WMM is always on if you enable N/AC wireless modes.Looking at the wireless interfaces of my CAPSMAN enabled "WAP AC" devices: "WMM Enabled" is not enabled?
Reason for asking: I have users complaining about bad battery time when they are connected to our Mikrotik access points, e.g. After 1/2 day the battery on an Galaxy S6 is down when he´s connceted with Mikrotik. While he´s at home, the battery runs for almost 2 days while it is connected to that local wlan access point.
No downgrade. Clean router after netinstall 6.40.3 has same problem. Routerboard BIOS version has been updated, but without positive result.Did DHCP client problem appeared after downgrade from 6.41rc?
We did install 6.40.3 on hEX lite router, did reset configuration and ran "/system led print". Whole configuration was still there.
- On a CAPSMAN enabled WAP AC:WMM is always on if you enable N/AC wireless modes.
add admin-mac=[/interface ethernet get 1 mac-address] auto-mac=no name=bridge-local
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no distance=indoors \
frequency=auto mode=ap-bridge rx-chains=0,1 tx-chains=0,1 adaptive-noise-immunity=ap-and-client-mode \
wireless-protocol=802.11 wmm-support=enabled
set [ find default-name=ether3 ] master-port=ether2
set [ find default-name=ether4 ] master-port=ether2
set [ find default-name=ether5 ] master-port=ether2
add name=dhcp ranges=192.168.88.50-192.168.88.250
add address-pool=dhcp disabled=no interface=bridge-local name=default lease-time=1d
add bridge=bridge-local interface=ether2
add bridge=bridge-local interface=wlan1
add address=192.168.88.1/24 comment="default configuration" interface=ether2 network=192.168.88.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.88.0/24 comment="default configuration" gateway=192.168.88.1
/ip dns static
add address=192.168.88.1 name=router
add action=fasttrack-connection chain=forward connection-state=established,related
add chain=input in-interface=ether1 protocol=udp dst-port=53 action=drop
add chain=input in-interface=ether1 protocol=tcp dst-port=53 action=drop
add chain=forward protocol=udp dst-port=53 out-interface=!ether1 action=drop
add chain=forward protocol=tcp dst-port=53 out-interface=!ether1 action=drop
add chain=input comment="default configuration" connection-state=established,related
add chain=input comment="default configuration" protocol=icmp
add action=drop chain=input comment="default configuration" in-interface=ether1
add chain=forward comment="default configuration" connection-state=established,related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=drop chain=forward comment="default configuration" \
connection-nat-state=!dstnat connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment="default configuration" out-interface=ether1
/tool bandwidth-server
set enabled=no
BootROM 1.41
Booting from SPI flash
BootROM: Image checksum verification PASSED
RouterBOOT booter 3.41
CRS326-24G-2S+
CPU frequency: 800 MHz
Memory size: 512 MiB
Storage size: 16 MiB
..[CUT]..
your choice: i - board info
Board Info:
Board type: CRS326-24G-2S+
Serial number: 763C075929FE
Firmware version: 3.41
Build time: 2017-08-09 09:58:46
eth1 MAC address: 64:D1:54:C6:C4:F0
..[CUT]..
your choice: t - do memory testing
This may take some time, ESC aborts testing
Fill memory with addresses:
Filling memory...
Error in address=0x016FFEEC, W=0x016FFEEC R=0x01009C5C X=0x006F62B0
Error in address=0x016FFEF0, W=0x016FFEF0 R=0x01002C04 X=0x006FD2F4
Error in address=0x016FFEF8, W=0x016FFEF8 R=0x20000000 X=0x216FFEF8
On CRS326-24G-2S+ / ros 6.40.3 and RouterBOOT booter 3.41, the memory test fail (tested on 2 different board); I guess the test is broken otherwise I've two defecting board memory.
## choice "t" (do memory testing)
(see details:)
Code: Select allBootROM 1.41 Booting from SPI flash BootROM: Image checksum verification PASSED RouterBOOT booter 3.41 CRS326-24G-2S+ CPU frequency: 800 MHz Memory size: 512 MiB Storage size: 16 MiB ..[CUT].. your choice: i - board info Board Info: Board type: CRS326-24G-2S+ Serial number: 763C075929FE Firmware version: 3.41 CPU frequency: 800 MHz Memory size: 512 MiB Storage size: 16 MiB Build time: 2017-08-09 09:58:46 eth1 MAC address: 64:D1:54:C6:C4:F0 ..[CUT].. your choice: t - do memory testing This may take some time, ESC aborts testing Fill memory with addresses: Filling memory... Error in address=0x016FFEEC, W=0x016FFEEC R=0x01009C5C X=0x006F62B0 Error in address=0x016FFEF0, W=0x016FFEF0 R=0x01002C04 X=0x006FD2F4 Error in address=0x016FFEF8, W=0x016FFEF8 R=0x20000000 X=0x216FFEF8
Ok, one of these CRS326 will stay on my test lab so I'll be able to test/stress it and we'll see.Hi, we found this test do not work correctly and most likely device memory works without errors. It will be fixed in next versions.On CRS326-24G-2S+ / ros 6.40.3 and RouterBOOT booter 3.41, the memory test fail (tested on 2 different board); I guess the test is broken otherwise I've two defecting board memory.
..[CUT]..
Yes. I see it tries to connect to the strongest 2 APs but did not succeed as I blocked it with access-lists at the AP. It does not consider the 3. AP. I have situations where I want to route CPEs to APs which do not have the strongest signal. This worked up to 6.35.4. So downgraded the cpe and it reconnects.ste, enabled wireless,debug logging and check the logs. Wireless station will always try to connect to the strongest signal AP unless you have some specific Connect-list rules. Also note that we have station-roaming setting in newer versions.
