normis
MikroTik newsletter January 2020 (#93)
Tue Jan 28, 2020 1:01 pm
Read our latest newsletter and learn more about:
• CRS354-48G-4S+2Q+RM – the 48 port champion you’ve been waiting for!
• NetMetal ac²
• Real-life “firewall” fighting hail in Serbia
• MikroTik 5G booth at MWC2020
• “Most valuable company in Latvia” award
• MUM Europe 2020 in Prague
• Upcoming MUM events in 2020
https://mikrotikdownload.s3.eu-west-1.a ... ews_93.pdf
2jarek
Re: MikroTik newsletter January 2020 (#93)
Tue Jan 28, 2020 2:22 pm
God bless Mikrotik for cheap & fast swith lane we need them fast.
2jarek
Tue Jan 28, 2020 2:28 pm
We need new Nstreme-dual protocol for DUAL radios like new netmetal V2 or RBLHGG-5HPacD2HPnD-XL.
FULL DUPLEX & separate UL@2.4/DL@5Ghz
I don't even try ask for p2mp protocol all know why :lol: but p2p nstreme dual should be possible i think.
djdrastic
Tue Jan 28, 2020 2:30 pm
The NetMetal AC2 I can see myself using quite a bit in some of the last sites we still have MTK Wireless remaining.
Can you run 2.4 and 5 Ghz radios at the same time or is it like the Groove where it's one or the other ?
The CRS is pretty cool , though the CRS326-24S+2Q+RM meets our needs a bit better in general. Wish there was a way where we could marry a CRS Switch and 4011's packet routing capability in a single box , but it's saved us mega bucks for some projects thus far.
anav
Tue Jan 28, 2020 4:26 pm
Congrats on the award!!
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
IPANetEngineer
Trainer
Trainer
Tue Jan 28, 2020 6:01 pm
I especially enjoyed reading about the network in Serbia to detect hail. Good stuff!
Global - MikroTik Support & Consulting - English | Español | Serbian | Danish +1 855-645-7684
https://iparchitechs.com/ecosystem/mikr ... consulting mikrotiksupport@iparchitechs.com
r00t
Tue Jan 28, 2020 7:30 pm
Yes! Full duplex p2p will be great. Just look at the competition with their LTU, it can use different TX and RX frequencies on both ends. This is killer feature, because 5GHz band is now completely saturated and full of signals, so finding empty channel on both sides of the link is often impossible.
So not just 2+5GHz radios, but have two 5GHz radios that can be used to split frequencies for tx and rx and also run in full duplex mode.
Mikrotik is having problems with nv2 for p2mp on AC hardware, but fixing it at least for p2p should be easier then full p2mp. No need to handle stations joining/leaving, just do the one thing only and one thing only: p2p link with minimum latency like NSTREME did. It's badly needed!
Also lack of any news on WIFI6 features or 802.11ax hardware is rather sad, perhaps we will see something announced on the MUM...
SiB
Tue Jan 28, 2020 7:39 pm
We need LHGR + R11e-LTE6 with
  • 1GbE port - currently even SXTR with bonding at 2xFE have a bottleneck to FE at CPU :(
  • 2CA for 1+3 and 1+7 and 3+7 - currently only 3+7 :(
  • LGHR with corrected 700 and 900Mhz Gain - currently works better with inverted antenna at 180°. Only 800Mhz works straight forward (and >1800Mhz).
  • Bigger DISH
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
I back :) Hello again.
biland
Tue Jan 28, 2020 8:17 pm
the NetMetal AC2 works over 100 km? or has it the same problem like the older AC that we get only about 80 MB throughput ?
mgostom
Tue Jan 28, 2020 10:11 pm
• NetMetal ac²
Netmetal ac2... we can use 2.4 and 5Ghz both, at the same time or not?
megalar
Wed Jan 29, 2020 1:46 pm
the NetMetal AC2 works over 100 km? or has it the same problem like the older AC that we get only about 80 MB throughput ???
no problem with the Old NetMetal AC tested 12.2 kilometers 232mbps TCP Speed....:-)
olivier2831
Fri Jan 31, 2020 9:08 am
I hoped to hear news about:
CRS354-48P-4S+2Q+RM (with PoE)
CSS610-8P-2S+ (announced last year)
Maybe, next time
rushlife
Sun Feb 02, 2020 5:28 pm
Hi, about CRS354-48P-4S+2Q,
Mikrotik support says it will be released about couple weeks after CRS354-48G variant.
I will believe them, We will seee...
mistry7
Sun Feb 02, 2020 11:50 pm
And you think there is no difference between 12,2 and 100km?
bpwl
Wed Feb 05, 2020 2:34 pm
And your received signal strenght at 100km is ????? -xxdBm ??
(source: https://www.duckware.com/tech/wifi-in-the-us.html)
erlinden
Long time Member
Long time Member
Wed Feb 05, 2020 3:07 pm
M = Mega
m = milli
B = Byte
b = bit
s = seconds
Usually throughput is measured in Mbps (i.e. 100 Mbps)
First the problem, then the solution
2jarek
Thu Feb 06, 2020 10:33 am
For 80Mhz channel :D:D:D ?
Mikrotik in most case don't scale ACK properly for long distance p2p link. Can have good signal with big antenas but tcp speeds sucks. For 20Mhz channel u can use Nstreme but nstreme no scale properly for 40, 80 Mhz channel.
megalar
Thu Feb 06, 2020 12:16 pm
it has a line of sight...no interference at all....@ 12.2 kilometers only
no not 100kms.
RogerWilco
Fri Feb 14, 2020 1:10 am
Since MWC2020 has been cancelled, does MikroTik still have plans to show a peak at their 5G gear?
normis
Fri Feb 14, 2020 10:06 am
The biggest announcements of the year are always reserved for the MUM EUROPE (see banner in header)
mistry7
Fri Feb 14, 2020 10:42 am
the bad news......
after announcements it will take 12 month or more before products are available
normis
Fri Feb 14, 2020 10:43 am
The MUM EUROPE has always introduced the plan for next 12 months, yes
mistry7
Fri Feb 14, 2020 11:45 am
And CRS318, CSS610, MUps Pro did arrive Market in the next 4 weeks?
vortex
Fri Feb 21, 2020 5:59 pm
Did MT just immediately respond to STH?
I see it was announced in March.
taduikis
Sun Feb 23, 2020 8:11 pm
What improvement will the new NetMetal ac² provide in comparison with former NetMetal ac (wave1)? Besides 160MHz channels and MU-MIMO, which are basically interesting only for some small indoor/closed deployments for mass end-user access, but have little use for WISP PtP or PtMP.. Unless MT plans to release some cheap AC wave2 SXTsq's?
vortex
Fri Mar 06, 2020 4:49 am
I have not seen anybody selling an SFP+ access point.
krafg
Forum Veteran
Forum Veteran
Sat May 09, 2020 7:58 pm
Someone has speed tested the throughput of NetMetal ac2 using WiFi with some meters of distance?
Any feedback is appreciated.
Thanks and regards.
If you want to know my network, you can find it here.
Telegram: @krafgrgi
Users browsing this forum: No registered users and 10 guests
