nkourtzis
Re: v6.43rc [release candidate] is released!
Tue Jul 24, 2018 3:45 pm
*) wireless - improved Nv2 reliability on ARM devices;
The first point-to-point tests with nv2 on arm are not satisfactory. We will perform more tests
Just a question without intention of doubting what you say: why use NV2 on PtP?
JimmyNyholm
Tue Jul 24, 2018 4:07 pm
And even worse the chap packet that you send out doest not contain any password (you are sending empty radius request even before asking the user of a password. Clean upp your code and enable PAP/CHAP/MSCHAP as option NOW!
I'm trying this RC in a CRS328-4C-20S-4S+RM
After downgrading to Current 6.42.6 Radius pap (one time passwords) and rename admin works like a charm again.
Chupaka
Tue Jul 24, 2018 4:26 pm
Ok so now I test the RC45 Build. My setup scripts fail can't rename user admin anymore? WHY?
yeah, that's funny :)
[admin@internal] > user set admin name=adminn
failure: user name can't be changed
BartoszP
Tue Jul 24, 2018 5:13 pm
Changing name of logged in user is not good idea. What if you are logged as different user?
SergeyMorozov
Tue Jul 24, 2018 5:26 pm
[sergey@router.home] > /user set admin name adminn
osc86
Tue Jul 24, 2018 5:46 pm
even more important, the memory leak is still not fixed
hzdrus
Tue Jul 24, 2018 6:17 pm
Drop of RADIUS PAP support for ssh logins is a big problem for us too.
We're using a one-time password implementation which is impossible to integrate with MS-CHAPv2 - the security appliance only stores the hash of the PIN (fixed part of the password) and because of this cannot support MS-CHAPv2 since it would require to store PIN as clear-text. 6.43rc is forcing us to drop the OTP, actually decreasing security of the network.
Please allow us to make decisions on how to secure our network ourselves and make a setting allowing to select PAP for "login" service authentication. In any case RADIUS requests can always be sent via encrypted tunnels, while MS-CHAPv2 security strength has been watered down to level of a long obsolete single DES56 - one can find online services that will crack it in a day.
joserudi
Wed Jul 25, 2018 12:12 pm
I always use nv2 with mikrotik. There are some noise in my city.
ivanfm
Wed Jul 25, 2018 1:49 pm
I agree.
If the internal system works with hash passwords ok, but If the router manager has a secure radius and want to use this kind of system should be permitted.
The SSH passwords are plain text in the encrypted tunnel and PAP still can be used.
alfregil
Fri Jul 27, 2018 6:34 pm
Hi, need some help to configure a paypal payment option with hotspot and usermanager. Just found this and update it to the RC version, but still need help on this.
ziegenberg
Mon Jul 30, 2018 5:14 pm
This is definitely the wrong thread for your request. There are separate threads and parts of the forum for those kind of questions. This thread is solely for issues with this particular release version and it's update.
TestCRS
Tue Jul 31, 2018 4:03 pm
>What's new in 6.43rc45 (2018-Jul-17 08:30):
>Changes in this release :
>sfp - fixed default advertised link speeds;
please say: what exactly was corrected
strods
Thu Aug 02, 2018 11:51 am
Version 6.43rc51 has been released.
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
MAJOR CHANGES IN v6.43:
!) api - changed authentication process (https://wiki.mikrotik.com/wiki/Manual:API#Initial_login);
!) backup - do not encrypt backup file unless password is provided;
!) btest - requires at least v6.43 Bandwidth Test client when connecting to v6.43 or later version server except when authentication is not required;
!) cloud - added IPv6 support;
!) cloud - added support for licensed CHR instances (including trial);
!) cloud - reworked "/ip cloud ddns-enabled" implementation (suggested to disable service and re-enable after installation process);
!) mac-telnet - require at least v6.43 MAC Telnet client when connecting to v6.43 or later version server;
!) radius - use MS-CHAPv2 for "login" service authentication;
!) romon - require at least v6.43 RoMON agent when connecting to v6.43 or later RoMON client device;
!) webfig - improved authentication process;
!) winbox - improved authentication process excluding man-in-the-middle possibility;
!) winbox - minimal required version is v3.15;
Other changes in this release:
*) bridge - added per-port based "tag-stacking" feature;
*) bridge - fixed "ingress-filtering", "frame-types" and "tag-stacking" value storing;
*) bridge - improved bridge port state changing process;
*) bridge - improved packet processing when bridge port changes states;
*) bridge - renamed option "vlan-protocol" to "ether-type";
*) certificate - do not allow to perform "undo" on certificate changes;
*) crs3xx - added command that forces fan detection on fan-equipped devices;
