It is probably not the 43 to 43.2 upgrade that did it, but instead, the routerboot firmware upgrade for 43. If you didn't reboot a second time after 6.43, the routerboot upgrade would not take place until the following reboot, which is probably by happenstance when you rebooted to upgrade to 6.43.2.
My RB912UAG-2HPnD (cpu: MIPS 74Kc V4.12, fw type: ar9340) was bricked by ROS update from 6.43.1 to 6.43.2:
ROS 6.42.7, fw 6.42.7: uploaded 6.43 packages, /sys reb - OK
ROS 6.43, fw 6.42.7: /sys rou up, /sys reb - OK
...a few days later...
ROS 6.43, fw 6.43: uploaded 6.43.1 packages, /sys reb - OK
ROS 6.43.1, fw 6.43: /sys rou up, /sys reb - OK
ROS 6.43.1, fw 6.43.1: uploaded 6.43.2 packages, /sys reb - BRICKED
Recovered the box by Netinstall (installed 6.43.2 packages), then completed the firmware upgrade, downgraded both ROS and fw back to 6.43.1 and repeated the failed step:
ROS 6.43.2, fw 6.43.1: /sys rou up, /sys reb - OK
ROS 6.43.2, fw 6.43.2: uploaded 6.43.1 packages, /sys pack down - OK
ROS 6.43.1, fw 6.43.2: /sys rou up, /sys reb - OK
Netinstall again, 6.43.2 packages. Another experiment:
(contrary to the first experiment, here I skipped firmware downgrade 6.43.2->6.43.1)
ROS 6.43.1, fw 6.43.2: uploaded 6.43.2 packages, /sys reb - OK
Thus in my case the problem occurs when upgrading ROS packages and the firmware is exacly 6.43.1.
Ondrej
