I put bridge and ports (interfaces) because it was not done and my old config worked till the 750Gr3 crashed after about 3 minutes and lost his config. It went back to default config after a reset, because I could not connect to the 750Gr3 in any way.
Put backup back that I made with 6.40.5 and added again the bridge and ports and it crashed again after a few minutes. Went back to 6.40.5 and restored the backup so that was my adventure with the reiteration of 6.41.
I have a autosupout.rif file will e-mail that to support.
Grickos
Fri Dec 15, 2017 5:17 pm
DHCP server, DNS setings still does not work.
ErfanDL
Fri Dec 15, 2017 5:50 pm
What does this feature do?
andriys
Fri Dec 15, 2017 6:21 pm
Implements rfc4372, I guess.
Neovr
Fri Dec 15, 2017 10:07 pm
more info?
hapi
Sun Dec 17, 2017 12:07 am
v6.41rc61 and v6.41rc66
AP - RB921GS-5HPacD (a/n/ac)
CL - RB411+R52
in nstreme not connecting to ap. In NV2 is ok. Other RB SXT is connecting ok in nstreme.
RafGan
Sun Dec 17, 2017 1:41 am
In my case, DNS servers are both from dhcp server and client, at all hosts in networks.
MT, please revert back it. I have several networks and some of them use DNS parental control access to the internet. I must use nat redirects and access lists.
Zloy2452
Sun Dec 17, 2017 3:31 am
I have to stick with rc56 until DNS issue got fixed. Please, Mikrotik, we need a fix as soon as it possible!
strods
Mon Dec 18, 2017 8:29 am
If you are experiencing problems with DHCP on latest RouterOS version, then please do the following:
1) Run this command on router - "/system logging add topics=dhcp"
2) Renew DHCP client;
3) Generate supout file;
4) Send this file to support@mikrotik.com and provide problem description.
We are not being able to reproduce such problem between two RouterOS devices. If DHCP client is not receiving/adding DHCP parameters, then this must be something specific and in order to fix this we need to see this on an actual example.
RafGan
Mon Dec 18, 2017 10:57 am
Done, suppout file you have on e-mail, [Ticket#2017121822002736]
I have this problem on all my MT devices with rc61 and rc66.
onnoossendrijver
Mon Dec 18, 2017 11:05 am
Can you tell me more about this?
JimmyNyholm
Mon Dec 18, 2017 11:13 am
In this new bridge implementation what is Actually correct.
[admin@MikroTik] /interface ethernet switch port> print
Flags: I - invalid
# NAME SWITCH VLAN-MODE VLAN-HEADER DEFAULT-VLAN-ID INGRESS-RATE EGRESS-RATE
0 sfp-sfpplus2 switch1 secure leave-as-is 1 5.0Mbps 15.0Mbps
1 sfp-sfpplus3 switch1 secure leave-as-is 1 5.0Mbps 15.0Mbps
2 sfp-sfpplus4 switch1 secure leave-as-is 1 5.0Mbps 15.0Mbps
3 sfp-sfpplus5 switch1 secure leave-as-is 1 5.0Mbps 15.0Mbps
4 sfp-sfpplus6 switch1 secure leave-as-is 1 5.0Mbps 15.0Mbps
5 sfp-sfpplus7 switch1 secure leave-as-is 1 5.0Mbps 15.0Mbps
6 sfp-sfpplus8 switch1 secure leave-as-is 1 5.0Mbps 15.0Mbps
7 sfp-sfpplus9 switch1 secure leave-as-is 1 5.0Mbps 15.0Mbps
8 sfp-sfpplus10 switch1 secure leave-as-is 1 5.0Mbps 15.0Mbps
9 sfp-sfpplus11 switch1 secure leave-as-is 1 5.0Mbps 15.0Mbps
10 sfp-sfpplus12 switch1 secure leave-as-is 1 5.0Mbps 15.0Mbps
11 sfp-sfpplus13 switch1 secure leave-as-is 1 5.0Mbps 15.0Mbps
12 sfp-sfpplus14 switch1 secure leave-as-is 1 5.0Mbps 15.0Mbps
13 sfp-sfpplus15 switch1 secure leave-as-is 1 5.0Mbps 15.0Mbps
14 sfp-sfpplus16 switch1 secure leave-as-is 1 5.0Mbps 15.0Mbps
15 ether1 switch1 secure leave-as-is 1
16 sfp-sfpplus1 switch1 secure leave-as-is 1
17 switch1-cpu switch1 secure leave-as-is 1
[admin@MikroTik] /interface ethernet switch port> /interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
# INTERFACE BRIDGE HW PVID PRIORITY PATH-COST INTERNAL-PATH-COST HORIZON
0 I H sfp-sfpplus2 bridge1 yes 64 0x80 10 10 none
1 I H sfp-sfpplus1 bridge1 yes 64 0x80 10 10 none
2 I H sfp-sfpplus3 bridge1 yes 64 0x80 10 10 none
3 I H sfp-sfpplus4 bridge1 yes 64 0x80 10 10 none
4 I H sfp-sfpplus5 bridge1 yes 64 0x80 10 10 none
5 I H sfp-sfpplus6 bridge1 yes 64 0x80 10 10 none
6 I H sfp-sfpplus7 bridge1 yes 64 0x80 10 10 none
7 I H sfp-sfpplus8 bridge1 yes 64 0x80 10 10 none
