strods
Winbox 3.14 released!
Mon May 28, 2018 11:12 am
What's new in v3.14:
*) added support for new style authentication and encryption for connections to RouterOS v6.43;
*) make all connections in secure mode (all data is encrypted with AES128-CBC-SHA);
*) make winbox self upgrade check .exe signature;
*) make up/down keys select previous/next entry in address/neighbors list in connect window while login name or password fields are in focus;
*) make mouse wheel work anywere in connect window if login or password fields are in focus;
*) remember Romon Neighbours Table column widths;
*) fixed problem where selected table items were moved to the top if the table filters dropdown button was clicked twice;
If you experience version related issues, then please report them to support@mikrotik.com.
Winbox is available here:
http://www.mikrotik.com/download
If you try to upgrade directly from Winbox loader and version is not available, then you might need to wait for a while until cache in path between your device and our servers is refreshed.
Spidlacz
Re: Winbox 3.14 released!
Mon May 28, 2018 11:28 am
Why does Winbox look for neighbors when running with parameters and directly connecting to a device? There is always a delay of about 2 seconds.
freemannnn
Long time Member
Long time Member
Mon May 28, 2018 12:56 pm
thank you for this aked by many forum members
and thank you for this personal request!!!!
Chupaka
Mon May 28, 2018 1:52 pm
Sweet! Works good! Thanks!
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
R1CH
Forum Veteran
Forum Veteran
Mon May 28, 2018 6:50 pm
Nice to see a focus on security! Does the "new style authentication" in 6.43 include router/host verification so that man in the middle attacks are no longer possible?
Chupaka
Mon May 28, 2018 7:01 pm
It doesn't. It's just new way of password hashing :) SSH checks hosts.
R1CH
Forum Veteran
Forum Veteran
Mon May 28, 2018 7:05 pm
I just tested this.. it checks for a signature, but not Mikrotik's signature! I sign it myself and winbox blindly runs it :-?
https://imgur.com/7k8e09p
netflow
Mon May 28, 2018 7:43 pm
Is that really certificate based ? Or simply some MD5 hash ? In the later case this should not be called signature as this has nothing to do with a secure feature.
R1CH
Forum Veteran
Forum Veteran
Mon May 28, 2018 9:09 pm
It checks that the .exe has authenticode signature (certificate based), but doesn't care who the signer is. It should verify that the Mikrotik public key is used.
bajodel
Long time Member
Long time Member
Mon May 28, 2018 9:20 pm
Now it works again ! Thanks
diablothebest
Mon May 28, 2018 9:26 pm
Works fine with CHR!
ErfanDL
Mon May 28, 2018 11:25 pm
Add dark mode please
Sent from my C6833 using Tapatalk
rzirzi
Tue May 29, 2018 7:47 am
NOT repaired problem with log displaying at high resolution screens and Windows scaling: viewtopic.php?f=2&t=134723
MikroTik team - please repair that problem.
normis
Tue May 29, 2018 9:55 am
Yes, but to be honest, I can't imagine which other legitimate organisation would go to the trouble of using their Extended Validation certificate to sign Winbox :) It's not like it is simple to obtain.
normis
Tue May 29, 2018 10:06 am
Man in the middle attack is not possible, because
*) WinBox now uses ECSRP for key exchange and authentication (requires new winbox version),
both sides now verify that other side knows password (no man in the middle attack is possible anymore);
Chupaka
Tue May 29, 2018 12:21 pm
Nice. Can we see SRP in API login?
zyzelis
Tue May 29, 2018 12:32 pm
+1 for dark mode. Its very useful when you are on site and laptop batery is <50%
genesispro
Tue May 29, 2018 12:43 pm
+1
Mikrotik Rulez
R1CH
Forum Veteran
Forum Veteran
Tue May 29, 2018 3:00 pm
I used a regular non-EV certificate to sign the example, those are easy to get and easy to buy on dark web too. A lot of malware abuses code signing certificates these days.
normis
Tue May 29, 2018 3:06 pm
You must accept it in Windows trusted certificates first. At least in our test here it must be so.
R1CH
Forum Veteran
Forum Veteran
Tue May 29, 2018 3:11 pm
I've tested on 2 PCs, one of them is the PC which has the signing certificate and private key, the other one is a fresh Windows 10 laptop with no certificates installed. Both ran the example .exe file with no warning.
