RomanT
Re: v6.43.1 [stable] and v6.43.2 [stable] is released!
Thu Sep 20, 2018 5:17 pm
Greetings!
I`ve upgraded many routers to 6.43.1 (OS + firmware). Today one of RB2011 was rebooted and didn`t wake up! I can`t see it even using netinstall. It seems to be an endless boot cycle... By the way, the router made no sound till I`d used a "curcuit" reset instead of button.
Please, help me. I`m afraid that my another routers will do the same.
sid5632
Long time Member
Long time Member
Thu Sep 20, 2018 5:37 pm
Three "stable" releases in just over a week seems to be rather a contradiction in terms to me.
Perhaps "current" really was the correct name.
WirelessRudy
Thu Sep 20, 2018 5:43 pm
Agree.
andriys
Indeed!
WirelessRudy
Thu Sep 20, 2018 6:27 pm
A version should only be called "stable" if the user community deemed it stable..... as long as users still report issues, it should be "current". Only if determined after 1 or 2 weeks a 'current' version is stable it can be called 'stable'.
To me it looks that with a user base as Mikotik a week is long enough to find out if a certain version indeed is stable to be called so.....
So either a 'current' is replace by a new 'current' version or after a week might upgrade to 'stable'.
And only 'stable' version should come up in the auto upgrade process.
You should be able to pick 5 options;
1. 'bugfix only' for those that wan't 100% security (doesn't exit but heho) with bux fixed if found and solved so far but not the latest features
2. 'current' for those that wan't the tested version of the most recent features but without the real world test of many thousands of different Mikrotik devices.
3. 'stable' is just the same version as '2' but after maturing process of one week... Only if the OS one week has no reports of issues from the user community.
4. 'release candidate' for those that want to see new features or new issues sorted out and tried out. NOT to be used in wide scale real world networks.
5. 'development' for the latest features, improvements or upgrading of the ROS. ONLY for players or those that would like to help MT ROS to lift to a higher level. DEFENITELY NOT for production environment.
I this list there can never be a 'current' version with the same number as a 'stable' version. A new version goes from 'current' into 'stable'. A new 'current' version then needs to have a higher number.
The aim is that if you wan't to upgrade your network to the latest feature level you can either go for the 'current' version but don't be surprised that the community (and that might be you!) still finds issues.
Or just wait a week (or longer) to see if it is really stable enough to go blind for it.....
In the present if you wan't 'current' of the now called 'stable' (which also happens to be the version that is represented and used in the 'auto upgrade') you still put your network in harms way since it is not been tested widely against all kind of different networks and hardware configurations. So you need to read and follow the forum to see if, and what kind of, issues emerge and if they might have an impact on your network. I can make better use of my time to be honest...
xvo
Thu Sep 20, 2018 6:36 pm
Totally agree with WirelessRudy.
stef84
Thu Sep 20, 2018 6:42 pm
Hello.
With 6.43 i don't connect remote from wan with winbox or 80 port. I enter only from LAN.
were is the solution?
vovchikkd
Thu Sep 20, 2018 6:48 pm
I have two bricked device after flashing with 6.43.1 firmware. sxt lite2 and groove5 in bootloop.
What should i do?
mducharme
Trainer
Trainer
Thu Sep 20, 2018 8:15 pm
What should i do?
It should be fixed in 6.43.2, you will need to netinstall v6.43.2.
I agree that the recent renaming of 'current' to 'stable' is probably unfortunate given these issues.
Perhaps 'current' should remain, and bugfix-only/long-term named 'stable' instead? the bugfix-only should certainly be stable. Then there is testing, current, and stable, those names are rather self explanatory, unlike bugfix-only or long-term.
andriys
Thu Sep 20, 2018 9:42 pm
I have a theory that they may want to support 6.40.x line (the last release branch before the bridge overhaul) for an extended period of time, hence the "long-term". This does not justify, however, renaming "current" to "stable".
bbs2web
Thu Sep 20, 2018 10:21 pm
RouterOS 6.43.2 still hasn't fixed VirtIO multi-queue CPU association problem, both input queues are pinned to the same CPU core:
Tx and Rx queues should share the same core, as detailed here:
Reference: https://www.linux-kvm.org/page/Multiqueue
Sent email to support@mikrotik.com [Ticket#2018091422005951]
TheRealJLH
Re: v6.43.1 [stable] is released!
Thu Sep 20, 2018 10:30 pm
Yesterday upgraded two CCRs from 6.41.3 to 6.43.1 in the hotel I had vacation in Greece :) At least, now it's not vulnerable to WinBox user database reading xD Unfortunately, WinBox access is still allowed for every Free WiFi user in the hotel :(
:) Proper Input chain filtering in the ip firewall solves the winbox issues quite well.
Hrobocop
Thu Sep 20, 2018 10:31 pm
Hi MikroTik,
sorry, but this wasn't good. Problems happen, but if you totally screw firmware upgrade, which will brick a lot of routers, resulting in a lot of troubles for your loyal customers, and even lot of kilometres and hours of driving, you should at least try to not screw your support. I know you have three-day response policy, but in this case, ignoring users with bricked routers is a really bad thing. And the same is for changelog. There should be a real and clear warning, that 6.43.1 can potentially brick your unit.
bbs2web
Thu Sep 20, 2018 10:33 pm
L2TP VPN security concern since upgrading 6.42.6 to 6.43.2, MPPE128 is disabled after VPNs connect in approximately 33.3% of the cases:
21:12:41 l2tp,info first L2TP UDP packet received from xxx.xxx.xxx.xxx
21:12:41 l2tp,ppp,info,account zzzzzzzzzz logged in, yyy.yyy.yyy.yyy
21:12:41 l2tp,ppp,info vpn-zzzzzzzzzz: authenticated
21:12:41 l2tp,ppp,info vpn-zzzzzzzzzz: connected
21:12:41 l2tp,ppp,info vpn-zzzzzzzzzz: using encoding - MPPE128 stateless
21:12:41 l2tp,ppp,info vpn-zzzzzzzzzz: disabling encoding - MPPE128 stateless
33.3% of the VPN connections have no encryption active on them:
Configuration:
/interface l2tp-server server
  set allow-fast-path=no authentication=mschap2 caller-id-type=ip-address default-profile=default-encryption enabled=yes ipsec-secret="" keepalive-timeout=30 \
    max-mru=1440 max-mtu=1440 max-sessions=unlimited mrru=disabled one-session-per-host=no use-ipsec=no
/ppp profile
  set *FFFFFFFE only-one=yes
/ppp secret
  add local-address=10.254.254.1 name=user password=***************** remote-address=10.254.254.2 service=l2tp
sid5632
Long time Member
Long time Member
Thu Sep 20, 2018 11:36 pm
At time of writing, these would seem to fit:
Legacy: 5.26
Long-term/bugfix: 6.40.9
Stable: 6.42.7
Current: 6.43.2
Testing: 6.44beta9
Development: Who knows
Winbox still seems to have the old 4 categories though (bugfix, current, testing, development) - but I've never seen anything in 'development' so why have it (unless it's for internal use only)?
It seems like they only have 4 slots, so they ought to be Long-term/bugfix, Stable, Current, Testing
mducharme
Trainer
Trainer
Thu Sep 20, 2018 11:59 pm
You should really be using L2TP over IPsec, not just regular L2TP.
OldSwitchConfigLiker
Fri Sep 21, 2018 12:46 am
I have the same impression.... thankfully they understood the importance of stability for production environments. Much more than always having the latest features.
I can only applaud this.
But frankly, the only thing they really need to do to remain compatible with old config's is an extra package that restores masterports, and probably later (in a few versions, as bridge hardware vlan filtering etc. finally works for all RB's) also the switchconfig-menu, which seems to be oh-so-difficult for some to understand.
Limited distribution of such package is sufficient. And the code for set package is well known and well tested, since successfully in use for many years. Shouldn't need to much engineering effort.
There is also no need for such package for newly released hardware, since that never had a RoS release that supported masterports. So it will be of a limited scope and it is a self extinguishing service as time progresses...
In fact.... all functionality that is abandoned, and has a reasonable userbase, should be covered like that imho. It's called: taking your professional customers seriously. (not just the enthusiasts)
But don't get me wrong, I'm all for new features. That is progress. It is that what also made Routerboard great. There NEED to be new features in new versions, and those features will have bugs.