*) crs3xx - fixed port disable on CRS326 and CRS328 devices;
*) dhcpv6-client - allow to set "default-route-distance";
*) dhcpv6-client - fixed "add-default-route" parameter;
*) dhcpv6-client - fixed option handling;
*) dhcpv6-server - added additional RADIUS parameters for Prefix delegation, "rate-limit" and "life-time";
*) ethernet - fixed default ethernet advertise values after configuration reset (introduced in v6.43rc33)
*) filesystem - fixed NAND memory going into read-only mode (requires "factory-firmware" >= 3.41.1 and "current-firmware" >= 6.43);
*) health - fixed voltage measurements for RB493G devices;
*) hotspot - allow to properly configure Hotspot directory on external disk for devices that have flash type storage;
*) hotspot - fixed RADIUS CoA & PoD by allowing to accept "NAS-Port-Id";
*) ike1 - added unsafe configuration warning for main mode with pre-shared-key authentication;
*) ike1 - zero out reserved bytes in NAT-OA payload;
*) ike2 - fixed rekeyed child deletion during another exchange;
*) ike2 - improved basic exchange logging readability;
*) ipsec - fixed "sa-src-address" deduction from "src-address" in tunnel mode;
*) ipsec - fixed "static-dns" value storing (CLI only);
*) ipsec - fixed AES-CTR and AES-GCM key size proposing as initiator;
*) ldp - properly load LDP configuration;
*) led - fixed default LED configuration for RBLHGG-5acD-XL devices;
*) lte - added "registration-status" parameter under "/interface lte info" command;
*) lte - added additional D-Link PIDs;
*) lte - added additional low endpoint SIM7600 PIDs;
*) lte - added signal readings under "/interface lte scan" for 3G and GSM modes;
*) lte - fixed memory leak on USB disconnect;
*) lte - fixed SMS send feature when not in LTE network;
*) lte - ignore empty MAC addresses during Passthrough discovery phase;
*) lte - properly detect interface state when running for IPv6 only connection for R11e-LTE modem;
*) multicast - allow to add more than one RP per IP address for PIM;
*) ospf - improved link-local LSA flooding;
*) rb1100ahx4 - added DES and 3DES hardware acceleration support;
*) routerboot - removed RAM test from TILE devices (routerboot upgrade required);
*) sfp - hide "sfp-wavelength" parameter for RJ45 transceivers;
*) snmp - added "phy-rate" reading for "station-bridge" mode;
*) snmp - fixed "remote-cap" peer MAC address format;
*) ssh - strengthen strong-crypto (add aes-128-ctr and disallow hmac sha1 and groups with sha1);
*) tile - added DES and 3DES hardware acceleration support;
*) w60g - added distance measurement feature;
*) w60g - fixed random disconnects;
*) w60g - improved MCS rate detection process;
*) w60g - improved MTU change handling;
*) w60g - properly close connection with station on disconnect;
*) wireless - fixed "/interface wireless sniffer packet print follow" output;
*) wireless - fixed packet processing after removing wireless interface from CAP settings;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as expected or after crash.
Note that release candidate versions are published strictly for testing purposes and should not be used on production routers.
pe1chl
Thu Aug 02, 2018 12:21 pm
Thank you, I will test it soon and report.
Netstumble
Thu Aug 02, 2018 12:33 pm
Please clarify:
Ex:
I run 6.40.8
System routerboard print:
routerboard: yes
model: RouterBOARD 3011UiAS
serial-number: 689A05572F46
firmware-type: ipq8060
factory-firmware: 3.27
current-firmware: 3.41
upgrade-firmware: 3.41
Will the fix be included only in later production runs?
I was under the assumption that the factory-firmware identifies the firmware ver# the device initially shipped with,
and it can't be somehow upgraded.
Or we are talking about bakup routerboot code... (in which case I still think it is not user-upgradeable?).
Nothing relevant on the wiki.
Thanks.
paulct
Thu Aug 02, 2018 12:35 pm
Can this also be explained. Similar to selective q-in-q?
vspider
Thu Aug 02, 2018 3:02 pm
I have LtAP mini International Kit and have LTE some stability issues. Is it worth upgrading to 6.43rc51 version as it claims fix for my case
*) usb - fixed modem initialisation on LtAP mini;
Is it stable enough for LtAP device at least?
grusu
Fri Aug 03, 2018 10:46 am
Something is wrong with the Hash Algorithms in Peer Proposal setting in v6.43.51:
If I have to set the SHA1 algorithm, in WinBox I have to set md5.
pe1chl
Fri Aug 03, 2018 5:42 pm
Unfortunately it is the same - report sent to support.
Any others who try to do IPsec from a Draytek router behind NAT?
MonkeyDan
Fri Aug 03, 2018 10:33 pm
rc51 seems better on point-to-point Wireless Wires (fixed dropping issues in 6.42.6)
But we're still seeing a lot of disconnects with multipoint.
janos66
Sat Aug 04, 2018 1:17 pm
I think factory routerboard firmware = backup bootloader.
