whitbread
Re: v6.43 [current] is released!
Thu Sep 13, 2018 9:59 pm
*) bridge - improved performance when bridge VLAN filtering is used without hardware offloading;
Just testet 6.43 on a hap ac2 - everything went smooth so far.
As I am struggling for the best way to deal with my setup I did performance tests anyway. Just wanted to let you know that there is a performance improvement when using VLAN aware bridges but you have to use a magnifying glass. My values did increase from 360 to 380 Mbps w/o IP-Filtering and 345 to 365 Mbps w/ IP-Filtering, unfortunately far away from wire speed.
So bad you cannot use switch chip together with bridges anymore :(
kriszos
Thu Sep 13, 2018 10:05 pm
I updated my hAP ac^2 from 6.42.7 and upgraded firmware
after update my cpu usage rise from 2% to 30% and dhcp stopped working. export also hang out after /interface wireless. reboots doesn't helps. Downgraded to 6.42.7 now is working fine again.
I updated it again with same result.
mkx
Thu Sep 13, 2018 11:12 pm
You can definitely use VLANs in "hybrid" mode ... do the VLAN filtering on switch chip (/interface ethernet switch) and "new bridge" (without using bridge vlan functionality) with individual ports as members.
Regarding low speed: I suspect your configuration is not optimal. I conducted some tests using VLANs on bridge (SW implementation) and I could achieve wire speed for port-to-port transfers (without any filtering) while CPU utilization was around 30% of a single core (8% overall CPU utilization).
Railander
Thu Sep 13, 2018 11:30 pm
Don't know if it's already been mentioned, but I can no longer change the name of a user in /user
It's not only the default user, it applies even to newly created users.
> user set admin name=test
failure: user name can't be changed
ozone
Thu Sep 13, 2018 11:46 pm
Upgraded Hap-lite (rb941) from 6.42.6 to 6.43 (Ros+Routerboot), and now internal dhcpv4-client (from an external DNSMASQ server) does not work anymore.
The RB does not get an valid IP anymore. (stays on "searching").
If you reboot the hap-lite, the hap-lite DOES get an IP... But when you request an IP while running, you do not.
If DHCP-server is another routerboard, no issue exists, only with DNSMASQ dhcp-server.
Tried also upgrading a HAP-ac to 6.43, then there is NO DHCPv4-client issue with external dnsmasq DHCP-servers. (with identical config as hap-lite)
Second issue on hap-lite is the reduced wifi performance. Drops about 30%.
Went back to 6.42.7 on hap-lite, and internal dhcpv4-client works again (from dnsmasq), and wifi speed is back up.
Thirdly, HAP-lite still has no ramdisk functionality like HAP-ac, so upgrading is a real pain in the *ss!
If you have a few saved config files on there, you can be happy to get upgrading working with ONLY system and wireless package.
Anything beyond that, and disk is full. No errormessage though, so a reboot then usually ends up in a bricked device where only netinstall will help out.
Had this a few times already on the hap-lite.
16MB flash is simply to small :(
ozone
Fri Sep 14, 2018 12:04 am
Oh Yeah,
Anyone tested what happens when you choose "SWos" in system->routerboard->settings->boot-os ?
(on a device that normally does not support that)
schadom
Fri Sep 14, 2018 1:52 am
Upgraded two CCRs to 6.43 and no issues (including the described ones above) so far.
Only thing we noticed that the OpenVPN bridge was disabled after upgrading and we had to re-enable it manually.
*) winbox - fixed "sfp-connector-type" value presence under "Interface/Ethernet";
S-RJ01 SFP's are still shown with "Connector Type: LC" on 6.43 and Winbox v3.17 at least in our case.
Cal5582
Fri Sep 14, 2018 2:32 am
just had 6.43 break my RBM11G + R11e-5HacT wireless access point. after the update my mpcie card would no longer pick up but would display a red and yellow light. tried reseating card but no luck. restored back to mmips 6.42.7 and everything came back up and worked. looks to be a software issue. any way i can report this bug?
ste
Fri Sep 14, 2018 9:09 am
Updated a new CCR to 6.43. Added some bridges and then some vlans to the bridges. One vlan does not show as slave of the bridge. I guess a problem of the bridge changes. So I downgraded to stable. This bricked the ccr. Hangs with starting services. Netinstalled 6.43 and started over. So sure stable and long term matches the truth ?
