Hi jarda,My similar experience many years ago teached me not to rename the ports. I use comments to mark the ports by their meaning instead and keep the original port names.
Ahhhh the first victim of the new firmware version notation keeping in touch with the RouterOS version notation.Could you please use the proper forum sections and not pollute a firmware announcement topic?need abit of CRS326 help.
"Also you can try to power off router, press and hold reset button. power router on and release the button."
tried, no luck
I do not have any serial cable. What should i do? (hAP AC was bought a week ago)
Tried patch cord + netinstall... The device reboots and invisible in Netinstall app
I've also noticed a slight cpu (not as much as yours) increase on CCR1036 after upgrading to 6.40.5 from 6.38.x.increase in cpu usage to 16% from 1% on RB3011UiAS
Code: Select all
/sys script
add name=clear_voip_conntrack owner=admin policy=read,write source="/ip firewall connection remove [find dst-address ~ \":4569\"];\r \n/ip firewall connection remove [find dst-address ~ \":5060\"];\r \n"
/ppp profile
add change-tcp-mss=yes name=voip-reset-conntrack on-down="/sys script run clear_voip_conntrack" on-up="/sys script run clear_voip_conntrack"
/interface pppoe-client
add interface=ether1 keepalive-timeout=60 name=ADSL password=***** profile=voip-reset-conntrack user=user@realm
That is not a vulnerability. Somebody made a ping script that floods the device, and result is that CPU usage rises.Dear Mikrotik Team
A DoS vulnerability has been released to RouterOS 6.40.5.
https://cve.mitre.org/cgi-bin/cvename.c ... 2017-17538
https://www.exploit-db.com/exploits/43317/
What kind of schedule is correspondence such as update?
Best regards.