It's normally not allowed but seems possible to upgrade the factory version: https://wiki.mikrotik.com/wiki/Manual:R ... D_settings
The backup RouterBOOT version can not be older than v3.24 version. A special package is provided to upgrade the backup RouterBOOT (DANGEROUS). Newer devices will have this new backup loader already installed at the factory. Download the package for:
I usually assumed the factory/backup version to be completely irrelevant unless you force it by a RESET button sequence (or possibly some other means).
I still think this is the case here. The new feature will probably be available when using the normal boot loader (of a high enough version) but be absent when using the backup bootloader (either manually forced or may be automatically triggered if the "main" one is too corrupted to do anything).
I never tried but thought the secondary (factory) version can be upgraded too, either via Netinstall or even just by using the "force backup booter" and initiating an upgrade from ROS. But I never felt the need, so never tried... I just tried to latter (force backup and upgrade from ROS) but it's not that easy. I wonder if Netinstall could do it.
Edit:
Oh! And I think even though we now have a matching ROS and bootloader version (even for every incremental, let alone RC version), that firmware still has some internal version number (probably still somewhere around 3.4x for ROS 6.4x). So this change only complicates this question (it's probably possible to have basically the same factory backup and "main" booloader on a device even though the visible version number is seemingly much higher on the normally-upgradeable "main" firmware).
I think they just rebuild the source code of the bootloader for every ROS release, so it has a matching version number but this no longer indicates they made any change to the source. But this seems to be impractical because now we don't know when the code actually changes.
Netstumble
Sat Aug 04, 2018 8:58 pm
Edit:
All valid considerations.
I suppose they do refer to the secondary bootloader,
in witch case they should provide a "special" package for the users who would want to upgrade the backup loader.
Still, I would like a clarification from mikrotik.
janos66
Sat Aug 04, 2018 11:08 pm
In my opinion the best solution would be to always auto-upgrade the main bootloader along every ROS upgrade (without the need to issue manual reboot twice) and allow the user to manually upgrade the backup bootloader once the new ROS successfully booted with an upgraded main bootloader (which is a fair enough confirmation that the device is stable enough with the new bootloader to use ROS for bootloader changes, thus it's probably possible to downgrade if some small error occurs later on).
laca77
Sat Aug 04, 2018 11:40 pm
Hi
I ran into a strange problem.
I had to reinstall the system with Netinstall to the latest rc51 version.
My device is a CRS109-8G-1S-2HnD which is a DHCP client on the SFP copper port (ISP is UPC). I try to run a speedtest.net from my desktop PC .
After everything was ready, i tried to run a speedtest, The speed was 80Mbps with 90% of cpu load. The idle load was 17%.
Ok, i installed back to the 6.42.6. The speed was 400Mbps with 50% of cpu load. Idle load is 4%.
Nice. So i did some screenshot from the tools/profile.
The last step was back to 6.43rc51 to reproduce the problem. But now everything is looks nice, on this RC i can get the 400Mbps with the same load as it was on the 6.42.6...
I don't know what happened, i didn't changed the config.... but now looks like everything is ok...
Just write this post as a note, may be helps to somebody.
schadom
Sun Aug 05, 2018 4:44 pm
"sfp-connector-type" is still falsely displayed as "LC" for S-RJ01 modules in Winbox and CLI
jondavy
Mon Aug 06, 2018 12:08 am
in queues tree in parent does not appear to select queue of hotspot users like <hotspot-john>
chubbs596
Mon Aug 06, 2018 10:23 am
Would also like this explained
petern
Mon Aug 06, 2018 11:56 am
Hi, I'm also using PAP with radius for authentication to support 2FA logins. Using only chap is not helpful. Is feedback here taken on board or is there a more official way to get this heard?
artz
Mon Aug 06, 2018 2:05 pm
Wiki has been updated with an example:
https://wiki.mikrotik.com/wiki/Manual:I ... g_stacking
Selective QinQ is not possible yet, only port based QinQ or CVID stacking is possible now.
nicoguido
Mon Aug 06, 2018 4:46 pm
Here is a problem with CRS317 and rc51.
My configuration :
some clients <---> CRS326 <===== Trunk1(only tagged VLANs) =====> CRS317 <===== Trunk2 (only tagged VLANS) ====> CRS328 <---> some clients
Installation with version 6.42.6 for the three devices : no problem.
Upgrade on version 6.43rc51 for the three devices :
everything is working like version 6.42.6, except the fact that CRS317 is unreachable for remote management via CRS326/CRS328 :
- no access to the web pages
- no access with winbox + it doesn't appear in 'neighbors'
CSR317 is still manageable through a direct connection to one of its ports.
1st Test : I decide to change CRS317 with and old TP-link switch with the same VLAN/Trunk configuration. The TP-Link switch is available for remote management via CRS326/CRS328.
