emils
v6.47.3 [stable] is released!
Thu Sep 03, 2020 12:35 pm
RouterOS version 6.47.3 has been released in public "stable" channel!
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 6.47.3 (2020-Sep-01 05:24):
Changes in this release:
*) bridge - fixed host table update on SNMP query;
*) crs3xx - fixed hardware offloaded bonding on Ethernet interfaces for CRS354 devices;
*) crs3xx - fixed hardware offloaded MPLS forwarding when using bonding interfaces;
*) crs3xx - fixed switch ACL rules for CRS312, CRS326-24S+2Q+ and CRS354 devices;
*) crs3xx - improved Ethernet port group traffic forwarding for CRS354 devices;
*) crs3xx - improved system stability when using hardware offloaded MPLS;
*) dns - fixed multiple TXT string replies;
*) dns - hide default static entry "type" from export;
*) dot1x - fixed duplicate EAP request packets for server;
*) dot1x - fixed EAP packet version numbering;
*) ike2 - fixed local side NAT detection;
*) lte - fixed multiple passthrough APN default route installation;
*) lte - fixed RSCP value reporting;
*) lte - validate interface existence on initiation;
*) ospf - fixed disappearing NSSA default route;
*) ospf - fixed processing of "unknown" LSA type;
*) poe - fixed "power-cycle" functionality on RB960GSP;
*) routerboot - fixed etherboot FCS errors with 100Mbps rate for CRS305, CRS309 and CRS317 devices ("/system routerboard upgrade" required);
*) webfig - fixed negative value usage in "spoof-gps" parameter (introduced in v6.47.1);
*) wireless - allow setting "tx-power" up to 40;
*) wireless - fixed potential wireless driver issue related to CVE-2020-3702;
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
Kindis
Re: v6.47.3 [stable] is released!
Thu Sep 03, 2020 1:26 pm
Can we have more information on CVE-2020-3702 and what it is.
More should I patch now or later type of question.
Cha0s
Thu Sep 03, 2020 1:29 pm
https://www.welivesecurity.com/2020/08/ ... sdropping/
mozerd
Forum Veteran
Forum Veteran
Thu Sep 03, 2020 1:34 pm
Switch CRS326-24G-2S+
Software upgrade successful from v6.47.2 TO v6.47.3 but after upgrade no longer able to login using Winbox to upgrade the firmware -- showing the following error message:
ERROR could not connect to 192.168.10.88
When using Mac Address to login returns error message:
ERROR could not connect to XX:xx:XX:32:xx:68
This condition started with v6.47.2 and now has carried over to v6.47.3
To resolve I had to remove the power supply and reinsert the power supply after which I was able to upgrade the firmware.
nichky
Thu Sep 03, 2020 1:45 pm
MikroTik is there any chance to add wireguard in v6?
If both SSIDs are good quality signal, most modern devices choose 5GHz for the speed.
viewtopic.php?f=7&t=176537
!) Safe Mode is your friend;
Kindis
Thu Sep 03, 2020 1:59 pm
I might be off here but my understanding is that this is a feature in the Linux kernel and version 6 will not upgrade the kernel without major overall I think this will be a V7 feature we have to wait for,
Kindis
Thu Sep 03, 2020 2:02 pm
You had the same issues with 6.47.2 if I remember correctly? I wonder if this is more for you setup. I have a couple of these switches and I do not have this problem but I run them on Long-Term. I keep all my switches on this release to not have to patch as often.
erlinden
Thu Sep 03, 2020 2:13 pm
Flawless upgrade on:
RB4011iGS+RM
hEX S
cAP ac
wAP ac
CRS112-8P-4S-IN
First the problem, then the solution
Ixander
Thu Sep 03, 2020 2:16 pm
On the version 6.47.3 command repartition (e.g. "/partitions repartition partitions =3") causes the router's cyclic reboot (about every 10 seconds). On versions 6.47.x situation the same.
Reset didn't help, I've been able to repare it only with netinstall
On the version 6.46.6 this command works correctly
model: 951Ui-2HnD
revision: r2
firmware-type: ar9344
factory-firmware: 6.46.1
current-firmware: 6.47.3
upgrade-firmware: 6.47.3
mozerd
Forum Veteran
Forum Veteran
Thu Sep 03, 2020 2:19 pm
@Kindis
If you read my post properly you would have noticed that I stated that this behavior started with v6.47.2 :-)
No problem with v6.47.1 insofar as using Winbox and updating software and Firmware ... issue surfaced with v.6.47.2
Normally for production Switches I would stay with Long-Term but because this is my LAB work where I want to see MikroTik issues I play the upgrade game.
