msatter
Re: v6.45beta [testing] is released!
Sat Jun 29, 2019 5:22 pm
Have a look at this page for NordVPN, if your provider has no specific certificate then you need the root cert from/for that provider
https://wiki.mikrotik.com/wiki/IKEv2_EA ... d_RouterOS
Loving my freedom and so, no Twitter, no Facebook/Instagram/WhatsApp, no Apple and no Google/Alphabet, no Amazon/Cloudfront/AWS.
Running:
RouterOS 6.49Beta / Winbox 3.27 64bits
ztx
Sat Jun 29, 2019 9:00 pm
In windows, it needs username and password only.
I found a setup guide for strongswan:
1. launch the app and then tap on Add VPN profile.
2. Now you’ll need to enter a VPN server address.
3. Now choose the VPN type. Select Ikev2 EAP (username/password).
4. Next, enter [REDACTED] provided credentials in Username and Password fields.
5. Next, check the CA certificate.
6. Profile Name: [REDACTED] Ikev2 (you may type anything).
Now tap on show advanced settings and type in server identity: pointtoserver.com
Finally, hit save and then connect to the newly created Ikev2 profile.
How can I setup on routeros?
thanks!
ztx
Sun Jun 30, 2019 9:36 am
msatter All EAP methods require at least the root CA certificate for IKEv2. On Windows, it is possible, that the CA certificate is already in the Trusted Windows Certificate store so you do not have to import anything. Either ask your provider for the CA certificate or try finding out which certificate is used on Windows and export it to RouterOS.
Also there is no wildcard support for remote-id fqdn field. I would suggest leaving the remote-id to auto.
mezzovide no, conntrack has nothing to do with it, however we have already fixes for your described issues in previous betas. Did you try the latest beta and can verify the issue is still present?
emils How can I find which certificate is used? thanks!
msatter
Sun Jun 30, 2019 10:58 am
I am not Emils however I can answer your question.
You need the comodo-root.crt and import it in system-certificate. Stae that you ignore the check on it in the ipsec screen.
viewtopic.php?f=21&t=146087&p=731038&hi ... er#p731253
Running:
mattgorecki
Sun Jun 30, 2019 10:28 pm
The current download of 6.45beta62 for MIPSBE is giving me a checksum error.
On my mac:
MD5 (routeros-mipsbe-6.45beta62.npk) = 637a0bbb58bb0a3012ae9289dc9e7cbc
The website says it should be:
MD5 routeros-mipsbe-6.45beta62.npk: d7b9284935f8123cbf4df0c735c995c3
emils
Mon Jul 01, 2019 10:15 am
New version 6.45.1 has been released in stable RouterOS channel:
viewtopic.php?f=21&t=149786
Users browsing this forum: No registered users and 15 guests
