tay
Re: v6.41 [current]
Mon Jan 29, 2018 7:42 pm
hi everybody
My opinion is too bad over version 6.41 , i didnt find master port.........
best regards
raffav
Re: v6.41 [current]
Mon Jan 29, 2018 8:41 pm
hi everybody
best regards
Read the changes log before posting
Master port was removed, now is all on bridge interface
Enviado de meu XT1580 usando Tapatalk
anuser
Long time Member
Long time Member
Re: v6.41 [current]
Wed Jan 31, 2018 7:15 pm
*) capsman - use "adaptive-noise-immunity" value from CAP local configuration;
I cannot find that option. Can someone please give some hints?
Update: That should be sufficient, right?
/interface wireless cap set enabled=no
/interface wireless set adaptive-noise-immunity=ap-and-client-mode wlan2
/interface wireless set adaptive-noise-immunity=ap-and-client-mode wlan1
/interface wireless cap set enabled=yes
spikehome
Re: v6.41 [current]
Thu Feb 01, 2018 10:34 am
today i updated my 2011 from 3.41 to 6.41
but one of the routers give now the msg when i do the command system routerboard print
error - contact MikroTik support and send a supout file (2)
also when i connect with winbox and go to system routerboard
the page is empty
it seems the update is not good.
The file is at my router
the commands to update are not working
how can i force to install the routeros manualy?
also i cannot make the supout.rif file with the command:
/system sup-output name=supout.rif
get then the same error.
strods
Re: v6.41 [current]
Fri Feb 02, 2018 7:22 am
Version 6.41.1 has been released:
viewtopic.php?f=21&t=130356
Users browsing this forum: usern and 21 guests
