emils
v6.47.6 [stable] is released!
Thu Oct 22, 2020 1:53 pm
RouterOS version 6.47.6 has been released in public "stable" channel!
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 6.47.6 (2020-Oct-21 10:41):
Changes in this release:
*) cap - fixed L2MTU path discovery;
*) crs3xx - fixed hardware offloaded LACP bonding on Ethernet interfaces for CRS354 devices;
*) crs3xx - fixed switch rules for CRS309 and CRS317 devices (introduced in v6.47.3);
*) defconf - fixed default configuration loading on RBmAP-2nD;
*) dhcpv4-client - fixed DHCP offer packet parsing with overload option present;
*) dhcpv6-server - properly save bindings when executing "make-static" command;
*) fetch - improved SSL handshake processing;
*) ike1 - allow using "my-id" parameter with XAuth;
*) leds - fixed LED type setting;
*) lora - expose "joinEui" un "devEui" values in the log;
*) lte - fixed multiple APN passthrough on R11e-4G;
*) lte - improved EARFCN reporting in 3G and LTE modes on Sierra modems;
*) lte - limit allowed APN count to 3 on R11e-LTE;
*) mpls - fixed duplicate "LabelRelease" message sending;
*) ospf - optimized LSA printing for smaller message sizes;
*) radius - added "Service-Type" attribute to Access-Request for IPv4 and IPv6 DHCP servers;
*) smips - reduced RouterOS main package size;
*) switch - fixed Ethernet padding for small packets;
*) user - improved WinBox and The Dude authenticated session handling;
*) vrrp - made "password" parameter sensitive;
*) w60g - general stability and performance improvements;
*) wireless - added support for US FCC UNII-2 and Canada country profiles for NetMetal series devices;
*) wireless - fixed incorrect wireless capability information in association response frames;
What's new in 6.47.5 (2020-Oct-08 06:48):
(factory only release)
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
eworm
Forum Veteran
Forum Veteran
Re: v6.47.6 [stable] is released!
Thu Oct 22, 2020 2:17 pm
This is now suffering the log messages on default configuration script we had in testing before:
system;error;critical error while running customized default configuration script: expected end of command (line 1337 column 53)
This happens without wireless package only.
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
Ixander
Thu Oct 22, 2020 2:33 pm
On the version 6.47.6 command repartition (e.g. "/partitions repartition partitions =2") causes the router's cyclic reboot (about every 10 seconds). On versions 6.47.x situation the same.
Reset didn't help, I've been able to repare it only with netinstall
On the version 6.46.7 this command works correctly
model: 951Ui-2HnD
revision: r2
firmware-type: ar9344
factory-firmware: 6.46.1
current-firmware: 6.47.6
upgrade-firmware: 6.47.6
ivan2000
Thu Oct 22, 2020 3:36 pm
I am having the same issue.
anuser
Long time Member
Long time Member
Thu Oct 22, 2020 4:03 pm
interesting bug fixes for our wireless clients
Kamaz
Thu Oct 22, 2020 4:47 pm
HEX with latest firmware and ROS v6.47.6
Wireless package disabled.
robsgax
Thu Oct 22, 2020 7:01 pm
Will this fix the high battery issue with mobile devices? this started with the 6.47 versions, up to 6.46 the battery drain was normal on phones and tablets, it went up to 4x with the 6.47 versions.
vili11
Thu Oct 22, 2020 7:22 pm
Could you elaborate on the w60g improvements?
buset1974
Thu Oct 22, 2020 9:50 pm
"error while running customized default configuration script: expected end of command (line 1337 column 53)"
DarkNate
Fri Oct 23, 2020 12:22 am
RB450Gx4, everything worked great for months until I updated to 6.47.6. Wireless package installed since forever but is obviously disabled.
Edit: I found this on the 6.48 thread, however: viewtopic.php?t=163308#p811799
strods
Fri Oct 23, 2020 7:06 am
The defconf issue is already resolved. Fix will be included in the next RouterOS release.
Jotne
Fri Oct 23, 2020 8:52 am
And also fix the log naming as I have posted both here and to support email before. (fix it for the new v7 as an minimum)
viewtopic.php?f=2&t=124291
3 years and nothing has been done!!!
Look at this line:
Is this an error message or an critical message.
Look at how wiki describes syslog messages: https://en.wikipedia.org/wiki/Syslog
Value	Severity
0	Emergency
1	Alert
2	Critical
3	Error
4	Warning
5	Notice
6	Informational
7	Debug
I have never seen any other system messing up logging prefix the way MikroTik does it.
Why do not use Splunk to monitor your MikroTik Router(s)? Look at this page in how to set it up.