Kindis
Thu Sep 03, 2020 2:28 pm
@Kindis
I know just that I have not heard that many complain and I have not noticed this on any other units running ARM platform, equal or similar to that of CRS326-24G-2s+RM.
Could be a bug that is somehow trigged on you config during a upgrade. Have you sent a supout file to MT support so they can have a look?
Edit: Spelling
rb9999
Thu Sep 03, 2020 3:09 pm
Fun fact... It seems upgrading my RB4011 from 6.47.2 to 6.47.3 broke my network somehow... either a spanning tree issue or something else, as I have a loop on a remote system.. can get to the first hop, but the switch behind isn't accessible, and there's quite a lot of traffic...
sid5632
Long time Member
Long time Member
Thu Sep 03, 2020 3:29 pm
Looking forward to 6.47.4 on Monday then... :-)
ErfanDL
Thu Sep 03, 2020 3:36 pm
WoW 40 dBm wifi :D
vaszabi
Thu Sep 03, 2020 3:43 pm
*) sfp - stabilized CRS212 SFP port functionality and improved monitoring of optical modules;
After upgrade to 6.47.2 stable on CRS212 all connected SFP are "bricked".
It seem that firmware upgrade clear out SPF eeprom.
Did anybody meets with this problem ?
msatter
Thu Sep 03, 2020 4:17 pm
Did you tried that SFP in a other device? It could be read error.
Or did you downgraded to the previous version to see if the SFP worked again?
[IN READ-ONLY MODE]
Loving my freedom and so, no PayPal, no Twitter, no Meta/Facebook/Instagram/WhatsApp, no Apple and no Alphabet/Google, no Amazon/Cloudfront/AWS.
Running: RouterOS 7.5.11 and 7.2.1 / Winbox 3.37 64bits
vaszabi
Thu Sep 03, 2020 4:51 pm
Of course, tried it with two different Mikoritik product and different fw version, everywhere do the same.
In other branded network device (like TPlink, Dahua) works well but no more in Mikrotik.
Three pieces of SFPs was in the device while firware upgrade was running, all of these do the same.
al3xeezer
Thu Sep 03, 2020 5:09 pm
Hi, I'm experiencing the same behaviour as in previous versions at trying to upload files via SFTP from Mikrotik to a remote server.
/tool fetch upload=yes url="sftp://server/path/file" user=example password=example src-path=file src-address=ip
failure: only http[s]/sftp supports src-address
It is a bug... right?
saaremaa
Thu Sep 03, 2020 5:58 pm
is it for which WIFI models? High power can damage devices as previously stated by Mikrotik.
CMDR Saaremaa (Gutamaya Sierra Alpha Alpha)
msatter
Thu Sep 03, 2020 6:58 pm
Did you sent a support request to support@mikrotik.com? It takes a while (days) before you get a specific reply.
[IN READ-ONLY MODE]
osc86
Thu Sep 03, 2020 9:43 pm
So far, one HAP AC2 didn't survive the update from 6.47.2 -> 6.47.3. No response via IP / RoMON. Have to check tomorrow what is going on.
Another 951Ui-2HnD took ages to come back online again, and didn't reply to pings anymore, I had to reboot the router a second time (RouterBOARD FW Update) and everything was back to normal.
I'm stopping any upgrade actions right now, and do everything else locally tomorrow.
rb9999
Thu Sep 03, 2020 10:22 pm
So... I pulled out the 'backup' ethernet cable from RB4011, so only SFP+ was connected to the uplink switch (both ports part of a bridge with RSTP), and rebooted it... So far so good, even after another reboot and reconnecting the ethernet cable back. Note to self - never upgrade ROS unless you are on site.
krafg
Forum Veteran
Forum Veteran
Fri Sep 04, 2020 12:48 am
Updated without issues.
Thanks and regards.
If you want to know my network, you can find it here.
Running ROS 6.49.7, Kali Linux 2022 & Windows 11.
Telegram: @krafgrgi
russelld
Fri Sep 04, 2020 1:16 am
Updated a number of devices from 6.47.2 to 6.47.3 without issue:
CCR1009-8G
CCR1009-7G
2 * CRS317
2 * RB760iGS
However, one RB4011iGS upgraded without a hitch, but my second RB4011iGS hung after updating and required a power cycle to come back.... Not great and not the first time I've had issues updating an RB4011..... The one which hung only had minimal configuration on it....
