Kraken2k
Re: Winbox vulnerability: please upgrade
Mon Oct 29, 2018 11:14 am
Automatic upgrade should be the default and is quickly becoming best practice.
This is plain stupid!
I could be fired on the spot if I don't issue warning about down time. Some environments depend on
equipment which is 24/7/365 up.
Not every one have Mikrotik in home or small office environment.
If you like automation there is what Normis proposed as a script for doing it.
Happy networking,
I think that automatic upgrade could be in "default configuration" - if you do anything beyond average home configuration (like the example you described), first step with a new device is "remove default configuration" and then config the device from the very beginning, tailored to your needs.
Home users, who does not care much and leave the default config on (or those who does not understand/does not care) will get automatic updates and won't stay behind with old vulnerable versions. And these usually don't run the critical applications, that does not survive two or three minutes outage during the night hours.
No, if that ever sees day light then it should be an "opt in" option with warning sign on first connect screen otherwise it should be as it is now.
That's my opinion based on 30 years of experience as system engineer/admin. I don't say it lightly.
Here, in country where I am from all home based routers CPE's are belonging to providers and are directly managed by them. If you use MT it will be in most cases behind their router with port forwarding enabled.
Br,
Sasa
Just to be sure, I would like to say, that by " should be in default configuration" I don't mean "it should be default value". Yes, default value (when you erase configuration) should be "off", in "default configuration" (the factory default when you turn on the device for the first time) it imho should be "on".
The reason is simple: if you just connect the device to network and you don't care about config at all, it become a ticking bomb for the rest of the network - this is is the way how to partially fix this kind of behavior (as it happens, and you cannot do anything about it). It's similar thing to default configuration that forbids the logon from WAN port. If you reset the configuration (which is what we usually do after RoS/firmware update), the option for autoupdate will be set to "off" and you can configure it by yourself as you want.
CsXen
Mon Nov 05, 2018 11:00 pm
Hi.
Well... our good old RB532A's gets no security updates, because MT retired the MIPSLE branch. Not backporting any security update.
And the latests release (6.33.4) is vulnerable... so we backrolled to 6.27, which is virtually not vulnerable.
We have no chance to filter the WAN side, because the Android WinBox app over a mobile net is comes from "random" IP's.
And we have no funds to change the hardware, because they works on charity based on some very remote site.
What to do ? Should I blame MT for they ignorance ? Or just pray and hope, that no vulnerability will be found in the old 6.27 ?
Best regards: CsXen
caresss
Mon Nov 05, 2018 11:45 pm
With my total respect to Mikrotik let me tell you guys again that your ROS 6.43.4 is still vulnerable and tonight I was playing with the hacker by closing every single door to access my router. He was kind enough not to directly change my password and kick me out ... He was just playing with some mangle rules and using my gateway to increase the traffic through whatever he needs making my WAN graph full all the time.
Regardless of all, I locked all ip services and changed the default ports to something way so far from the original. Created a syslog dedicated to this mikrotik RB2011UiAS where I wanted to see what was going. Initially, the hacker was using my username to gain access again and to unbind the winbox and telnet from locking them to internet IP and not keeping them.
I realized that and rapidly deleted all users and created a totally new crazy user with a hard to guess password. In a sudden I was still in mikrotik session, tracing the log I saw him got in again through mac-telnet he scans what's changed and logs on back from winbox :| "Casper". (while using telnet nothing is logged it is the first time I know this!)
After that, I dropped all the ways for him to access the router-board ... added his mac-address which appeared in mikrotik's log to filter rules "input,forward,output" dropping everything possible from his way ... For a sudden after countable minutes and I was still inside the mikrotik session, the router rebooted and I got kicked out! He did it this time and changed the password I knew that from the Syslog!!!!! It was logged because he ran to change the pass prior to entering and kicking him out and prior to changing the log location so I had the chance to read what happened while I was kicked out.
Unfortunately, it seems I have no chance except resetting the router but I am truly so highly disappointed from Mikrotik which I used its hardware/software personally for almost 14 years without a headache ... By this vulnerability which is still active my reliance on Mikrotik is 0 and I will be replacing all my companies firewalls/routers to something more which is rigid.
Sorry guys but we no longer have trust in your stuff.
Fix ROS6.43.3 because I am sure 10000% it is still vulnerable and I saw the proof tonight with a very long fight.
CsXen
Tue Nov 06, 2018 12:05 am
Hi.
If you can, try to switch on the packet sniffer, and log everything to and from your WinBox/API port.. and stream it to another machine to record it.