Just a small rant after wasting 2 hours with "stable" software. Just call it "current" again ...
dg1kwa
Fri Sep 14, 2018 10:18 am
L2TP/IPsec works properly for me on 6.42.7 and 6.43, must be something specific to your configuration or network. Have you sent a supout.rif file to support@mikrotik.com?
when I have a little time I send. I not change any configuration last time.
osc86
Fri Sep 14, 2018 12:09 pm
After updating CCR1009 to 6.43 there is a problem with port stability! Has anyone else encountered such a problem?
I doubt this is a software issue. Seems only one port is affected.
I don't have such a problem on my CCR1009.
lomayani
Fri Sep 14, 2018 12:46 pm
I seen the issue with dhcp stop working. check in dhcp server if you have dhcp server configured with unknown interface, if you have remove that and upgrade to 6.43. When you have dhcp-server configured with unkwnon interface and upgrade to 6.43 will cause dhcp to stop working
whitbread
Fri Sep 14, 2018 2:18 pm
Not sure if I understand you correctly - using bridge with hw offloading, then bridging vlan interfaces of 'switch bridge' to new plain bridges? I am using this config on my rb2011, but I thought it is blacklisted by Mikrotik?!?
Not sure if we are talking about the same here - I am doing real world tests with tcp and smb reaching 114MB/s when switching or bridging, but I need the filtering. So at the moment you turn on IP filtering with some rules present, performance breaks down to ~50% while cpu on hap ac2 is maxed out. Using VLAN aware bridges is even worse.
Splash
Fri Sep 14, 2018 2:51 pm
Nope, CCR1016, CCR1036 and CCR1072's all behaving.....
thg3x
Fri Sep 14, 2018 2:54 pm
"DHCPv6 PD Pool (PPP Profile) not work anymore."
i'v got this problem too.
When connection established, dinamic DHCPv6 server creating, but client not get address from pool.
I had the same problem.
The dynamic server is created, but the client router does not receive the pool.
mkx
Fri Sep 14, 2018 3:52 pm
I mean the setup I discussed in this thread where I posted functionally identical setups, both done on then current ROS 6.42.7, one using switch chip VLAN and the other using bridge VLAN setup.
I'm not sure about it either. I did this test:
WinPC <-- access port with PVID=42 --> RBD52G <-- trunk port --> RB951G <-- access port with PVID=42 --> LinPC
So both end machines used usual untagged access and both "border" routerboards did VLAN tagging/untagging. I was running iperf both TCP and UDP. And I could achieve wire speed transfers (but I had to tune iperf parameters to get there so obviously performance does depend on client setup). I posted some results of my tests here.
alexvdbaan
Trainer
Trainer
Fri Sep 14, 2018 4:10 pm
@MikroTik support, do you have any feedback on the question below?
bridge - add dynamic CAP interface to tagged ports if "vlan-mode=use-tag" is enabled;
Great work MT team!
I was wondering if you could elaborate on the dynamic vlan function? I can see that the Caps interfaces are included in the bridge and that the active interfaces are tagged in the dynamic vlan entry for PVID 1. I would expect that the dynamic caps interfaces are dynamically added to all the bridge vlan entries. I have also tried to add the Capsman interfaces in their own interface list. However the newly created interface list woith all the dynamic caps interfaces can not be selected in the bridge vlan entry.