R
buset1974
Fri Sep 04, 2020 4:51 am
still having problem with /system autoupgrade
works fine in long-term version 6.45.9
thx
Jotne
Fri Sep 04, 2020 8:07 am
That is why I always let it go some weeks before I upgrade, and only after testing it on a similar device that has same config and software version.
Use Splunk> to log/monitor your MikroTik Router(s). See link below. :mrgreen:
MikroTik->Splunk
jbl42
Fri Sep 04, 2020 9:19 am
Updated three RB4011iGS+RM boxes 6.47.2 -> 6.47.3 in Winbox and all went smooth. No issues so far.
First the log window in Winbox was empty. This was solved by updating Winbox to the latest available version 3.27
vaszabi
Fri Sep 04, 2020 10:44 am
No, i didn't sent it to the support.
I'll do right now.
mathieuhofstra
Fri Sep 04, 2020 12:31 pm
I have a question regarding the release notes of v6.47.1 but that topic is locked so I post it here.
*) netinstall - removed "Flashfig" from Netinstall;
Wy is this removed? Is it comming in a seperate tool?
Will the flashfig functionality remain in RouterBoot?
walterav1984
Sat Sep 05, 2020 12:40 pm
Is this a new model "RB960GSP" ?
Or has the POE powercycle bug for the "RB960PGS" / hEX PoE has been fixed after more than 2 years?
donline
Sun Sep 06, 2020 8:19 am
Interesting, my years stable hap ac 5g needed a power cycle twice (reboots wouldn't correct it) after 6.47.2 upgrade, now I've upgraded to .3, 2 android devices wont even connect any more.
nostromog
Sun Sep 06, 2020 11:17 am
I'm seeing wireless problems with hAP ac^2 since I upgraded to 7.1beta2 and I wonder if it is the same kind of thing. After some time the devices remain connected but no traffic flows, unless they recognise a not working network and blacklist it. I only can recover with disable/enable on wlan1/2, depending on which one is failing. Usually works for 5 to 20 hours before I notice it is going on again in some or all devices, either or both interfaces.
Enviado desde mi Redmi Note 5 mediante Tapatalk
huntermic
Sun Sep 06, 2020 12:41 pm
Same issue here with the 7.1 beta 2 on 3 hAp ac^2 devices. Had te return to the stable branch for wireless to become stable again.
emils
Mon Sep 07, 2020 10:41 am
Anyone experiencing wifi issues with this release, could you please specify which exact devices are having connectivity issues? Please check the logs and find out the reason why the device is disconnected.
anav
Mon Sep 07, 2020 5:09 pm
Software humour!!
???? FQT sound familiar, dry runs etc...
If its stable then why all the post release issues.
Do you have a QA department (rhetorical question)!
Oh I get it, the user community does your regression testing. ;-PPPPP
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
PS. I only scratch the surface!
Chupaka
Mon Sep 07, 2020 5:37 pm
Samsung Galaxy S8+, I didn't see anything in Log, no disconnections, but it looked like packet loss (like "DNS error" -> then in 2 seconds a page opens successfully; or cannot connect via MikroTik App to the router, 2-3 attempts later - it connects successfully).
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
santyx32
Mon Sep 07, 2020 6:38 pm
If Mikrotik creates a new development branch called wireless-testing with propietary QCA drivers and deprecate the existing ROS WiFi implementation there wouldn't be that much problems with Mikrotik WiFi.
I know it will take time and several releases to get Mikrotik stuff like Capsman working with the new implementation but the results will be worth.
Mishuliq
Tue Sep 08, 2020 11:28 am
I had trouble configuring ovpn server on RB760IGS.
After set it up, when i try to connect to it, it hangs with the following error: OVNP Connection reset, restarting [0].
Downgrading to 6.45.9 (Long-term) and reconfig the ovpnserver worked instantly. It toked me 2 days to figure it out
I did the upgrade to 6.47 and it seems to work just fine.
Client : OpenVPN GUI v11.15.0.0 / win10 pro OS Version:1919
In
mikegleasonjr
Wed Sep 09, 2020 1:26 pm
Thanks, v6.47.2 introduced my CapACs to max out at 50 mbit/s, now with v6.47.3, they're back up at full speed. CapsMan on a hEX PoE.
Waffla
Wed Sep 09, 2020 6:08 pm
I am expierincing Wi-Fi issues on a hap ac^2 on default wireless settings. Had no issues until 6.47.3. There are no tx/rx errors or any weird entries in the logs as far as I can tell.
Randomly the apps on every connected phone will just hang trying to access the Internet while still being connected. If left alone it won't recover until I re-connect to WiFi. It doesn't happen on all clients at the same time either but after a number of hours of being connected. Very strange stuff.