Hi, sorry about hijacking this thread, I have similar issue, so I removed from backup script global enviroment and used full file name:JohnTRIVOLTA - This problem is already fixed in 6.41rc version. However, I recommend to fix the script. E-mail tool does not have a full file name in your script so if there will be two files with similar names, then you will still get an error. For example, now you specify file=test, but actual file name is test.backup. If you will have a file test1.backup and test2.backup, then script will fail anyway. Use full name on e-mail command file=test.backup.
I have the same issue rb951ui-2hnd + 4x 802.11n smartphoneStill hoping You will solve Mikrotik 2.4G Band and Qualcomm chip based phones connection issue. Mikrotik transmission rate connects maximum 54Mbps, G-standard. Rx rate connects normally, as fast as phone supports. Mikrotik connects to other brand cards, samsung phones i.e. normally, but not qualcomm chip phones. These phones connects to other routers at full speed. Even then other routers uses same chips. Mikrotik wifi chip configuration need to be tuned. Tested on QCA9531, AR9344.
Somewhat related to your post ...A wireless CPE still consideres only the strongest 2 APs with the same SSID for connection. This changed after 6.35.4. So if I block a CPE with access-list to connect to 2 APs it does not connect to the third. Not mentioned in the change log so I guess this is a bug.
Could it be, that you accidentally use of fasttrack?I installed 6.40.3 over the weekend and seem to have a problem.
I use passthrough firewall rules to track Bytes used by IP addresses in an Address List.
Before the update I was using about 2 GB per day, but since the upgrade that has fallen to approx 10MB. I know I am using more!
Has anyone noticed something similar.
I have this problem too with MediaTek Helio X10 MT6795, TX rate max 54, RX 72 or 150 with 40mhzStill hoping You will solve Mikrotik 2.4G Band and Qualcomm chip based phones connection issue. Mikrotik transmission rate connects maximum 54Mbps, G-standard. Rx rate connects normally, as fast as phone supports. Mikrotik connects to other brand cards, samsung phones i.e. normally, but not qualcomm chip phones. These phones connects to other routers at full speed. Even then other routers uses same chips. Mikrotik wifi chip configuration need to be tuned. Tested on QCA9531, AR9344.
I want to get a better understanding of the problem you are experiencing.I have this problem too with MediaTek Helio X10 MT6795, TX rate max 54, RX 72 or 150 with 40mhzStill hoping You will solve Mikrotik 2.4G Band and Qualcomm chip based phones connection issue. Mikrotik transmission rate connects maximum 54Mbps, G-standard. Rx rate connects normally, as fast as phone supports. Mikrotik connects to other brand cards, samsung phones i.e. normally, but not qualcomm chip phones. These phones connects to other routers at full speed. Even then other routers uses same chips. Mikrotik wifi chip configuration need to be tuned. Tested on QCA9531, AR9344.
May I ask about more details?Changelog:
lte - improved reliability of USB LTE modems;
I have this problem too and it is very easy to understand...I want to get a better understanding of the problem you are experiencing.I have this problem too with MediaTek Helio X10 MT6795, TX rate max 54, RX 72 or 150 with 40mhzStill hoping You will solve Mikrotik 2.4G Band and Qualcomm chip based phones connection issue. Mikrotik transmission rate connects maximum 54Mbps, G-standard. Rx rate connects normally, as fast as phone supports. Mikrotik connects to other brand cards, samsung phones i.e. normally, but not qualcomm chip phones. These phones connects to other routers at full speed. Even then other routers uses same chips. Mikrotik wifi chip configuration need to be tuned. Tested on QCA9531, AR9344.
Question - Is the problem (to you) that you can not connect up a client device (that uses a Qualcomm chip) to a Mikrotik AP ?
If then is the issue, does it appear the problem is the wireless connection -or- the device does not get an IP address after the connection ?
Some things to try re the wireless:
Channel Width: 20/40MHz Ce
Band: 2GHz-B-G-N (or even better if you do not have old devices 2GHz G-N)
Wireless Protocol: 802.11
Frequency: Is the frequency used dark in the drop-down list of frequencies ?
Data Rates: default
Advanced: Distance: indoors
Advanced: Hw Retries: 15
Advanced: Preamble Mode: both
Advanced: Disconnect Timeout: 00:00:15
Advanced: On Fail Retry Time: 1.00
DHCP server: Authorative: after 2s delay
Also - try changing your security profile: to WPA-PSK -and-also- WPA2-PSK (use same key for both).
AP access-list (nothing in the access-list)
If anything here works/helps - please post the results.
North Idaho Tom Jones
00:00:00:00:00:00 are just incomplete entries, there was no ARP reply received from them (no letter 'C' in Flags in WinBox)After update to 6.40.3 some device disappeared from the network and ARP is seen IP : 00:00:00:00:00
maybe I missed something?
После обновления на 6.40.3 некоторые устройства пропали из сети и в ARP видны как IP:00:00:00:00
Может это не глюк, а это я чего то не знаю?
Your EoIP traffic should normally be catched by IPsec policy and be blocked until phase 2 comes up. If you are behind NAT and have to use some "magic", try simply blocking the unencrypted EoIP traffic using firewall.When EoIP tunnel (using IPs of LAN interfaces in both sites as Local and Remote address on both sides) is created before the IPsec tunnel, then the encapsulated traffic of EoIP tunnel is not processed through IPsec Policies and sent to WAN interface (and there blocked by firewall output chain of course, because the source IP is private address).
Android energy saving, to me is the same, except to 802.11ac which is around of 97~433 Mbps.There is no way to change it - All android smartphones with 802 N use only RX Rate 54 Mbps and I don't know why???
