normis
Newsletter 88, April 2019
Mon Apr 08, 2019 9:38 am
- MikroTik mobile app
- New PWR-LINE series products
- CCR upgrades
- S+RJ10 improvements
- ±48v telecom power supply for new CCR models
- new Gigabit Passive Ethernet Network product GPEN11
- Gigabit Ethernet Surge Protector RBGESP
- MUM schedule
Download newsletter here:
https://download2.mikrotik.com/news/news_88.pdf
connormill
Re: Newsletter 88, April 2019
Mon Apr 08, 2019 2:00 pm
Is there any plans to release PWR-Line products with UK Plugs? and some with the 24v Barrel Jack instead of Micro USB?
Would be great to use it with a hAP AC2
mkx
Mon Apr 08, 2019 2:44 pm
... and some with the 24v Barrel Jack instead of Micro USB?
As hAP ac2 can't be powered through USB (and USB connection is required), this kind of setup becomes questionable ... since PL[67]411-2nD has it all (and more :wink:) and the price difference is not outrageous ($42 for full device VS. $29 for power + homePlug adapter) ...
BR,
Metod
psannz
Mon Apr 08, 2019 3:47 pm
Great news on the S+RJ10 /r2. Thanks :)
pants6000
Mon Apr 08, 2019 5:50 pm
Always nice to see new telco powered stuff!
The new CCR-1036es, do they use soldered-in RAM or DIMMs or something else?
cpakeith
Mon Apr 08, 2019 7:38 pm
Does the RBGESP support POE? And if so, how much current/voltage and is it over 2 pair or 4 pair? Is it avalanche diodes?
krafg
Forum Veteran
Forum Veteran
Tue Apr 09, 2019 3:45 am
When the release of Ltap?
Regards.
If you want to know my network, you can find it here.
Telegram: @krafgrgi
mbrtonpye
Tue Apr 09, 2019 11:21 am
@normis What are the ports which need to be opened for the app to work? I was expecting that it would be the same as the WinBox, which I have on a different port, but it does not connect OR does it not have the ability to connect using as WinBox using a different port from standard?
EDIT: Have been looking through and wonder if it is API-SSL as this is the nearest I seem to be able to get to a connection.
normis
Tue Apr 09, 2019 12:46 pm
Winbox port is the only thing the smartphone apps use, make sure you have no limits in "ip services" under winbox, and see how your firewall rules are ordered.
anav
Wed Apr 10, 2019 4:54 am
What is the throughput of the powerline equipment, its not exactly reviewed at smallnetbuilder.com ;-)
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
mkx
Wed Apr 10, 2019 11:47 am
Block diagram for US-variant says it uses QCA6410 chip for powerline interface (block diagram of EU variant states some AR chip, but I believe it's an error). Chip's specifications state peak speed: 200Mbps. Which is misleading, HomePlug AV standard says 200Mbps is at physical layer while MAC layer reaches about 80Mbps.
But then this largely depends on the state of electrical wires in the building so realistic number might be anything between almost zero and almost 80Mbps.
BR,
Metod
anav
Wed Apr 10, 2019 2:23 pm
okay thanks mkx its probably safe to assume to look at similar models with the same chip.........
Edit:
the top ranked powerlines - have QCA7500 (which came out in 2015)
Lesser ranked powerlines - have the older QCA7450 (circa 2014 ish)
https://www.engadget.com/2012/01/10/qua ... etworking/
So we are supposed to get excited about a product that came out in 2012 with some bells and whistles around it???
YOu can probably find consumer products with the hunk and junk performance of that chip in the junk bin or on ebay for about $5.
https://www.smallnetbuilder.com/lanwan/ ... er-roundup
What is key about the QCA7450 and 7500 chips is the huge leap in performance due to better use of the electrical wiring which cleans up the connectivity in terms of cross circuit and general noise.
Wait, let me get my betamax out, polish the turd and sell it with an attached USB cable and a pOE port and brand it Mikrotik. ;-P
neutronlaser
Thu Apr 11, 2019 8:31 pm
PWRLINE not available on Amazon USA
anav
Thu Apr 11, 2019 9:58 pm
Beone
Fri Apr 12, 2019 3:59 pm
does it mean they run less hot than before so we can use them in each sfp+ slot next to each other?
neutronlaser
Mon Apr 15, 2019 9:44 pm
Sadly I have to consume its foul milk. I'm sure they'll be on one day.
Users browsing this forum: No registered users and 9 guests
