emils
v6.46.6 [stable] is released!
Tue Apr 28, 2020 3:03 pm
RouterOS version 6.46.6 has been released in public "stable" channel!
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 6.46.6 (2020-Apr-27 10:32):
Important note!!!
- The Dude server must be updated to monitor v6.46.4+ and v6.47beta30+ RouterOS type devices.
- The Dude client must be manually upgraded after upgrading The Dude server.
- The Dude requires "winbox" policy instead of "dude" to monitor v6.46.4+ and v6.47beta30+ RouterOS type devices.
Changes in this release:
*) crs3xx - fixed switch rule "dst-port" parameter for IPv6 traffic on CRS305-1G-4S+, CRS326-24G-2S+, CRS328-24P-4S+, CRS328-4C-20S-4S+, netPower 15FR devices;
*) defconf - fixed default IP address assigning on non-paired 60 GHz devices;
*) lora - added "altitude", "latitude" and "longitude" to stat json if GPS is available;
*) lte - fixed "band" value setting when configuration is reset on R11e-4G;
*) snmp - fixed "ifSpeed" reporting for tunnel interfaces;
*) snmp - fixed multiple LTE interface OID reporting;
*) ssh - fixed SHA256 user authentication algorithm checking (introduced in v6.46.4);
*) winbox - fixed memory leak (introduced in v6.46.4);
*) winbox - increased limit of multi-entry fields to 100;
*) wireless - improved 5GHz interface stability on RB4011iGS+5HacQ2HnD and Audience;
*) wireless - improved system stability on hAP ac^2;
*) wireless - updated "south africa" regulatory domain information;
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
templeos
Re: v6.46.6 [stable] is released!
Tue Apr 28, 2020 3:42 pm
Any reasons why it says v6.46.6 (testing) instead of stable?
dvm
"stable" channel
normis
Tue Apr 28, 2020 4:00 pm
This is just text, you can ignore it. Small bug in the description field
emils
Tue Apr 28, 2020 4:01 pm
Unfortunately we have left it as "testing" by mistake when building the version. It is just the name of the version - this is a stable build published in stable channel.
CoUL
Tue Apr 28, 2020 4:14 pm
Poor dude who just didn't break it ... With every update it's getting worse. :(
I want you to administer 100000 MikroTik to your dude using the built-in features. :shock:
hAP, LHG, mANTBox, mAP, NetBox, NetMetal, PowerBox, PWR-Line, QRT, RB9xx, SXTsq, cAP, hEX Lite, RB4xx, wAP, BaseBox, DynaDish, RB2011, SXT, Groove, hAP mini, hAP lite, CRS3xx, CCR, RB3011, CHR, X86
RouterOS 6.45.9 (Long-term) | WinBox 3.28 (64-bit)
Grant
Tue Apr 28, 2020 4:50 pm
Make a correct WOL or remove it. Without hosts list it is useless. Add bridge interface
templeos
Tue Apr 28, 2020 4:57 pm
Not only that but you cannot select bridge from the list because it's not there. Terminal command works so that's what I am going to use until WoL gets improved in WinBox.
nerxu
Tue Apr 28, 2020 5:14 pm
Why you don't fix OSPF ? :?
llubik
Tue Apr 28, 2020 5:42 pm
which means specifically *) wireless - improved system stability on hAP ac ^ 2 ?
eworm
Forum Veteran
Forum Veteran
Tue Apr 28, 2020 5:48 pm
Possibly because they could not reproduce. Did you open a support ticket?
MTCNA # 2111NA7836 | MTCRE # 2202RE4756 | MTCTCE # 2202TCE5043
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
For contact join the RouterOS-Scripts Telegram group!
bda
Tue Apr 28, 2020 7:06 pm
We have this strange OSPF problems too. Especially on large routers with many EPL circuits, with many Ethernet links and many GRE-links.
This problem rise up at random, but I do not know how to reproduce it... It is appear after large scale carrier takes downtime and many links goes down\up at once. I think so, but I may be wrong...
Several members here note this problem from 6.44.6 till now...