MikroTik->Splunk
mkx
Fri Oct 23, 2020 8:54 am
It's a critical error ;-) With value 2 (2 and 3 binary and-ed together).
BR,
Metod
revan
Fri Oct 23, 2020 10:24 am
In 6.47.6, nothing has changed since my last post.
viewtopic.php?f=21&t=166428&p=822010#p822010
Fix the Mac table via snmp!!! Not only can the poe port not be managed via snmp, but the Mac table is now not correctly returned!!!
onnoossendrijver
Fri Oct 23, 2020 10:53 am
I see no improvement here. My Oneplus drains like crazy, but GF's Nokia doesn't seem to have problems.
On the laptops I don't know, They are used with power adapter.
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
pe1chl
Fri Oct 23, 2020 11:05 am
It has been resolved before!
I would hope that when such mistakes are made, they are added to the regression testing done before releasing a new version, especially in [stable].
8an
Fri Oct 23, 2020 12:20 pm
I can confirm the w60g link instability problem is fixed, I upgraded the Wireless Wire link that was the least stable on 6.47.4 from 6.46.6 to 6.47.6 and it's still stable.
Kindis
Fri Oct 23, 2020 1:57 pm
Yes I agree how does this not get noticed? I just updated two of my 3011 and only one had this issue and that is the one that has wireless package disabled. So it might be related to that?
mozerd
Fri Oct 23, 2020 2:42 pm
On my CCR1009-7G-1C-1S+
updating from 6.47.4 to 6.47.6 went without one hicup
On my CRS326-24G-2S+
updating from 6.47.1 [long term] to 6.47.6 [stable]
1. software update .... at the 2 minute mark -- after the update -- could not login into Winbox
2. BUT waiting to the 3 minute mark succeeded in login into Winbox for Firmware update
3. After firmware update no problem login into Winbox at the 1 minute mark :-)
Kraken2k
Fri Oct 23, 2020 2:44 pm
Updated RB1100AHx4 half a day ago - so far, everything is running without any problems.
pe1chl
Fri Oct 23, 2020 4:06 pm
Yes, it is the cause. The problem is that the configuration script contains commands that refer to features not available (wireless) and bombs out.
It has happened before.
However it is not as critical as it sounds, at least not when you make small incremental upgrades. I.e. you upgraded from an earlier 6.47.x version.
In that case no conversion is really necessary and the fact that the script failed has no further effect on the operation of the upgraded router.
(I had this problem before and my router still works fine)
Of course it may/will be different when you make a big version jump and there actually may be things that need changing in the config.
robsgax
Fri Oct 23, 2020 11:23 pm
have you tried the long-term release? with that one or any 6.46 version my devices drain is very low, with any 6.47 version, it goes up to 4x times the normal drain.
UpRunTech
Sun Oct 25, 2020 3:04 am
No evidence but I felt recently battery life improved with 6.47.4 on my Samsung phone. Anyone else notice?
notToNew
Sun Oct 25, 2020 9:59 am
Tiere is a keep-alive setting in the wireless options which seems to help reducing the power-usage.
CCR1036-12G-4S, several 952Ui-5ac2nD, ...
Miklan
Sun Oct 25, 2020 10:14 am
WiFi beacon interval / DTIM could also really help :
viewtopic.php?f=2&t=116221
n17v8ke28u5969nd3i4h
Sun Oct 25, 2020 11:06 pm
:set currentIP [/ip cloud get public-address] is no longer working - "currentIP" gets set to a null string, even though "/ip cloud print" shows the correct value for public-address.
Jotne
Sun Oct 25, 2020 11:34 pm
You do declare the variable before you are using it?
Try cut/paste this to a terminal windows (with the brackets {})
:local currentIP
:put $currentIP
You may in some cases set it while declare it like this (it will fail in a do loop and other places):
:local currentIP [/ip cloud get public-address]
:put $currentIP
MikroTik->Splunk
EdPa
Mon Oct 26, 2020 8:59 am
The bridge host table has slightly changed since 6.47. Now the dot1dTpFdbPort (1.3.6.1.2.1.17.4.3.1.2) shows the bridge port number where the source address has been learned, see the dot1dBasePort (1.3.6.1.2.1.17.1.4.1.1). To link these ports with ifIndex, see the dot1dBasePortIfIndex (1.3.6.1.2.1.17.1.4.1.2).
Kraken2k
Mon Oct 26, 2020 11:43 am
Strange CPU overload after router attempts to connect to MikroTik cloud :( since then, "unclassified" process in Profile gets 60-65% all the time even if there is literally no traffic going through the RB1100AHx4 router.
