AlainCasault
Trainer
Trainer
Re: v6.44.3 [stable] is released!
Wed May 29, 2019 1:22 am
We are trying to upgrade to 6.44.3 from 6.29. I can download the file and it is in the files window. It will not install. I have tried to reboot 5 or 6 times and still nothing. Any advice?
Look at the log. It should tell you why. Usually, you've chosen files for the wrong architecture.
Sent from my cell phone. Sorry for the errors.
___________________________
Alain Casault, Eng.
If I helped you, let me know!
pe1chl
Wed May 29, 2019 10:11 am
That is not advisable! You have not updated for so many years that it cannot be expected to be a smooth process.
It is better to investigate what is configured, make a /export so you have complete notes, and then netinstall the new version and start from scratch.
Kindis
Wed May 29, 2019 1:40 pm
I would say the same but if they want to try it out (make propper backup and export before attempting) test the following upgrade patch
6.30.1
6.34.5
6.40.9
6.42.9
6.43.16
I'm not saying this will work without issues but will give you a better odds at making it :-)
mlenhart
Wed May 29, 2019 9:58 pm
BUG REPORT
I would like to report a wrong Last Link Down Time showed in Winbox.
This issue has been seen on WW Dish, and hAP AC.
Time is in future, which is impossible.
Please see attached screenshot: https://paste.pics/5OJ84
Thulgar
Thu May 30, 2019 8:54 am
BUG REPORT
You didn't show the time in winbox (next to the Uptime). Your MK probably has wrong time settings.
mlenhart
Fri May 31, 2019 9:10 am
BUG REPORT
Will this convince you it´s a bug ?
pe1chl
Fri May 31, 2019 11:13 am
That wrong time is a "known problem" that was introduced several versions ago, not with this version.
It likely is already on the list of things to fix.
Cha0s
Forum Veteran
Forum Veteran
Fri May 31, 2019 12:45 pm
Also I believe it's a winbox bug and not a ROS bug. CLI shows the correct times.
IIRC deleting the session on winbox also shows the correct times (until the next login using a previous session).
amojak
Fri May 31, 2019 2:38 pm
hi,
no mention of a recent routing bug we have experienced. Simple static routes stop working, to restore them you disable/re-enable them. Had this happen twice on two routers with 6.44.1 on them.
One occurred after a power cycle, the other for no apparent reason at all.
Has the dev team come across this at all ?
pe1chl
Fri May 31, 2019 7:18 pm
Never seen that, likely there are more circumstances particular to your installation.
You should provide a supout.rif to support in such cases.
o4korez
Sat Jun 01, 2019 11:21 pm
I know this is not critical, but wanted to know the reason for this change, since it was a good visual aid:
*) rb2011 - removed "sfp-led" from "System/LEDs" menu;
Thanks!
+, removed a very useful feature. wonder why
Beone
Sun Jun 02, 2019 12:27 am
we are awaiting solution/response from helpdesk team already since march 2019.
[Ticket#2019030922002071] CAP not correctly forwarding tagged vlan traffic towards wired network
Quite often, the CAPs arent forwarding DHCP offers anymore towards the clients, resulting in loss of network connectivity.
Just a reprovision resolves this for awhile until it happens again...
We see this in 6.42.x, 6.43.x and even 6.43.x
We have sent multiple debug traces to support without any feedback except with "upgrade to 6.44.3" and as we can confirm, also that release is broken.
I'm pretty sure it has todo with new bridging implementation as 6.39.3 doesn't have this issue. (however most recent delivered devices cannot be downgraded to that release anymore).
Can you please look at this case which impacts/involves more then 5000 access-points
anuser
Wed Jun 05, 2019 9:37 pm
Interesting, let´s quote myself:
I´m currently "watching" an Apple client (C8:3C:85:33:B3:10). The phone connects itself automatically to one specific cAP ac. What can I see repeatedly:
- The client connects to wifi successfully
- The DHCP server shows the MAC of the client. Within "DHCP Lease" windows I can see the status which is "offered".
- "Expires After" is couting down from 00:00:31 seconds to 0.
- Inbetween that time frame the client disconnects and reconnects.
- For some few seconds (~5), within the "DHCP Lease" window, it shows "bound"
- After that it changes from "bound" to "DHCP Lease" again.
- The whole process repeats now for over 10 minutes while writing this message.