2nd Test : I rebuild CRS317 with a netsintall of version 6.43rc51 and a fresh configuration. Same behaviour, the CRS317 is unreachable for remote management via CRS326/CRS328.
Are you aware of this king of problem with the RC version ?
If I find the time, I'll do a last test by reinstalling version 6.42.6 on the CRS317 only.
msatter
Wed Aug 08, 2018 2:45 pm
Found the problem and it was that I changed to an other DNS server that did not Round Robin by default.
emils
Forum Veteran
Forum Veteran
Tue Aug 14, 2018 1:33 pm
Version 6.43rc56 has been released.
Before an upgrade:
!) security - fixed vulnerabilities CVE-2018-1156, CVE-2018-1157, CVE-2018-1158, CVE-2018-1159;
*) bridge - added support for BPDU Guard (CLI only);
*) bridge - added support for DHCP Option 82 (disables hardware offloading, CLI only);
*) bridge - added support for DHCP Snooping (disables hardware offloading, CLI only);
*) bridge - forward LACPDUs when "protocol-mode=none";
*) bridge - improved packet handling;
*) cloud - added simultaneous IPv4/IPv6 support;
*) console - added "dont-require-permissions" parameter for scripts;
*) dhcpv4-relay - fixed false invalid flag presence;
*) dhcpv6-server - do not allow to run DHCPv6 server on slave interface;
*) dhcpv6-server - fixed dynamic simple queue creation for RADIUS bindings;
*) dhcpv6-server - properly update interface for dynamic DHCPv6 servers;
*) ethernet - fixed possible link flaps after disabling/enabling the interface (introduced in v6.43rc51);
*) ethernet - improved large packet handling on ARM devices with wireless;
*) ethernet - removed obsolete slave flag from "/interface vlan" menu;
*) hotspot - fixed customized HTML file usage (introduced in 6.43rc47);
*) ike2 - fixed initiator first policy selection;
*) ippool - improved used address error message;
*) ipsec - added warning messages for incorrect peer configuration;
*) ipsec - separate phase1 proposal configuration from peer menu;
*) ppp - fixed interface enabling after a while if none of them where active;
*) ppp - improved modem mode switching;
*) snmp - added "temp-exception" trap;
*) switch - fixed possible switch chip hangs after initialization on MediaTek and Atheros8327 switch chips;
*) tile - fixed false HW offloading flag for MPLS;
*) tr069-client - allow editing of "provisioning-code" attribute (CLI only);
*) tr069-client - fixed unresponsive tr069 service when blackhole route is present;
*) upgrade - fixed RouterOS upgrade process from RouterOS v5;
*) ups - improved UPS serial parsing stability;
*) w60g - general stability and performance improvements;
*) w60g - stop doing distance measurements after first successful measurement;
*) winbox - added "default-route-distance" parameter for "IPv6/DHCP-client" menu;
*) winbox - fixed "sfp-connector-type" value presence under "Interface/Ethernet";
*) winbox - fixed warning presence for "IP/IPsec/Peers" menu;
*) winbox - fixed "write-sect-since-reboot" value presence under "System/Resources";
*) winbox - show "System/RouterBOARD/Mode Button" on devices that has such feature;
*) wireless - added option to disable PMKID for WPA2 (CLI only);
*) wireless - fixed memory leak when performing wireless scan on ARM;
*) wireless - updated "united-states" regulatory domain information;
raffav
Tue Aug 14, 2018 1:46 pm
Nice..
Good work
I get very happy when there are a lot of changes logs, even if I don't use 80% of this improvement , I get happy for whose does.
Can't wait to this became stable release.
Sent from my XT1580 using Tapatalk
indjov
Tue Aug 14, 2018 1:52 pm
sorry now works.
nz_monkey
Tue Aug 14, 2018 3:38 pm
Could we please get some examples of how to use these features on the Wiki ?
I cannot see any of the options I would expect, e.g. being able to set the contents of the Option-82 injection string with variables for the first feature, or being able to specify the valid DHCP server for the second.
macgaiver
Tue Aug 14, 2018 4:09 pm
All my everyday devices still connects just fine.
artz
Tue Aug 14, 2018 5:59 pm
Did you specify which ports are trusted ports under /interface bridge port?
MonkeyDan
Tue Aug 14, 2018 7:29 pm
Still seeing multipoint Wireless Wire disconnects with 6.43rc56. I don't think the RC branch has been stable on these since rc17 :(
6.42.3 continues to be my recommended version.
StubArea51
Trainer
Trainer
Tue Aug 14, 2018 10:57 pm
I second that!
Florian
Wed Aug 15, 2018 11:08 am
Funny thing after Version 6.43rc56 , my DHCPv6 client is showing in red in winbox, even though everything is working, and my ipv6 connectivity is ok. Still after after re-creating it from scratch... Not a big deal, but...
pe1chl
Wed Aug 15, 2018 11:57 am
I tested it again with Draytek router behind NAT and now it works OK!