Put those new versions in a current branch (or whatever you like to call it), and leave a "long term" branch available for the reasonable lifetime of a product with only security and bugfixes.
As such, I'm happy with the 6.40.xxx as "long term", like they seem to do now. (As long as they do not abandon it in a few months or so...)
mducharme
Trainer
Trainer
Fri Sep 21, 2018 12:50 am
Why do you need master ports back? You get the same thing with a bridge without vlan filtering and with hardware offloading enabled, and I believe MikroTik has added back all of the the switch menus that were removed in 6.41+. A lot of people seem to be under the (I believe mistaken) impression that certain configurations are no longer possible now that master ports are gone. I have not personally seen any configurations that you can do with the old switch chip that are no longer possible after 6.41, and can't really think of any. The master ports are still there under the hood, just hidden from view.
The only change is that you are now forced to have a bridge, but this bridge really has no impact on the configuration and changes nothing, as long as it is hardware offloaded, with STP off and VLAN filtering off. The switch chip VLAN configuration etc. is still possible in the same way.
So if you look at the old 6.40.x way if you have a 5 port router, you could have set it up without a bridge or with a bridge, and it really made no difference in the behavior of the device:
Old 6.40.x configuration (without bridge):
     ether2-master
ether3   ether4  ether5
Old 6.40.x configuration (with bridge):
       bridge
     ether2-master
This bridge should have no effect on the behavior of the router and what you could do (this bridge would be standard on MikroTik wireless routers).
The new 6.41+ config behaves exactly the same as the old way with the bridge. You are now forced to use this bridge, but it really has no impact in terms of possible configurations and the router should behave the same as if it was not there. It should not be a show-stopper preventing upgrade. You can still do switch chip hardware VLANs etc as before.
r00t
Long time Member
Long time Member
Fri Sep 21, 2018 2:25 am
*) routerboot - fixed RouterOS booting on devices with particular NAND memory (introduced in v6.43);
It would be really helpful if you listed affected devices or at least product ranges. Is CCR affected? Or just MIPS maybe? Do I have to update wireless wire?
This is quite important information you are not giving us!
It's NO FUN updating large network of devices and if there is no reason to update some it could save a lot of time and possibly issues.
"devices with particular NAND memory" is as helpful as saying nothing...
Spirch
Fri Sep 21, 2018 3:42 am
Have you tried netinstall using the ARM main package instead?
https://download.mikrotik.com/routeros/ ... 6.43.1.npk
Also, make sure you are using the newer netinstall 6.43.1 and not an older version. Each time there is a new ROS release, there is a new netinstall version, and using an older one may not work correctly.
I have tried the exact same thing with 6.43.2, without using main package
this time it work #1 the first time, so ... not sure why it didnt work with 6.43.1 ...
flipylost
Fri Sep 21, 2018 5:44 am
RouterBOARD 941-2nD 6.43.1, upgrade error 6.43.2 "not enough space for upgrade"
several attempts same error, after erasing files(files empty) same error :(
after attempt, routeros-smips-6.43.2.npk remains in files. reboot causes same error.
deleted routeros-smips-6.43.2.npk file and reboot the router works correct in 6.43.1
2X RouterBOARD 750G r3 upgrade ok.
ailtojr
Fri Sep 21, 2018 8:04 am
Hello friends I just upgraded to version 6.43.2 and our clients stopped working with ipv6, after this last update I downgraded to version 6.42.7 and returned to normal function.
jarda
Fri Sep 21, 2018 8:05 am
Flipylost, Don't put upgrade files into flash but into ramdisk.
macgaiver
Fri Sep 21, 2018 8:16 am
Why? IF your devices booted - stay on v6.43.1, if they didn't - use v6.43.2, in future use v6.43.2, feature wise both are identical versions.
mducharme
Trainer
Trainer
Fri Sep 21, 2018 8:33 am
Yes, 6.43 - 6.43.2 have a problem with DHCPv6 server, the bindings do not get added. If manual bindings are present, they continue to work, but dynamic bindings are not properly created.
dadaniel
Fri Sep 21, 2018 10:08 am
Great, I did an upgrade to 6.43.1 on hEX and auto-upgrade of firmware was active. I did not reboot yet, so what to do now? I cannot upgrade to 6.43.2 bootloader before reboot! Will it be bricked afterwards?
emils
Forum Veteran
Forum Veteran
Fri Sep 21, 2018 10:11 am
No, a reboot or upgrade will not brick the router. If your router works with 6.43.1, there is no need to upgrade to 6.43.2.
dadaniel
Fri Sep 21, 2018 10:31 am
Ok, so it isn't the bootloader that bricks the devices?
My log says "firmware upgrade successfully, please reboot..." so it hasn't been rebooted since 6.43.1 upgrade.
mducharme
Trainer
Trainer
Fri Sep 21, 2018 10:43 am
I have the same question, I know a few people who have upgraded RouterOS but haven't necessarily rebooted a second time for the firmware update to take effect.
ssbaksa
Fri Sep 21, 2018 11:01 am
I have high CPU usage on switch which does nothing. Only up-link port is connected and nothing else. There is no rules except bridge, admin IP, default route, NTP client, and DNS server.
[admin@mtKO3-SW] /system resource> print
uptime: 22m23s
version: 6.43.2 (stable)
build-time: Sep/18/2018 12:12:48
free-memory: 42.6MiB
total-memory: 64.0MiB
cpu: MIPS 24Kc V8.5
cpu-count: 1
cpu-frequency: 400MHz
cpu-load: 20%
free-hdd-space: 110.5MiB
total-hdd-space: 128.0MiB
write-sect-since-reboot: 144
write-sect-total: 584632
bad-blocks: 0%
architecture-name: mipsbe
board-name: CRS226-24G-2S+
platform: MikroTik
andriys
Fri Sep 21, 2018 11:15 am
ssbaksa, what is in /tool profile?
CsXen
Fri Sep 21, 2018 11:27 pm
NO ! If I have 2 swich chip in my RB2011, and one is 100M, another is 1G, I can make 2 individual "switch". No influence one on another.
If I must do it in bridge, my max. speed will be 100M and NOT 1G on any port. I tested it on 6.40.9 (eth1 - uplink, eth2 - master port of 1G lans, simple NAT): I got 240+Mbps throughput on my ISP.
Other test with 6.42.7 (eth1 - uplink, all other ports on bridge with HW offloading): I got stable 100Mbps on my ISP. Bridge limited my speed to its slowest port speed!
So not having master ports, only one bridge for everything... is a big drawback for us.
CsXen
Fri Sep 21, 2018 11:53 pm
This is a quote from normis
#35
2016. May 25. (Wed), 07:05
Is MikroTik really publicly committing to never allowing the combo package to increase in size to the point where it does not fit on a 16MB device?
Do you seriously suggest that our own software will one day no longer run on our own devices?
Best regards: CsXen
B.G.: "640K ought to be enough for anybody"
mducharme
Trainer
Trainer
Sat Sep 22, 2018 1:22 am
With a 2011, you can make two bridges with 6.42.7, one with 1G lans and one with 100M LANs, both should get hardware offloading as long as they don't include any ports from the other switch chip. Performance should be unchanged from the equivalent master port configuration on 6.40.9.
If however you had both master ports connected via a bridge on 6.40.9 already, the bridge connecting everything-except-ether1 on 6.42.7 should behave in the same way. If it doesn't, this may be a bug, not a shortcoming of the new design.
Sat Sep 22, 2018 1:26 am
It is not so much that I do not like the efforts of MT to make it easier for everyone. And by now, I know how to reconfigure it too... I'm all for having a proper 1-fits-all easy bridge config, although I personally never felt the old switch config was to hard, albeit specific for each device type.
I do however have a problem with the potential unavailability of the "old ways", at least if it is decided from one day to the next without regards.
Moreover, it is the fact that reconfiguration is NEEDED that is my problem. To be more exact: the industries problem. (I'm just relaying the message so to speak)
If you use Mikrotik devices in a production environment, especially in the food&pharma where every programming change needs to be tested and validated, a change like the masterports->bridge will require reprogramming, and therefore needs to go through the re-validation process. Meaning a lot of testing, documenting and re-certifying. And so, cost a lot of money!
