To Normis: The CE certification is done according to CE ETSI 302 567 or ETSI 300 550 ? For fixed outdoor installations it must be according to ETSI 300 550 ...Is it really legal to use it in all countries in Europe ? According to the "Decision 2006/771/EC on harmonisation of the radio spectrum for use by short-range devices" fixed outdoor installations are excluded (page 18 - http://eur-lex.europa.eu/legal-content/ ... 52&from=EN).In Europe, the EIRP is the only value that needs to be known, and this device does not exceed 40dB maximum EIRP, therefore it is valid for use in the EU and has all the FCC/CE certifications.
Pls provide us link to the CE certification !
Thank you.
Haward
Thanks normis, that's sounds good.1. The CPU is more than capable. Without the 1Gbit port limitation, speed would be greater. The tests are done over the link, not from wireless-to-wireless.
Yes! You just remove a gigabit cable, plug these devices in place, do not even configure them - they will link automatically. Just point them roughly at one another and continue using your network just like before, just without that cable.Hi Normis,
I may have missed it, but is it possible at all if the RBwAPG-60ad kit can be simply deployed without any further configuration on a non-MikroTik router?
For example, plugging one unit to a LAN port of any router, then link wirelessly with the remaining unit as IF a continuous Ethernet cable is plugged into that LAN port instead.
If it is, I believe, MikroTik has a potential winning product. Kinda an 'alternative Gigabit Ethernet cable'.
Thank you.
Currently no information. This is the wAP60G announcement newsletter. You will have to wait until one of the future announcement newsletters.lots of people didn't read all the posts :/
@normis, can you share when the LHG60 will be released? Do you have specs on it's range? Maybe a chart of range vs throughput and MSRP?
60Ghz is great. It's extremely predictable. unlike 5Ghz which can feel a bit like black magic and only season magicians can make accurate predictions, 60Ghz really is ( can you see it? is it in range? then here are the numbers ______ ), and zero interference.
To Normis: Does Mikrotik plan re-certification to ETSI 300 550 ? For me fixed outdoor usage is essential ! Do you plan similar device for 80GHz band ?To Sovking: You are probably wrong. If certified according to ETSI 302 567 as wideband data transmission device, fixed outdoor installations are excluded (see page 18 - http://eur-lex.europa.eu/legal-content/ ... 52&from=EN). If certified according to ETSI 300 550 as non-specific short-range device, no limitation for outdoor usage.
To Normis: Is re-certification according to ETSI 300 550 as non-specific short-range device possible ? What would be maximal distance (speed 1 Gbit full-duplex) with max. 20dB EIRP ?
Will/are they certified for Australia?Please contact your favourite distributor and place an order, they will be able to allocate a unit as soon as they receive their stock. They are already placing orders now.
The product has FCC/CE/IC certification.Will/are they certified for Australia?
Chipset limitation.why only 3, not 4 channels
It will not pass certification anymore. Regulatory limitation.any chance it will support channels narrower than 2 GHz
You mean to potentially increase range? It most likely would work with a dish, although no guarantees.- what is the antenna beam-width, would it work to mount it in focus of a satellite dish "LDF 60'?
There are no restrictions in the USA or other regions. Only a few countries in the EU have stricter rules.Is the outdoor restriction for fixed installations valid only in Europe ? (In the USA no restriction ?)
Please normis, could you be more specific ? I'm in EU/Italy and this information would be usefull (also for other EU citizens)...[CUT].. Only a few countries in the EU have stricter rules.
You need to study your legislation (In Italy). For example, in Czech Republic for 60Ghz band - fixed installations are not allowedPlease normis, could you be more specific ? I'm in EU/Italy and this information would be usefull (also for other EU citizens)...[CUT].. Only a few countries in the EU have stricter rules.
Thank you.
Ok, thank you.I suggest checking with your local authorities. There are new laws coming soon, some countries have already implemented them. For example check the left map on page 11:
http://www.etsi.org/images/files/ETSIWh ... 150629.pdf
You are absolutely right, I'm quite a newbie in outdoor wireless stuff. We have another problem here: in Italy it's not that easy to undestand what you can really do (overcomplicated/obscure legislation, information sources lacks).You need to study your legislation (In Italy). For example, in Czech Republic for 60Ghz band - fixed installations are not allowed
probably not, and even if it works it will poorly perform (fraction of the nominal speed) and it will be unreliable IMHOI'm curious, does this work on 360 meters distance?
Anyway ..thank you.
Would the new S+RJ10 establish 10Gbps connection over 50 meters cat5e cable? My cables are in walls of my home and can not be upgraded.Indeed!!! Just to be sure - MT didn't you forget to add one digit ("1", "2" or even "3") in front of S+RJ10 "$65" price??? I got pair 10G-only modules for almost $700 few months ago, and these are 6-speed...Wow some awesome new products
The S+RJ10 SFP module is pretty interesting for the price.I remember buying a ProLabs one , for about 10 times the price last year.
According to the spec. sheet it probably will not work.Would the new S+RJ10 establish 10Gbps connection over 50 meters cat5e cable? My cables are in walls of my home and can not be upgraded.
Thank you.According to the spec. sheet it probably will not work.Would the new S+RJ10 establish 10Gbps connection over 50 meters cat5e cable? My cables are in walls of my home and can not be upgraded.
https://i.mt.lv/routerboard/files/sfp_s ... 151033.pdf
How short link? W60G is up to 100m. (Without reserve up to 130m)W60G
there is no option to adjust txpower? On shortlink we can't get higher than MCS4.
25mHow short link? W60G is up to 100m. (Without reserve up to 130m)W60G
The WAP60 is meant for 100m max. How did you connect it to a dish?Hi. Sory bad english.
This day install wap60 link 1.1 km. Distance. Wap60 mount 45 cm parabolic dish antenna. My signal min. 75 maks. 85 but not connected. Status connect and notconnect connect and notconnect. What problem. ? Wap60 software distance limitation or ack timing problem ?
YesWould like to know if any of below are in the pipeline :
- CAP AC
The devices are designed and advertised for a specific purpose, like it says on the box, they work at Gigabit speeds over 100m long distances.Normis: we have bought a couple of RBwAPG-60ad.
The interface of this products is the same of other MikroTik products (both winbox and webfig), but the wireless interface lack of Tx power level. That seems strange.
We think it could be useful to use only the needed power for the specific use case.
That is a design choice, or chipset limitation, or whatother else ?
If there is no specific limitation, we could hope to have that "knob", in next 6.xx RouterOS release ?
Noteikti ne fixed-outdoor, drīzāk tad other@normis, I have a question regarding wireless wire and it's statuss in LV according to VAS Elektroniskie sakari. - Does it fall under term "other devices" or fixed outdoor installation?
Do you have some written communication with them?.....
The device can be used outdoors with more than one client (point to multipoint):It is so that spx on their page are noting next to product name "(indoor use)".
also this other and fixed outdoor is so tricky, as while it is standing on table it could even be other, bet when you fix it to the pole on the roof it becomes "fixed outdoor"
45cm dish is too small for 1.1km or not right focusedHi. Sory bad english.
Any chance you could share your test results again (if that's what that image was; maybe upload to imgur or some other permanent hosting site)Just today tested for 120 metres:
