emils
Updated btest.exe available for download
Fri May 08, 2020 10:45 am
We have published an updated version of our Bandwidth Test version for Windows with some minor tweaks and authentication support for RouterOS versions newer than 6.43.
You can download the utility from our Downloads page or directly from here: https://mt.lv/btest
Please remember that Bandwidth Test uses a lot of resources. If you want to test real throughput of a router, you should run Bandwidth Test through the tested router not from or to it. To do this you need at least 3 devices connected in chain: the Bandwidth Test server, the router being tested and the Bandwidth Test client.
Zacharias
Re: Updated btest.exe available for download
Fri May 08, 2020 4:29 pm
Maybe the Local Tx Size and Remote Tx size would be best if they were renamed to MTU and MRU size ?
r00t
Fri May 08, 2020 4:38 pm
Nice to see this tool updated, it's really handy!
However after a quick test, it doesn't seems like it's working correctly:
If local Tx/Remote Tx speeds are not set, it will just not do anything (if using direction=receive):
If direction is set to send, it starts sending data but at very low rate like 1264bps and never goes above that:
With speeds set manually, TCP testing is now working well:
(deleted the UDP testing screenshots, as Tx sizes were incorrect and prevented it from working... DOH!)
All testing done between directly connected PC and RB800, link at 1Gb/s. Router CPU never went above 50%. Using no firewalls or any software that would prevent it from working.
r00t
Fri May 08, 2020 4:53 pm
Small update:
Local Tx and Remote Tx speeds just must not be grayed out. If you set them to 0 bps, btest will automatically ramp up the rate and now everything works.
Also tried using the server feature in btest, but router can't connect to it, no matter if using UDP or TCP.
Going to server tab, checking "Enabled" and pressing "Apply settings" does nothing. I don't even see open btest TCP port...
Cha0s
Fri May 08, 2020 4:58 pm
Works ok here.
Maybe your windows firewall blocks the incoming btest connections?
r00t
Fri May 08, 2020 5:04 pm
I have no firewall software, not even the windows one, double checked it's turned off and disabled on all interfaces.
Also used process explorer to see what ports is btest.exe using and it does have no open or listening ports when it should be running.
Never mind, found the culprit: Some other SW had TCP port 2000 open...
And if it can't bind the TCP port 2000, UDP server also doesn't work...
Also found you can get some debug messages if you redirect btest.exe stdout to file:
btest.exe > log.txt
mszru
Sat May 09, 2020 12:31 am
I guess most of you have already noticed that <TAB> key does not move focus from one input field to another.
Zacharias
Sat May 09, 2020 10:47 am
Yes...
Cha0s
Sat May 09, 2020 12:39 pm
And double click on an input field does not select the text.
Zacharias
Sat May 09, 2020 12:48 pm
I can confirm that as well...
vinay456
Mon May 11, 2020 1:51 pm
This version is very stable and convenient to use, I am very grateful to MikroTik that I am able to use it without involving WebFig, I'd love to have settings search though so I could find the thing I want to change easier, but it's rather an overall WinBox design complain. Also design is good, not really Material Design but fits well in Android ecosystem.
easyspot
Mon May 11, 2020 3:26 pm
Tab button not working is annoying but the most annoying is we must input tx speed. This is bandwidth test, to measure maximum speed we can get. Isnt it silly if we must input tx speed?
santyx32
Wed May 13, 2020 6:34 pm
Can we get btest for Android?
wichets
Thu May 14, 2020 5:07 am
Thank you for New look of btest for windows
i am happy to use it on my ms surface..
All about display look so good..
Rgsd/
Wichets
Urajmal
Sat Jul 18, 2020 3:15 pm
Adding the display of local IP in the server page would be appreciated. Also this tool can be run without Mikrotik HW or?
neutronlaser
Sat Sep 05, 2020 3:31 am
Awesome but it's nothing to do with Android.
noyo
Thu Dec 03, 2020 8:07 pm
New btest on debian 8 doesn't work with 6.47.8.
I can see sessions on routerbord, but the traffic is not flying.
Users browsing this forum: dioeyandika, Ilya, nuffrespect and 12 guests