People who ever had to take (for instance) a GAMP course for their work, know what I mean.
In general, in a production environment, companies have no desire to do any reprogramming if it does not mean that it adds something badly needed for that environment. It would only cause useless expenses.
So if something just works with 6.40.xxx and it needs a security fix, the industry expects just that. And not the need for qualified engineers to be contracted to reprogram numerous Mikrotik devices, since 6.41+ just does not work anymore with the old config. (And "no", the auto-convert function did not yield the desired results in many cases)
Anyway, I'm glad to see that MT now understands the needs of production environments and hope they continue to do so from now on.
And I'm also absolutely aware that this may conflict with the desire to have the most beautiful RoS that there can be.
I guess it's all part of growing up as a company. MT has pushed forward to also supply very expensive equipment to the big-boys, and not just target enthusiasts-devices anymore. And that comes with it's very own set of requirements, and one of it is 'configuration stability'.
RouterOS fits in very well in that model, both <6.40.xx or >6.41.xx. As long as each version can be relied on of being supported for a few years, without serious extra investments along the way to keep it secure. Cisco has that, HP has that, Dell and Juniper has that.... just to name a few...
And one way that would make it possible, if it is (from MT point of view) undesirable to keep many 'long term' versions in parallel, is to create a .npk with the removed functionality.
That is why I mentioned the package as a potential solution. Since it would avoid extensive reprogramming in existing environments, while keeping only ONE main "long term" branch alive.
That package would solve the issue for the industry, and RoS would remain state of the art for the rest of the community.
So it's not specific for the masterports-change per se, but more in general as a 'way of working' for MT. But the changeover from masterports to bridges was such a fundamental change that I basically use it as baseline to try to get this 'general point' of configuration stability across.
The masterport-change is however the no.1 reconfiguration issue I run into in production situations. Any previous MT changes were less impacting so far.
If MT would decide the current "long term" 6.40.xx line really is only for a few months (so actually more "short term"), I foresee many of these new big customers moving back to the more conventional suppliers the next time network hardware is needed.
And that would be a pity.
Few months ago I tried getting this point across here in the forum, but (almost) nobody understood or cared enough to agree....
When I see reason somewhere in a post to reiterate this point, I will. So I did that in my original reply.
But there is no need to make it into a "is-too is-not" kind of discussion. Everybody may feel about it as they wish. And it's not the place in this thread here.
I'm just relaying concerns I know already exist in the industry regarding MT long term strategies.
Yet, MT DOES still have a 6.40.xx as long term now, and I'm very glad they do!!
(I however do not pretend to be the reason for that fact. I'm sure they probably already understood the importance of that themselves, and are struggling with it too to keep everybody happy)
Sat Sep 22, 2018 2:17 am
Hi MduCharme,
I realize that it might be somewhat unclear why I take masterports and switch-config as a candidate in one legacy package.
In the past in the early public testing of the new bridge model (I believe it was 6.37rc or 6.38rc) it was stated that, because of the perceived complexity of the switch-config and the relation to masterports on that chip, MT would make efforts to make one new bridge model for both. One that would be the same for all MT devices, and no longer specific to the type of RB.
This was put in effect in 6.41, where some new types of RB no longer had a switch chip config.
Realizing that this had an impact on the functionality of those types (now lacking some features other types did have, and features that were available in hardware) MT added the switch menus again.
But in doing so, negating most of their original goal of creating a universal solution, since switch-config is still highly hardware dependent.
I'm pretty sure MT did not bury this goal just yet, they just weren't quite ready.
As such, since the bridge still can't do many things the switch-menu CAN, you still need the switch config as you clearly explained.
But also, I do expect this to be just a matter of time. As soon as they add this functionality to the bridge to form a universal solution, I fear the switch-menu will disappear.
From that moment onwards, configurations made with a configured switch-chip menu (vlan's, port mirroring etc) will need to be reprogrammed in the scripts to work in the bridge, which constitutes problems for production-environments I outlined in the other post.
That is why I basically see the two (masterports and switch-menu) as one. And both together as a candidate for a .npk after both dissappear.
But currently, if one would start a NEW config with vlan and hardware assist, it is indeed perfectly possible to do so in a bridge+switch-menu config.
You're absolutely correct about that.
ozone
Sat Sep 22, 2018 3:51 am
On Thu Sep 13, I reported in the 6.43 thread that after upgrading hap-lite to 6.43, it would no longer accept ipv4 addresses from our dnsmasq dhcpv4 server.
On the HAP-ac it did seem to work fine, as well as on all 6.42.6 and .7 RoS's before it on any RB.
Yesterday I upgraded out test Hap-ac to 6.43.2 (skipped 6.43.1), and now it too does not accept ipv4 addresses anymore from the dnsmasq dhcpv4 server.
Before spitting it out here on the forum, I first asked the admin of the dhcpv4 server if there were any specifics on his servers.
The answer was basically "no", accept for 5 extra dhcp options. I personally do not know what the reason was to add them, but apparently it was needed somehow.
Adding those exact 5 options to the routerboard DHCP-client options list, would fix the problem, and now RB successfully receives ipv4 leases from the dnsmasq-server.
All fine and well... But the million dollar question remains:
WHY do all previous versions of routeros (and all windows and linux clients we have) accept the dnsmasq dhcp-leases, but starting from 6.43 they do not anymore?
What changed in the DHCPv4 client of RoS6.43?
brg3466
Sat Sep 22, 2018 5:33 am
Upgraded to 6.43.2 on CCR1009 (running CAPsMAN), but cannot upgrade the 5 cAPac with 6.42.7 ( running as CAP). Downloaded the OS and put under the /pub in CPAsMAN, then in CAPsMAN> Remote CAP, click upgrade, it doesn't work.
mducharme
Trainer
Trainer
Sat Sep 22, 2018 6:53 am
It may be easier and more realistic to lobby them to improve the auto-convert function instead of keeping 6.40.xxx around forever, or adding an .npk to re-add master port function (which maybe sounds easy but I doubt would be that easy to code, and it becomes much easier to get the auto-convert more bulletproof for unusual configs).
I do not personally know what MikroTik's plans are in this regard, but I would caution against reading too much into the "bugfix-only" being renamed "long-term" as having anything to do with a long term continuation of the 6.40.x software, unless they have made a specific announcement in this regard. Yes, 6.40.x is still in the bugfix-only tree, but it is pretty common if you dig back to see that the bugfix-only firmware is typically two or three versions behind the current release, and so the situation we have now is not that unusual.
pe1chl
Sat Sep 22, 2018 10:46 am
What we need is a version that can auto-convert existing configurations that use a combination of master-port, VLAN subinterfaces on that master port, and switch configuration for tagged/untagged VLAN on the ports,
into a new configuation with a single bridge with VLAN filtering and full hardware acceleration just like the above configuration always had.
(i.e. the VLAN-filtering bridge just invisibly configures the switch chip for configurations where is is possible, and for simple VLAN tagging/untagging it clearly is possible because that works fine up to 6.40)
mkx
Sat Sep 22, 2018 11:13 am
What we need is ROS version that fully HW offloads everything that underlying HW supports.
Only after that we will actually need auto-coversion functionality. My fear, though, is that the afore-mentioned all-HW-offload version will come so late thate there won't be enough adventurous users still running 6.40.x to thoroughly test the auto-conversion and thus the conversion will fail on some (more or less mission critical) setups making MT look bad (yet again).
pe1chl
Sat Sep 22, 2018 11:50 am
Well, I would be satisfied with the common scenario described above. There are so many obscure filter possibilities in some of the switch chips that probably nobody uses, that it would be too much work to move those all into the new bridge functionality.
But simple VLAN tagging/untagging in a config without spanning tree or bridge-level IP filtering should be simple enough to support, and in fact I always assumed during the 6.41RC development that this would be part of the finally released version. Then 6.41 went out without accelerated VLAN support, and now chances that it is ever going to be fixed become slimmer and slimmer.
Fortunately in most scenarios we have external switches connected to MikroTik routers so we have a way to migrate away from using MikroTik equipment as a switch...
But still...
ssbaksa
Sat Sep 22, 2018 12:33 pm
@andriys
Strange! After changes form switch without any rules to switch with VLANs usage fell down. I must check another switch with this strange high usage.
