follow the instruction. you haven't chosen the frequency and data-date.i could Not to choose Radio
Tap the "Eye" icon to hide the calculator.Cannot access the map behind the calculator to set the locations in Mozilla on android phone. The speed slider should allow only possible values for the set pair of devices in selected band.
Select the data rate first (top to bottom). It will then read the values from the selected data rate.Maybe I'm using this wrong, but it appears to me that if I select a product the calculator fills in the maximum power of that product, and then doesn't let me edit that figure if the maximum power is more than I can use legally in my area.
UPDATE: It actually does this now e.g:Currently the map appears to start in Riga (not sure why ?? hehe ) but it would be nice to have it default to the users default location ? Or allow passing start point via URL so we could add a link on our website and have it default to our own country ?
Out of missile range we hopeStart point - Well I guess I now live in Wellington - where ever that is or what country it is in.
The elevation data is not so precise that a meter would matter. Don't you see that location in the satellite layer ?using coordinates would be easier than moving map markers to positions
+1 for change default location to user current locationCurrently the map appears to start in Riga (not sure why ?? hehe ) but it would be nice to have it default to the users default location ? Or allow passing start point via URL so we could add a link on our website and have it default to our own country ?
https://developers.google.com/maps/docu ... eolocation+1 for change default location to user current locationCurrently the map appears to start in Riga (not sure why ?? hehe ) but it would be nice to have it default to the users default location ? Or allow passing start point via URL so we could add a link on our website and have it default to our own country ?
It is!Cool!
But look like Earth buldge is not taken into account. Like the Earth is flat.
It surprising important for links (10 km and more)
This only finds your current position (point). There are two markers though. We have to place them in random positions then? Isn't it easier just to place markers where you want them with right-click?https://developers.google.com/maps/docu ... eolocation+1 for change default location to user current locationCurrently the map appears to start in Riga (not sure why ?? hehe ) but it would be nice to have it default to the users default location ? Or allow passing start point via URL so we could add a link on our website and have it default to our own country ?
Hi Normis,This only finds your current position (point). There are two markers though. We have to place them in random positions then? Isn't it easier just to place markers where you want them with right-click?https://developers.google.com/maps/docu ... eolocation+1 for change default location to user current locationCurrently the map appears to start in Riga (not sure why ?? hehe ) but it would be nice to have it default to the users default location ? Or allow passing start point via URL so we could add a link on our website and have it default to our own country ?
Should not be possible, did you look at the elevation image in top-right corner?Be aware it give reliable links through mountains...
What kind of speed did you choose? I have it working like this:Maybe a explanation when "Link status: Link impossible"
Because I can't figure out how in an open field, 2 LHG HP5's would not be able to setup a connection over a distance of: 0.7 Km (0.43 miles)
https://mikrotik.com/calculator/#map:52 ... 1011199952
What am I doing wrong?
A copy link button in the "Specifications and results" windows, the button on the map gave me a link, but only after the 4th try(?)
Clear the field TX/RX Sensitivity move the existing numbers over when you type a - (it does that when you type a number but not when you type a -)
Browser: Chrome 62.0.3202.18
+1, height is necessary for this to be useful, have no idea what your definition of "high antenna tower" is"Link is possible but high antenna tower is required" Please add AP and CPE height option! Would love to use but I find AirLink is way better since I can edit the height of both sides!
Sure, if you know how to use it, it is very good. This tool is more for quickly selecting a suitable product. Simple.i will still stick to Radio Mobile.... it's highly accurate!
you have posted this in the wrong thread... please post this in the Wireless section.when i login hotspot mikrotik and off my laptop and the return back isee another accont login in my laptop that is login and i can use the internet
Like that another person uses my laptopwhy?
Satellite is always better than street map, since you can see the building or the terrain. Did you enable the satellite view?hi normis...
yes the tool by Mikrotik is good but i found the maps a bit unconvincing. also could not enter the Lat and Lon directly.
any chance of using Google Maps?
Actually no, it will be less precise, because the calculator uses the data from the map, to calculate the link. If your coordinates may be more accurate to the real life location, but in this case, it is more important to match the point with the map, not with the real life. This is because terrain data will be taken from the map.Yes... I enabled Satellite View.
but putting in direct Lat / Lon does help in being more precise.
as i said the Openstreet maps do not have much of details for my area as Google Maps.
Google Maps is showing everything in great detail.
+1Normis
It will be nice and useful , if you add two filed for height of towers and draw fresnel zone . some thing like this :
+1Normis
+1+1+1Normis
+10000000000000Normis
