strods
v6.41.4 [current]
Mon Apr 09, 2018 1:03 pm
RouterOS version 6.41.4 has been released in public "current" channel!
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 6.41.4 (2018-Apr-05 12:23):
!) tile - improved overall system performance and stability ("/system routerboard upgrade" required);
*) led - fixed unused "link-act-led" LED trigger on RBLHG 2nD, RBLHG 2nD-XL and RBSXTsq 2nD;
*) led - removed unused "link-act-led" trigger for devices which does not use it;
*) netinstall - sign Netinstall executable with an Extended Validation Code Signing Certificate;
*) poe - do not show "poe-out-current" on devices which can not determine it;
*) poe - hide PoE related properties on interfaces which does not provide power output;
*) winbox - made UDP local and remote TX size parameters optional in Bandwidth Test tool;
*) winbox - show dual SIM options only for RouterBOARDs which does have two SIM slots;
*) winbox - use proper graph name for HDD graphs;
*) wireless - enable all chains by default on devices without external antennas after configuration reset;
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
Please keep this forum topic strictly related to this concrete RouterOS release.
dmorg
Re: v6.41.4 [current]
Mon Apr 09, 2018 2:51 pm
Still no fix for hAP ac2 poor WiFi performance unfortunatly.
dasiu
Trainer
Trainer
Mon Apr 09, 2018 3:04 pm
Thanks! :)
- is it the same improvement, as in 6.41.3 (identical description), or yet a new improvement (improving it even more), or did the improvement in 6.41.3 didn't work? :)
Simono
Mon Apr 09, 2018 3:22 pm
CAP AC remonte upgrade from router:
upgrade status: no such file, failed, failed to download file 'routeros-arm-6.41.4.npk', no such file'
strods
Mon Apr 09, 2018 5:53 pm
dmorg - First this problem must be resolved within RC version and backported to bugfix/current channels only if it would be possible. Please follow the changelog.
dasiu - We can say that this is improved improvement :)
Simono - I do not see any problems with download links. Do you try "Check for updates" feature? If you do, which IP is resolved by this command ":put [:resolve upgrade.mikrotik.com]"? Try the command multiple times until resolved IP addresses start to repeat themselves. Should be - 159.148.147.204 and 159.148.172.226.
Simono
Mon Apr 09, 2018 7:03 pm
strods upgrade from Winbox connected directly to Cap ac is OK. Eariel I was connected remonte to my router and I do upgrade from Capsman on it to Caps connected to router. On others Caps (lite) upgrade was OK only on Cap ac upgrade was unsucces. Now I have 6.41.4 on all my units.
jetelina
Mon Apr 09, 2018 10:53 pm
after upgrade to 6.41.4 I have noticed in log message "installed wireless@-6.41.4"
Few lines above there is "verified wireless-6.41.4-mipsbe.npk", which is correct.
After upgrade in System - Packages shows correct "wireless" with version.
I think I have also seen that in 6.41.3.
Just log message seems to be wrong - looks like typo or small bug.
netflow
Mon Apr 09, 2018 11:11 pm
Sadly still no fix for the issue introduced with 6.41.3 with LTE modem Huawei ME909s-120 connected through USB port.
irghost
Mon Apr 09, 2018 11:17 pm
where is the ova Download link in download page?
MTCNA MTCRE MTCTCE MTCUME MTCWE MTCIPv6E MTCINE
strods
Tue Apr 10, 2018 7:16 am
jetelina - Do not worry about that. In the past (old versions) we had wireless package and now we have another one which is also called wireless. This "@" symbol is there on purpose;
netflow - Is modem working properly on 6.42rc?
irghost - Will be back on download page as soon as possible.
woro
Tue Apr 10, 2018 9:32 am
Since I just ordered a few. Is there any pointer to more information about that one?
pepek
Tue Apr 10, 2018 9:56 am
Try this topic viewtopic.php?f=7&t=132648 - RC builds are slightly better, but still crappy. Still no info from MT, only many complains from users.
Kindis
Tue Apr 10, 2018 10:15 am
Updated two 3011, two wAP AC, one CHR running on Hyper-V and also a 493G without any issues.