[admin@mtKO3-SW] > /tool profile
NAME CPU USAGE
console 1%
networking 2%
winbox 0%
logging 0%
management 3.5%
profiling 1%
telnet 1%
bridging 0.5%
unclassified 3.5%
total 12.5%
mkx
Sat Sep 22, 2018 12:50 pm
While generally I agree with pe1chl I still think that vast majority of things that switch chips are capable of doing should be HW offloaded before "legacy" way of configuring them gets murdered. Problem is that as soon one configures one simple thing which is not HW offloaded, all HW offload stops and performance of the whole box drops to lowest level of underground.
Example (and I'm not sure if you can do it on SW bridge): port mirroring. Some switches can do it and some can not. While one had to configure it via switch chip settings, if it wasn't supported, it couldn't be configured and thus it didn't work. Period. If one is using modern bridge with HW offload enabled (e.g. simple port switching without VLANs and other bells and whistles) and configures port mirroring (again: I don't know if it's possible), she will get port mirrored but will loose all switching performance ... which in turn might change behaviour of device under investigation so much that symptoms, which made administrator to enable port mirroring, become completely obfuscated and whatever investigation might render results unrelated to reality.
nordex
Sun Sep 23, 2018 12:33 am
DO NOT upgrade it on 2011.
Bricked one from 43 to 43.2., me too.
Remote destination...tommorow will be looong day.
mducharme
Trainer
Trainer
Sun Sep 23, 2018 1:09 am
It is probably not the 43 to 43.2 upgrade that did it, but instead, the routerboot firmware upgrade for 43. If you didn't reboot a second time after 6.43, the routerboot upgrade would not take place until the following reboot, which is probably by happenstance when you rebooted to upgrade to 6.43.2.
Sun Sep 23, 2018 7:30 am
Hi MduCharme
The renaming of the bugfix branch into long-term, just makes me a little hopeful :)
When I first posted my concerns, 6.41 wasn't even out as "current/stable". It was still in 6.41rc (testing).
But it was clear where MT was going with the bridge. Also they did not have a very good track record of keeping the bugfix-versions for long.
That's basically what made me do the post back then.
Today, 6.40.xxx can indeed be discarded at any time since it's already pretty old (measured against their previous lifecycles). But doing so would make their new title "long term" a little ludicrous.
A more serious "longer term" would be at least a few years of configuration stability.
This in itself does not mean keeping 6.40 indefinitely. It can ALSO mean some other way of still supporting the original config scripts, preferably without (auto)converting them (since this would mean re-certification in certain cases).
This is not at all unique in the industry. Eg., since Microsoft changed their update model with Windows10, they too added an LTSB edition to cater production environments....
I do not have real insight in MT's kitchen, but it at least 'seems' that they are becoming more sensitive to longer-term stability then the were before. And that makes me cautiously optimistic.
I hope I won't be disappointed....
And frankly, how they do it, makes no difference. (I just expressed how it seems to me to be easiest way for them)
mducharme
Trainer
Trainer
Sun Sep 23, 2018 7:40 am
Almost every major version they have released lately has brought about config changes that, unless they are auto-converted by the upgrade process, prevents an older config from being loaded into a newer version router. Even simple changes like moving to interface lists for the MAC server / IP neighbor discovery lists breaks direct compatibility with old documented configs. These changes are unrelated to the new bridge code. There may be more re-certification needed already than is generally realized.
Sun Sep 23, 2018 7:45 am
I agree with most of the points being made here, at least in a technical sense.
Sequentially:
1) First MT needs to add all current options into the bridge-menu, without disabling them in the switch-menu.
2) After "1", as 2nd step a proper (auto)conversion must be created (although there can be SOOOO many different configurations out there it will never work in all cases)
3) And after "2", a transition period should be organized (let's say 3-5 release versions) where it is released to the masses (many users don't even run rc's, or just stick with a certain version for over a year, so you need more time here to get proper new-feature-penetration).
This way the kinks can be properly be ironed out, instead of serving everyone with a buggy/incomplete version that we unfortunately seen all to often recently.
Only then can they start thinking of "murdering" the old options.
And even so, I would do the "assassinating" in phases... eg. first remove it in Webif and Winbox for again a few more release versions, but leave it in the CLI. (this way old scripts at least still work, but new users will most likely stop using it)
With all these phased steps and overlaps, almost automatically you get a grace period of "the old ways" of a few years...
(just thinking out loud here)
But all that is "the tech" part of me talking... But in the many years in the business I now sometimes have to wear a second hat.
And if I let the company-representative in me do the talking, the above might still be to progressive and uncertain.
I doubt if the pure company-guy in me should honestly advise in favor of a new MT purchase, if it's not absolutely clear that investments are going to be safe for a few years.... I know for a fact that this is a genuine concern at many companies.
The tech guy in me LOVES the Routerboards. But sometimes one needs to be upfront about why you choose a Routerboard device. And if it is for a business that needs it for certain purposes, current MT strategies just might not be best suited for it in the long run.
Even if the RB-device can do it, and even though RB is definitely an amazing piece of kit from an engineers point of view.
Ultimately it's up to MT to decide if they are serious about committing to this target group, or just stick with being an engineers dream.
Sun Sep 23, 2018 7:59 am
Yes that's true.....
But it's no reason to ignore certain problems "just" converting something may create in the field. And the potential consequences of it.
Even if, in itself, it is a great idea.
Just one more reason to pursue certain feature-frozen versions imho.
Funny that you bring up this exact example ... as it was an issue I noticed on some devices suddenly not being able to be winboxed anymore.
The autoconvert hadn't worked just as it should have been working...
OndrejHolas
Sun Sep 23, 2018 11:57 am
My RB912UAG-2HPnD (cpu: MIPS 74Kc V4.12, fw type: ar9340) was bricked by ROS update from 6.43.1 to 6.43.2:
ROS 6.42.7, fw 6.42.7: uploaded 6.43 packages, /sys reb - OK
ROS 6.43, fw 6.42.7: /sys rou up, /sys reb - OK
...a few days later...
ROS 6.43, fw 6.43: uploaded 6.43.1 packages, /sys reb - OK
ROS 6.43.1, fw 6.43: /sys rou up, /sys reb - OK
ROS 6.43.1, fw 6.43.1: uploaded 6.43.2 packages, /sys reb - BRICKED
Recovered the box by Netinstall (installed 6.43.2 packages), then completed the firmware upgrade, downgraded both ROS and fw back to 6.43.1 and repeated the failed step:
ROS 6.43.2, fw 6.43.1: /sys rou up, /sys reb - OK
ROS 6.43.2, fw 6.43.2: uploaded 6.43.1 packages, /sys pack down - OK
ROS 6.43.1, fw 6.43.2: /sys rou up, /sys reb - OK
Netinstall again, 6.43.2 packages. Another experiment:
(contrary to the first experiment, here I skipped firmware downgrade 6.43.2->6.43.1)
ROS 6.43.1, fw 6.43.2: uploaded 6.43.2 packages, /sys reb - OK
Thus in my case the problem occurs when upgrading ROS packages and the firmware is exacly 6.43.1.
Ondrej
CZFan
Location: South Africa, Krugersdorp (Home town of Brad Binder)
Mon Sep 24, 2018 4:21 pm
Note sure if someone has mentioned this before, if so, apologies for reposting
Current TX Power = 0dBm
board-name: hAP ac^2
model: RBD52G-5HacD2HnD
firmware-type: ipq4000L
factory-firmware: 3.43
current-firmware: 6.43.1
upgrade-firmware: 6.43.1
andriys
Mon Sep 24, 2018 7:24 pm
Current TX power readings are not supported for 802.11ac-capable wireless cards. That's a known (and documented!) limitation that has always been there.
CZFan
Mon Sep 24, 2018 7:40 pm
My post is on the 802.11b/g/n WLAN card
Can you provide link to the documentation, want to go read up a bit more
andriys
Mon Sep 24, 2018 7:57 pm
Look at the very bottom of this wiki page (in the "Winbox" section).
CZFan
Mon Sep 24, 2018 8:02 pm
Got it, thx.