According to external SNMP monitoring tool and router output chain in firewall, issue started after router attempt to connect to 159.148.172.251:15252 via UDP (MikroTik cloud) - but the cloud feature is deactivated in the configuration since the very beginning. Any ideas what could be wrong?
r00t
Mon Oct 26, 2020 3:58 pm
Make sure you also disable "time zone autodetect" in System/Clock, otherwise router will still contact cloud for that.
nickb333
Mon Oct 26, 2020 5:07 pm
RB450G - I updated from 6.46.4 to 6.47.6 then reset to the default configuration. I see only see the error if the wireless package is disabled, which is as you explained above. Not a show stopper as far as I'm concerned.
Nick B.
UK.
whitbread
Tue Oct 27, 2020 7:55 pm
Is the issue with maximum address list entries on arm devices (hap ac^2) resolved?
anuser
Long time Member
Long time Member
Wed Oct 28, 2020 5:33 pm
That´s new for me (MikroTik cAP ac). Any ideas?
16:12:20 wireless,debug wlan3: denying assoc to E0:D0:83:00:F3:53, does not support all basic rates
16:12:27 wireless,debug wlan3: denying assoc to E0:D0:83:00:F3:53, does not support all basic rates
16:20:11 wireless,debug wlan3: denying assoc to E0:D0:83:00:F3:53, does not support all basic rates
16:20:22 wireless,debug wlan3: denying assoc to E0:D0:83:00:F3:53, does not support all basic rates
16:20:53 wireless,debug wlan3: denying assoc to E0:D0:83:00:F3:53, does not support all basic rates
16:21:06 wireless,debug wlan3: denying assoc to E0:D0:83:00:F3:53, does not support all basic rates
16:21:15 wireless,debug wlan3: denying assoc to E0:D0:83:00:F3:53, does not support all basic rates
16:23:39 wireless,debug wlan3: denying assoc to E0:D0:83:00:F3:53, does not support all basic rates
WLAN3 is sub interface of WLAN1
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode allow-sharedkey=no ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=2 area="" arp=enabled arp-timeout=auto band=2ghz-g/n basic-rates-a/g=6Mbps \
basic-rates-b="" bridge-mode=disabled channel-width=20mhz compression=no country=germany default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0 default-forwarding=no disable-running-check=no disabled=no disconnect-timeout=3s \
distance=indoors frame-lifetime=0 frequency=CH6-20MHz frequency-mode=regulatory-domain frequency-offset=0 guard-interval=any hide-ssid=no ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs=\
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23 hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 \
hw-retries=7 installation=any interworking-profile=disabled keepalive-frames=disabled l2mtu=1600 mac-address=B8:69:F4:81:62:86 max-station-count=2007 mode=ap-bridge mtu=1500 multicast-buffering=enabled multicast-helper=full name=wlan1 \
nv2-cell-radius=30 nv2-downlink-ratio=50 nv2-mode=dynamic-downlink nv2-preshared-key="" nv2-qos=default nv2-queue-count=2 nv2-security=disabled nv2-sync-secret="" on-fail-retry-time=100ms preamble-mode=both radio-name=B869F4816286 \
rate-selection=advanced rate-set=default rx-chains=0,1 scan-list=CH6-20MHz security-profile=edugeek skip-dfs-channels=disabled ssid=edugeek station-bridge-clone-mac=00:00:00:00:00:00 station-roaming=enabled supported-rates-a/g=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b="" tdma-period-size=2 tx-chains=0,1 tx-power-mode=default update-stats-interval=disabled vlan-id=1000 vlan-mode=use-tag wds-cost-range=50-150 wds-default-bridge=none \
wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode allow-sharedkey=no ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=3 area="" arp=enabled arp-timeout=auto band=5ghz-n/ac basic-rates-a/g=6Mbps \
bridge-mode=enabled channel-width=20/40/80mhz-Ceee compression=no country=germany default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0 default-forwarding=no disable-running-check=no disabled=no disconnect-timeout=3s \
distance=indoors frame-lifetime=0 frequency=CH136-20MHz frequency-mode=regulatory-domain frequency-offset=0 guard-interval=any hide-ssid=no ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs=\
hw-retries=7 installation=any interworking-profile=disabled keepalive-frames=disabled l2mtu=1600 mac-address=B8:69:F4:81:62:87 max-station-count=2007 mode=ap-bridge mtu=1500 multicast-buffering=enabled multicast-helper=full name=wlan2 \
nv2-cell-radius=30 nv2-downlink-ratio=50 nv2-mode=dynamic-downlink nv2-preshared-key="" nv2-qos=default nv2-queue-count=2 nv2-security=disabled nv2-sync-secret="" on-fail-retry-time=100ms preamble-mode=both radio-name=B869F4816287 \
rate-selection=advanced rate-set=default rx-chains=0,1 scan-list=CH136-20MHz security-profile=edugeek skip-dfs-channels=disabled ssid=edugeek station-bridge-clone-mac=00:00:00:00:00:00 station-roaming=enabled supported-rates-a/g=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps tdma-period-size=2 tx-chains=0,1 tx-power-mode=default update-stats-interval=disabled vht-basic-mcs=mcs0-7 vht-supported-mcs=mcs0-9,mcs0-8,mcs0-7 vlan-id=1000 vlan-mode=use-tag \
wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
osc86
Wed Oct 28, 2020 6:23 pm
you only allow 6Mbit/s basic rate, I use 6,9,12,24. This works fine with all of my devices.