You can test it yourself, simply edit hosts file or add static DNS to point upgrade.mikrotik.com to 188.226.152.164. The example .exe is harmless, it shows only a messagebox and exits.
acung
Tue May 29, 2018 3:16 pm
I winbox to RB751U-2HnD and RB751G-2HnD via rb751gr2(romon), there is no wireless menu.
ditonet
Forum Veteran
Forum Veteran
Tue May 29, 2018 4:54 pm
Same problem was also with previous version 3.13.
Regards,
Grzegorz | MTCNA, MTCRE, MTCSE, MTCSWE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
rzirzi
Tue May 29, 2018 6:26 pm
Normis - could You tell me when will be solved problem witl Log display at WinBox and high resolution screens (with WinBox Windows scaling)?
strods
Wed May 30, 2018 7:39 am
The problem with missing specific menu in Winbox (when connected over RoMON) is a known issue that will be fixed in upcoming Winbox/RouterOS releases. Problem is that the RoMON agent does not have this menu.
normis
Wed May 30, 2018 8:51 am
What problem do you mean? Tell me the version of OS you have used, and how the issue manifests itself.
Chupaka
Wed May 30, 2018 11:20 am
For example, MacOS, 120 dpi instead of 96:
The same is in Windows
normis
Wed May 30, 2018 11:28 am
We have many many retina MacOS devices here, also Linux.
See attachment. No issue. Same in Log section.
Also tried other DPI settings. Still no issues. Probably Wine config problem.
Chupaka
Wed May 30, 2018 12:31 pm
I just went to winecfg, Graphics, and increased Screen Resolution
normis
Wed May 30, 2018 12:35 pm
How about checking actual HiDP Displays, not trying to simulate something that isn't taking place :) ?
Chupaka
Wed May 30, 2018 12:45 pm
Unfortunately, changing display settings is not possible over RDP, so I can't show you scaling in Windows right now :)
Chupaka
Wed May 30, 2018 12:47 pm
What about this post?
viewtopic.php?p=581768#p581768
normis
Wed May 30, 2018 1:10 pm
Has nothing to do with DPI, the log column sizing is a different question.
mrz
Wed May 30, 2018 1:18 pm
Windows removed display options from control panel, leaving only scaling in new settings. There are no problems with increased scaling:
JimmyNyholm
Wed May 30, 2018 1:24 pm
Does this let us get Radius with pap work later on for winbox login (I am using OTP-Tokens there simply is nothing to do chap on so now it's impossible to login to winbox in my more secure way) Question about to be able to have setting for pap/chap in Ros has been sent to Support since a long time back. This notice makes me think there could be an openings for this later on in development cycles.
Traveller
Wed May 30, 2018 3:04 pm
mrz:
In the new edition of Windows 10 (1803), font scaling is made more diverse. There are three options: "application, system, extended system". Sorry, windows on russian location.
On the "system / system extended" in the log fields everything is visible. But the fonts are fuzzy. On the "application", clear fonts. But you can not see the fields in the log file.
jondavy
Wed May 30, 2018 4:53 pm
the wireless menu not show and not work with this winbox
avacha
Wed May 30, 2018 4:58 pm
Normis
We have a number of remote devices with remote acces via VPN (only for support tech people). These remote devices all have same private IP as VPN router. It looks like (client 172.16.1.x) <----> (vpn router 172.16.1.1). These networks are never will be connected together, so this is not big trouble about routing. Currently it's working fine and we don't touch this, except for ROS upgrades for security reasons (all this some kind a legacy, nevermind).
But we have some problems when we trying to save winbox params for connections to these devices. Winbox uses IP as unique ID and just replace logins and notes in saved sessions. Can you just make a checkbox in winbox settings like "use Note column as primary key" or something simular? It can be disabled by default.
eddieb
Wed May 30, 2018 5:00 pm
works fine here with winbox 3.14 to RB962 running ROS 6.42.3
Running 6.48.1 (stable) on :
CCR1009-8G-1S (2x ipsec/l2tp site-to-site, ipsec/l2tp roadwarrior, dhcpd, dns), CRS125-24G-1S, RB1100, RB962UiGS-5HacT2HnT (10pc), RB931-2nD, RB951, RB750GL ,RB2011UAS-RM, PWR-LINE-AP, RB750Gr3 running dude
Chupaka
Wed May 30, 2018 5:03 pm
RoMON? Known and will be fixed
LatinSuD
Wed May 30, 2018 9:46 pm
Could it display a better error message when trying to connect to RouterOS 5.x?