I think it should rather be placed under headings for TX power, not right, right at the bottom of the document under some willy nilly comment about Winbox.
bennyh
Tue Sep 25, 2018 8:54 am
I have MTU problem with IPIPv6 in these and older ROS releases too. There is IPsec encrypted IPIPv6 tunnel between 3011 and 750gr3, if I change the proposal auth method from SHA1 to SHA256, the MTU is changing, but the clamp MSS option doesnt work and all TCP connection is broken (HTTP, Winbox) till I make postrouting TCP MSS changing rules, where I lower the MSS, then It semms the TCP connections ar workable again (but IPV6 stay broken, because a cant made IPv6 change MSS rules, no options to check the MSS value in IPv6 firewall, there are greyed sections at rules).
andriys
Tue Sep 25, 2018 10:10 am
Rather then doing MSS clamping you'd better fix your firewall to allow PMTUD to function properly across your tunnel...
kos
Tue Sep 25, 2018 10:26 am
Since ROS 6.43 there are entries setting ethernet speed to 100Mbps for every cooper not auto negotiated interface on every MT device. Is it normal?
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] speed=100Mbps
set [ find default-name=ether7 ] speed=100Mbps
bennyh
Tue Sep 25, 2018 10:40 am
And how? There is nothing blocked between two router and two sites, ICMP goes trough freely from one site to other. What sould I do? It looks like, the PMTU discovers wrong MTU value.
saaremaa
Tue Sep 25, 2018 2:06 pm
Is there any information on correcting the error "Delegated-IPv6-Prefix" attribute for PPPoE?
viewtopic.php?f=1&t=89443&start=100#p687190
viewtopic.php?f=1&t=89443&start=100#p687516
viewtopic.php?f=1&t=89443&start=100#p687867
thg3x
Tue Sep 25, 2018 4:40 pm
Waiting too !
mducharme
Trainer
Trainer
Tue Sep 25, 2018 8:22 pm
The problem is bigger than just the Delegated-IPv6-Prefix - from my testing, DHCPv6 prefix delegation is basically entirely broken, at least with PPP connections, whether or not RADIUS is used. Only if there is a static DHCPv6 binding will DHCPv6 prefix delegation work with PPP connections in 6.43.xx. We can't really tell if there is a problem with the Delegated-IPv6-Prefix RADIUS attribute until this issue is fixed.
mkx
Tue Sep 25, 2018 9:11 pm
This was always set like this (you could verify it by checking output of /interface ethernet print). It is now shown in export because default setting starting with 6.43 is 1Gbps ... upgrade does not change settings and export shows differences from default. The value does not apply when autonegotiation is enabled... which is default as well.
BTW you can set speed to 1Gbps even if underlying interface hardware is 100Mbps only (e.g. on hAP ac lite).
bennyh
Wed Sep 26, 2018 11:46 am
Today I checked all my firewall rules (IPv6 and IPv4 too), I disabled some rules, that may have negative aftermaths, but these rules only touched that interfaces between them the tunnel is created on (end interfaces of 2 WWAN connection bridged trough unsafe switch in a tower). Inside the tunnel and on tunnel interfaces there is no blocking rules, all input output and forward allowed.
The problem still exists.
If I change the keying method from SHA1 to SHA256, the IPIPv6 reconnect and after thet the new TCP connections are broken, but ping works.
What next now?
Kraken2k
Wed Sep 26, 2018 12:36 pm
I found a strange behavior about bridges - might be only WinBox issue but still...
I have two bridges in my config - when I create bridge, MAC address is automatically assigned (I never use administrative MACs, or create bridges by Copy) and these are unique. But since the moment, when I assign a port to the bridge, Winbox shows the same MAC for both bridges.
in configuration, there is no sign of that addresses (not even in the whole device config export):
add arp=proxy-arp comment=LAN fast-forward=no name=bridge-lan
add fast-forward=no name=bridge1
Device is RB1100AHx2 with RoS and RB firmware upgraded to 6.43.2
andriys
Wed Sep 26, 2018 12:48 pm
What next now?
Check if the MTU settings on your tunnel interfaces are correct. In case you rely on RouterOS to calculate it automatically try setting it to the correct value manually (I'm not even sure RouterOS can calculate it correctly in all possible tunneling/encapsulation scenarios).
bennyh
Wed Sep 26, 2018 2:29 pm
What next now?
Which values are correct for IPIPv6 MTU trough 802.11 with SHA256+AES256 IPSec? Now there is nothing set for MTU, the Actual MTU with SHA1 is 1414, with SHA256 is 1410 .
pe1chl
Wed Sep 26, 2018 2:52 pm
You can always set it lower than strictly required, e.g. 1400 or 1300
mkx
Wed Sep 26, 2018 3:12 pm
Can you post output of command /interface bridge export? Just to check if there's something weird.
Kraken2k
Wed Sep 26, 2018 4:04 pm
Here is the output - bridge1 was only created to demonstrate this, and there is only one interface included atm. Yes, I'm aware that vlan filtering is inactive in this configuration - the thing is that after upgrade and removing the second bridge the vlan filtering rules (that so far worked as expected) suddenly blocked all traffic, even if removing second bridge should not definitely affect the operation of the first one:
add bridge=bridge-lan interface=ether2
add bridge=bridge-lan interface=ether4
add bridge=bridge-lan interface=ether5
add bridge=bridge-lan interface=ether1
add bridge=bridge-lan interface=ether6
add bridge=bridge1 interface=vlan100-remote1
add bridge=bridge-lan frame-types=admit-only-vlan-tagged interface=ether3-tst pvid=10
add bridge=bridge-lan interface=ether7 pvid=20
add bridge=bridge-lan interface=ether8 pvid=10
add bridge=bridge-lan interface=ether9 pvid=10
/interface bridge settings
/interface bridge vlan
add bridge=bridge-lan comment=A tagged=ether1,ether2,ether6,ether4,ether5 vlan-ids=30
add bridge=bridge-lan comment=M tagged=ether4,ether5,ether1,ether2,ether6,ether3-tst vlan-ids=10
add bridge=bridge-lan comment=S tagged=ether6 untagged=ether7 vlan-ids=20
add bridge=bridge-lan comment=G tagged=ether4,ether5,ether2 vlan-ids=60
add bridge=bridge-lan comment=TST tagged=ether6 vlan-ids=70
add bridge=bridge-lan comment=R1 tagged=ether6-server vlan-ids=100
mkx
Wed Sep 26, 2018 4:33 pm
I was hoping to see actual configuration ... better yet, post output of /inteface bridge print, /interface bridge port print and /interface ethernet print ... it would be interesting to see where MAC of both bridges comes from.