God bless UNIX!
corp9592
Tue Apr 28, 2020 7:37 pm
Please could you elaborate on
I just opened a ticket asking for tech support regarding wireless sudden re-associations of some of my devices, and I just saw this release. I am currently on long-term branch, but if you explain this wireless changes I may consider switching to stable. Working from home is a pain in the *** doing video calls and getting disconnected of the AP, even for juts 5 seconds.
Regards.
w0lt
Long time Member
Long time Member
Wed Apr 29, 2020 1:09 am
Does L2TP_IPSec now work? :?
I had to downgrade from 6.47.rc60 to 6.44.6 in order to find a version that would behave normally.
Not sure if I had to go that far but did it by recommendation.
Guess I'm going to wait till someone else gives me an ok wave. 8)
-tp
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
easyspot
Wed Apr 29, 2020 2:33 am
Upgraded from 6.46.5 to 6.46.6 n so far I didnt see any better. Maybe need to wait for 6.46.7 for stability.
Jotne
Wed Apr 29, 2020 8:46 am
Did it get worse than 6.46.5? Do you have problems with 6.46.5? All fixes are not for all, so it may be that there are changes that makes it better for others.
Use Splunk> to log/monitor your MikroTik Router(s). See link below. :mrgreen:
MikroTik->Splunk
notToNew
Wed Apr 29, 2020 9:31 am
Upgraded a AC 2 to this Version, configured as CAP. Nothing else changed. Several Devices cannot see the WiFi ssid. Nö connection possible.
Just downgrading to LT Version helps.
CCR1036-12G-4S, several 952Ui-5ac2nD, ...
easyspot
Wed Apr 29, 2020 9:48 am
Some of my routers are HAP AC2. Not getting worse but not any better.
I can tell if 6.43.16 still faster n more stable than 6.44.6 to 6.46.6.
Problem? Yes.
1. Sometimes wireless G cant connect, while wireless N can always connect n working just fine. Mode bgn. 6.43.16 dont have this issue.
2. Some installation at office building with alot of noise, 6.43.16 perform better for 2.4ghz.
3. PPTP from android phone, will go disconnect in few mins. With 6.43.16, the same phone can connected for hours without any problem.
Most installation still with 6.43.16 n will stay at 6.43.16 until MT can make another real stable version.
CoUL
Wed Apr 29, 2020 4:54 pm
Downgraded to 6.45.8 (longhterm). It's a pleasure to work with a dude after 2 months of hell with "super stable" versions of the dude 6.46.4 - 6.46.6. How did you manage to make him such a disabled person?
Splash
Wed Apr 29, 2020 8:19 pm
Interesting :) this stable version is marked as "testing"
            uptime: 1h33m5s
            version: 6.46.6 (testing)
         build-time: Apr/27/2020 10:32:16
I see it has been mentioned already :)
MTCNA, MTCRE, MTCINE, MTCTCE, MTCIPv6E, MTCUME, MTCSE
Discord MikrotikZA Server: https://discord.gg/CvaGbjP
mmc
Thu Apr 30, 2020 3:59 pm
we are using ospf, and mt ospf was always a little bit 'sensitive', special when u have a lot of interface changes because you have 'dynamic' interfaces inside the ospf - than it just stops working sometimes.
currently i'm chasing an ospf bug, where just the presence of an ospf-out filter breaks ecmp / cost calculation, but i don't know if this happened already in previous versions..
you mentioned that 'your problems' started with 6.44.6 - you mean the 'long term build' i guess, because that's the only one, where there were documented ospf-code changes.
please confirm, that you don't have ospf stability problems with 6.44.5 long term, or which was the last well-known-working version?
bda
Thu Apr 30, 2020 5:57 pm
We have no 6.44.5, but only 6.44.6 and older. All these verisons have up/down/init/extart problem. This problem solved only with full instance restart. Manual interface up/down does nothing.
God bless UNIX!
nichky
Fri May 01, 2020 6:28 am
about WOL it work until you unplug/plug the cable.
