normis
Expected down time for this forum SEPT 11
Thu Sep 10, 2020 1:22 pm
We will be performing migration and maintenance tasks on this forum tomorrow (September 11) at lunch time (mid day, 12:00 PM GMT+3 / EET) which will last around 6 hours. Please be aware that the site will not be responding during this time. It is planned and expected. Sorry for the inconvenience.
Other MikroTik services will be available, for any urgent questions, please contact MikroTik support or your local MikroTik representative.
Kindis
Re: Expected down time for this forum SEPT 11
Thu Sep 10, 2020 1:28 pm
Thanks for the hears up but what should I do on my lunch and afternoon break now? ;)
msatter
Thu Sep 10, 2020 1:45 pm
It will bit earlier when you are on CET at 11:00 or GMT 10:00 (both still on summertime)
Advantage it will also be ready on a earlier time. ;-)
Loving my freedom and so, no Twitter, no Facebook/Instagram/WhatsApp, no Apple and no Google/Alphabet.
Running:
RouterOS 6.48 / Winbox 3.27 64bits
erlinden
Long time Member
Long time Member
Thu Sep 10, 2020 1:50 pm
If asking what not to do...don't change you config ;-)
Good luck team on the migration!
First the problem, then the solution
jarda
Thu Sep 10, 2020 4:53 pm
Keeping fingers crossed.
Hope we will get more stability and working features.
Hope you will not break anything.
anav
Thu Sep 10, 2020 4:55 pm
My shrink has recommended I take videos now while scrolling through threads, but only to be played when I suffer the worst withdrawal systems - start contemplating cutting the lawn.......
Msatter, didn't you get the memo, at least those that are MT certified did - we all use the same Zulu time. ;-PP\
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
Sob
Thu Sep 10, 2020 8:51 pm
Like the optional "prosilver" style, it's extremely important to have that! :)
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
msatter
Thu Sep 10, 2020 9:24 pm
So, on 9-11 we are going to update the forum. Great timing.
I remember it as yesterday that we sat in front a small TV in the firm with the staff looking, with disbelieve what was happening in New York.
Running:
anav
Thu Sep 10, 2020 11:11 pm
I was in a MIL operations centre, standing stunned but realizing the shit was going to hit the fan big time when one of the video feeds clearly showed the second explosion was without doubt due to an airplane
santyx32
Fri Sep 11, 2020 5:11 pm
The forum it's working again, good job!
jarda
Fri Sep 11, 2020 6:29 pm
Yep. So what's new or better?
santyx32
Fri Sep 11, 2020 8:00 pm
Probably migrated the forum to new hardware
anav
Fri Sep 11, 2020 8:51 pm
A few of us are now getting paid per post and they need a tracking mechanism built in!
bpwl
Fri Sep 11, 2020 9:12 pm
This forum "hangs" again on that e-mail step. Not sending out notifications, and not going further after hitting "submit". The input is posted, but you have to come back to see it.
Link to mail server not migrated ????
Hmmm , here it worked! Fixed already?
anav
Fri Sep 11, 2020 9:26 pm
Yes, hit or miss for me bpwl. Its inconsistent, just like configuring WIFI ;-)
It hangs for an original post but not necessarily for an EDIT.
They must have used the same folks assigned to wifi, to do the migration.
bpwl
Fri Sep 11, 2020 9:31 pm
And they are still indexing the content? Search just gives "waiting" ! ... until error 500 .
anav
Fri Sep 11, 2020 9:34 pm
I am sending a supout report with ticket!! ;-P
neutronlaser
Fri Sep 11, 2020 10:57 pm
Imagine just going home on a Friday.
msatter
Fri Sep 11, 2020 11:08 pm
So, are we having a Mikrotik weekend?
Running:
anav
Sat Sep 12, 2020 1:21 am
Going home? What a foreign concept. Who goes to work and leaves home these days???
neutronlaser
Sat Sep 12, 2020 3:20 am
I meant the other room.
jarda
Sat Sep 12, 2020 5:55 am
I told them not to break anything.
But did they hear? Like always.
Mikrotik.
krisjanis
Sat Sep 12, 2020 10:19 am
Both search function and mail notifications should be working now.
bpwl
Sat Sep 12, 2020 10:27 am
Modified password ?????? Had to reset it to be able to Login !?
Edit: also did reset to same password as before.
krisjanis
Sat Sep 12, 2020 11:30 am
Nothing was modified for users. I did switch PHP version to make search work and notifications was FW issue. Forum Cache was cleaned. That could had possibly messed up session, but that's all.
msatter
Sat Sep 12, 2020 12:29 pm
Darn I had to change my password because it needs now a capital and a number in it after the cleaning of the PHP/forum cache, I assume. Before that I could login.
If you have a problem during login you can contact the board administrator....yeah works great.
The board administrator contact page has been disabled.
Had to complete a captcha from Google that was not vissible to attempt to create a temp account to find out about the changed password settings.