Kraken2k
Wed Sep 26, 2018 5:58 pm
Here - MACs seems to be originated from ether1 default MAC address:
/interface bridge> print
 0 R ;;; LAN
     name="bridge-lan" mtu=auto actual-mtu=1500 l2mtu=1598 arp=proxy-arp arp-timeout=auto mac-address=D4:CA:6D:41:F5:CA protocol-mode=rstp fast-forward=no
     igmp-snooping=no auto-mac=yes ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6 vlan-filtering=no dhcp-snooping=no
 1 R name="bridge1" mtu=auto actual-mtu=1500 l2mtu=1594 arp=enabled arp-timeout=auto mac-address=D4:CA:6D:41:F5:CA protocol-mode=rstp fast-forward=no igmp-snooping=no
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE                                              BRIDGE                                              HW  PVID PRIORITY  PATH-COST INTERNAL-PATH-COST    HORIZON
 0   H ether2                                                 bridge-lan                                          yes    1     0x80         10                 10       none
 1   H ether4                                                 bridge-lan                                          yes    1     0x80         10                 10       none
 2   H ether5                                                 bridge-lan                                          yes    1     0x80         10                 10       none
 3   H ether1                                                 bridge-lan                                          yes    1     0x80         10                 10       none
 4   H ether6                                                 bridge-lan                                          yes    1     0x80         10                 10       none
 5     vlan100-remote1                                        bridge1                                                    1     0x80         10                 10       none
 6   H ether3                                                 bridge-lan                                          yes   30     0x80         10                 10       none
 7   H ether7                                                 bridge-lan                                          yes   20     0x80         10                 10       none
 8   H ether8                                                 bridge-lan                                          yes   10     0x80         10                 10       none
 9   H ether9                                                 bridge-lan                                          yes   10     0x80         10                 10       none
Flags: X - disabled, R - running, S - slave
 #    NAME                                                             MTU MAC-ADDRESS       ARP             SWITCH
 0 RS ;;;
      ether1                                                          1500 D4:CA:6D:41:F5:CA enabled         switch2
 1 RS ;;;
      ether2                                                          1500 D4:CA:6D:41:F5:CB enabled         switch2
 2 RS ;;;
      ether3                                                          1500 D4:CA:6D:41:F5:CC enabled         switch2
 3 RS ;;;
      ether4                                                          1500 D4:CA:6D:41:F5:CD enabled         switch2
 4 RS ;;;
      ether5                                                          1500 D4:CA:6D:41:F5:CE enabled         switch2
 5 RS ;;;
      ether6                                                          1500 D4:CA:6D:41:F5:CF proxy-arp       switch1
 6 RS ;;;
      ether7                                                          1500 D4:CA:6D:41:F5:D0 enabled         switch1
 7 RS ;;;
      ether8                                                          1500 D4:CA:6D:41:F5:D1 enabled         switch1
 8 RS ;;;
      ether9                                                          1500 D4:CA:6D:41:F5:D2 enabled         switch1
 9 X  ether10                                                         1500 D4:CA:6D:41:F5:D3 enabled         switch1
10 R  ;;; WAN
      ether11-wan                                                     1500 D4:CA:6D:41:F5:D4 enabled
11 X  ether12                                                         1500 D4:CA:6D:41:F5:D5 enabled
12 X  ether13                                                         1500 D4:CA:6D:41:F5:D6 enabled
Kraken2k
Wed Sep 26, 2018 6:30 pm
It seems that bridge gets it's MAC automatically from the first port connected to it - dynamically changing this whenever the config change is made.... okay, tl;dr; probably my mistake with configuration.
I think I see the problem: routing vs. bridging configuration:
/interface vlan> print
 #   NAME                                     MTU ARP             VLAN-ID INTERFACE
(output omitted)
 7 R ;;; R1
     vlan100-remote1                         1500 enabled             100 bridge-lan
router interface vlan100-remote1 has been defined on bridge-lan in router configuration, but later added to bridge1 which caused strange behavior (including strange traffic flow over the LAN).
So "MAC flow" was ether1 -> bridge-lan -> vlan100-remote1 -> bridge1
*sigh* I need some rest.
andriys
Wed Sep 26, 2018 7:46 pm
This is actually a documented behavior...
2jarek
Wed Sep 26, 2018 7:49 pm
Again in6.43.2 Nv2 frame priority qos works very poorly for dynamic downlink. For fixes downlink or sync master works fine.
Kraken2k
Wed Sep 26, 2018 8:59 pm
Yes, it is... I just had no idea, how two bridges managed to get the same MAC dynamically. Now I know - my mistake, case closed.
arneh00
Wed Sep 26, 2018 9:28 pm
Hello every one I just update my microtik os and i can not reach from outside to my internal network, actually when I trace my internal network address from outsite it comes till my internet ip address which is set on microtik but doesnt reach my local network, can any one help please.
ziegenberg
Wed Sep 26, 2018 9:47 pm
Do you have an public IPv4 address for your internal network?
arneh00
Thu Sep 27, 2018 7:21 am
My internal network ip rage is 192.168.1.x , I dont know what you mean by public IPV4 address
sindy
Thu Sep 27, 2018 8:52 am
Did it work before upgrade to 6.43.2? If not, create a new topic and export your configuration there; if it did, create a new topic with a configuration export anyway and place a link to it here. Accessing the (private) address range which you use on LAN via the Internet is normally only possible by means of VPN, so something important must be missing in your description.
bennyh
Thu Sep 27, 2018 8:59 am
Ok, it seems work with 1400 (I tried with Actual MTU 1410 too but TCP failure trough tunnel), if I set this value at booth ends, but with SHA1 such thing didnt need, it looked like actual MTU worked right without MTU settings.
pe1chl
Thu Sep 27, 2018 9:07 am
Well, when you think the default values are not good enough for you it always could mean you need to study the matter to
know the result of changing encryption lengths or hash methods. I happily run everything at the default SHA1/AES128 and
I am not too worried that the theoretical weaknesses will actually be exploited by someone...
bennyh
Thu Sep 27, 2018 9:59 am
For SHA256: A clever latin guy said once in the far past: Si vis pacem, para bellum, and Google said, SHA1 is breakable (but expensive), so If the HW engine can accelerate SHA256, why we dont use?
The ROS is changing the actual MTU if I change the method, but it semms there is some sh*t in pancake, as we say it. Ok I am not a professionel in tunnelling and crypting techniques, but If a Mikrotik document doesnt write other (please link it for me if exists), It should work, but it doesnt. Thats it, should be fix.
andriys
Thu Sep 27, 2018 12:14 pm
The ROS is changing the actual MTU if I change the method, ... , but If a Mikrotik document doesnt write other (please link it for me if exists), It should work, but it doesnt.
The IPIP wiki page says the default is 1500. Nothing is said about MTU being automatically/dynamically adjusted, so I assume no automatic adjustment ever happens. Though I'd still expect it to work happily (though not fully efficiently) even with the default MTU of 1500, unless you set dont-fragment interface property to yes.
pe1chl
Thu Sep 27, 2018 12:44 pm
The tunnel interfaces have a manually adjustable MTU that may default to 1500, but once they are installed and up they have an "actual MTU" which is automatically set to 1500 minus the tunnel overhead for that type of tunnel (sometimes a bit lower: when the header actually has a variable size it is set according to the maximal size of that header, even when it really cannot increase to that size with the functionality that RouterOS offers).
So when you create an IPIP tunnel and don't set the MTU, it will set an actual MTU of 1480 (correct).
However, this calculation apparently fails when IPsec is configured with nondefault hash/encrypt selection. So the "overhead of IPsec" was likely only calculated for the default case.
Note that it fails as well when the outer packets are routed through an interface that does not have MTU 1500 (e.g. PPPoE).
There is apparently no dynamic adjustment of the "actual MTU" based on MTU of the outgoing route, or returned ICMP "size exceeded" messages.
So in such cases you need to manually set a lower MTU on the tunnel interface.
andronovDmitriy
Fri Sep 28, 2018 3:57 am
Problem firmware 6.43 - 6.43.2.
Multiple gre with ipsec unreachable with new dynamic peer.
Because router os no distinction is made between peers with different
local addresses to one remout address.
I was able to start gre from the second local address only manually create peer and set passive mode.
sindy
Fri Sep 28, 2018 11:46 am
Because router os no distinction is made between peers with different local addresses to one remout address.
Dmitriy, are you 100% sure that it did work different before 6.43? If yes, send your observations to support@mikrotik.com together with a supout.rif file; if not, create a separate topic in General section of the forum because in such case this one would not be the right topic to discuss it.
kelner
Fri Sep 28, 2018 2:18 pm
On v.6.43.[12] RADIUS authentication at login does not work on my routers. It worked well on v.6.42 though. Does anybody has such problem too?
BartoszP
Fri Sep 28, 2018 2:19 pm
kelner
Fri Sep 28, 2018 2:50 pm
Thank you!
Adding "mschap" into freeradius' config file radiusd.conf looks like the solution.
authorize {
files
mschap
authenticate {
mschap
mducharme
Trainer
Trainer
Fri Sep 28, 2018 11:41 pm
It has now been nearly three weeks since 6.43 was released and DHCPv6 PD server over PPP is still completely broken, preventing all PPP clients from getting IPv6. Is a fix coming soon? It is a rather critical issue.
jasonx
Sat Sep 29, 2018 3:54 pm
the problem with the ipv6 dhcp server continues, in bindings does not work in version 6.43.2
sophitus
Sun Sep 30, 2018 2:01 pm
My hap ac has still memory leak and crashes even in 6.43.2 not really stable
kernel failure in previous boot
out of memory condition was detected
mducharme
Trainer
Trainer
Mon Oct 01, 2018 2:46 am
I also have instabilities with my hap AC, crashing every week, although I wasn't graphing memory usage before so I can't be sure there is a leak on mine. I've just set up the graphing to try to see.
sophitus
Mon Oct 01, 2018 3:00 pm
Reverted to 6.42.7 and no related crashes anymore, with 6.43.2 I had daily out of memory crashes....