Probably it can be help to discover and resolve the problem.
Best regards: CsXen
honzam
Tue Nov 06, 2018 12:08 am
You have a proof? For example, screens or something?
LAN, FTTx, Wireless. ISP operator
caresss
Tue Nov 06, 2018 12:11 am
Hi.
Best regards: CsXen
I will do so when I reset the router in order to gain access back to it ...
honzam
Hi.
You can use VPN for remote access. It's simple and then WAN can be easily filtered...
caresss
Tue Nov 06, 2018 12:13 am
I have a full Syslog!
caresss
Tue Nov 06, 2018 12:15 am
Hi.
I secured the router perfectly closing every single anty door! Filtering and blocking the mac address of the attacker didn't do anything! Where is mikrotik from that!
honzam
Tue Nov 06, 2018 12:18 am
And? Can you share it with us? Or with support@mikrotik.com
caresss
Tue Nov 06, 2018 12:20 am
I will mask the users and mac address and post the log!
caresss
Tue Nov 06, 2018 12:55 am
Date Time Message Text
#Password changed and I cannot access the router anymore!
11/5/18 22:38:15 system,info,account user NewUserCreated logged in from ??:3B:??:22:??:AC via mac-telnet
#It seems he rebooted the router and I was unable to login as you see a failure below!
11/5/18 22:38:08 system,error,critical login failure for user NewUserCreated from 192.168.my.ip via winbox
11/5/18 22:37:52 interface,info ether5 link up (speed 1G, full duplex)
11/5/18 22:37:52 interface,info ether3 link up (speed 1G, full duplex)
11/5/18 22:37:52 interface,info ether1 link up (speed 1G, full duplex)
11/5/18 22:37:52 interface,info ether9 link up (speed 100M, full duplex)
11/5/18 22:37:52 interface,info ether8 link up (speed 100M, full duplex)
11/5/18 22:37:52 interface,info ether7-WAN link up (speed 100M, full duplex)
11/5/18 22:37:52 interface,info ether4 link up (speed 100M, full duplex)
11/5/18 22:37:52 interface,info ether2-WAN link up (speed 100M, full duplex)
11/5/18 22:37:08 system,info,account user NewUserCreated logged out from ??:3B:??:22:??:AC via mac-telnet
11/5/18 22:37:08 system,info,account user NewUserCreated logged out from 192.168.my.ip via winbox
11/5/18 22:36:56 system,info user NewUserCreated changed by NewUserCreated
11/5/18 22:32:56 system,info,account user NewUserCreated logged in from ??:3B:??:22:??:AC via mac-telnet
11/5/18 22:32:10 system,info,account user NewUserCreated logged out from 192.168.my.ip via telnet
11/5/18 22:32:08 system,info,account user NewUserCreated logged in from 192.168.my.ip via telnet
11/5/18 22:29:55 interface,info ether9up (speed 100M, full duplex)
11/5/18 22:29:53 system,info device changed by NewUserCreated
11/5/18 22:29:45 system,info filter rule changed by NewUserCreated
11/5/18 22:29:15 system,info,account user NewUserCreated logged out from 192.168.my.ip via telnet
11/5/18 22:29:10 system,info filter rule added by NewUserCreated
11/5/18 22:29:09 system,info filter rule added by NewUserCreated
11/5/18 22:29:07 system,info,account user NewUserCreated logged in from 192.168.my.ip via telnet
11/5/18 22:22:47 system,info,account user NewUserCreated logged out from ??:3B:??:22:??:AC via mac-telnet
11/5/18 22:22:21 system,info device changed by NewUserCreated
#This is the interface he was attacking from. I trusted the mikrotik filter more than disabling the interface BUT he was faster this time to change the newuserpass keeping me out!
11/5/18 22:22:21 interface,info ether9 link down
11/5/18 22:18:01 system,info arp entry changed by NewUserCreated
11/5/18 22:09:11 system,info,account user NewUserCreated logged out from 192.168.my.ip via telnet
11/5/18 22:07:22 system,info,account user NewUserCreated logged in from 192.168.my.ip via telnet
11/5/18 22:03:30 system,info mangle rule removed by NewUserCreated
11/5/18 22:03:25 system,info mangle rule removed by NewUserCreated
11/5/18 22:00:47 system,info,account user NewUserCreated logged in from 192.168.my.ip via winbox
11/5/18 21:59:49 system,info,account user NewUserCreated logged out from 192.168.my.ip via winbox
#This tells that I lost hope with everything and I had no other chance other than adding a filter rule to block his mac-address from input,forward,output!BUT nothing worked!