Tubeorange667
Thu Sep 10, 2020 8:05 am
hAP Ac. Was on 6.47.2 upgraded to 6.47.3, firmware also upgraded after reboot. Everything went flawlessly.
kowal
Thu Sep 10, 2020 6:22 pm
I've Winbox 3.27 on Wine (ubuntu) and I can't log in to any device after upgrading them to 6.47.3. It stays at "Logging in" and nothing is happening.
Of course, devices are accessible by in.ex. SSH but winbox is missing. From windows I still can log in. Trying older winbox didn't work.
Strange thing is that if I don't upgrade device, in.ex. from 6.47.2 to 6.47.3 I can log in by winbox (wine - ubuntu).
If I upgrade device to 6.47.3, I can't log in from ubuntu anymore.
Kindis
Fri Sep 11, 2020 8:45 am
Have you tried to restart the device again and see if it works?
RegyJenkins
Fri Sep 11, 2020 11:06 am
Just took ownership of a Chateau lte12 (getting some wicked speeds, so pretty happy there :) ). Went to update to latest version stable version (like a good admin) failed a few times until I realise that it had shipped with a 7.0beta6 version, and Winbox doesn't let you downgrade?!
Obvious questions perhaps: a) but should I downgrade? and b) if the consensus is yes, can some share a link instructions on the simplest way give Winbox won't let you
Thanks.
r00t
Long time Member
Long time Member
Sat Sep 12, 2020 9:36 pm
No, you can't. Chateau requires ROS v7.x and can't be downgraded to 6.x.
That's right, Mikrotik sells a device with beta (behaves more like an alpha) version of software...
muhanadali
Sun Sep 13, 2020 3:19 pm
Support Memory up to 16GB like RouterOS V7
seriousblack
Sun Sep 13, 2020 10:16 pm
Update on this CVE-2020-11881
d3nnisc
Tue Sep 15, 2020 6:36 pm
I have an hapac2 that i updated to 6.47.3 and now has a lot of link downs on the 2 wifi intefaces......
revan
Fri Sep 18, 2020 12:52 pm
Bug in mac-table by snmp. The interface number in the mac-table is offset by -1:
RB960PGS
firmware 6.47.3:
# snmpwalk -v 2c -c public 10.160.0.24 1.3.6.1.2.1.17.4.3.1.2
SNMPv2-SMI::mib-2.17.4.3.1.2.0.14.94.11.38.242 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.3.1.2.72.143.90.107.197.193 = INTEGER: 0
# snmpwalk -v 2c -c public 10.160.0.24 1.3.6.1.2.1.17.7.1.2.2.1.2
SNMPv2-SMI::mib-2.17.7.1.2.2.1.2.0.0.14.94.11.38.242 = INTEGER: 5
SNMPv2-SMI::mib-2.17.7.1.2.2.1.2.0.72.143.90.107.197.193 = INTEGER: 0
firmware 6.46.7
#snmpwalk -v 2c -c public 10.160.0.24 1.3.6.1.2.1.17.7.1.2.2.1.2
SNMPv2-SMI::mib-2.17.7.1.2.2.1.2.0.0.14.94.11.38.242 = INTEGER: 6
SNMPv2-SMI::mib-2.17.7.1.2.2.1.2.0.72.143.90.107.197.193 = INTEGER: 7
list of interfaces (6.46.7 and 6.47.3):
# snmpwalk -v 2c -c public 10.160.0.24 1.3.6.1.2.1.2.2.1.2
IF-MIB::ifDescr.1 = STRING: ether1
IF-MIB::ifDescr.2 = STRING: ether2
IF-MIB::ifDescr.3 = STRING: ether3
IF-MIB::ifDescr.4 = STRING: ether4
IF-MIB::ifDescr.5 = STRING: ether5
IF-MIB::ifDescr.6 = STRING: sfp1
IF-MIB::ifDescr.7 = STRING: bridge
Mac 00:0e:5e:0b:26:f2 in fact, located on the port sfp1. At firmware 6.47.3 it is detected on the ether5 port!
templeos
Fri Sep 18, 2020 2:35 pm
Hopefully next release. Too bad this was ignored. Security researcher reported the issue in time.
https://github.com/botlabsDev/CVE-2020-11881
emils
Mon Sep 21, 2020 9:58 am
New version 6.47.4 has been released in stable RouterOS channel:
viewtopic.php?f=21&t=166428
Users browsing this forum: fraxinus, winap and 7 guests
