doush
Long time Member
Long time Member
Re: v6.42.2 [current]
Wed May 23, 2018 2:12 am
@storp
Same here.
Institor
Wed May 23, 2018 10:23 am
If neighbor discover-interface-list is set to exclude (i.e. !WANs, where WANs is list of interfaces, for example), export command produces incorrect output (without "!")
> /ip neighbor discovery-settings set discover-interface-list=!WANs
> /ip neighbor export
set discover-interface-list=WANs
ofer
Wed May 23, 2018 11:53 am
This update has bricked one of my HAP AC units to a reboot loop I had to use netinstall to restore it (first time for me)
After netinstall and upgrade everything seems fine :D
Thanks!
alexsolovyev
Wed May 23, 2018 3:05 pm
Be carefull, netwatch utility broken since 6.42.1. Up and down scripts does not execute.
A scheduler can be used as a workaround, e.g.
/system scheduler
add disabled=yes interval=1m name=script1 on-event=\
    "/system scheduler disable script1\r\
    \n/system script run script1" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=may/23/2018 start-time=00:00:00
add disabled=yes interval=1m name=script2 on-event=\
    "/system scheduler disable script2\r\
    \n/system script run script2" policy=\
/system script
add name=script1 owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=\
    "/log info \"script1 runs\""
add name=script2 owner=admin policy=\
    "/log info \"script2 runs\""
/tool netwatch
add down-script=\
    "/log info \"down, enable script2\"\r\
    \n/system scheduler enable script2" host=8.8.8.8 up-script=\
    "/log info \"up, enable script1\"\r\
    \n/system scheduler enable script1"
Clevelus
Wed May 23, 2018 4:40 pm
CHR 6.42.2 not working on Hyper-V (VMM SCCM network)
Every few hours (if used IPSec every 30 min) interface is not visible any MAC address (in ARP table)
Reboot (for example as Watchdog timer to ping gateway) and some time works further.
The properties of the network interface shows that the full duplex does not work and there are problems.
Modestas
Wed May 23, 2018 11:32 pm
Hi
I wonder if VPNFilter malware threat is addressed in this release.
See https://www.symantec.com/blogs/threat-i ... ot-malware and https://blog.talosintelligence.com/2018 ... ilter.html for more details.
jmay
Wed May 23, 2018 11:37 pm
Thanks!
Same thing just happened to me. Updated all the MT's at home and now my outdoor AP seems to be power cycling. I shoulda left it alone. Tonight I get to climb up to the 18' roof and fix, YAY!
EDIT, been so long since I had to use netinstall I was thinking I needed a serial port. Forgot that I also have a server running at home so I remoted in fixed the HAP AC so big deal since it was at my house. Would have been awful had it been a production device somewhere tho.
dravnieks
Thu May 24, 2018 12:20 am
RB HEXr3 upgrade from 6.42 to 6.42.2
dude packet also active
Manual ugrade in windows dude.exe 6.42.2 , and cant log in
SAY: cant read database
edit
go back to 6.42.1 .. and again
cant read database .. well done mikrotik.. aaaaah
Well first post says. Export and backup your config before upgrade :D In my undestanding that would include downloading dude database export to PC before upgrade.
artemk
Thu May 24, 2018 12:43 am
Hi
Apprently - it is not fixed in 6.42.2. I found logins as admin from different IPs allover the world to my CCRs1036 with 6.43rc11.
Moreover not only CCRs are affected as I found similar logins into my RB3011.
What is common - is that VPN server (pptp and l2tp) was enabled and accessible from internet on all affected devices.
pe1chl
Thu May 24, 2018 1:13 am
Did you find actual logins, or only logs about attempted logins that were not successful?
And why do you enable logins from internet?
td32
Thu May 24, 2018 1:25 am
i guess he got pwned on the previous version(stolen user pass), then upgraded but did not change access credentials.
But they still have the credentials to login.
pe1chl
Thu May 24, 2018 1:36 am
Yes, you should always make backups and in case you are running Dude you should do regular exports and store them on another system.
However in reality we see people here who run a WISP for business and never made a backup or only did so 9 months ago...
It is of course a disaster waiting to happen, but I guess in some regions the WISP business is very attractive for people with little hand-on experience with networking and no knowledge about generic IT practices.
anuser
Long time Member
Long time Member
Thu May 24, 2018 11:22 pm
Version 6.43rc17 has been released.
*) wireless - fixed wireless interface lockup after period of inactivity;
*) wireless - increased stability on hAP ac^2 and cAP ac with legacy data rates;
*) wireless - improved client "channel-width" detection;
It would be great if we could get those wireless fixes into 6.42.3
upower3
Fri May 25, 2018 8:57 am
I have a ccr1009 with flash partitioned into 2 partitions. So each of that flash parts are of 32 Mb, which was ok for me so far.
After recent upgrade to 6.42.1 I found all of my flash almost taken by unknown (invisible) files or data. Right now I have only 10 Mb of flash and the upgrade to 6.42.2 needs ~15Mb. I asked this in different topic and got
this answer saying I'm not along with the problem, so looks like 6.42.1 upgrade script won't do its job well, or something. Not sure is this can be more widespread or not, and surely don't know if this can happen to any new version.
What should I do? The device is on remote location so it's not an option to netinstall it. So far I can not upgrade to any new version.
How can I clean up these extra files/data? If I format the flash then the device won't boot afterwards, isn't it?
strods
Fri May 25, 2018 10:25 am
Version 6.42.3 has been released in current channel:
viewtopic.php?f=21&t=134824
strods
Thu May 31, 2018 9:48 am
Everyone who complained about the Netwatch issue - Please see this topic viewtopic.php?f=2&t=134538
Users browsing this forum: DanMos79, eworm, fl4co, sutrus, Techsystem and 15 guests