11/5/18 21:59:15 system,info filter rule added by NewUserCreated
11/5/18 21:59:03 system,info filter rule added by NewUserCreated
11/5/18 21:58:49 system,info filter rule added by NewUserCreated
#I can't believe it howcome he knew rapidly the exact newly created user!
11/5/18 21:56:36 system,info,account user NewUserCreated logged in from ??:3B:??:22:??:AC via mac-telnet
#After I cleaned fully my mikrotik he tried to login with the old deleted user as you can see below!
11/5/18 21:55:58 system,error,critical login failure for user OldDeletedUser from ??:3B:??:22:??:AC via mac-telnet
11/5/18 21:54:18 system,info address changed by NewUserCreated
11/5/18 21:54:14 system,info address changed by NewUserCreated
11/5/18 21:54:09 system,info address changed by NewUserCreated
11/5/18 21:54:05 system,info address changed by NewUserCreated
11/5/18 21:54:00 system,info address changed by NewUserCreated
11/5/18 21:53:44 system,info address changed by NewUserCreated
11/5/18 21:53:41 system,info address changed by NewUserCreated
11/5/18 21:53:12 system,info address added by NewUserCreated
11/5/18 21:53:07 system,info address changed by NewUserCreated
11/5/18 21:52:55 system,info address changed by NewUserCreated
11/5/18 21:52:44 system,info address changed by NewUserCreated
11/5/18 21:51:21 system,info nat rule changed by NewUserCreated
11/5/18 21:50:20 system,info address changed by NewUserCreated
11/5/18 21:50:06 system,info route changed by NewUserCreated
11/5/18 21:50:03 system,info route changed by NewUserCreated
11/5/18 21:49:32 system,info,account user NewUserCreated logged out from 192.168.my.ip via telnet
11/5/18 21:49:14 system,info,account user NewUserCreated logged in from 192.168.my.ip via telnet
11/5/18 21:47:47 system,info address changed by NewUserCreated
11/5/18 21:46:42 system,info route changed by NewUserCreated
11/5/18 21:44:30 system,info nat rule changed by NewUserCreated
11/5/18 21:44:29 system,info nat rule changed by NewUserCreated
11/5/18 21:43:13 system,info nat rule changed by NewUserCreated
I masked his mac and some ips ... after his last mac-telnet and login, logging stopped and I was no longer able to login again.
vecernik87
Tue Nov 06, 2018 2:07 am
Thanks for sharing! This does not look good and support staff should be notified. However, unless we give them some better info (ideally packet capture from TAP) I do not believe, they will be able to help. I can personally confirm that the known attack vector was closed. (I still have few devices on purpose with older ROS. I can hack them (i.e. steal passwords from any user) but the same approach does not work on new ROS). There might be another unknown attack vector. In addition, as far as I know, the file with readable passwords is still available in current ROS versions:
What's new in 6.43 (2018-Sep-06 12:44):
*) user - all passwords are now hashed and encrypted, plaintext passwords are kept for downgrade (will be removed in later upgrades);
Therefore if there is still some other way to access the file, it means it is still possible to get password of any user.
I will not speculate about possible reasons in your situation. There are many possibilities including unknown vulnerability or incorrect way of resetting device (maybe you didn't wipe it completely or you had it unprotected and connected for few minutes while attacker had enough time to implant some backdoor). Such speculation is wild guessing without knowing what really happened.
Anyway, you mentioned that your firewall rule for MAC address did not work. I can confirm such behavior - MAC winbox/telnet cannot be filtered using /ip firewall rules. For example following code won't do anything:
/ip firewall raw add action=drop chain=prerouting src-mac-address=3C:97:0E:D7:XX:XX
I believe that is happening because MAC winbox/telnet communication is not an IP communication, therefore does not go through "routing" block shown at packet flow and therefore it does not go through any chain available in /ip firewall. (however packet count of such rule still increase, which is weird...)
I found only way to filter incoming non-IP communication by creating a bridge over single interface and using /interface bridge filter. This unfortunately breaks other behavior because bridge will be in running state even if you disconnect the cable from your ethernet port.
Other way to block access to your MAC winbox/telnet is use correct interface-list in /tool mac-server and /tool mac-server mac-winbox. Simply said - there should be no MAC access to your device from WAN port. Can you please clear up, if the attacker was accessing your device from WAN and if you had enabled/disabled MAC access on WAN interface?.