Thanks!
IntrusDave
Thu Aug 16, 2018 12:31 am
How does this one work? Any specific commands that it works with?
ath
Thu Aug 16, 2018 4:16 am
I notice that in 6.43rc34 the /interface bridge vlan untagged= configuration no longer strips all the C-tags from a packet with multiple C-tags. Instead it only strips the top C-tag.
Will this be the case in the production version?
If so, would it be possible to reinstate the former behaviour as an option?
diablothebest
Thu Aug 16, 2018 7:02 am
Where I can change this settings via CLI?
artz
Thu Aug 16, 2018 10:39 am
IntrusDave - you can find more information about this option here:
https://wiki.mikrotik.com/wiki/Manual:S ... repository
https://wiki.mikrotik.com/wiki/Manual:T ... Properties
diablothebest - this can be done under /interface bridge port
https://wiki.mikrotik.com/wiki/Manual:I ... t_Settings
ath - can you please port an example and configuration when this was working?
boldsuck
Fri Aug 17, 2018 11:00 pm
Same in Webfig and Terminal. DHCPv6 client Flag = I - invalid.
IPv6 connection works without problems. :wink:
[admin@migo] /ipv6 route> check
status: ok
interface: pppoe-out1
nexthop: ::
[admin@migo] /ipv6 route> print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, o - ospf, b - bgp, U - unreachable
#      DST-ADDRESS               GATEWAY                  DISTANCE
0 ADS	 ::/0			pppoe-out1			1
1 DS	 ::/0			fe80::90:1a00:2a3:47c...	1
2 ADSU	 2001:4dd2:8986::/48					1
3 ADC	 2001:4dd2:8986::/64    bridge-local			0
[admin@migo] /ipv6 dhcp-client> print
Flags: D - dynamic, X - disabled, I - invalid
#    INTERFACE	STATUS          REQUEST         PREFIX            ADDRESS
0  I	pppoe-out1       bound              prefix             2001:4dd2:8986::/48, 22h28m17s
adamgardner2
Sat Aug 18, 2018 1:32 am
So, I spun up a brand new CHR in AWS and updated it to 6.43rc56, to play around with it. One of my main goals was to update the ruby 'mtik' gem to use the new login method, so that when the 6.43 is eventually released for real, I can continue to use it.
Oddly, though, the old login method still seemed to work on 6.43rc56. Is it intended that both methods are available at the moment? While that certainly provides a better transitional user experience, it does seem to imply that the unhashed password is still being stored (at least insofar as I understand the challenge-response login process).
Can anyone clarify this?
soomanyquestions
Sat Aug 18, 2018 9:19 pm
Just posting a datapoint that the disable-pmkid=yes option works flawlessly with android, iphone, ipad, 2x windows 10 laptop, a macbook pro and a LG smart tv.
mlenhart
Mon Aug 20, 2018 11:53 pm
I have to report, that distance measurement does not work correctly. On AP side it reports 706.54m while on client side just 374.28m (374.28 is the correct distance)
tigro11
Wed Aug 22, 2018 5:02 pm
hi guys, it seems to me that it is still not possible to change the date format in dd / mm / yyyy. It would be very useful as I also work with userman reports.
Does anyone have a solution?
thank you
Valerio
pe1chl
Wed Aug 22, 2018 5:04 pm
thank you
Valerio
I agree with that, it should be possible to have a system setting that changes the date format everywhere, but it would be feature request not something for the v6.43rc topic.
tigro11
Wed Aug 22, 2018 5:09 pm
very strange, now all the devices have the ability to change the format of the date ....
I am amazed that until now nobody has raised the problem
S4bulba
Thu Aug 23, 2018 12:07 am
Version 6.43rc56 as well as version 6.43rc51 are good builds for 951Ui-2nD.WAN PPPoE stability , good wireless signal for what i use in my house.No problems for a casual SOHO user.
diablothebest
Thu Aug 23, 2018 8:15 pm
I lose my UserManager database on last RC!
diablothebest
Thu Aug 23, 2018 8:17 pm
Lost all userman data on last RC...
freemannnn
Forum Veteran
Forum Veteran
Thu Aug 23, 2018 8:52 pm
viewtopic.php?t=134098
emils
Forum Veteran
Forum Veteran
Fri Aug 24, 2018 10:12 am
Version 6.43rc64 has been released.