Are there any official plan to fix the firmware so it auto upgrades so I do not have to restart each machine twice every time? By offical plan I mean when this will be solved and not Yes it will be solved.
eddieb
Tue Apr 10, 2018 10:19 am
Updated RB2011UAS, RB750GL, RB1100, RB962 (9x), CRS125 and CHR running Dude without any issues
Running RouterOS 7.6 on : CCR1009-8G-1S, RB750Gr3 (dude), CRS125-24G-1S, RB1100, RB962UiGS-5HacT2HnT, RB931-2nD, RB951G-2HnD, RB750GL, RB2011UAS-RM, PWR-LINE-AP, RBwAPGR-5HacD2HnD
feeding ADSBExchange https://www.adsbexchange.com/how-to-feed/
Simono
Tue Apr 10, 2018 10:35 am
For me the speed is also poor on my cAP AC, on cAP Lite i've got better speed and stability. I'm dissapointed. I've buy some cAP AC to my company and now ...........
I,ve have connected all cAPs to CAPsMAN on router.
Lakis
Forum Veteran
Forum Veteran
Tue Apr 10, 2018 10:45 am
Dear Mikrotik please for the last time fix throughput problem when hw offload is enabled on 960PGS (hEX PoE)
Just add two units to hEX make a btest from 1gbit Unit to 100mbit (Or from 100mbit to 100mbit) Unit with hwofload=yes
Also log show "apr/10/2018 09:43:13 system,info,critical cpu not running at default frequency" cpu is set on default 800Mhz?
fvdm
Tue Apr 10, 2018 2:51 pm
Updated a 2x CRS226 without a problem. But...... my RB2011 is stuck. I hear a beep every few seconds, display shows routerboot, starting kernel....... over and over again.
Power off/on does not solve anything. How to fix this (preferably without losing my config)?
Yeah, recently got the RB2011 back in use and forgot to back-up my config :( .
strods
Tue Apr 10, 2018 3:31 pm
woro, pepek, Simono - We are working on fixes for wireless improvements. Please note that this is "user forum". In order to contact MikroTik staff, you should write to support@mikrotik.com. Please do not expect that your problem will be resolved after you have posted that on forum. Yes, we might notice your posts and topics, but official way is through an e-mail.
Kindis - We are slowly moving forward and preparing for something like this. In future, at some point, firmware upgrade will happen together with RouterOS upgrade.
Lakis - Have you reported this to support@mikrotik.com?
fvdm - Use Netinstall and make sure that "Keep old configuration" is enabled - https://wiki.mikrotik.com/wiki/Manual:Netinstall
fvdm
Tue Apr 10, 2018 3:39 pm
Thanks, will give it a try!
woro
Tue Apr 10, 2018 6:08 pm
Thanks for the feedback. I came across those issues only today in that announcement so I was looking for pointers only (yet).
But I also understood now that it's not required to report further hAP ac2 wifi issues? Just asking because I got my first one today and going to test a bit.
Apart from that I fully get that the support mail is the only right thing (process wise).
fvdm
Tue Apr 10, 2018 7:42 pm
Worked like a charm, thanks a lot!
netflow
Tue Apr 10, 2018 8:37 pm
@strods I have juste installed 6.42RC56, so far so good, no issue with LTE on USB. Thanks.
mikeeg02
Tue Apr 10, 2018 11:48 pm
I have a CCR1009 thats connected to a cisco 2911. After about 10 days or so, latency suddenly becomes sporadic. Did not happen on 6.38.5. Does happen on 6.41.3, will the above listed in 6.41.4 fix this issue? As trivial as it sounds, admin down the port, and back up seems to fix it. We had to set both devices to auto negotiate for them to link up at all. I have tried emailing support on another larger issue with a RB1100AHx4, but Im not getting replies.......... I have asked for updates.......
EDIT: Not sure why I thought CRS, It was a CCR1009
SirPrikol
Tue Apr 10, 2018 11:55 pm
New bridge interface created with L2 65535 MTU. After then all local network down and cpu on all mikrotik routerboard is above 100%
strods
Wed Apr 11, 2018 7:11 am
woro - It is not possible through forum to determine what kind of problem do you have. I recommend that you still contact support team since problem might even not be related to hardware.
netflow - Please write to support@mikrotik.com and explain the problem that you have with 6.41.4 and that you do not have the same issue on 6.42rc. We will try to include required fixes into 6.41.5 release.
mikeeg02 - Quoted fix is for CCR devices, not for the CRS. Does the same problem persist on 6.42rc version? Please test this if possible. If problem persist, then contact support.
SirPrikol - Please generate supout files on your router and send them to support@mikrotik.com. Without additional information we can not determine what is the cause of the problem that you have.
edgarsm
Wed Apr 11, 2018 7:38 am
After upgrade I don't see anymore LTE AP profile in Quick Menu dropdown list. Device: wAP LTE kit. After changing some other settings and Apply, I cannot connect to my device with WinBox and WebFig anymore because apparently another profile was applied and management IP address was reset.
strods
Wed Apr 11, 2018 9:48 am
edgarsm - This fix is available only in 6.42rc version and not in the 6.41.4 - "quickset - properly detect LTE interface on startup". Sounds that this is the fix which is required on your case.