Vovanys
Re: v6.43.1 [stable] and v6.43.2 [stable] are released!
Mon Oct 01, 2018 11:28 pm
hAP ac
After update to 6.43.2 (stable)
system,error,critical router was rebooted without proper shutdown by watchdog timer
This happened several times already.
Before this year no reboots
dziku2
Wed Oct 03, 2018 9:44 pm
On hAP ac2 is similar problem. Unexpected reboots every 2h to 48h. I sent description of problem to Mikrotik support.
mkx
Wed Oct 03, 2018 9:52 pm
My experience on hAP ac2: very unstable, plenty of watchdog reboots (most of them due to ping timeouts, pinged address is linux server on LAN).
For me instability is regression from 6.42.9.
mducharme
Trainer
Trainer
Thu Oct 04, 2018 5:14 am
Update: I do not seem to have a memory leak, graphing the memory usage over the past few days has shown no changes, but my device is still crashing about once a week since the new versions.
grawerpl
Thu Oct 04, 2018 1:20 pm
After upgrade can't make to work EoIP over IPSec (IPIP over IPSec works but not without issue) and not working IPSec witch older firmware. What is even more disturbing it shows that established tunnel but no traffic pass and that same with EoIP over IPsec. Configuration was restored from backup, and i try everything but still nothing helps.
Ooo and another thing is that every change in ipsec is done, it not reset tunnel i must reset it manual :/
Davis
Fri Oct 05, 2018 1:30 am
I have the same issue - one of my hAP ac2 is rebooting from time to time (looks like it usually reboots within 24 hours and then works properly till I reboot it manually - however this most likely is pure coincidence). My hAP ac2 also stuck/crashed without rebooting once (it resumed working after unplugging+replugging power).
For me the issue started after upgrade from 6.43.1 to 6.43.2. Router was working on 6.43.1 for around 48 hours without a single reboot. Then router was upgraded to 6.43.2 and after around 6 hours it rebooted for the first time.
Resource graphing is enabled on the router and memory usage was always below 17% (so memory leak should NOT be the cause of reboot, at least a memory leak that grows longer than 5 minutes).
Has MikroTik support replied to you?
sophitus
Fri Oct 05, 2018 9:57 am
As it looks like I have again mem leak reboots on hap ac with RouterOS 6.42.9. Just before reboot IPSEC failure show up in logs. 6.42.7 seemed to be ok, but 6.42.9 is again bad even on bugfix!
mkx
Fri Oct 05, 2018 7:09 pm
I take my words back. Instability is not a regression from 6.42.9, my hAP ac2 was not completely stable while running 6.42.7 (but much more stable than any of 6.43.x). Two days ago I downgraded to 6.42.9 and so far it's stable.
Some statistics:
  • while running 6.43 for 7d21h it rebooted 13 times due to "watchdog cannot ping address W.X.Y.Z, reboting". So it had average uptime of 14.5 hours.
  • while running 6.43.1 for 15d4h it rebooted 48 times, so it had average uptime of 7.6 hours
  • while running 6.42.9 for 1d21h it never rebooted (current uptime 1d21h16m57s)
Every time I installed another version of ROS I also upgraded (or downgraded) firmware. Next I'll try to upgrade only ROS to determine if source of instability is ROS or firmware.
N.b.: my hAP ac2 doesn't seem to suffer of memory leaks, memory usage graph shows more or less steady usage of less that 1/4 of available RAM.
dziku2
Fri Oct 05, 2018 8:43 pm
It's the reply from Mikrotik support:
Right now I do not see where is the issue.
Try to turn of watchdog timer:
"/system watchdog set watchdog-timer=no"
And after device freeze, reboot or powercycle it and then manually create new supout.rif file. Send it to us.
Cha0s
Fri Oct 05, 2018 10:53 pm
After upgrading to 6.43.2 from 6.42.7 you can no longer have multiple IPsec peers to the same destination IP but with different source addresses.
This worked fine on 6.42.7.
What's the reasoning behind this restriction?
I need multiple peers to the same destination but using different gateways (source addresses).
Please revert this change.
sophitus
Fri Oct 05, 2018 11:02 pm
Appearently there is a memory leak since changelog 6.44beta17 (2018-Oct-04 09:42) states:
"*) bridge - fixed possible memory leak when VLAN filtering is used;"
I had VLAN filtering turned on... on my hap ac
The ones who monitored stable memory usage, did you have VLAN filtering on?
6.42.7 is still the best release for me so far and not 6.42.9.
mducharme
Trainer
Trainer
Fri Oct 05, 2018 11:32 pm
I have stable memory usage on my hAP AC and no VLAN filtering, but unexplained reboots approximately once a week.
mkx
Sat Oct 06, 2018 11:14 am
As I noted memory usage on my hAP ac2 is stable and I don't have VLAN filtering enabled (I'm dealing with VLANs on switch chip).
andriys
Sat Oct 06, 2018 1:41 pm
This regression is said to be fixed in 6.44beta14. Please check the change log in the post here. And I'd expect this kind fix to be merged to 6.42.x later as well.
Cha0s
Sat Oct 06, 2018 1:56 pm
Thanks. I totally missed that entry in the changelog.
narian
Mon Oct 08, 2018 2:42 pm
Just upgraded RB951Ui-2nD from 6.42.7 to 6.43.2 and it's bricked. Netinstall does not see it.
I've upgraded it from winbox system -> packages -> download and install.
What could be a reason and is there any way to ressurect bricked device?
draguzet
Mon Oct 08, 2018 10:13 pm
Same here, repeated on 4 devices :(, copy paste .npk file, reboot...device DEAD, it make beep beep, but is not live, no winbox, no IP access, no wifi powered on ??
Something are bad with 6.43.2 ? Mikrotik ?
mkx
Mon Oct 08, 2018 10:32 pm
Some statistics:
So I upgraded ROS to 6.43.2 while leaving firmware at 6.42.9 ... instability came back, in 2d10h it rebooted 8 times with average uptime of 7.3 hours. Memory usage (as charted by graphing tool) never raised above 40MB (out of 240MB), so this clearly is not the reason for reboots.
I hope MT will improve on stability of 6.43 branch ... or launch better (and more stable) 6.44 soon.
draguzet
Mon Oct 08, 2018 10:50 pm
Narian, what is the behavior of bricked device ? I have sveral with same problem.
1. After upgrade to 6.43.2 device are unreachable, boot up properly but not working.
2. I try to reset on default, and is passed, but same problem
3. Wifi are powered on with default SSID, after I try to connect to wifi stop working
4. LAN led are green even I disconnect LAN cable from that port
5. Netinstall not working
FiREWiRE
Tue Oct 09, 2018 1:27 am
I've just upgraded my good old RB750G from 6.42.7 to 6.43.2 using check for updates and then download and install. The front LEDs of the router went out, as they usually do when it reboots, but they never came back. Winbox (latest version) couldn't connect to the router, no DHCP, no internet, nothing, the router was stuck. I've waited for about 5 minutes and decided to disconnect and reconnect the power cord. The router came back to life. I've checked the package list and version 6.43.2 was installed.
I've then upgraded the firmware using /system routerboard upgrade
After the firmware update a reboot is required so I've used system reboot and again the router was stuck.
I've waited a couple minutes and did the same disconnect and reconnect of the power cord to fix it.
There is a serious problem happening when rebooting the router using 6.43.2
I'm wondering if this has anything to do with it:
What's new in 6.43.2 (2018-Sep-18 12:12):
Changes in this release:
UpRunTech
Tue Oct 09, 2018 1:34 am
Seeing as 6.44 will be a while can you please put any wireless patches from 6.44RC into the 6.43 branch? I have had CAPAC and HAPAC units stop registering clients on 6.43.2 until they were rebooted even though the interface was running.
*) wireless - improved stability for 802.11ac;
dasiu
Trainer
Trainer
Wed Oct 10, 2018 2:40 pm
On mipsbe devices with AR8227 switch chipset (100 Mbps 5-port routers like hAP, hAP ac lite, hEX lite, hEX PoE lite, RB951Ui-2Hnd, OmniTik 5) it seems you can damage the routerboard after upgrading it to 6.43.2 and using no-default settings...
