Finally you decided to add external antennas to routers, what happend to all the talk how they are not needed you where tell us all this years when we complained about poor signal? :D
Antenna designs for MIMO systemsSush! Don't bring this out, they might decide not to do it for future devices.Finally you decided to add external antennas to routers, what happened to all the talk how they are not needed you where tell us all this years when we complained about poor signal? :D
Normis as a movie star :-)Excellent videos! Good to see the team and the products, puts a human touch behind the brand.
Yes it looks good, I am sort-of looking for a router to replace my aging RB2011 at home and this could be it (of course with an additional switch).I loved the hAP ac³! And it comes with 128MB storage! Now it will be possible to use partitioning at home! :D
hAP ac3 looks wonderful!
Finally you decided to add external antennas to routers, what happend to all the talk how they are not needed you where telling us all this years when we complained about poor signal? :D
Our Polish friends say Sep 28! So, next week...hAP ac3 looks wonderful!
Now, when will we see these devices at the retailers? 2021,2022 ?? :-)
That's not so hard to figure out since hAP ac3 is based on hAP ac2 with more storage, more ram and external antennas. But the same CPU.Yes it looks good, I am sort-of looking for a router to replace my aging RB2011 at home and this could be it (of course with an additional switch).I loved the hAP ac³! And it comes with 128MB storage! Now it will be possible to use partitioning at home! :D
Unfortunately there are no performance specs for routing and IPsec. But I think the ipq-4019 should do IPsec acceleration so that should not be too bad.
If I remember correctly, the IPQ4019 is almost identical to the IPQ4018, used on the hAP AC2. It had minor differences, if I'm not mistaken on memory and NAND size limits. I believe the routing and IPSec performance will be the same of the hAP AC2.Yes it looks good, I am sort-of looking for a router to replace my aging RB2011 at home and this could be it (of course with an additional switch).I loved the hAP ac³! And it comes with 128MB storage! Now it will be possible to use partitioning at home! :D
They are not only start making 60G gear with sfp ports, but dare offering with FE ports :DhAP ac³ is not bad, but home AP market is really competitive and at $100 you can get more chains, working MU-MIMO or 2.5/5GbE ports.
But nice to see more than 16MB of flash!
Also bit disappointed by lack of 60GHz gear with SFP. I was hoping to see some new 60GHz gear announced.
I see you are adding it to some 5GHz models, but 60GHz PtP would make much more sense.... and not a single 60GHz model have SFP right now.
What is the problem? I had not heard of this problem. I would appreciate reading more details about this problem.Need to see if there is WiFi problem resolved with hAP AC3. There was a big issues caused by ARM optimizations. Still not working as should be... Two years ago, and still not perfect software for ARM based devices.
Details, please.Need to see if there is WiFi problem resolved with hAP AC3. There was a big issues caused by ARM optimizations. Still not working as should be... Two years ago, and still not perfect software for ARM based devices.
Google is your friend..Details, please.Need to see if there is WiFi problem resolved with hAP AC3. There was a big issues caused by ARM optimizations. Still not working as should be... Two years ago, and still not perfect software for ARM based devices.
Google certainly is not my friend.Google is your friend..Details, please.Need to see if there is WiFi problem resolved with hAP AC3. There was a big issues caused by ARM optimizations. Still not working as should be... Two years ago, and still not perfect software for ARM based devices.
https://www.google.com/search?q=terribl ... e&ie=UTF-8
Too many opened topics about poor performances on hAP AC2, and other ARM based devices.
There is nothing there. I did a search and there was nothing there. So I am asking again what the problem is.Check forun topics opened on Mikrotik Forums..
The ARM line had several teething problems: the RB3011 had port flappings, the RB4011 some instability and the hAP AC2 got several complaints about wifi speed and stability - don't remember any serious complain about the CCR2004. Some of these complaints looked like user error - but several of them were acknowledged by Mikrotik, and got fixed/improved over time. Even the 6.47.x version is still getting ARM improvements.There is nothing there. I did a search and there was nothing there. So I am asking again what the problem is.Check forun topics opened on Mikrotik Forums..
If you buy from another brand.When will we get Wifi 6?
Yes, but that is long fixed now, I don't believe there is any ARM related WiFi issue open. It's easy to fall into one of those "me too" traps, but sometimes it's just a wifi placement / config issue, not a device or hardware problem.The ARM line had several teething problemsThere is nothing there. I did a search and there was nothing there. So I am asking again what the problem is.Check forun topics opened on Mikrotik Forums..
