Copy that.. , Confirmed.. ThudProblem of changing column width and row position in active window (i.e. which shows counters that are being updated during the change operation) has NOT been fixed!
Back to 3.21
I experience the same issue. Otherwise seems that the major resizing issues have been solved."Inner window size" problem not solved
1. Fixed inner window size (first picture)
2. Exit from Winbox
3. Again open Winbox (second picture)
4. See second picture's Inner window is change automatically in width
But Winbox 3.21 not changed Inner window automatically
It is true. On any interface scale more than 100% - inner window resize bug appears...Everytime I open a new Winbox .viw file it increases the scaling.
I'm using custom scaling in Windows 10 = 115%
as a linux and macos user I'm going to ask they don't do this and instead release a 64 bit version of the dude so I can update to latest osx and future proof against a 64bit only linux future which is comingThanks but any chance to get a native application in other OSes like MacOS or Linux without the need to use Wine?
and shows me "What's new in v22" and the change log of 22 and previous ones."There are no new versions"
32Bit: https://download.mikrotik.com/winbox/3.21/winbox.exeAnyone know where to find 3.21?
Thank you very much. I was so frustrated of this problem and now with the update I rushed to 3.23 but...32Bit: https://download.mikrotik.com/winbox/3.21/winbox.exeAnyone know where to find 3.21?
64Bit: https://download.mikrotik.com/winbox/3.21/winbox64.exe
*) improved large table loading speed in RouterOS v7;
Check your download/install procedure! This is certainly not right!I think, that 3.23 is the same soft as 3.21-3.22. Same bugs...
Only 15-25 mins ago auto-update solved. But all bugs, means before - still exists.Check your download/install procedure! This is certainly not right!I think, that 3.23 is the same soft as 3.21-3.22. Same bugs...
Go to Tools and check "Legacy Mode".Looks like connecting to local devices is now broken. I can't connect to my router or switch at 192.168.10.x
Legacy mode, which I've never had to use before, doesn't work either. Gets stuck on "logging in" permanently.
Both are up to date on latest packages and firmware.
Back to 3.21 I guess.
I mentioned in my post that I tried Legacy mode. It didn't work, gets stuck on "Logging In" permenently.Go to Tools and check "Legacy Mode".Looks like connecting to local devices is now broken. I can't connect to my router or switch at 192.168.10.x
Try SSH and look inside logs... Or winbox via MAC-connectionI mentioned in my post that I tried Legacy mode. It didn't work, gets stuck on "Logging In" permenently.Go to Tools and check "Legacy Mode".Looks like connecting to local devices is now broken. I can't connect to my router or switch at 192.168.10.x
Hi, but 3.21 have main window resize bug on hi res displays. I think, the stable version is 3.20, imho.Same problem here: the connection window (that which pop-up just after starting Winbox, where you enter IP address) and inner windows are being bigger every time I start Winbox or enter a session.
Environment
- Winbox 3.22 x64 and 3.23 x64;
- Windows 7 and Windows 8.1;
- DPI set at default 100%.
Problem doesn't occur on Winbox 3.21 x64.
Hello, I didn't check that, can tell only about my environment.Hi, but 3.21 have main window resize bug on hi res displays. I think, the stable version is 3.20, imho.
Little precisely!?Cant download the latest version. Getting warning about non-HTTPS certificate, and im unable to download the file..
3.22, 3.23 have resizing problem or bug.Problem that was also present in 3.22 with the display of the window when clicking on a certificate crl. The window is not resizable and exceed the size of the winbox window.
True. 3.21 - works fine, as I said before... Lets wait...It is only Thursday today, so we do not know yet.
On the other hand, MikroTik are closed tomorrow and monday so indeed likely no release tomorrow.
However, I can assure you that posting messages like that will do absolutely nothing to change it.
I recommend you to go back to a release that works OK. For me that is 3.21 but I do not use scaling at all.
Newer versions that tried to improve things for users that use scaling have introduced far worse problems.
Just loggin to say TY! resizing bug it's sooooo anoying!32Bit: https://download.mikrotik.com/winbox/3.21/winbox.exeAnyone know where to find 3.21?
Hey guys - any chance of getting a checksum for the WinBox downloads too? Wary of downloading an EXE file without any confirmation it's safe to work with. Thanks in advance.
Looks like Winbox needs an adequate beta test program. What it has now doesn't even pretend to qualify. This sort of thing should have been nipped in the bud prior to release. Now we can't get rid of it.
Unfortunately they are just aspiring to get into the enterprise sector. They don't actually try to.But now they are aspiring to be in the range of Enterprise hardware/software vendors, so such topics must receive top priority.
V7 released ?? Where can I get it ?Enterprises cannot rely on "beta" software and tons of unfullfilled promises of eveyrhing will be fixed in v7 (which got released without a routing package
This is so dam TRUE!! +100000 for this!Unfortunately they are just aspiring to get into the enterprise sector. They don't actually try to.But now they are aspiring to be in the range of Enterprise hardware/software vendors, so such topics must receive top priority.
I can't imagine any big enterprise that can wait for over 6 years for fixes/optimizations in BGP, or newer kernel.
Even WISPs that made MikroTik who they are, are switching to other vendors because of terrible wireless support, even since 802.11n.
Nstreme is dead. NV2 is terrible compared to pretty much every other TDMA implementation out there. 802.11ac wave 2? What is that? MikroTik still lives in pre-2016 era![]()
In the meantime MikroTik has dedicated tons of resources to useless features in a futile attempt to appeal to the SOHO market, such as internet detect, kids control, quickstart, smartphone apps etc.
Even MikroTik doesn't appear to know which is their target group anymore...
- WISPs cannot get the best out of their available frequencies when using MikroTik.
- Enterprises cannot rely on "beta" software and tons of unfullfilled promises of eveyrhing will be fixed in v7 (which got released without a routing package - A Router OS without routing. It's like taking the latest car model, for a test drive that doesn't have an engine released yet - need I say more?)
Not to mention customer support. Imagine a big ISP having Cisco gear, but no support from Cisco.
- Home users simply don't understand networking - MikroTik has no business in homes with their current OS - unless they design something akin to TP-Link or Netgear so non-technical people can use. Hell, even cisco guys many times cannot use ROS, and they are supposed to understand networking.
That's MikroTik in the Datacenter/Enterprise.
So considering all that, digital signatures and other security features apparently are fine print...