SirPrikol
Wed Apr 11, 2018 10:34 am
send
[Ticket#2018041122002806]
mikeeg02
Wed Apr 11, 2018 5:01 pm
Im not sure why I said CRS, it is a CCR1009. My mistake, I'm about half sick. What was addressed with the tile improvement? I have not upgraded it to 6.41.4 yet, the problem had shown itself ~10 days after upgrading to 6.41.3 from 6.38.5 which never missed a beat.
Any suggestions on getting a reply from support on [Ticket#2018040522000294] ? I got an initial reply, and nothing further.
hapi
Wed Apr 11, 2018 6:06 pm
capsman: with "name format = prefix", missing a dash in name intarface. WIth "name format = identity" is ok.
name-format=prefix name-prefix=cap2
result:
 #      NAME                                            RADIO-MAC         MASTER-INTERFACE
 0 MDBR cap21                                           E4:8D:8C:9E:89:AC none
but
name-format=identity
result:
 0 MDBR hAP lite-1                                      E4:8D:8C:9E:89:AC none
zeane
Wed Apr 11, 2018 7:24 pm
II have come across exactly the same issue on RB3100 and also on a Dynadish, >>> after upgrading via winbox, then wait for reboot. The system thereafter apparently restarts imto a continual loop. As soon as it starts , it restarts. No time to configure setup or netinstall. Extremely frustrating.
Now what does one do??
CZFan
Location: South Africa, Krugersdorp (Home town of Brad Binder)
Thu Apr 12, 2018 12:40 am
Upgraded SXT LTE remotely from 6.40.6 to 6.41,4, device rebooted after downloading new ros but I can't access the device anymore.
Arranged with client to meet onsite in the morning, will revert back once I have more re info
MTCNA, MTCTCE, MTCRE, MTCSWE & MTCINE
pepek
Thu Apr 12, 2018 11:24 pm
Of course, this is discussion forum, not helpdesk. You cannot monitor all topics and respond to all posts with symptoms of possible problem. But you can respond to problem discussed in at least five different topics (to which you respond to other questions). Just quick note "working on it" would reduce number of posts in these topics to half. Systematically ignoring all mentions about this problem seems very strange and suspicious. Admiring that there is a problem and you are trying to make it work is fair and trustworthy behavior.
When I find some problem, I try to search for anybody else in same situation. When I find some public blog post/forum thread, I try to search it for solution/more info (and not to bother support with repeated question to problem with already known and published solution). If I don't find any public info, I contact support/helpdesk. Here? I found tens of users with exactly the same problem, MikroTik responses to other questions in same topics but absolutely no info about current state of this bug. This can confuse users and make them panic.
Is it better to receive tens of questions about wifi speed to helpdesk every day, or to send few posts to forum, that this is known general problem and you are working on it?
CZFan
Fri Apr 13, 2018 3:02 am
Unfortunately client restarted device before I could get to site, so can't add anything more
strods
Fri Apr 13, 2018 7:02 am
zeane - Please connect serial console cable to this router, connect to serial console from your computer, power on router and wait for it to go into reboot. After that provide whole serial output to support@mikrotik.com.
pepek - We are trying our best and will try to improve our communication with users through forum. However, point of my previous post was that the fastest way to get a response would be through official support e-mail.
trujulu
Mon Apr 16, 2018 11:33 pm
I am having, since I have mikrotik problems with multicast, related with continuity errors on the channels.
P.S.: Restarting IGMP Proxy partial fix it. But it is not a solution for me.
nin
Tue Apr 17, 2018 12:26 pm
I just recently upgraded all of my devices to v6.41.4 [current].
I have one RB450G (configured as a pure switch) behind my CCR1016-12G router. Thus, the RB450G itself should not ask for and should not get any IP assigned from the DHCP server (CCR).
But since I updated the RouterOS, suddenly my logs on my CCR are flooded with
dhcp,warning dhcp1 offering lease 192.168.7.247 for <MAC_OF_RB450G_HERE> without success
Any idea what is wrong now?
Cheers, nin
strods
Tue Apr 17, 2018 1:58 pm
Version 6.42 has been released in current channel:
viewtopic.php?f=21&t=133272
Users browsing this forum: Safi and 4 guests