8 I H sfp-sfpplus9 bridge1 yes 64 0x80 10 10 none
9 I H sfp-sfpplus10 bridge1 yes 64 0x80 10 10 none
10 I H sfp-sfpplus11 bridge1 yes 64 0x80 10 10 none
11 I H sfp-sfpplus12 bridge1 yes 64 0x80 10 10 none
12 I H sfp-sfpplus13 bridge1 yes 64 0x80 10 10 none
13 I H sfp-sfpplus14 bridge1 yes 64 0x80 10 10 none
14 I H sfp-sfpplus15 bridge1 yes 64 0x80 10 10 none
15 I H sfp-sfpplus16 bridge1 yes 64 0x80 10 10 none
Are all features that are not reflected to switch menu to be considered overridden by bridge and feature that bridge don't have to be considered functioning in switch menu.... The current state is very unintuitive please release some clean up so we may have a look and feel about your release of this bridge functions. I've read the updated wiki and even though it have section with pre and post 41rc switch menu is used for all nice features on the switch chip.
In the above setting pvid on /interface/bridge/port is not setting it hardware wise at /interface/ethernet/switch/port so my real question is: Are there any corner cases when ingress frames will be assigned vlan 1?
Another observation setting /interface/bride/port acceptable-frame-types is not reflected back on /interface/ethernet/switch/port: Do I need to set the switch port counterpart setting to be on the safe side in corner cases as well.
Function wise the new implementation seems to work good but the system as a whole is not ready because I as user and admin can't read the manual nor see the intention in the currently available release candidate. Do you understand the confusion?
PS: Output is from a CRS317-1G-16S+ Hence my questioning running RouterOs on a switch...
Grickos
Mon Dec 18, 2017 6:33 pm
I only send settings and logs.
It is easy to reproduce the problem because it is so behaving on all router boards.
+++++++++++  DHCP server  +++++++++++++
/ip dhcp-server network> print
Flags: D - dynamic
 #   ADDRESS            GATEWAY         DNS-SERVER      WINS-SERVER     DOMAIN
 0   192.168.0.0/24     192.168.0.1     192.168.0.1
 1   192.168.30.0/24    192.168.30.1    192.168.30.1
 2   192.168.90.0/24    192.168.90.1    192.168.90.1
 /ip dns> print
                      servers: 213.191.128.8,8.8.8.8,4.2.2.2
              dynamic-servers:
        allow-remote-requests: yes
          max-udp-packet-size: 4096
         query-server-timeout: 2s
          query-total-timeout: 10s
       max-concurrent-queries: 100
  max-concurrent-tcp-sessions: 20
                   cache-size: 2048KiB
                cache-max-ttl: 1w
                   cache-used: 168KiB
+++++++++++++++++   DHCP Client  ++++++++++++++++
/ip dhcp-client> print detail
 0   interface=ether1 add-default-route=yes default-route-distance=0 use-peer-dns=yes use-peer-ntp=yes dhcp-options=hostname,clientid status=bound
     address=192.168.0.5/24 gateway=192.168.0.1 dhcp-server=192.168.0.1 primary-dns=192.168.0.1 secondary-dns=213.191.128.8 primary-ntp=161.53.123.5
     secondary-ntp=66.199.22.67 expires-after=23h51m19s
/ip dns> print
                      servers:
              dynamic-servers: 192.168.0.1,213.191.128.8,8.8.8.8,4.2.2.2
        allow-remote-requests: no
                   cache-size: 2048KiB
                cache-max-ttl: 1w
                   cache-used: 9KiB
+++++++++++++++Log Debug++++++++++++
17:04:11 dhcp,debug,state dhcp-client on ether1 entering <renewing...> state
17:04:11 dhcp,debug,packet dhcp-client on ether1 sending request with id 2667306647 to 192.168.0.1
17:04:11 dhcp,debug,packet     ciaddr = 192.168.0.5
17:04:11 dhcp,debug,packet     chaddr = 6C:3B:6B:00:00:01
17:04:11 dhcp,debug,packet     Msg-Type = request
17:04:11 dhcp,debug,packet     Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
17:04:11 dhcp,debug,packet     Host-Name = "name"
17:04:11 dhcp,debug,packet     Client-Id = 01-6C-3B-6B-00:00:01
17:04:11 dhcp,debug,packet dhcp-client on ether1 received ack with id 2667306647 from 192.168.0.1
17:04:11 dhcp,debug,packet     yiaddr = 192.168.0.5
17:04:11 dhcp,debug,packet     siaddr = 192.168.0.1