Below the config for my test setup on 6.43
add fast-forward=no name=Lo0 protocol-mode=none
add fast-forward=no name=bridge protocol-mode=none vlan-filtering=yes
add bridge=bridge interface=ether1
add bridge=bridge interface=ether2 pvid=666
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
/interface bridge settings
set allow-fast-path=no
/interface bridge vlan
add bridge=bridge tagged=bridge,ether1 untagged=ether2 vlan-ids=666
add bridge=bridge tagged=bridge,ether1 vlan-ids=200
add bridge=bridge tagged=bridge,ether4,ether5 vlan-ids=10,20,30,667
/caps-man datapath
add bridge=bridge client-to-client-forwarding=yes local-forwarding=no name=vl10-data vlan-id=10 vlan-mode=use-tag
add bridge=bridge client-to-client-forwarding=yes local-forwarding=no name=vl20-data vlan-id=20 vlan-mode=use-tag
add bridge=bridge client-to-client-forwarding=yes local-forwarding=no name=vl30-data vlan-id=30 vlan-mode=use-tag
add bridge=bridge client-to-client-forwarding=yes local-forwarding=no name=radius-data vlan-mode=use-tag
/caps-man security
add authentication-types=wpa2-eap disable-pmkid=yes eap-methods=passthrough encryption=aes-ccm group-encryption=aes-ccm group-key-update=1h name=Radius-Sec
/caps-man configuration
add country=netherlands datapath=radius-data distance=indoors hide-ssid=no mode=ap name=DynVlan security=Radius-Sec ssid=AllVlan
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes package-path=/upgrade upgrade-policy=require-same-version
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=vl667
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=DynVlan name-format=prefix-identity name-prefix=5Ghz-
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=DynVlan name-format=prefix-identity name-prefix=2.4Ghz-
DummyPLUG
Fri Sep 14, 2018 5:31 pm
CCR1009, just found out all the "last link up time" is the current time in winbox (except those have link down will be in future), anyone have the same issue?
posetr
Fri Sep 14, 2018 10:23 pm
Hello , i am having difficuties about ccr1036-12g-4s when get udp attack with 0 length .
Using RouterOS 6.4 and here is the tcp dump of attack :
21:10:26.299021 IP 132.155.220.60.39812 > x.x.x.x.44710: UDP, length 0
21:10:26.299034 IP 180.19.33.203.lxi-evntsvc > x.x.x.x.2342: UDP, length 0
21:10:26.299035 IP 56.24.15.219.6200 > x.x.x.x.1234: UDP, length 0
21:10:26.299036 IP 11.90.77.183.23051 > x.x.x.x.44710: UDP, length 0
21:10:26.299057 IP 28.110.53.197.28188 > x.x.x.x.44710: UDP, length 0
21:10:26.299062 IP 215.92.148.235.23767 > x.x.x.x.3453: UDP, length 0
21:10:26.299064 IP 0.19.41.141.4864 > x.x.x.x.80: UDP, length 0
21:10:26.299065 IP 137.132.25.40.33929 > x.x.x.x.44710: UDP, length 0
21:10:26.299065 IP 49.38.104.169.9777 > x.x.x.x.110: UDP, length 0
21:10:26.299067 IP 203.183.15.186.47051 > x.x.x.x.44710: UDP, length 0
21:10:26.299185 IP 51.163.222.160.41779 > x.x.x.x.44710: UDP, length 0
21:10:26.299191 IP 0.33.48.114.8448 > x.x.x.x.4432: UDP, length 0
21:10:26.299193 IP 143.96.62.38.24719 > x.x.x.x.447: UDP, length 0
I have added many rule like :
0 chain=forward action=drop connection-state=invalid protocol=udp log=yes
log-prefix="log-paket"
1 chain=forward action=drop protocol=udp connection-bytes=0-10 log=yes
log-prefix="udp-attack"
It makes routerboard freeze and unaccesible, please help me to solve that.
No logs.
mkx
Fri Sep 14, 2018 10:37 pm
It really depends on scale of attack (and possibly there's some mis-handling of zero size UDP packets in ROS). But I'd say that major contribution to service failure is that you're logging each malformed UDP packet. Try to silently drop it, it might help your CCR to survive.
ognjen
Sat Sep 15, 2018 8:57 am
I don't have a problem with upgrade OS and fimware. Everything work fine (Dhcp, DNS, vlan, PPPoE, PPTP, L2TP, OVPN, CAPsMAN, Bridge, Wireless 802.11 over 5Ghz and 2.4GHz, Queue, Tools..). I don't under you guys, what u do to get a problem? :D
Joking apart.. I just see problem with scripts when try to start, but when check Don't requir Permissions problem is resolved.