bpwl
Wed Oct 28, 2020 6:42 pm
/interface wireless
band=2ghz-g/n
basic-rates-b=""
ht-supported-mcs= mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
rx-chains=0,1
supported-rates-a/g= 6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
band=5ghz-n/ac
rx-chains=0,1
tx-chains=0,1
Is this post v6.47.6 related somehow? (here come only version specific posts)
The problem is device E0:D0:83:00:F3:53. It probably does not support 6 Mbps.
(Limitation of basic rates should be done in the AP, not in the client! Clients support 6Mbps per default. 6 Mbps (or 1 Mbps) is ALWAYS used for the first connection packet, even if it is not in the basic rates.)
This config seems correct (supports all basic rates mentioned.)
Not using "verbose" would show what you have changed versus default, and would include WLAN3
WLAN2 has a strange VHT setting (VHT=ac, settings are per radio not as HT, two radio's)
tx-chains=0,1
Should be
tx-chains=0,1
vht-supported-mcs=mcs0-9,mcs0-9
Or must have a reason why MCS9 cannot be used on chain 1
jo2jo
Forum Veteran
Forum Veteran
Wed Oct 28, 2020 7:43 pm
After upgrading a CCR1009 from 6.45.x to 6.47.6 , im seeing 2x (my only 2x) GRE tunnels fail. They do show GRE connection success (both are connecting to different mikrotiks, running 6.45.6, but i cant upgrade those two MTs to 6.47.x until the weekend).
While the GRE tunnels do show connect success, the static routes that route across them keeping going up and down about every 30s (and even when up, wont pass traffic). Im not even able to ping the IP address i have assigned to the GRE tunnel on the opposite end (thus the static route issues I assume). even at debug level im not seeing any unusual log messages.
There are brief moments (~10 seconds) when traffic/pings do pass, but its rare. (i have no issues, that i can see, with connectivity/packet loss to these 2x endpoints, both are ~ 10ms away)
I tried disabling IPsec on all sides of the GRE tunnels (ie remove the IPsec PW in int->gre) but the issue remains the exact same.
Whats worse- for some reason im not seeing any log messages related to the routes going up and down, i even tried temp. enabling debug logging, nothing. (so i didnt notice this issue until about 36h after the rOS upgrade).
Clearly there is an issue here related to 6.47.6 (and maybe 6.47.x but .6 is all i have tried so far).
(note, 3x unrelated L2TP PPP client connections (not using IPsec on these) on this CCR work fine under 6.47.6)
Downgrading to the long term release (6.46.7) fixed the GRE issue (instantly).
I do like the change Mikrotik made ~1 yr ago to the various release trees/branches! very helpful, especially in situations like this.
thanks
:beep :beep :beep
lleysan
Thu Oct 29, 2020 8:48 am
Hello everyone!
After upgrade from 6.46.3 to 6.47.6 I have error:
but my config have only 229 lines....
Whats can be wrong?
Devices: CRS226-24G-2S+ and CRS326-24G-2S+
I tried export config with "verbose" and I got 1638 lines, but line 1337 have no column 53....
eworm
Forum Veteran
Forum Veteran
Thu Oct 29, 2020 9:39 am
This is a known issue when wireless package is disabled, but nothing to worry about.
The default configuration script is an internal one that runs on boot to handle configuration changes after update.
lleysan
Thu Oct 29, 2020 10:15 am
You are absolutely right, after turning on the wireless package, the error disappeared. Thanks!
emils
Thu Oct 29, 2020 1:52 pm
New version 6.47.7 has been released in stable RouterOS channel:
viewtopic.php?f=21&t=168254
Users browsing this forum: No registered users and 7 guests