Before an upgrade:
*) bridge - added an option to manually specify ports that have a multicast router (CLI only);
*) bridge - added a warning when untrusted port receives a DHCP Server message when DCHP Snooping is enabled;
*) bridge - added more options to fine-tune IGMP Snooping enabled bridges (CLI only);
*) bridge - added support for DHCP Option 82 (CLI only);
*) bridge - added support for DHCP Snooping (CLI only);
*) bridge - added support for IGMP Snooping fast-leave feature (CLI only);
*) cloud - close local UDP port if no activity;
*) console - made "once" parameter mandatory when using "as-value" on "monitor" commands;
*) console - removed automatic swapping of "from=" and "to=" in "for" loops;
*) crs326/crs328 - fixed packet forwarding when port changes states with IGMP Snooping enabled;
*) crs3xx - added hardware support for DHCP Snooping and Option 82;
*) crs3xx - fixed packet forwarding when "frame-type" is changed (introduced in v6.43rc51);
*) crs3xx - fixed SwOS config import;
*) defconf - fixed default configuration for RBSXTsq5nD;
*) dhcpv6-client - fixed false invalid flag (introduced in v6.43rc56);
*) fetch - added "as-value" output format;
*) fetch - fixed address and DNS verification in certificates;
*) health - added missing parameters from export;
*) ipsec - improved stability when using IPsec with disabled route cache;
*) leds - fixed LED behaviour when bonding is configured on SFP+ interfaces;
*) lte - added "sector-id" to info command;
*) lte - fixed SIM7600 series module support with newer device IDs;
*) ppp - added support for Alfa Network U4G modem;
*) rb3011 - added IPsec hardware acceleration support;
*) snmp - added EAP identity to CAPsMAN registration table;
*) supout - added monitored bridge VLAN table to supout file;
*) switch - added CPU Flow Control settings for devices with a Atheros8227, QCA8337, Atheros8327, Atheros7240 or Atheros8316 switch chips;
*) tr069-client - use SNI extension for HTTPS;
*) w60g - added "beamforming-event" stats counter;
*) wireless - accept only valid path for sniffer output file parameter;
*) wireless - added "czech republic 5.8" regulatory domain information;
*) wireless - added "etsi2" regulatory domain information;
*) wireless - added option to disable PMKID for WPA2;
*) wireless - updated "czech republic" regulatory domain information;
nescafe2002
Forum Veteran
Forum Veteran
Fri Aug 24, 2018 11:07 am
That was.. unexpected! :D
zyzelis
Fri Aug 24, 2018 11:26 am
Dear Mikrotik stuff,
please add dhcp option82 to dhcp server
mrz
Fri Aug 24, 2018 11:32 am
Already possible with RADIUS server.
bennyh
Fri Aug 24, 2018 12:23 pm
very-very-very-very big thanks for the Miki stuff if it works :D
If they fix the web proxy ipv6 website support too that will makes me very happy :D
nkourtzis
Fri Aug 24, 2018 12:55 pm
And VERY VERY welcome! Thanks Mktik!
zyzelis
Fri Aug 24, 2018 1:01 pm
Yes i know that.
But to keep radius only for option82 not very smart. isn't?
nkourtzis
Fri Aug 24, 2018 1:20 pm
The winbox behaviour where winbox closes upon reconnecting to a previously broken connection, is again here since v3.16. It occurs not always, but quite often. Mktik, can you please look into it?
Another issue: I am trying to connect to a device via RoMON which runs over a EoIP connection (L2 only, not bridged, no IPs) which is established over a L2TP tunnel. Even though the L2TP tunnel is quite stable, winbox cannot stay connected for more than a few seconds at a time. Actually, winbox opens the RoMON connection, but any list (say, interfaces) shows up empty and after a few seconds the window closes. Any ideas?
gwartass
Fri Aug 24, 2018 3:13 pm
Is it what I mean? So now we'll have two czech 5GHz ranges now - one for traditional channels and second for channels over 5700 which can have max transmit power 20dBi only?
If yes, It's great! Because now I have big problem if I have the wireless link calculated for 30dBi and DFS switches to channel over 5700 and 20dBi..
eworm
Fri Aug 24, 2018 3:33 pm
[admin@MikroTik] > :put [/tool fetch https://www.eworm.de/ip/ output=user as-value ]
data=80.133.168.147;downloaded=0;duration=00:00:01;status=finished
Finally we can fetch data without writing and reading a file. Thanks a lot!
Looks like it's required to cut the data part, though... Or is there a way to put the data only into a variable?
Jotne
Fri Aug 24, 2018 3:34 pm
Maybe we could have some hope that RB750Gr3 would get HW support sooooon. :mrgreen:
eworm
Fri Aug 24, 2018 3:36 pm
It has support for harware ipsec for a long time...
sindy
Fri Aug 24, 2018 3:38 pm
RB750 Gr3 does have hardware acceleration of IPsec ever since the first release. What it does not have is "hardware acceleration" of VLAN handling on the switch chip.
mkx
Fri Aug 24, 2018 3:55 pm
Unfortunately this is true for most devices, some of them have quite a decent switch chip built in.
eworm
Fri Aug 24, 2018 3:56 pm
[admin@MikroTik] > :global test
[admin@MikroTik] > :set test [ / tool fetch https://www.eworm.de/ip/ output=user as-value ]
[admin@MikroTik] > :put [ :pick $test 0 ]
80.133.168.147
Works!
