fixed it ! try nowi couldn't upload pic , next to options no attachments
Very nice! And mounting is always very important. We have dishes as well in the tower shown on the first picture, in the concrete base. And during a storm the wind is very strong there due to wind deflection around the tower. So we had to make strong mountings as well, and because we used round tubes the dishes still slipped and changed direction...We welded special brackets, becouse previous version what we monted on aluminium pipe, was very unstable and was moving in the wind! This is very strong bracket no moving at all!!
...well it's not mine...and it's not from mikrotik as i see... but it's good![]()
take a look
https://hybridtechcar.com/2018/04/24/th ... -internet/
Wow nice job!!!!Small towers fixed on the rocks with steel rods or galvanized iron piles,
We use them for small POPs in the rural areas of Sardinia (IT). Very often in the hills it is not possible to have electricity, so we use 24V photovoltaic panels and batteries. The low power consumption of MT devices allows for electrical continuity throughout all the year.
This type of small POPs are usually made with two or more sectoral antennas mANTBox 15s/19s or MTAS-5G-19D120 with Netmetal and RB2011 for switching.
cetalfio
Ciao sono installazioni fatte nell'oristanese e medio campidano.Wow nice job!!!!Small towers fixed on the rocks with steel rods or galvanized iron piles,
cetalfio
Near Cagliari?
Yes it canDoes a solar panel can generate enough power for a full house?![]()
Lets not forget about Duct TapeReal world without tie-wraps does not exist![]()
Is it possible to have a forum without spammers?Is it possible to use a solar tower in country like India?
Do the routers really use that much power, or did you simply add extra panels and batteries to avoid unnecessary downtime?Small towers fixed on the rocks with steel rods or galvanized iron piles,
cetalfio
Cool! (pun intended)5x directional antennas (ARC) and 1x 90 degree sector antenna (MTI)
Routerboards in the antennas and as router inside the manholes.
The rack is in the middle of a meadow?Inside rack![]()
No, rack is inside the tower of the churchThe rack is in the middle of a meadow?Inside rack![]()
This is recent photo?
The grasshopper is only one hop awayInside rack
Well, what I want to pay may not be so much...^^^^
You can pay me what you want, you will not get me on that tower![]()
Sent from my cell phone. Sorry for the errors.
Hi how long it can stay on battery?Recent installation on tower
Sent from my SM-A520W using Tapatalk
Cheers mate. Yeah, quite a large panel for the equipment - the site only gets 1 hour of direct sunlight per day. The rest of the day the panel is covered in shadows from the tree which bring it down quite a bit.@RogerWilco that is a big panel. Isnt it ?
I really like your photo...
Can we see inside the box ?
Is it telescopic pipe ?a couple of installations, lhg5 and omnitik 5 poe.
read the undertitle on photoIs it telescopic pipe ?a couple of installations, lhg5 and omnitik 5 poe.
and how long is it.
Sent from my RMX1901 using Tapatalk
Mounted this on top of my caravan.
Yes, this is completely manual. When the caravan has its position I can place the antenna - neither caravan nor lte station will move then.How do you turn antenna, by losening the mount on the pole? What do you do while driving around, take the whole installation (including pole base) down?
maybe, mounted on a plastic plate (Polyethylenplast) then a rubber-sucker (Saugnapf) in each corner to fasten to roof.Yes, this is completely manual. When the caravan has its position I can place the antenna - neither caravan nor lte station will move then.How do you turn antenna, by losening the mount on the pole? What do you do while driving around, take the whole installation (including pole base) down?
The whole installation is taken down when driving.
Yes, it's a heavy plastic plate. But it has just rubber-feet, no sucker. But I will fasten it with a strong cord and eyelets in keder rails.maybe, mounted on a plastic plate (Polyethylenplast) then a rubber-sucker (Saugnapf) in each corner to fasten to roof.
then very portable.
It now looks like this. Let's hope it will withstand bad weather and strong wind...Yes, it's a heavy plastic plate. But it has just rubber-feet, no sucker. But I will fasten it with a strong cord and eyelets in keder rails.
It will, definitely - have a nice summer, what is left of itIt now looks like this. Let's hope it will withstand bad weather and strong wind...