Anyone experienced physical Ethernet port problems after upgrade to 6.43.2? Port not linking or port showing false link without any cable connected (and looping traffic)?
Happened to me few days ago and to my friend yesterday:
Me: RB951Ui-2HnD. After upgrade - ports 2,3 stopped working. First they were just off (not reacting to the cable), then they started showing link (one - 10 Mbps, other one - 100 Mbps). Then port ether5 also stopped working (no reaction to link, showing inactive all the time). Additionally - I can use ether1, but when I add ether1 to the bridge (even if it's the only port in the bridge and regardless of hw-offload on or off) I have packet losses on the port.
My friend - 2 hAP ac lite devices. After upgrade - few Ethernet ports are just down (not showing link with cable connected), while others work (you can log in, etc.) with the same config.
The same architecture, the same chipset (AR8227), the same software version and problem after upgrade, both of us using "no-defaults" reset. Different devices with different configs on different continents. Is it possible, that the upgrade "destroyed" something physically? Or is it really just that strange coincidence only 2 of us had?
draguzet
Wed Oct 10, 2018 3:20 pm
Same situation, described below:
dasiu
Trainer
Trainer
Wed Oct 10, 2018 3:35 pm
Thank you, draguzet!
I reported it, Ticket#2018101022006114.
Can you, please, also share if you did firmware (RouterBoot) upgrade on it (System -> Routerboard -> Upgrade)? Or did it stay on older firmware? Also - what is the device model?
BTW - wifi is available, but "not working", the same for me. Reason is - the wifi is in the same bridge as the faulty ports, and is getting a broadcast storm (the ports are doing loop), and after connecting to wifi I'm getting the MNDP broadcast packets multiplied thousands times.
BTW2 - Netinstall not working also for me...
draguzet
Wed Oct 10, 2018 4:54 pm
It is on old Firmware, because first boot are not successful and I did not have a way to upgrade firmware (Routerboard - Upgrade).
Device models with problems are: RB951Ui-2HnD , RBDynaDishG-5HacDr3, RB921GS-5HPacD-19S, and for now we stop to upgrade !
I have successful Netinstall (on DynaDish for now) on following way:
1) Power your device off;
2) Power device on;
3) Press and hold the reset button (hold about 1m and relese reset button).
4) Device are detected on Netinstall, and DO NOT install 6.43.2 because same problem are present again !
owsugde
Re: v6.43.1 [stable] and v6.43.2 [stable] is released!
Thu Oct 11, 2018 1:51 pm
I suspect this fix to be incomplete, to say the least. Several of my wAP ac's in the field have become quite unstable, especially on reboots. Not sure if by .43.x or specifically .43.2 though.
schadom
Thu Oct 11, 2018 5:03 pm
We encountered an issue with the /routing bgp advertisements print detail where ... command which seems to crash/reboot our CCR1009-7G-1C-1S+s running on 6.43.1. We have two BGP full feeds with each approx. 720k IPv4 and 58k IPv6 routes, Cymru feed with 105k bogon prefixes and we redistribute a full feed to a single customer. Free Memory is at 840/1968MB, CPU usage average at 12%.
Generally stability of the BGP implementation and routing-related commands seems to have gotten much worse following the 6.43 release. Peering sessions terminate randomly, CMDs like /ip route print sporadically return false double results for the same dynamic route with same origin/path or even fail entirely, causing the terminal to freeze. With a (Cisco) peer we even encountered "AFI invalid address family" errors on the peers-side recently which all of a sudden disappeared again without any changes on the MT- nor Cisco-side.
Before opening a support ticket with MT, is anyone else seeing this (or similar) behaviour recently?
strods
Thu Oct 11, 2018 5:55 pm
schadom - Please send supout file and problem description to support@mikrotik.com. Please provide precise command that you use in order to filter print command output.
ssbaksa
Fri Oct 12, 2018 11:07 am
----snip-----
The same here. My RB750GL is gone. Bricked. LED is blinking as it should but Netinstall never gets anything from RB750GL.
That's third time in 7 years of working with various MT's but this time I just can't do a thing.
Any sugestion?
Br
Sasa
draguzet
Fri Oct 12, 2018 11:26 am
Any sugestion?
Try this:
2) Power device on;
4) After board appears in Netinstall install version lower than 6.43.x !! (try different waiting time while holding reset button, 1 minute, 2 minute...)
I'm really strange when the Mikrotik will remove the 6.43.2 version and declare it unstable, since obviously the different boards are falling after the upgrade!
kris62
Sun Oct 14, 2018 3:34 am
Connection between RB450GX4 and Winbox 3.18
Hi, guys: I just wanted to get help from this forum because my new device RB450GX4 has problem about connection to Winbox 3.18.
I need to close winbox for several times then it can be connected to RB450GX4... Very strange.
Have you guys with similar problem as mine ?
P.S.
The firmware in my RB450GX4 is mostly updated ~ 6.43.2.
Kris from Taiwan
Chupaka
Sun Oct 14, 2018 11:19 am
Was it working good in previous versions? If not, please create separate topic with more details.
denisun
Sun Oct 14, 2018 4:38 pm
In queue export file and full backup export file has separate queue tree statements.
If i have queue tree with parent and childs then i have:
first parent statements
then queue types
and final the rest statements of tree, that childs.
/queue tree
add bucket-size=0 max-limit=4500k name=pppoe-out1-UP parent=global
add bucket-size=0 limit-at=3M max-limit=4500k name=QoS_Low-UP parent=\
    pppoe-out1-UP
/queue type
/queue tree
add bucket-size=0 limit-at=500k max-limit=4500k name=QoS_1-UP packet-mark=\
    QoS_1-UP parent=pppoe-out1-UP priority=1 queue=fifo-UP-1
If i have only childs and no parents (except that global) the i have all statements together:
/queue tree
add bucket-size=0 max-limit=50M name=pppoe-out1-DW parent=global queue=\
    default
add bucket-size=0 limit-at=500k max-limit=50M name=QoS_1-DW packet-mark=\
    QoS_1-DW parent=pppoe-out1-DW priority=1 queue=pcq-DW-1
ssbaksa
Tue Oct 16, 2018 8:36 am
Any sugestion?
Try this:
2) Power device on;
Done all of this. As I have few more devices for testing purpose it will wait for having some spare time to fiddle with this but it is annoying problem.
In 30 years this is my second completely bricked device. First was Buffalo router without header.
BTW, Mikrotik, are those 3 hidden spots with Rx, Tx, and GND marking real serial port or just ...
Br
Sasa
pe1chl
Tue Oct 16, 2018 11:20 am
TTL serial. Get a TTL serial to USB converter from aliexpress or similar, and you can connect it to a PC and watch the boot procedure.
(or even flash new firmware over serial when you are patient)
DummyPLUG
Tue Oct 16, 2018 7:50 pm
Speak about TTL serial to USB (and many serial to USB), beware that of them are using PL2303 series chipset and some of them are using fake PL2303 chipset, the latest driver and win10 driver will refuse to work with them. If you look for a Serial to USB cable better check if can work in win10 without manually install any driver.
p.s. I have one from UGreen which work in win10.
pe1chl
Tue Oct 16, 2018 8:00 pm
Could be, I never use Windows, and in Linux they all work without problem...
DummyPLUG
Thu Oct 18, 2018 3:50 am
I have a fake PL2302 cable which damage my old wifi AP
ssbaksa
Thu Oct 18, 2018 8:02 am
Ah, nice suggestion but, all my laptops are Pro type and I have real serial ports on them :-)
Serial port is not a problem on computer side. Question is, are those 3 spots on MT board real serial connections or just some
relics from past.
Br
Sasa
andriys
Thu Oct 18, 2018 9:35 am
The key here is that TTL serial and RS232 are somewhat different beasts- they differ at least in the voltage levels (while on the protocol level they must be compatible). You can easily damage TTL serial port by directly connecting it to a standard serial port on your laptop.
emils
Forum Veteran
Forum Veteran
Thu Oct 18, 2018 10:41 am
New version 6.43.4 has been released in stable RouterOS channel:
viewtopic.php?f=21&t=140560
Users browsing this forum: bschapendonk, grusu, kristapsd, Marc66FR, onnoossendrijver, soulflyhigh and 31 guests