17:04:11 dhcp,debug,packet     Msg-Type = ack
17:04:11 dhcp,debug,packet     Server-Id = 192.168.0.1
17:04:11 dhcp,debug,packet     Address-Time = 86400
17:04:11 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
17:04:11 dhcp,debug,packet     Router = 192.168.0.1
17:04:11 dhcp,debug,packet     Domain-Server = 192.168.0.1,213.191.128.8,8.8.8.8,4.2.2.2
17:04:11 dhcp,debug,packet     NTP-Server = 161.53.123.5,66.199.22.67
17:04:11 dhcp,debug,state dhcp-client on ether1 entering <bound> state
17:08:34 dhcp,debug,state dhcp-client on ether1 entering <renewing...> state
17:08:34 dhcp,debug,packet dhcp-client on ether1 sending request with id 2667306647 to 192.168.0.1
17:08:34 dhcp,debug,packet     ciaddr = 192.168.0.5
17:08:34 dhcp,debug,packet     chaddr = 6C:3B:6B:00:00:01
17:08:34 dhcp,debug,packet     Msg-Type = request
17:08:34 dhcp,debug,packet     Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
17:08:34 dhcp,debug,packet     Host-Name = "name"
17:08:34 dhcp,debug,packet     Client-Id = 01-6C-3B-6B-00-00-01
17:08:34 dhcp,debug,packet dhcp-client on ether1 received ack with id 2667306647 from 192.168.0.1
17:08:34 dhcp,debug,packet     yiaddr = 192.168.0.5
17:08:34 dhcp,debug,packet     siaddr = 192.168.0.1
17:08:34 dhcp,debug,packet     Msg-Type = ack
17:08:34 dhcp,debug,packet     Server-Id = 192.168.0.1
17:08:34 dhcp,debug,packet     Address-Time = 86400
17:08:34 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
17:08:34 dhcp,debug,packet     Router = 192.168.0.1
17:08:34 dhcp,debug,packet     Domain-Server = 192.168.0.1,213.191.128.8,8.8.8.8,4.2.2.2
17:08:34 dhcp,debug,packet     NTP-Server = 161.53.123.5,66.199.22.67
17:08:34 dhcp,debug,state dhcp-client on ether1 entering <bound> state
msatter
Mon Dec 18, 2017 8:03 pm
I tried to run this version on my 750Gr3 but became totally unreachable after a few minutes.
When I put a heavy load on IPSEC by using several connections the load is not distributed and the first core goes to 100% and the fourth sometimes follows. I hoped this change would distribute the load better.
RafGan
Mon Dec 18, 2017 8:19 pm
Flags: D - dynamic
 /ip dns> print
              dynamic-servers:
                   cache-size: 2048KiB
                cache-max-ttl: 1w
                   cache-used: 168KiB
/ip dns> print
                      servers:
                   cache-size: 2048KiB
                cache-max-ttl: 1w
                   cache-used: 9KiB
Don't waste your time. I 've got an answer from MT today:
Is DHCP client receiving DNS server specified under DHCP server network settings and DNS servers used by router itself?
If this is correct, then this is how RouterOS works. We will in future add option which will allow to enable/disable such functionality.
Best regards,
Martins S.
For me it is very unusable and reckless. I will revert back to rc56 until option which will allow to enable/disable such functionality will be implemented.
Zloy2452
Mon Dec 18, 2017 8:44 pm
RafGan, thank you for posting this! I have mailed Mikrotik about this issue today, but have not received any answer from them by now.
If so, I will not upgrade from rc56, until they add an option to disable this new "mega-useful" feature. It's very pity that they have broken a thing, which had been working perfect for ages.
ZeroByte
Mon Dec 18, 2017 9:38 pm
Best regards,
Martins S.
They're just trying to achieve feature parity with the RADNSS "functionality" in IPv6. :roll:
RafGan
Mon Dec 18, 2017 11:06 pm
Maybe, but better is the enemy of good. Things, that works great a lot of time, should not be changed at the same time of major implements in one version of OS. DHCP server is a certain service in network. Also, infos for users (administrators) are very important.
strods
Tue Dec 19, 2017 10:00 am
At the moment DHCP DNS server problem reports in this post has been mixed up. There are reports that DNS servers are not assigned, too many servers are assigned and there is reference to DNS server assignment process discussed in support ticket to DHCP clients in general.