Karas
Tue Nov 06, 2018 9:09 am
Um, quick question.
Isnt this hacker on your local network?
All the IPs Im seeing are local (unless I skipped over something), and logging in via mac-telnet...
Jotne
Forum Veteran
Forum Veteran
Tue Nov 06, 2018 10:02 am
With my total respect to Mikrotik let me tell you guys again that your ROS 6.43.4 is still vulnerable ....
Is this the first time this router has been hacked?
Have you done netinstall and added config from scratch?
Use Splunk to monitor your MikroTik Router
MikroTik->Splunk
td32
Tue Nov 06, 2018 10:41 am
you can change the password all day long but if someone has remote access on you pc most probably has installed a keyloger also
nescafe2002
Long time Member
Long time Member
Tue Nov 06, 2018 10:59 am
Can you identify the MAC address (mac vendor)?
Have you tried looking it up via ip/arp / bridge/hosts or switch/hosts after regaining access to check which interface it is connected to?
Have you crossed checked with your own machines and ensured it isn't a local device?
Deantwo
Tue Nov 06, 2018 11:21 am
Hey caresss
As mentioned by vecernik87, MAC-Telnet and MAC-WinBox are not an IP protocols, so an IP firewall will do nothing to block it. You need to configure your interface list to prevent access from any untrusted networks.
The fact that the attacker is using MAC-Telnet or MAC-WinBox means that they have direct access to your router. This can mean that they are INSIDE your network, or maybe they have hacked your ISP's router and are attacking you from there. Assuming that is it isn't from inside your own network, simply exclude your WAN interface from the mactel and mac-winbox interface lists.
For example:
/interface list member print
/interface list member remove [find list~"^mac" interface="WAN"]
I don't know why you were even fighting the hacker, just unplug the ethernet cables. Then you can reset the router and fix the issues. If you need time to get to the router, you can use the shutdown command so the router goes offline until you manually reboot it by power cycling.
For example:
/system shutdown
y
I suggest netlinstalling the router, to be sure that nothing nasty has happened.
See: https://wiki.mikrotik.com/wiki/Manual:Netinstall
You can e-mail support@mikrotik.com and they might have more/better suggestions.
By the way if it is your ISP that has been hacked, you might want to let them know. Because if your ISP is compromised, then EVERYTHING you send over the internet is vulnerable to man-in-the-middle attacks.
I wish my FTP was FTL.
caresss
Tue Nov 06, 2018 6:42 pm
Thanks for your time replying with all the above! Yes I was missing the mac access and when I wanted to take over and set them to none he trapped me and kicked me out. Anyway the ether9 is the LAN to the ISP for microwave link with inter branching! When he realized that I was aware of the situation he started resetting every single router on the ISP side almost 30 mikrotik APs with ROS versions below 6.40 ...
The story ended up netinstalling the main backbone which he attacked and restoring all the mikrotik APs after he reset them all and locking everything even the mac side with the latest OS. He wasn't that smart but it was the OS fault. Anyway thank God all is back to normal now after dealing with almost 80 routers and switches. Absolutely pain in the neck and applause for Mikrotik over that :))
We were born to learn so every day is a new school day in this new techie era!
Have a calm eve...
caresss
Tue Nov 06, 2018 6:54 pm
Unfortunately, it wasn't the 1st time. I was cleaning after him every time but he kept getting back in through that mac-telnet and again mac-winbox. Absolutely Casper! Until yesterday where I decided for the 1st time to install a remote syslog! From that syslog I was able to trace his prints, and started to fight back and clean all what he did ... The funny thing is that while mac-telnet whatever you do the log will not catch it!!! I was expecting to see some commands but nothing! I never knew this :)
An advice, don't take things with carelessness and absolutely install syslog because it is very essential for everything and especially security which comes 1st.
But I confirm 10000% that I updated the ROS to 6.34.4 and it was absolutely clean with totally new user and very long and complicated pass ... It took him seconds to guess the user and logon with it! I was so sure he was out, no scripts, no packet sniffing config, no php file in files nothing and absolutely nothing so he can guess the user. In seconds he guessed it!!! That truly frightened me and I gave up somehow knowing that whatever I will do he will keep coming back. Happened what happened and the lesson learned.