Once you do that WOL stops to work
If both SSIDs are good quality signal, most modern devices choose 5GHz for the speed.
viewtopic.php?f=7&t=176537
!) Safe Mode is your friend;
Zett
Sun May 03, 2020 9:42 am
hAP ac^2 occasional loss of IP address after upgrade.
08:16:04 interface,info ether1 link down
08:16:04 dhcp,info dhcp-client on ether1 lost IP address 10.99.9.1 - lease stopped locally
08:16:15 interface,info ether1 link up (speed 100M, full duplex)
08:16:16 dhcp,info dhcp-client on ether1 got IP address 10.99.9.1
08:20:45 interface,info ether1 link down
08:20:45 dhcp,info dhcp-client on ether1 lost IP address 10.99.9.1 - lease stopped locally
08:20:56 interface,info ether1 link up (speed 100M, full duplex)
08:20:57 dhcp,info dhcp-client on ether1 got IP address 10.99.9.1
08:32:49 interface,info ether1 link down
08:32:49 dhcp,info dhcp-client on ether1 lost IP address 10.99.9.1 - lease stopped locally
08:32:59 interface,info ether1 link up (speed 100M, full duplex)
08:33:00 dhcp,info dhcp-client on ether1 got IP address 10.99.9.1
Z.
mkx
Sun May 03, 2020 11:19 am
The problem is actually flapping of ether1 port ... now you only have to find out why is that happening.
BR,
Metod
tiran
API Login fail
Mon May 04, 2020 7:16 am
6.46.6 i have issue with API login. that show error message as user name and password wrong. but i can use my api without any changes in v 6.43.16 or older.where can be the issue
sindy
Re: API Login fail
Mon May 04, 2020 7:57 am
https://wiki.mikrotik.com/wiki/Manual:API#Initial_login
A new way of API login has been implemented in association with the change of user credentials storage. Both methods could be used in 6.43 and 6.44, and since 6.45 only the new one is available.
Don't write novels, post /export hide-sensitive file=x. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Zett
Tue May 05, 2020 8:32 am
Z.
I tested the long term version and the previous one and everything works without a problem. Only 6.46.6 makes problems.
Z.
IFV
Tue May 05, 2020 11:08 am
I am new user of a hap ac^2, could you please tell me what version of OS I should use: 6.46.6 stable or 6.45.8 long term ?
Thank you,
IF
pe1chl
Tue May 05, 2020 2:29 pm
That problem is only in 6.47.rc60 all lower versions are OK
horuck
Tue May 05, 2020 4:51 pm
Where can I get the ARM64 build for my brand new
CCR2004-1G-1S+2XS
Can not find anywhere please.
Thanks horuck
ofca
Wed May 06, 2020 2:14 am
arm64 build is missing, and CCR2004 product page incorrectly links to arm build
pe1chl
Wed May 06, 2020 12:04 pm
What happens when you use the built-in "system->packages->check for updates" on CCR2004?
pe1chl
Wed May 06, 2020 7:45 pm
It appears that the "interface slideshow" (configured in the interfaces screen under the LCD menu) on devices like the CCR1009 has stopped working in this release...
Anyone else who can confirm that?
osc86
Wed May 06, 2020 11:05 pm
For me it's working fine. Tested with 2 interfaces, timeout 10 seconds.
horuck
Thu May 07, 2020 3:12 pm
The check for updates in winbox shows latest version 6.46.6 but in the lower left corner it says:
ERROR: missing routeros-arm64-6.46.6.npk
I can nowhere find a newer arm64 OS than on the CCR2004 delivered 6.46.3!
Please HELP mikrotik!
horuck
Thu May 07, 2020 3:13 pm
unfortuanelty very true, I tried via the product page myself too!
Grant
Thu May 07, 2020 6:25 pm
RouterOS ARM64 does not exist
You need to download ARM version
pe1chl
Thu May 07, 2020 7:24 pm
No, I think he needs to wait until MikroTik have resolved this issue... apparently the build- and downloadsite environment does not support arm64 yet.
That router is quite a new product.