Explanation is this:
1) In the past and now (also before 6.41rc), if DHCP server network configuration does not contain DNS server settings, then same DNS servers which are used by router are assigned also for DHCP clients. This is the behavior for which we will consider implementing enable/disable functionality;
2) For DHCP clients only DNS servers provided in DHCP server network configuration must be assigned (at the moment this is broken and we will try to fix this).
If there is an actual case where DNS server is configured on DHCP server network settings but suddenly is not assigned for DHCP client when server uses 6.41rc version, then please report to support@mikrotik.com.
emils
Forum Veteran
Forum Veteran
Tue Dec 19, 2017 11:18 am
The fix addresses exactly this issue. Were you able to recover the router after the loss of reachability? Are you able to reproduce the issue somehow?
more info?
There were some rare incidents that caused routing table update process to crash and start all over again. This fixes the issue.
msatter
Tue Dec 19, 2017 11:47 am
My ticket number is: 2017121522004034 and I sent in an autosupport and support file
It crashed twice and a third time is expected when I update again from 6.40.5.
The router restarts and no normal way to connect. Even a notebook connected directly does not see a network.
eworm
Tue Dec 19, 2017 2:30 pm
Successfully updated a CRS109-8G-1S-2HnD to version 6.41rc66, then installed the firmware update to version 6.41rc65 and rebooted. Now the device is stuck at 'staring services', which is displayed on the lcd display. No link on interfaces...
Anybody seen this? Is there any chance to recover without reset?
kometchtech
Tue Dec 19, 2017 2:37 pm
If you can make a serial connection, you can check the boot process ...
Perhaps, there is no way to recover only by netinstall.
eworm
Tue Dec 19, 2017 3:05 pm
I connected a serial cable and messages are shown at boot time:
RouterBOOT booter 6.41rc65
CRS109-8G-1S-2HnD
CPU frequency: 600 MHz
 Memory speed: 200 MHz
  Memory size: 128 MiB
    NAND size: 128 MiB
Press any key within 2 seconds to enter setup..
loading kernel... OK
setting up elf image... OK
jumping to kernel code
Starting...
Starting services...
Followed by a login prompt:
MikroTik 6.41rc66 (testing)
e-mt-01 Login:
I can log in but most commands just hang.
CPU is at 100% with 99.5% to 100% for management.
pe1chl
Tue Dec 19, 2017 4:19 pm
From what earlier version did you upgrade? 6.41RC too or before?
It looks like it is time for netinstall and restore backup.
eworm
Tue Dec 19, 2017 5:13 pm
The device ran nearly every rc release from 6.41 series.
Done. :D
Let's hope this does not happen more often.
pe1chl
Tue Dec 19, 2017 5:26 pm
When it has more than 16MB flash (which unfortunately is quite common lately) you can partition the flash and
keep the previous version in the other partition. It is then easier to recover from such mishaps.
msatter
Tue Dec 19, 2017 9:14 pm
I hope Mikrotik won't rush 6.41 to be there before the end of the year and 2018 seems to be a good bridge year to the last digit of this year. :wink:
ZeroByte
Thu Dec 21, 2017 5:40 pm
The RADIUS accounting packets for DHCP sessions do not include the User-Name attribute, which should be set as the MAC address of the client, just as it had been sent in the authentication request.
Freeradius also logs warnings about this because the User-Name is part of its hashing for generating unique-session-id
JimmyNyholm
Thu Dec 21, 2017 8:11 pm
CRS317-1G-16S+RM is powered by a next generation switching chip, giving you wire speed performance for all sixteen 10GbE ports with any Ethernet frame size. New features such as hardware-based Spanning Tree Protocol and Link Aggregation (LACP) provide enhanced protection and true professional performance for your demanding network.
When can we se this hardware based LACP in Router Os?
If it's already there and I am a fool not to have found it then please tell me how to?
eworm
Thu Dec 21, 2017 9:01 pm
Looks like demo Routerboards find final version 6.41... Is the release being prepare right now?
freemannnn
Forum Veteran
Forum Veteran
Thu Dec 21, 2017 9:12 pm
lol i didnt know this site all these years. thanx.
6.41...christmas present. if yes...nice
honzam
Thu Dec 21, 2017 11:00 pm
And demo3 http://demo3.mt.lv/webfig/#System:Packa ... or_Updates
skuykend
Fri Dec 22, 2017 1:16 am
And no mention of the bridge update!
mducharme
Trainer
Trainer
Fri Dec 22, 2017 4:30 am
The list of changes there is from some older version, it's not showing the correct change list.
strods
Fri Dec 22, 2017 3:00 pm
Version 6.41 has been released:
viewtopic.php?f=21&t=128915
Users browsing this forum: No registered users and 57 guests