Looking at the "DHCP Server" => "Leases" window and sort it by "offered status", I currently see the about 8 "...iPhone" with the same behaviour, i.e. they reoccur within the list saying "offered" over and over. Those iPhone don´t use the same access point as the Apple device above, but also some other cAP ac running 6.44.3 code.
Update 1:
- Within "DHCP Lease" windows activated "Make Static" => No change
- Within static DHCP lease windows: I changed step by step: "Lease Time", hit "Usr Src. MAC Address", changed "Insert Queue Before" to bottom => No change
Update 2:
- I downgraded another cAP ac to 6.43.16 which is next to the cAP ac from above and deacitvated both radios on the the cAP ac with version 6.44.3 => the Apple client connected to the cAP ac with 6.43.16, the status within "DHCP lease" is now on bound for over 20 minutes.
- I deactivated both radios one cAP ac mentioned above
Update 3:
The client changed the building. It is now on another cAP ac with 6.44.3. The client obviously works and is producing traffic.
=> I have 2 CCR1036 running with CAPSMAN forwarding mode. I have >200 cAP ac / wAP ac / ... on each CCR. I don´t know how many times I changed settings for VLAN, bridges, MTUs. I have one CCR + cAP running 6.43.16 completely, the other CCR + cAP are running 6.44.3. The "solution" I mentioned above wasn´t one. Still the same problem. I´m looking for a solution, too.
redbullsteve
Wed Jun 05, 2019 11:20 pm
Update 1:
Update 2:
Update 3:
Glad it is not just me, I have the same issue effecting 1000's of units, if you disable the CAP and enable everything works again for a period of time and stops again.
I have raised tickets with support to get Zero reply so a reply saying upgrade is further than I have got. I hope this gets resolved soon as its been going on for months.
Beone
Fri Jun 07, 2019 3:01 am
Zero reply from support except upgrade to XXX (having same issues), provided them full packet capture and supouts when its happening showing the DHCP offer gets up to the LAN uplink on the CAP but isnt forwarded to the wireless client.
anuser
Fri Jun 07, 2019 9:30 pm
How many times a day do you provision your cAP devices?
whatever
Tue Jun 11, 2019 7:20 pm
Did you try setting multicast helper to full? This fixed some LAN to WiFi problems I was experiencing..
anuser
Fri Jun 14, 2019 9:35 am
I have multicast helper activated since I needed IPv6 for CAPSMAN forwarding. This doesn´t fix the problem with "dhcp offering lease...for...without success"
djerodrigues
Sat Jun 15, 2019 11:35 pm
HI all!
I have some PWR-LINE AP units, and upgraded to v6.44.3.
Issues:
- There is no PWR-LINE interface in the terminal / command line !!!
Can't configure or check configuration/status (done with WinBox)
- When setting "PLC CCO Selection Mode", it will always show as "auto".
- When setting "Network Key" or "Network Password", it will always show as empty.
- Can't downgrade at Winbox with "Downgrade" button. At command line it works fine.
Tks...
oldcrow
Sun Jun 16, 2019 6:03 am
Hi all
upgraded to hAP ac2 to 6.44.3(stabe) and it does not remember which ethernet is attached to WAN/LAN on restarts, Defaults back to ether1 (POE in port so not available for internet modem). Addresses and routes similarly default to ether1 on reboot.
cheers
chris
oldcrow
Mon Jun 17, 2019 8:46 am
Hi all
mea culpa as per usual. turns out seeing 0.0.0.0/0 and changing it to fixed ip in QuickSet not a great idea. It is what changed ether1 back to being WAN port. My apologies for not picking up my error.
regards
Oldcrow
pe1chl
Mon Jun 17, 2019 11:51 am
Ah, the usual problem with QuickSet...
It has been requested many times to have some feature to make QuickSet readonly (either manually or even automatically after changes outside QuickSet have been made) but it is not picked up by MikroTik.
Now, QuickSet remains a ticking timebomb in routers with non-default configuration...
bbs2web
Sat Jun 22, 2019 10:41 am
We have identified an issue with IP neighbour discovery packets, specifically Cisco Discovery Packets (CDP), being transmitted when ports are members of a bridge and spanning tree has detected the port as an alternate path towards the root bridge. Whilst STP correctly disables forwarding it still transmits CDP messages which are then bridged by the remote routers. We presume this to be due to CDP using the same destination multicast MAC address that Spanning Tree Protocol (STP) messages use, namely 01:00:0C:CC:CC:CC.