Nice, and by the way Google is E V I L
Thanks for the heads-up for implementing this change.........what adventure is planned for the next weekend by Mikrotik?[/size]
Anybody not able to login you have to reset your password!
You now need to insert a capital and number in your new password.
Running:
neutronlaser
Sat Sep 12, 2020 3:58 pm
Filling out that forced captcha earned money from google. Forced slavery.
Znevna
Sat Sep 12, 2020 4:27 pm
After reading that the old passwords no longer work I've said to give it a try and I've logged out.
Well, indeed I had to reset the password since the old one no longer worked. And yes the old one had all the security strength requirements since I've reused the old password (yes, bad, I know, but hey, it worked.)
Worth looking into it, MikroTik.
santyx32
Sat Sep 12, 2020 5:23 pm
I also had to reset my password, my previous password was also autogenerated by a password manager.
Cha0s
Sun Sep 13, 2020 3:19 am
Same here. Password was not working. Had to reset.
k6ccc
Long time Member
Long time Member
Sun Sep 13, 2020 7:32 am
Same here. My password was invalid - it said. Used the "I forgot my password" link. "reset" my password to what it has been before - 4 capital letters, 4 lower case letters, 7 special characters, and 1 number - cryptic crap generated by my password manager.
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Warning: I know enough to be dangerous...
Jim
R1CH
Forum Veteran
Forum Veteran
Sun Sep 13, 2020 6:28 pm
Also had to do a reset, made much more difficult when you have to reset by email and not username! My password was also long, autogenerated by password manager. Reset accepted the same one without a problem.
joan10
Sun Sep 13, 2020 7:38 pm
We're trying to register a new user for a mate. When we submit the registration form it takes about 30 seconds and then times out. Seems the server is not reaching google to verify the captcha.
Damn, now I remember how much I love the poster saying "readonly friday" in my office :P
Greetings and good work ;)
GregC
Tue Sep 15, 2020 4:45 am
Password was not working. Had to reset. I read a lot of other people's posting and do not write that frequent. But, I have to say that MikroTik is failing to communicate to us some of the changes. If you tell us that a new policy for passwords will be implemented that will be fine. But come on... why we have to figure it out after the fact? Respectfully, this is just a constructive criticism. I do know this hard work.
vecernik87
Forum Veteran
Forum Veteran
Tue Sep 15, 2020 5:44 am
If password does not work and @krisjanis was upgrading the PHP version, there is likely different hashing algorithm. I mean... it shouldn't be because afaik each hash has short prefix announcing what algorithm is used, but I can imagine that phpBB forum detected new PHP version and forced different algorithm. The only other explanation I have is they used shared salt for all passwords and lost it... Which seems highly unlikely.
normis
Tue Sep 15, 2020 9:39 am
Sorry for the inconvenience caused, but yes, this is a good opportunity to upgrade your password and set a better one. You will have to request a password recovery link and set a good password. I suggest using a password manager.
msatter
Tue Sep 15, 2020 10:21 am
Please stop implementing/releasing things at the end of the week or in the weekend because we have to wait then till the next week starts before Mikrotik can start fixing things!
Running:
Cha0s
Tue Sep 15, 2020 12:25 pm
In my 20 years of experience with PHP and phpBB, I've never ever seen users' password stop working because of a PHP version change.
So was this sudden "migration and maintenance" some type of compromise which MikroTik failed to inform us about?
psannz
Tue Sep 15, 2020 12:33 pm
They release it on fridays, so those who want to test over the weekend can. I myself enjoy it. :)
Remember the Readonly-Friday rule.
Never update/upgrade your productive systems on a friday unless you have tested everything or the update *must* be deployed at once due to security issues.
dimaskiddo
Wed Sep 16, 2020 6:23 pm
Did MikroTik forum team forgot to change back their HTTP redirection from forum.test.mt.lv to forum.mikrotik.com ?
When i type the address without https on it the redirection goes to forum.test.mt.lv
Small miss configuration here, i think :D
hostclub
Wed Sep 16, 2020 10:41 pm
The right topic name should be: "Expected down time for those who use Mikrotik equipment in their infrastructures" :D
jaytcsd
Sat Sep 19, 2020 2:48 am
is the help site down?
My hAP lite rebooted and failed to come up so I pulled the power cord to get it back up and made a support.rif but can't get into the service desk page, just get a spinning circle.
This happens on the sign up and resister pages, tried 2 browsers on one PC and one on a 2nd PC.
CZFan
Location: South Africa, Krugersdorp (Home town of Brad Binder)
Thu Sep 24, 2020 8:47 pm
Yup, recall this very well also, was at Microsoft Tech-Ed at Sun City at the time, all went back to their rooms to watch the horror unfold on TV
MTCNA, MTCTCE, MTCRE & MTCINE
Users browsing this forum: R00tKit and 9 guests