I believe he sniffed the packets between the latest winbox session from my side and the routerboard. There's still somehow a hidden vulnerability!
caresss
Tue Nov 06, 2018 6:58 pm
Didn't bother to look! This mac was another routerboard switch connected to the interbranching. Probably he natted the port from a pc or winbox enabled os to the machine with this mac to get a different mac other than real one! Mysterious :)
caresss
Tue Nov 06, 2018 6:59 pm
Noway :) I am a specialist, I use MacOS and is very clean. 0 chance for a keylogger.
caresss
Tue Nov 06, 2018 7:01 pm
Hey caresss
For example:
For example:
/system shutdown
y
I was so far from that location, and when I wanted to act badly he was faster :) anyway thank God things went OK this morning and I rescued everything having a very difficult and stressful time.
I'll keep you posted guys if anything new will come up regarding this mysterious issue :)
msatter
Forum Veteran
Forum Veteran
Wed Nov 07, 2018 12:49 pm
The hacker, who goes by the name of Alexey and says he works as a server administrator, claims to have disinfected over 100,000 MikroTik routers already.
https://www.zdnet.com/google-amp/articl ... k-routers/
Owners being angry at him should think about that someone from the outside could just walk in their router what is not the intention. As Gray Hat Hacker you are on the wrong side of law but with the good intentions and helping us all, it should not lead to consequences.
RB760iGS (hEX S) with the SFP being cooled.
Running:
RouterOS 6.44Beta50 / Winbox 3.18 / MikroTik APP 1.0.13
mozerd
Wed Nov 07, 2018 1:35 pm
Based on my experience with MikroTik and MOAB where I have been asked to remotely install the service many of the router firewall's are miss-configured.
The Value proposition that is MikroTik is such that it is very popular because MikroTik is POWERFUL, extensible and inexpensive. Very unfortunately a lot of these configurations are managed by people who have NO idea what they are doing applying the worst possible firewall disciplines one can imagine --- so its not at all surprising that a LOT get hacked.
IMO, MikroTik have provided the basic guidelines to effectively secure the router -- but when the undisciplined admin wants to expand on that capability they break the effective security model and get into trouble enabling the bad guys to invade their territory,
Jotne
Forum Veteran
Forum Veteran
Wed Nov 07, 2018 2:22 pm
Can any confirm this, or its just brag?
Has anyone seen a MT that has gotten an access list added to prevent external access?
MikroTik->Splunk
ognjen
Mon Dec 24, 2018 10:17 pm
after a year I came to a hotel that I once heard as a network engineer and I saw the following:
RouterOS before upgrade 6.40.3.
So.. everyone can be attacker and victim!
Be careful - Upgrade RouterOS!
Be careful with MikroTik Firewall because you can cut the line [yourself - MikroTik] :shock:
pe1chl
Tue Dec 25, 2018 11:10 am
That is exactly why such advises will not work as long as there is not some form of auto-upgrade...
You get a request from a hotel to install a WiFi, you install and configure equipment uptodate at that time, and you leave.
At that point there is not some hotel desk clerk reading the forum every day and acting upon topics like this.
So the router is left unmanaged. Why would you hire expensive service from a network admin to babysit a $100-$200 box?
And risks like this are the result.
So for an installation like that there should be some menu setting that makes it auto-update to some special release channel
that only gets the important and well-tested updates. (you do not want it to track "stable" or even "long-term" and install
a new version every couple of weeks when that is not required to fix problems, as it always induces a risk of failures)
ognjen
Tue Dec 25, 2018 10:10 pm
@pe1chl You are right. But, let's look the problem with wireless in new update 6.43.8. If I had set up a auto-upgrade, at the time of the upgrade, the entire network would be stopped?! (In 6.43.7: Frequency 5920, Frequence Mode superchannel, Country romania. After upgrade to 6.43.8: Frequency auto, Frequence Mode regulary-domain, Conutry romania. And link is down :shock: )
I know, superchannel with country is wrong conf.. but auto-upgrade can be danger in this example.
deanMKD1
Wed Dec 26, 2018 2:42 pm
Dont have noticed nothing serious in 6.43.4 stable. Winbox port opened still.
gotsprings
Long time Member
Long time Member
Fri Dec 28, 2018 4:46 am
When Mikrotik got rid of master slave... A BLIND update could really "screw some s__t up" on may configurations. And auto update would have resulted in disasterous results. That's what change logs are for, and why you read them before you hit UPDATE.
An unmanaged device gets hacked after the install???
