Version 6.43rc64 has been released.
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
MAJOR CHANGES IN v6.43:
!) api - changed authentication process (https://wiki.mikrotik.com/wiki/Manual:API#Initial_login);
!) backup - do not encrypt backup file unless password is provided;
!) btest - requires at least v6.43 Bandwidth Test client when connecting to v6.43 or later version server except when authentication is not required;
!) cloud - added IPv6 support;
!) cloud - added support for licensed CHR instances (including trial);
!) cloud - reworked "/ip cloud ddns-enabled" implementation (suggested to disable service and re-enable after installation process);
!) mac-telnet - require at least v6.43 MAC Telnet client when connecting to v6.43 or later version server;
!) radius - use MS-CHAPv2 for "login" service authentication;
!) romon - require at least v6.43 RoMON agent when connecting to v6.43 or later RoMON client device;
!) security - fixed vulnerabilities CVE-2018-1156, CVE-2018-1157, CVE-2018-1158, CVE-2018-1159;
!) webfig - improved authentication process;
!) winbox - improved authentication process excluding man-in-the-middle possibility;
!) winbox - minimal required version is v3.15;
Other changes in this release:
*) bridge - added an option to manually specify ports that have a multicast router (CLI only);
*) bridge - added a warning when untrusted port receives a DHCP Server message when DCHP Snooping is enabled;
*) bridge - added more options to fine-tune IGMP Snooping enabled bridges (CLI only);
*) bridge - added support for DHCP Option 82 (CLI only);
*) bridge - added support for DHCP Snooping (CLI only);
*) bridge - added support for IGMP Snooping fast-leave feature (CLI only);
*) cloud - close local UDP port if no activity;
*) console - made "once" parameter mandatory when using "as-value" on "monitor" commands;
*) console - removed automatic swapping of "from=" and "to=" in "for" loops;
*) crs326/crs328 - fixed packet forwarding when port changes states with IGMP Snooping enabled;
*) crs3xx - added hardware support for DHCP Snooping and Option 82;
*) crs3xx - fixed packet forwarding when "frame-type" is changed (introduced in v6.43rc51);
*) crs3xx - fixed SwOS config import;
*) defconf - fixed default configuration for RBSXTsq5nD;
*) dhcpv6-client - fixed false invalid flag (introduced in v6.43rc56);
*) fetch - added "as-value" output format;
*) fetch - fixed address and DNS verification in certificates;
*) health - added missing parameters from export;
*) ipsec - added warning messages for incorrect peer configuration;
*) ipsec - improved stability when using IPsec with disabled route cache;
*) leds - fixed LED behaviour when bonding is configured on SFP+ interfaces;
*) lte - added "sector-id" to info command;
*) lte - fixed SIM7600 series module support with newer device IDs;
*) ppp - added support for Alfa Network U4G modem;
*) rb3011 - added IPsec hardware acceleration support;
*) snmp - added EAP identity to CAPsMAN registration table;
*) supout - added monitored bridge VLAN table to supout file;
*) switch - added CPU Flow Control settings for devices with a Atheros8227, QCA8337, Atheros8327, Atheros7240 or Atheros8316 switch chips;
*) tr069-client - use SNI extension for HTTPS;
*) ups - improved UPS serial parsing stability;
*) w60g - added "beamforming-event" stats counter;
*) w60g - fixed random disconnects;
*) w60g - general stability and performance improvements;
*) wireless - accept only valid path for sniffer output file parameter;
*) wireless - added "czech republic 5.8" regulatory domain information;
*) wireless - added "etsi2" regulatory domain information;
*) wireless - added option to disable PMKID for WPA2;
*) wireless - updated "czech republic" regulatory domain information;
If you experience version related issues, then please send supout file from your router to
support@mikrotik.com. File must be generated while router is not working as expected or after crash.
Note that release candidate versions are published strictly for testing purposes and should not be used on production routers.