Product page specifications show storage size as 128 MB, but for some reason it reads "FLASH 16 MB" on block diagram...I loved the hAP ac³! And it comes with 128MB storage! Now it will be possible to use partitioning at home! :D
Probably a mistake, since they redid that diagram based on the hAP ac3 LTE kit (we hope :D).Product page specifications show storage size as 128 MB, but for some reason it reads "FLASH 16 MB" on block diagram...I loved the hAP ac³! And it comes with 128MB storage! Now it will be possible to use partitioning at home! :D
It is there, announced in May/2020:CCR 2004 is not longer listed in newsleter
and caralog ;) https://download2.mikrotik.com/catalog_2020.pdf
any idea why?
And also (as a separate item) a kit that will make possible to mount two units in one 19" space.It would be really nice if for smaller devices like this CSS610-8G-2S+IN switch MikroTik bundles second ear for 10" racks mount that are increasingly popular ...
Could you share the store name/web? I could not find anywhere, also not at eurodk as well.Our Polish friends say Sep 28! So, next week...hAP ac3 looks wonderful!
May be but on the other hand it seems more cost effective just to buy a larger unit like for example CSS326-24G-2S+RM that is only a bit more expensive but is full 19" rack unit and gives you 24Gbps ports etc ...And also (as a separate item) a kit that will make possible to mount two units in one 19" space.It would be really nice if for smaller devices like this CSS610-8G-2S+IN switch MikroTik bundles second ear for 10" racks mount that are increasingly popular ...
They have removed that availability date now.Could you share the store name/web? I could not find anywhere, also not at eurodk as well.Our Polish friends say Sep 28! So, next week...hAP ac3 looks wonderful!
https://shop.allnet.de => 14/10/2020Could you share the store name/web? I could not find anywhere, also not at eurodk as well.
I'm familiar with CRS318, but it is with 10/100 on the client side (reverse Poe). Are you planning CRS3xx with 10/100/1000 on client side (gigabit with reverse Poe). It would be great with 8 and 16 ports. And sfp+ 1/10 capable uplinks.aviper, we already have that product. note the difference in the name, Lite in this case indicates CCS.
here is the CRS version https://mikrotik.com/product/crs318_1fi_15fr_2s_out
Sure, but the idea mainly is to combine two 8-port PoE switches, or one PoE and one non-PoE.May be but on the other hand it seems more cost effective just to buy a larger unit like for example CSS326-24G-2S+RM that is only a bit more expensive but is full 19" rack unit and gives you 24Gbps ports etc ...
Thanks, just saw WiMood NL and CDR PL already available today. Strangely they are faster than Latvian stores..?https://shop.allnet.de => 14/10/2020Could you share the store name/web? I could not find anywhere, also not at eurodk as well.
So we are waiting for netPower 7R/8R and 15R/16R :) I hope you are developing this product line. Up until then we are going to test netPower Lite 7R when it hits the market to see how mature and usable is SwOS.aviper, we already have that product. note the difference in the name, Lite in this case indicates CCS.
I presume they needed a bit more room for larger heat sink for that 32 bit Arm CPU SoC, previous model hAP ac² could get pretty hot while running ...As for the hAP ac³ - it is almost 2x the size of the previous model. Pity there is still only 5 eth ports. Well, one is going to be used for the Internet connection, so actually 4 ports ... I use it for my home and my friend wants to redo his home network too, but needs more power. Will be deciding between the two, he has a concrete walls :-)
I think they are targeting a different kind of ISP than you have in mind... which more resembles home usage than enterprise usage.Second it is advertised as GPEN, which should be mostly ISPs area, less Enterprise area and almost none of Home area, but it is not usable for ISPs and Enterprise scenarios.
What kind of ISPs are closer to home usage?I think they are targeting a different kind of ISP than you have in mind... which more resembles home usage than enterprise usage.Second it is advertised as GPEN, which should be mostly ISPs area, less Enterprise area and almost none of Home area, but it is not usable for ISPs and Enterprise scenarios.
The "clever guy in the neighborhood setting up some wireless links to nearby appartment buildings and providing cheap internet access" kind of operation.What kind of ISPs are closer to home usage?I think they are targeting a different kind of ISP than you have in mind... which more resembles home usage than enterprise usage.Second it is advertised as GPEN, which should be mostly ISPs area, less Enterprise area and almost none of Home area, but it is not usable for ISPs and Enterprise scenarios.