Well it sucks for the person doing cleanup... Until they realize... "THE UNIT WAS UNMANAGED". If the system was set and forget or on break fix... This is a break... Time to fix.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
m4t7e0
Thu Jan 03, 2019 1:30 pm
It has come to our attention that a rogue botnet is currently using the same vulnerability in the RouterOS Winbox service, that was patched in RouterOS v6.42.1 in April 23, 2018.
Since all RouterOS devices offer free upgrades with just two clicks, we urge you to upgrade your devices with the "Check for updates" button, if you haven't done so already.
Steps to be taken:
- Upgrade RouterOS to the latest release
- Change your password after upgrading
- Restore your configuration and inspect it for unknown settings. Delete SOCKS configurations, and any unknown scripts
- Implement a good firewall according to the article here: https://wiki.mikrotik.com/wiki/Manual:S ... our_Router
[UPDATED with specific versions]: Full details on what to do and what is affected: https://blog.mikrotik.com/security/winb ... ility.html
Since the attacker is inserting his script into the targeted routers and changing configuration in them, we recommend to carefully inspect the configuration of your device, restore it from verified backups or export files, and follow generic advice in the above links.
Thanks, for these information, some mine device (setuped on 18 dic) fw vers 6.42.10 had this "attack".
normis
Thu Jan 03, 2019 1:53 pm
So why would your link be down? Clients connect to whatever frequency the SSID has set. And if you indeed have some very special purpose here, why did you set regulatory country ?
pe1chl
Thu Jan 03, 2019 2:20 pm
I can's speak for his situation but it is not really uncommon that a link goes down when one side changes frequency, e.g. because
that frequency has interference at the other side, is not in the other side's allowed channel list (e.g. it is an outdoor AP that has the
proper indoor/outdoor setting), or because the selected frequency has a lower allowed EIRP and thus the power is reduced.
normis
Thu Jan 03, 2019 2:24 pm
he already upgraded the router, which requires a reboot and link is down anyway (until it's restored in a minute).
power is only reduced if an indoor frequency is selected, which should not happen (frequency list knows outdoor from indoor)
gotsprings
Long time Member
Long time Member
Sat Jan 05, 2019 2:04 pm
I upgraded my router and it stopped working...
Check if the update changed your master-slave settings to bridge. Thats the #1 thing I saw taking out routers who upgraded from below 6.40.8 to above it. Fixing the bridges and moving IP/DHCP-Server/Filter-Rules to use the new bridge interface got things going again.
Mark Twain
weixvenum
Sat Jan 05, 2019 5:00 pm
im having issues upgrading. it doest do it.. check for uodates then select download and install.. auto reboots but it stays to the version not new one... im using hap ac....
Deantwo
Sat Jan 05, 2019 5:04 pm
Check the architecture of the router, make sure you are using the correct file.
Need more information to be able to help you. What and how are you updating? From what version to what version? Again how are you doing it?
weixvenum
Sat Jan 05, 2019 5:50 pm
i have hap ac lite with verion 6.42rc24 software version tried diffferent steps updating it to 6.44beta50
1. System>Routerboard>upgrade
then manual reboot
2. System>Package>check for updates> current>downkoad&install
it downloads thenrebiots automatically
3. System>Package>check for updates> release candidate> download and install, then it auto reboots
4.quickset>check for updates>current or release candidate>doenload and install>auto reboot
weixvenum
Sat Jan 05, 2019 5:52 pm
Need more information to be able to help you. What and how are you updating? From what version to shat version? Again how are you doing it?
then manual reboot
mkx
Sat Jan 05, 2019 5:55 pm
Anything in log just after reboot?
Did it upgrade to current (6.43.8 ) in the step 2?
Can you post the list of installed packages?
BR,
Metod
weixvenum
Sat Jan 05, 2019 6:22 pm
Screen shot of the logs after reboot
Nope, it did not upgrade to 6.43.8 or the 6.44beta
Packages installed
mkx
Sat Jan 05, 2019 6:31 pm
The problem is that you somehow ended with two instances of package hotspot installed. You can try to uninstall the stand-alone one (the top one on the screenshot which is not idented on the list). If you succeed, then you'll be able to upgrade. If you don't succeed (quite probable), then the only way out is netinstall (make fresh backup, save backup file off device, netinstall it to 6.42.x to ensure highest probability for successful backup restore) and upgrade to desired version after that.
BR,
Metod
weixvenum
Sat Jan 05, 2019 7:32 pm
tha ks.. let me try your suggestion
weixvenum
Sat Jan 05, 2019 9:33 pm
THANKS a LOT! it worked and its updated.
Users browsing this forum: miked315 and 4 guests