Routers and switches what i upgrad is:
1x RB3011UiAS
2x RB2011UiAS
1x RB433
2x RBwAP2nDr2
1x CRS125-24G-1S-2HnD
3x RBwAPG-5HacT2Hnd
5x RB921GS-5HPacD r2 (mANTBox 19s)
2x RBLHGG-5acD-XL
1x CRS326-24G-2s+
2x RB SXT 5nD r2
4x RB750
Edit:
Who have problem with login on v6.43 need to upgrade winbox:
kriszos
Sat Sep 15, 2018 9:22 am
I indeed has dhcp on unkown interface. deleted it but that doesn't resolve the problem. After update to 6.43 I cant even make supout.rif file because it hangs at 1% while cpu usage is at 30%.
/tool profile shows tha cpu is used mostly by "unclassified", "spi" and "management"
Anybody has any ideas? I would like to not need to use netinstall.
Kindis
Sat Sep 15, 2018 10:51 am
I'm very happy with this build I must say. Must be the best .0 build ever provided. Been running it since launch and a lot of things are better. OSPF is faster for some reason but it may come down to the huge improvements to CHR under Hyper-V. Granted I do not have a advanced environment and do not use IPsec yet so other may have other experiences but overall I'm very happy and good job Mikrotik!!
steen
Sat Sep 15, 2018 10:59 am
Hello Folks!
This is a humble question, someone might have tested this ros version with wifi and nv2 on older mipsbe (ARM) devices like RB411, RB433, RB800 etc. and SXT, SEXTANT, QRT5 ?
Is this wifi problem fixed yet in this version ?
Version greater than 6.41.3 fully fails with wifi and nv2 hand has to be net installed in order to get back to working versions.
DimaFIX
Sun Sep 16, 2018 5:13 am
Changing the identity on hAp ac² crashes the router with an error: "kernel failure in previous boot".
mkx
Sun Sep 16, 2018 11:56 am
You mean changing identity name as in
/system identity set name="some other name"
The above command doesn't crash my hAP ac² ... running ROS 6..43.
DimaFIX
Sun Sep 16, 2018 12:17 pm
Yes. I have problem with this option.
dvm
Sun Sep 16, 2018 3:32 pm
I can not reproduce this issue on my hAP ac^2 with ROS 6.43 (both CLI and WinBox).
DimaFIX
Sun Sep 16, 2018 4:08 pm
I don't know what the problem is. At me this problem is shown every time, even on a default config.
jasonx
Sun Sep 16, 2018 7:16 pm
on 6.43 current.
dhcp server bindings not working
ip pool used prefix shows pppoe's ipv6
but on dhcp server bindings don't received ipv6 pppoe
somebody with this problem?
mducharme
Trainer
Trainer
Sun Sep 16, 2018 10:14 pm
on 6.43 current.
We have this problem sometimes on 6.42.6 dhcpv6 server where it is like the dhcpv6 binding disappears without being cleaned from the pool. We even had it happen with ipv4 dhcp where suddenly it was like all dhcp leases disappeared without disappearing from the ipv4 pool used addresses, causing pools to fill up before they should since suddenly hundreds of systems network received new leases. I opened a ticket but mikrotik just suspects some problem on our network. Open a ticket and maybe it will help them track the issue.
alexsap
Mon Sep 17, 2018 12:18 am
We have a huge memory leak on the new 6.43 code running on our CRS326's. We use vlan. Within 12hrs the device reboots due to low memory.
venthyl
Mon Sep 17, 2018 10:54 am
No logs.
Hi i have similar problem
yesterday night
with no reason all Arm or 6.42.x devices hang up,
stop pass traffic,
stop respond even on mac ping
in the same time
manual power cycle was needed.
on one 450x device was ip watchdog, even this wasnt help.
450gx4 - bridge only ip local 192.168.5.x
450gx4- multibridge nat firewall different ips public ip firewalled
450gx2- router no bridge ip to core network 172.16. public ip firewalled
lhg60g - p2p link ip 192.168.88.x
6.42.1-6.42.7 verson on rb
Core network is network with
bridge wireless antennas,
and isolated by mikrotik routers to customers
every router in core network see each other in l2 (no vlan)
there is about 80 other mikrotik routers to serve internet
and 90 wds links soft below 6.42 nothing happend
no other arm devices
Any ideas ?