Thanks Mikrotik!
(BTW, what the hell make the formatting go nuts?)
mkx
Fri Aug 24, 2018 3:59 pm
Never mind.
emils
Forum Veteran
Forum Veteran
Fri Aug 24, 2018 4:00 pm
eworm, proper syntax would be:
:local test ([tool fetch url="https://www.eworm.de/ip" output=user as-value]->"data");
:put $test;
https://wiki.mikrotik.com/wiki/Manual:T ... a_variable
eworm
Fri Aug 24, 2018 4:03 pm
:put $test;
Even better! Thanks a lot!
osc86
Fri Aug 24, 2018 4:04 pm
I lost all ipsec connections after updating to rc64 because of a bug in peer profiles.
emils
Forum Veteran
Forum Veteran
Fri Aug 24, 2018 4:12 pm
osc86, we are aware of the issue. It will be fixed until 6.43 is released in current release channel.
sindy
Fri Aug 24, 2018 4:18 pm
You have to use preview and add some empty lines before the [code] ones where necessary.
osc86
Fri Aug 24, 2018 8:07 pm
Something must have been changed with ipsec processing in rc64. No traffic is passing through the tunnels.
I moved back to 56, where everything works fine.
msatter
Fri Aug 24, 2018 8:27 pm
It would be nice if that would also be communicated in the changelog if something gets broken in the process and there is knowledge about that. Preferable also in red to warn.
Saves downgrades for some who are using that specific feature.
mrz
Fri Aug 24, 2018 8:50 pm
Contact support with attached supout file.
JimmyNyholm
Fri Aug 24, 2018 9:10 pm
And what about making radius login scheme selectable. chap for people who use static shit that can be challenged pap for us who only use one time passwords.
JimmyNyholm
Fri Aug 24, 2018 9:12 pm
And what about making radius login scheme selectable. chap for people who use static shit that can be challenged pap for us who only use one time passwords. And therefore Inherrently dosen't have anything to do a challenge on. (CHAP is unusable in this case)
kometchtech
Sat Aug 25, 2018 3:53 am
I updated to rc64, but it seems I can not communicate with ipv6. There was no problem with at least rc56.
We used netinstall to reintroduce rc64, but the situation has not changed.
nicob
Sun Aug 26, 2018 2:06 pm
Same problem here, I updated from rc51 to rc64 and now the mikrotik does not seems to forward ipv6 packets anymore.
huntermic
Mon Aug 27, 2018 12:10 pm
Strange, all works fine here after upgrading to rc64
Aytishnikcom
Mon Aug 27, 2018 9:47 pm
bennyh
Tue Aug 28, 2018 7:57 am
Has anybody tried it? Any positive changes? Are CPU loads lower? Is it stable?
emils
Forum Veteran
Forum Veteran
Tue Aug 28, 2018 12:05 pm
IPsec throughput test results will be published on the RB3011 product page in the next few days. Currently one user has reported a kernel failure caused by the new hardware acceleration. We are looking into it and hopefully will be able to fix it in the next release candidate version. Initial tests show approximately 4 times higher throughput compared to software encryption.
ivicask
Tue Aug 28, 2018 10:42 pm
I cant update CCR1009-7G-1C from 6.43rc51 to 6.43rc64, i click check for updates, download&install, after reboot i still have old version.Tried also manually downloading the file and puting into root and rebooting, same thing.
EDIT:I figured it , i had other router package so it failed to select proper one to install.
emils
Forum Veteran
Forum Veteran
Thu Aug 30, 2018 8:34 am
Version 6.43rc66 has been released.