... But at same time in Western Europe, North America and any many other countries many many customers want better Wifi (full 11ac with all the benefits) and Wifi 6 NOWNot just a guy, a lot of eastern european countries have apartment building areas in outskirts of cities. Say 20-30 or more such builgings with 7-9 stories each. Small ISP companies drag cable from building to building, put a switch on the roof, then drag ethernets down ventilation shafts or lift shafts to each apartment. Usually their problem is power on the roof, cable lenght. This is where reverse-PoE and GPER come in handy.
Yes of course. I´m looking for the latest iPhone 12 which of course supports IEEE 802.11ax and MU-MIMO ;-)nearly off topic :) Did you watch yesterdays Apple presentation? LTE and 5G is the future there :)
Our company is from East Europe, we started as this kind of ISP. We built our network with unmanageable switches, after a while, we started to invest in fibers, managable switches, PON and etc. At the present moment I think that if someone is going to start such a small ISP, he would like to have at least option for future management. We still have multi-story buildings which are pre-cabled by the builder with UTP/FTP cable from every apartment to the basement or specialized room. Even at this moment some builders continue to build buildings without cable shafts and they put only cable from "internet room" to every apartment, without thinking for the future.Not just a guy, a lot of eastern european countries have apartment building areas in outskirts of cities. Say 20-30 or more such builgings with 7-9 stories each. Small ISP companies drag cable from building to building, put a switch on the roof, then drag ethernets down ventilation shafts or lift shafts to each apartment. Usually their problem is power on the roof, cable lenght. This is where reverse-PoE and GPER come in handy.
I must agree 100% with you. Even in east Europe clients are ready to pay, we are seeing many A**s/L****** routers for 150E+, the client is thinking that if he pays more, he will get much more. We are selling T*-L*** and Mikrotik routers as option to our home customers. But the customer is forced to choose between stability (Mikrotik) and Wi-Fi Performance and features (Other SOHO brands). At the same time we are giving to our Small business customers Mikrotik router as a part of our contract and this was one the best solution we could make ever.... But at same time in Western Europe, North America and any many other countries many many customers want better Wifi (full 11ac with all the benefits) and Wifi 6 NOWNot just a guy, a lot of eastern european countries have apartment building areas in outskirts of cities. Say 20-30 or more such builgings with 7-9 stories each. Small ISP companies drag cable from building to building, put a switch on the roof, then drag ethernets down ventilation shafts or lift shafts to each apartment. Usually their problem is power on the roof, cable lenght. This is where reverse-PoE and GPER come in handy.
And are ready to pay!!!
But there are plenty of other WiFi6 stuff on the market if you really need WiFi6. I don't see why Mikrotik has to rush to get a WiFi6 device for the SoHo-market. I have use separate WiFi and router/firewall for many years now. If you want performance and flexibility, then don't use all-in-one boxes.... But at same time in Western Europe, North America and any many other countries many many customers want better Wifi (full 11ac with all the benefits) and Wifi 6 NOW
This is what I tried in my building couple of years ago, but in my country people are small minded, thinking I'll be getting very rich if I'm sharing them internet for a small fee.The "clever guy in the neighborhood setting up some wireless links to nearby appartment buildings and providing cheap internet access" kind of operation.What kind of ISPs are closer to home usage?I think they are targeting a different kind of ISP than you have in mind... which more resembles home usage than enterprise usage.Second it is advertised as GPEN, which should be mostly ISPs area, less Enterprise area and almost none of Home area, but it is not usable for ISPs and Enterprise scenarios.
Also sometimes the "let's all share a single internet connection in our appartment building" type of thing.
Can you make some tests more? How you decided that signal is the same? Some config pls.I built hap ac3 in the same place as hap ac2. Disappointed, the 5ghz signal is the same. In one place, the speed dropped by half.
Some config, the signal is the same... I was left disappointed, their words promising, and the reality quite different.Can you make some tests more? How you decided that signal is the same? Some config pls.I built hap ac3 in the same place as hap ac2. Disappointed, the 5ghz signal is the same. In one place, the speed dropped by half.
I was thinking about this lately. I believe better reception (higher rx sensitivity) also means higher sensitivity to the interference. So you are getting better coverage, but can only enjoy it in quiet areas, whereas in the crowded areas you almost guarantee to get less available airtime (i.e. less speed/bandwidth).Only the reception of the access point may improve, not the signal strength.