Regards
bbs2web
Mon Sep 17, 2018 1:03 pm
How does on obtain the default settings for menu items?
The '/system default-configuration print' command details the default initialisation script and does not show default values.
6.43 on a hAP ac (962UiGS-5HacT2HnT):
[davidh@router] > /int ethernet export
# sep/17/2018 11:59:56 by RouterOS 6.43
# software id = 4KLB-K1IB
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = 6737060E2E31
set [ find default-name=sfp1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
PS: Would be useful to '/int ethernet export default'
chaostya
Mon Sep 17, 2018 1:17 pm
CRS125-24G-1S-2HnD
After update to 6.43 (including firmware update)
"router was rebooted without proper shutdown by watchdog timer" happened once for now.
dvm
Mon Sep 17, 2018 1:45 pm
1. Backup or export current config.
2. Disconnect router from internet and reset config without applying default configuration.
3. Connect to router via MAC.
3. /export verbose file=all_defaults, save this file for future reference
4. Restore backup or import config from step 1.
bbs2web
Mon Sep 17, 2018 2:11 pm
Thanks for your suggestions but that's fairly obvious. MikroTik change defaults in RouterOS releases and don't document changes properly (multi-line change log entries would be a start, linking changes to a bug tracking system would be much better). I still think it would be useful to have a command along the lines of '/int ether export default' so that one can adjust configurations after performing software and firmware updates.
nin
Mon Sep 17, 2018 7:33 pm
I cannot upgrade to 6.43. I think something messed up with packets installed - please see the picture!
https://www.imagebanana.com/s/1183/icxyABjR.html
Please help me!
PS. CCR1016-12G
mkx
Mon Sep 17, 2018 8:17 pm
The wireless package is installed both in basic bundle and as separate package. Until you resolve this issue, you can not upgrade to newer version. Whatever you try, first create backup and text configuration export (/export file=<file.rsc>) and get them off your CCR.
You have at least two possibilities (in order of preference of MT staff I guess):
  1. uninstall the extra wireless package, the lower one on your screenshot.
  2. install separate packages - get ZIP file from download section of mikrotik pages. Upload all needed packages except wireless. After reboot CCR will be running ROS 6.37. I guess you don't need wireless package at all, but if you feel like installing it, install it after ROS is already running upgraded.
  3. netinstall CCR
nin
Mon Sep 17, 2018 10:20 pm
"The wireless package is installed both in basic bundle and as separate package."
Exactly this should absolutely never be possible!
nin
Mon Sep 17, 2018 10:21 pm
1. uninstall the extra wireless package, the lower one on your screenshot. -> FAILS.
nin
Mon Sep 17, 2018 10:25 pm
2, install separate packages - get ZIP file from download section of mikrotik pages. Upload all needed packages except wireless. After reboot CCR will be running ROS 6.37. I guess you don't need wireless package at all, but if you feel like installing it, install it after ROS is already running upgraded. -> FAILS!
nin
Mon Sep 17, 2018 10:52 pm
I need to learn about netinstall. It is too late here. Thanks I will come back asap.
Cal5582
Mon Sep 17, 2018 11:19 pm
any update on wireless cards not detecting on mmips devices?
Splash
Tue Sep 18, 2018 11:38 am
I reported this too with CRS317's and the only way I could resolve it was to downgrade back to 6.42.7. The fix is supposed to be coming out in the next beta.
They took some support files during the memory filling up and seem to think they have identified the issue.
ithierack
Tue Sep 18, 2018 11:51 am
Same here, also an CCR1009. Web-Interface displays correct, WinBox some time in the future. I think, it's only an "cosmetic problem" with WinBox.
nin
Tue Sep 18, 2018 12:00 pm
3. netinstall CCR -> WORKED!
I am running now 6.43.1 and all went smoothly.
Thanks for your help!
emils
Forum Veteran
Forum Veteran
Tue Sep 18, 2018 12:01 pm
New version 6.43.1 has been released in stable RouterOS channel:
viewtopic.php?f=21&t=139353
Users browsing this forum: dervomsee, ormandj, petertosh, Techsystem and 30 guests