Before an upgrade:
Changes in this release:
*) bridge - added support for BPDU Guard;
*) bridge - added support for DHCP Snooping;
*) bridge - ignore tagged BPDUs when bridge VLAN filtering is used;
*) certificate - fixed RA "server-url" setting;
*) dhcpv6-client - improved dynamic IPv6 pool addition process;
*) ipsec - added "responder" parameter for "mode-config" to allow multiple initiator configurations;
*) ipsec - fixed AES-192-CTR fallback to software AEAD on ARM devices with wireless and RB3011UiAS-RM;
*) ipsec - fixed "static-dns" value storing;
*) ipsec - improved invalid policy handling when a valid policy is uninstalled;
*) l2tp - allow setting "max-mtu" and "max-mru" bigger than 1500;
*) lte - fixed LTE registration in 2G/3G mode;
*) ppp - added support for Telit LM940 modem;
*) snmp - fixed interface speed reporting for predefined rates;
*) supout - added "files" section to supout file;
*) switch - added CPU Flow Control settings for devices with a Atheros8227, QCA8337, Atheros8327, Atheros7240 or Atheros8316 switch chip;
*) tr069-client - allow editing of "provisioning-code" attribute;
*) userman - fixed "shared-secret" parameter requiring "sensitive" policy;
*) webfig - fixed www service becoming unresponsive;
*) winbox - added "tag-stacking" option to "Bridge/Ports";
*) winbox - fixed "bad-blocks" value presence under "System/Resources";
*) winbox - fixed "IP/IPsec/Peers" section sorting;
*) winbox - renamed "VLAN Protocol" to "EtherType" under bridge interface "VLAN" tab;
*) wireless - require "sniff" policy for wireless sniffer;
freemannnn
Forum Veteran
Forum Veteran
Thu Aug 30, 2018 9:47 am
just installed latest rc to test dhcp snooping and was amazed how fast winbox connects remotely to my rb at office that i upgraded.
eworm
Thu Aug 30, 2018 10:07 am
I updated a system from 6.42.7 to 6.43rc66, now my ipsec connections are broken... Peer configuration had a comment about wrong parameter (can't give the exact wording). Switched mode-config to "none", now setting it to "request-only" fails:
[admin@Mikrotik] > / ip ipsec peer set mode-config=request-only [ find where !dynamic ]
failure: Wrong mode-config
emils
Forum Veteran
Forum Veteran
Thu Aug 30, 2018 10:09 am
Send a supout.rif file to support@mikrotik.com
eworm
Thu Aug 30, 2018 10:41 am
Done, Ticket#2018083022003478
kometchtech
Thu Aug 30, 2018 10:50 am
As usual, client PC under Routerboard can not connect with IPv6.
Also, if you try to disable dhcp-snooping or option 82 again and enable it again, it is confirmed that the command times out.
[Ticket#2018083022003334]
eworm
Thu Aug 30, 2018 10:54 am
Worked around the issue:
/ ip ipsec mode-config add name=request responder=no system-dns=no
/ ip ipsec peer set mode-config=request [ find where !dynamic ]
So my system is up and running, but I suppose this is not how things are supposed to work.
kometchtech
Thu Aug 30, 2018 8:21 pm
Problems were solved by netinstalling Routerboard, which can not be connected normally from client PC under Routerboard with ipv6.
However, it is unknown whether this correspondence is satisfactory.
grusu
Sat Sep 01, 2018 10:53 pm
I can't change the name of the admin user:
[admin@MikroTik] > /user set 0 name=test
nor any other user.
dziku2
Sun Sep 02, 2018 11:47 am
There is a problem with 6.43RC66 on hAP AC2. My router reboot itself with info in log file: system,error,critical System rebooted because of kernel failure every half hour to 6 hours.
nescafe2002
Forum Veteran
Forum Veteran
Sun Sep 02, 2018 1:39 pm
Can you fetch autosupout.rif from the device and send it to support?
dziku2
Sun Sep 02, 2018 9:12 pm
Sorry, I can't. I downgraded soft to 6.42.7
eworm
Thu Sep 06, 2018 4:46 pm
Technically this is not about the release candidate version, posting here because of changelog:
Me device is running current version 6.42.7 and I want to update the latest release candidate. Looks like disabling ddns fails:
[admin@MikroTik] > / ip cloud set ddns-enabled=no
[admin@MikroTik] > / ip cloud print
    ddns-enabled: no
     update-time: yes
  public-address: 198.51.100.65
        dns-name: xxxxxxxx.sn.mynetname.net
          status: Error: request timed out
I can still query dns for my address. This should remove the record from dns, no?
mkx
Thu Sep 06, 2018 5:47 pm
After a while ... depends on how often is RB supposed to renew the DDNS record. If you turn cloud off, cloud (hopefully) doesn't know it and records have to expire.
eworm
Thu Sep 06, 2018 5:55 pm
No. From https://wiki.mikrotik.com/wiki/Manual:IP/Cloud:
After router sends it's IP address to the cloud server, it will stay on the server permanently. DNS name (/ip cloud dns-name) will resolve to last sent IP address. When user set /ip cloud set ddns-enabled=no router will send message to server to disable DNS name for this routerboard.
juliokato
Thu Sep 06, 2018 6:16 pm
eworm
Thu Sep 06, 2018 9:59 pm
    ddns-enabled: no
     update-time: yes
Works now, at least after some retries. Possibly the servers were too loaded?
telcouk
Fri Sep 07, 2018 9:24 pm
If IPv6 is configured on a bridge, you may need to mark the bridge port as "Trusted".
This resolved the issue for us.
risk
Sat Sep 08, 2018 4:40 pm
nor any other user.
same here.
rc56 was fine.
Users browsing this forum: rua and 72 guests