Network structure:
  • 3 sites with VPLS tunnels bridged between them, classic A B C triangle.
  • Router A has lower STP bridge priority (0x7000), so it becomes the root bridge
  • RSTP correctly sets one of the redundant VPLS bridge ports as alternate and disables learning and forwarding
Problem:
Bridge correctly drops all traffic on the alterative path port, except packets destined to the multicast address 01:00:0C:CC:CC:CC, used by STP and CDP.
I presume this to be so that the bridge can still process STP messages and unblock the port when necessary. The problem comes in that CDP neighbour discovery packets are still transmitted out the port which is in a non-forwarding state. This causes intermittent connectivity problems as remote bridges temporarily learn the path to the source MAC from the path/port which is in a non-forwarding mode.
Sample log message, showing MAC of blocked interface being received back on working port:
jun/20 23:57:16 interface,warning vpls-vlan2000-A: bridge port received packet with own address as source address (02:0f:f1:63:85:ea), probably loop
Expected behaviour:
Do not transmit CDP neighbour discovery packets out of a port when disabled by spanning tree protocol.
Configuration shows two VPLS interfaces, from ‘B’ to ‘A’ and ‘C’:
/interface vpls
  add disabled=no mac-address=02:0F:F9:48:BD:CA name=vpls-vlan2000-A remote-peer=192.168.255.1 vpls-id=1:22000
  add disabled=no mac-address=02:0F:F1:63:85:EA name=vpls-vlan2000-C remote-peer=192.168.255.3 vpls-id=3:22000
Router B’s bridge configuration, running RSTP:
  add name=bridge-vlan2000
  add bridge=bridge-vlan2000 interface=vpls-vlan2000-A
  add bridge=bridge-vlan2000 interface=vpls-vlan2000-C
Spanning Tree correctly sets the ‘vpls-vlan2000-C’ interface's role as alternative-port, thereby disabling learning and forwarding:
[davidh@B] > /int bridge port print stats where bridge=bridge-vlan2000
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 0     interface=vpls-vlan2000-A bridge=bridge-vlan2000 priority=0x80 path-cost=10 internal-path-cost=10
       edge=auto point-to-point=auto learn=auto horizon=none auto-isolate=no restricted-role=no
       restricted-tcn=no pvid=1 frame-types=admit-all ingress-filtering=no unknown-unicast-flood=yes
       unknown-multicast-flood=yes broadcast-flood=yes tag-stacking=no bpdu-guard=no trusted=no
       multicast-router=temporary-query fast-leave=no status=in-bridge port-number=1 role=root-port
       edge-port=no edge-port-discovery=yes point-to-point-port=no external-fdb-status=no
       sending-rstp=yes learning=yes forwarding=yes root-path-cost=10
       designated-bridge=0x7000.02:3A:EF:BC:95:B8 designated-cost=0 designated-port-number=2
 1     interface=vpls-vlan2000-C bridge=bridge-vlan2000 priority=0x80 path-cost=10 internal-path-cost=10
       multicast-router=temporary-query fast-leave=no status=in-bridge port-number=2 role=alternate-port
       sending-rstp=yes learning=no forwarding=no root-path-cost=20
       designated-bridge=0x8000.02:57:0E:3C:25:0E designated-cost=10 designated-port-number=2
6.44 made changes to transmit bond and bridge slave port information out via MNDP, CDP and LLDP, this is when the behaviour started. This also changes the previous behaviour in that these neighbour discovery packets are transmitted not just from the bridge itself, but additionally all slave ports. Herewith an example, showing the remote interface as being bridge-vlan2000/vpls-vlan2000-C:
[davidh@B] > /ip neighbor print detail
 0 interface=vpls-vlan2000-A,bridge-vlan2000 mac-address=02:0F:F1:63:85:EA
   identity="B" platform="MikroTik" version="6.44.3 (stable)" unpack=none age=9s
   interface-name="bridge-vlan2000/vpls-vlan2000-C" system-caps="" system-caps-enabled=""
Temporary work around:
  • Create an interface list called 'vpls' and add all VPLS interfaces to this list
  • Set IP neighbour discovery to use all interfaces except those in the 'vpls' interface list
Users browsing this forum: No registered users and 7 guests