Grant
Thu May 07, 2020 7:58 pm
yes, really, the version ARM64 6.45.9 (Long-term) appeared on the site
ofca
Fri May 08, 2020 3:00 am
arm64 build is still missing, and CCR2004 product page still incorrectly links to arm build, which may lead to pointless reboots and unnecessary frustration.
deanMKD1
Fri May 08, 2020 10:30 pm
Thank you,
IF
I use 6.45.6 Stable for my hAP AC2 for months and works well.
jp
Long time Member
Long time Member
Sun May 10, 2020 5:30 am
This version shows up as "testing" in IP neighbor instead of stable. Both in winbox and CLI.
easyspot
Sun May 10, 2020 7:34 am
Because they really know if this release not really stable lol
pe1chl
Sun May 10, 2020 8:45 pm
After disabling LCD and re-enabling it, it started to work again. Apparently a coincidental glitch.
(the usual diagnosis when something that is wrong happens for the first time... until it happens again :D )
webix
Mon May 11, 2020 10:30 am
I noticed that these problems that were corrected on last version are back again:
*) system - improved system stability when forwarding traffic from switch chip to CPU (introduced in v6.43);
*) system - improved system stability when receiving/sending TCP traffic on multicore devices;
If i downgrade the router to 6.45.9, i don't notice the problems anymore.
Chaosphere64
Mon May 11, 2020 10:44 am
Downgraded to 6.46.5 after seeing RB4011iGS+RM reboots without any entry in the log file or any external cause. Never seen on this device before.
surinameclubcard
Mon May 11, 2020 9:49 pm
There is a whole thread about RB4011iGS reboots. I solved it by disabling time management (SNTP + Cloud time). Check out this topic: viewtopic.php?f=2&t=158939&e=1.
zapata
Thu May 14, 2020 5:18 pm
Were v6.46.6 and 6.47beta53 re-released today? Why?
Run BSD! FreeBSD/NetBSD/OpenBSD
erlinden
Thu May 14, 2020 5:21 pm
For the v6.46.6 the date was "Tue Apr 28, 2020 1:03 pm", why re-released?
First the problem, then the solution
grusu
Thu May 14, 2020 5:45 pm
Maybe it's a restored backup?
surinameclubcard
Fri May 15, 2020 12:41 am
Maybe "testing" is renamed to "stable"?
camarguesol
Fri May 15, 2020 8:25 am
ROS v6.46.6 descriptive label still shows (Testing).
Downgraded to Long Term and then selected Stable to upgrade back to Stable.
Change log error with 5.9 from 2011 entries displayed :
New version is available
Channel
Installed Version 6.45.9
Latest Version 6.46.6
What's new in 5.9 (2011-Nov-29 14:32):
*) ssh - fix mempry leak when client uses public key authentication;
*) ppp - added support for new RADIUS attribute MT-Delegated-IPv6-Pool (#22);
*) ntp client - faster initial synchronization;
*) ppp - added support for dhcpv6 pd;
*) wireless - nv2 improvements for 11n cards;
*) hotspot - fixed login page to better handle big load;
*) wireless - change default rate-selection to advanced;
*) snmp - fix simple queue table;
*) webfig - ....
Upgraded to Stable 6.46.6 and changelog entries correct after rebooting.
pe1chl
Fri May 15, 2020 10:21 am
Apparently something has gone completely wrong at the upgrade server...
When checking for upgrades it now displays a change notes list from the 4.x and 5.x age (see above)....
R1CH
Fri May 15, 2020 8:48 pm
Just came to update some routers today and also seeing changelog from 2011, what is going on?!
Cha0s
Fri May 15, 2020 9:06 pm
CharlyBrown
Sat May 16, 2020 6:24 am
Hi everyone.
I want to report a bug with the LLDP discovery protocol. After upgrade from 6.45.3 to 6.46.6, I cannot receive data from neighbors.
Thanks in advance
mpavlek
Mon May 18, 2020 1:41 pm
There is a bridge configured on CCR1036-12G-4S MikroTik Router. There are 9 ethernet interfaces in that bridge and one root port (that leads to Internet).
The bridge is in 255.255.255.0 network. It is possible to sent WOL Magic packet from router using tool wol mac=... command and the computer wakes up.