It currently says:
ERROR: could not fetch index
Maybe something like "Remind that connecting to RouterOS 5.x or lower is not supported anymore" would be better
LatinSuD
Wed May 30, 2018 9:55 pm
On the RouterOS 5.x support issue, I know that removing support for deprecated systems is always more secure, but...
Have you considered whitelisting all previously released DLL?
It would be something like matching DLL against hardcoded hashes before installing and them.
expert
Wed May 30, 2018 11:03 pm
Winbox 3.14, but also all older versions:
How to edit such dialog window, when screen is so small? Scroll does not work.
Why aren't interfaces sorted by name?
CZFan
Location: South Africa, Krugersdorp (Home town of Brad Binder)
Thu May 31, 2018 1:42 am
As a workaround you can use Terminal / CLI to make changes, but a scroll bar will be good
MTCNA, MTCTCE, MTCRE & MTCINE
conrad
Thu May 31, 2018 11:54 am
People have long asked to increase the size of the fields in the log by only a few pixels....
You offer them to change the usual settings of their monitors.
It's not logical to change what you're used to.
normis
Thu May 31, 2018 11:58 am
Like shown in the examples, there is no problem with any monitor settings. If you have a problem, maybe it is caused by something else in your PC.
jebz
Thu May 31, 2018 12:16 pm
Normis
I've often struck this problem and would like some other field as the primary key as well. The router name or mac address would be better candidates for me.
conrad
Thu May 31, 2018 12:18 pm
I have no problem changing the settings.
But then I get a blurry font and the most important thing on the screen is less information.
And you have been told about this by other users many times.
Ask again.....
Is it really difficult to increase the size of the fields in the log at the repeated request of not only my but also other users ???
Traveller
Thu May 31, 2018 1:03 pm
Like shown in the my examples, the problem exists.
td32
Thu May 31, 2018 1:16 pm
whoever has a vertical screen resolution of 768 and below is faced with the No scroll issue. CLI is a work around, but it is still an issue in winbox
mrz
Thu May 31, 2018 4:37 pm
"application" disables all Windows scaling settings and only use the app developer's setting (winbox will appear in its original size) or ones with altered DPIs by other means (which of course will give weird appearance).
Choose the right settings. "System (Enhanced)" and in system->display->advanced scaling settings "Let windows try to fix apps so they're not blurry"
150% scaling and nothing in winbox is blurry
Traveller
Thu May 31, 2018 6:08 pm
Yes. "System (Enhanced)" is better than "System". But "application" is better than "System (Enhanced)". In "application" font is more delicate, clear, pleasant and standard for Windows than the font in "System (Enhanced)".
"application" font
"System (Enhanced)" font
Default explorer font in Windows
mrz
Thu May 31, 2018 6:39 pm
You will not get the same look because of image scaling and post processing.
conrad
Thu May 31, 2018 7:30 pm
If you remember the first beta 3.x you made it possible to change the size of the fields in the log.
In final version 3.x you have removed this possibility, promising to return it later.
Unfortunately I can't find this post but remember exactly what it was.
kewlgai
Thu May 31, 2018 8:43 pm
hello, help me find the hotspot on the gui? if i login with romon i can't find the /ip hotspot on the gui.
raffav
Thu May 31, 2018 10:55 pm
@normis
I'm getting a strange behavior I could't find a way to reproduce,
but either don't know if related to ROS 6.43RC or Winbox
in only one device a RB450G even if i put the correct pass i get error msg on winbox 3.14, I need to clear the pass and retype it and keep trying until I get access
My pass all are salved
acung
Fri Jun 01, 2018 10:37 am
Regards,
Not happened to me with version 3.13
Kraken2k
Fri Jun 01, 2018 11:39 am
I have problem with "Reconnect" button after the connection was lost: after clicking it, the Winbox window disappear. According to log, login to router was successful, but automatically disconnected after 30 seconds. (never happened in 3.13)
chubbs596
Fri Jun 01, 2018 12:24 pm
I have seen the same issue
LatinSuD
Fri Jun 01, 2018 4:52 pm
Check that hotspot package is installed and enabled in System -> Packages.
