Will be sometimes any ? It would be useful....rushlife - What about them?
Here it is.rushlife - Shortcuts are and have been available all the time. Are you talking about some specific ones? Can you provide an example?
denisun - Can you provide an example? Categories mode work just fine for me also in IPv6 firewall menus.
I mean something like "close all windows", open last window, open terminal or maybe big things, like some posibility to set CUSTOM shortcuts for some section.rushlife - Shortcuts are and have been available all the time. Are you talking about some specific ones? Can you provide an example?
If i sort by number (#) and select show categories it doesnt work.denisun - Try to sort columns by, for example, "Action" column;
rushlife - All shortcuts that are available are listed under menu that opens up when you press right mouse button under specific menu. We will consider implementing new shortcut related features in upcoming Winbox releases;
SiB - Such shortcut is working just fine for me and also we have not changed anything related to shortcuts between these Winbox versions. Can you please re-check?
Sounds like a nice idea for a feature. But it is not directly related to Winbox v3.18, so you might want to make a new thread about it.Please add feature to auto-reconnect or just status-icon what give as info that routerboard is online now.
I just logged to 6.42.6 via Winbox 3.18.Can anyone log to an older version of Mikrotik, through WinBox 3.18 ?
You mean, v5.x? New WinBox doesn't support it as it doesn't download .dll files from the router anymore, I believe.I mean version < 6.42.
I have a few RB133, that can not be upgraded to 6.x version
You're right. Thank you!Traffic depends on the number of open windows inside WinBox.
I am unable to login to a router running RouterOS v5.26 with WinBox v3.18, I just get an error saying "Error: could not fetch index".Can anyone log to an older version of Mikrotik, through WinBox 3.18 ?
That's probably because WinBox has neighbor discovery capability builtin.why dont have WinBox + MAC WinBox button?
WinBox discovery not working on VPN. The only way is thru IP>neighbor list.That's probably because WinBox has neighbor discovery capability builtin.why dont have WinBox + MAC WinBox button?
when you double click that area the window loses focus.can someone confirm this...
try double clicking on top right field "cpu or memory or uptime"
after that you cant terminate winbox, menu and windows inside winbox are inaccesible. you have to right click many times random inside winbox to make menu and windows accesible.
You should email that to support@mikrotik.com.Winbox when downloading descriptors get stock. After some troubleshooting, I found that winbox is being blocked by P2P/File transfer restrictions in the company.
Wouldn't that be himself? XDHe should email it to support@hiscompany.com, because it's false positive on company's DPI side, MikroTik cannot do anything with that.
I think that Winbox shouldn't be considered P2P at all.If P2P/File transfer is restricted in the company network, then it might cause problems with a lot of things. None of which would be MikroTik's fault.
But without knowing the whole story or setup it is hard to say what is and is not going on. I am sure MikroTik support can easily say if it is a WinBox issue or just a network issue.
It is not blocked by port and yes by some other way, maybe "signature, behaviour" IDK and I just work here in the company. I just know they are using Sophos as a Firewall hereA small suggestion would be to just whitelist port 8291 in those P2P/File transfer restrictions.
Ok, you are right, my bad I just thought that since this false positive, Maybe MK could fix it and some way.Anyway, it is not really related to this specific WinBox update, so please make a new forum thread about it if you want to discuss it on the forum.