Using WOL software it is possible to wake the computer if both computers are on the same switch (connected to same ethernet port on MikroTik router).
But it is not possible to wake the computer if one computer is connected to one port and another computer is connected to another ethernet port.
Both ports are in the same network and in the same bridge. RSTP is enabled. ARP is enabled. Edge port is chacked and Edge Port Discovery is checked.
What could be the problem? And what would be the solution? :)
Thank you
osc86
Mon May 18, 2020 5:20 pm
Thank you
Just tested this on a CCR1009 and it works fine. You may want to open up a new forum thread, providing configuration of the bridge and interfaces.
TheChad
Thu May 21, 2020 9:29 pm
For anyone having issues with SIP traffic, we have found that 6.46.6 has an issue with SIP traffic at this time. I tested it on 3 of our MikroTik's and they both cannot register SIP traffic at 5060. Big problem for us on two of them we host two different PBX's. So we had to downgrade our Routerboards in order to fix are phone system's at this time. Anyone else having this issue on this stable update???
osc86
Fri May 22, 2020 9:32 am
@TheChad did you check the status of sip helper? (IP->Firewall->Service Ports->sip). Some people recommend to turn this off.
sindy
Fri May 22, 2020 11:37 am
Some people recommend to turn this the SIP helper off.
I am one of those people, under specific circumstances - the helper is useful when individual phones are connected at the LAN side and the exchange is unable to deal with CPE-side NAT on its own. If the exchange is at the LAN side, whether the helper helps or causes trouble depends on the behaviour of that particular exchange.
@TheChad, from what you wrote, the behaviour seems to have changed as a consequence of the upgrade, whereas "sip" has been last mentioned in the changelogs for 6.38.1 (2017). Hence the chances that the change was intentional are low, and without a more detailed description than just "it stopped working", chances that Mikrotik could fix it are zero. So if you don't want to get frozen forever with the last version where it works, create a dedicated topic with all the details where some analytic steps could be suggested to identify the particular issue. Most of the analytic steps do not require that the production router was running 6.46.6 - it is enough to map the behaviour of both PBXes and imitate the same behaviour using appropriate tools with a lab router running the 6.46.6.
pe1chl
Fri May 22, 2020 11:49 am
I would say that hosting two PBXes behind a NAT router is just asking for big problems... you are just lucky when it works.
When you want to host a PBX on a public address (for outsiders to use), and even more when you want to host two of them, get some small subnet (like a /29) and use a routing that does not involve NAT (i.e., also don't put them on RFC1918 addresses and use a static NAT! just route the /29 which will give you 5 usable addresses on some DMZ network).
vpsrent
Sat May 23, 2020 12:05 am
Please Give Advice how to i make solve this issue
when i make connect ip cloud ... local ok .. but remotley showing time out
grusu
Sat May 23, 2020 8:00 am
The answer is right in the picture: the router is behind a NAT.
hossain
Sat May 30, 2020 6:28 am
@easyspot
Could you kindly explain the wireless client association problme? I am running a problem where the wifi user frequently disassociated for 2 to 5 second. Is it problem with this 6.46.6? my device is rb1100.
"echo: system,error,critical login failure for user Administrator from 00.00.00.00 via ssh" how to stop this attack dynamically, I mean, if any ip hit frequently or 5 times, the block list update automatically.
hossain
Sat May 30, 2020 6:48 am
Problem? Yes.
Kraken2k
Sun May 31, 2020 2:49 pm
I experience strange behavior with VLAN tied to Bonding interface (made of two eth ports; RB1100AHx4): When I change the bonding interface settings (this was Transmit Hash Policy from L2 to L2&L3), it restarts itself and also all tied elements went down (which is expected). The problem is that when bonding come back online, VLAN interface, that is tied to it, does not detect that bonding is back online and stays down forever. You need to manually disable and enable VLAN interface so it detects the parent bonding interface as online.
emils
Tue Jun 02, 2020 2:30 pm
New version 6.47 has been released in stable RouterOS channel:
viewtopic.php?f=21&t=161887
Users browsing this forum: flapviv, leonardogyn, Sob and 7 guests