It should be by default anyway.
andymok
Fri Jun 01, 2018 9:39 pm
Random mode switch-over quickly in Quick Set, causing settings completely wiped out before hitting any apply / ok, cancel / closed could not undo the changes either. Blocking myself complete out and router unreachable.
Forced to reset router and config Quick Set only via Webfig, then I dare to continue the rest on Winbox. Even Webfig Quick Set cannot recall the done Home Dual AP settings neither, and keeps displaying WISP AP mode, good that as long as you don't hit apply it won't change anything
Not sure whether it is winbox or RC's problem.
hAP ac
Packages / firmware ver. 6.43rc21
Winbox 3.14
vipnet
Sun Jun 03, 2018 5:59 pm
Bug use rmon,
i closed and open winbox and connect direct
i test R3.14 perssist
Alex Endres.
VIPNET TELECOM LTDA - MONTENEGRO-RS/BRASIL
https://bmspanel.bmsoftware.org/parceir ... 95dd/0/N/N
vipnet
Sun Jun 03, 2018 6:24 pm
I recovery control winbox after start machine Rmon IP and click disconnect,
if select advanced mode and clean Romon box work
Please Fix BUG
Alex Endres.
azatko
Mon Jun 04, 2018 3:33 pm
could not connect to old routeros (4.x, 5x) - winbox 3.12 works fine
ERROR: coud not fetch index
Chupaka
Mon Jun 04, 2018 4:43 pm
What's new in v3.13:
*) abandoned support for connecting to older RouterOS versions (older than v6), no DLLs will ever be downloaded;
erebusodora
Mon Jun 04, 2018 6:34 pm
This version 3.14 works very slowly before connecting to the router. In version 3.13 or 3.12 is connect very fast to riuter
juliokato
Tue Jun 05, 2018 12:40 am
so it requires more CPU processing power from both sides and more information exchange.
I apologize my grammatical errors, my english not so good, I am not a native speaker.
Wiki is maintained in English. I use Google translator. 8)
Sves
Wed Jun 06, 2018 1:14 pm
Hello!
Please, add in Winbox a feature to copy in a clipboard the text from the section "Log".
Thank you!
R1CH
Forum Veteran
Forum Veteran
Thu Jun 07, 2018 7:18 pm
This also means you should rotate your passwords if you haven't been using secure mode, anyone on the network could have intercepted them.
Chupaka
Fri Jun 08, 2018 11:31 am
It doesn't. They weren't plaintext :)
k3dt
Mon Jun 11, 2018 1:02 pm
In this version is impossible to connect to RouterOS via mac-telnet over ethernet with active wifi connection on MacOS (via Crossover and Wineskin).. Version 3.13 works fine.
Benjamin9
Tue Jun 12, 2018 10:07 am
paolopoz
Wed Jun 13, 2018 11:38 am
Hello all!
Since today I stubmled upon a problem with Winbox 3.14: every time I try to connect to a host beyond NAT, the application get stuck saying "Downloading descriptors" and then it crashes.
This happens also on another PC on my LAN with winbox 3.14.
If I try with version 3.13 everything works fine.
Connecting to host inside the LAN works well.
I tried to clear cache and delete session files but this doesn't solve the problem.
This happens consistently across different RouterOS versions.
I reproduced it also through another connection, so it doesn't depend on our firewall or any other network equipment.
Any hint on what might be the cause? Did I catched a bug?
Thanks!
mindaugasb
Thu Jun 14, 2018 6:42 pm
Hi guys,
How can I download winbox 3.12 from official sources to be able to connect to the legacy 5.X versions?
Thus far I could only find unofficial versions in some blogs.
Is winbox available in one of the packages here: https://mikrotik.com/download/archive ?
If so - which package?
Thank you.
Chupaka
Thu Jun 14, 2018 6:52 pm
Just copy link to the current WinBox and change version to the necessary one: https://download.mikrotik.com/routeros/ ... winbox.exe
Chupaka
Sun Jun 17, 2018 10:55 pm
what downloads? what anonymity? any link?
tangram
Mon Jun 18, 2018 1:52 pm
+1 - this is very annoying, please help.
strods
Tue Jun 19, 2018 11:10 am
Winbox v3.15 has been released:
viewtopic.php?f=21&t=135874
Users browsing this forum: akakua and 34 guests
