emils
v6.47.7 [stable] is released!
Thu Oct 29, 2020 1:52 pm
RouterOS version 6.47.7 has been released in public "stable" channel!
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 6.47.7 (2020-Oct-27 13:27):
Changes in this release:
*) crs3xx - improved system stability on CRS354 devices;
*) defconf - improved default configuration generation on devices without wireless package installed;
*) poe - fixed automatic PoE firmware upgrade procedure;
*) poe - improved PoE-out status detection;
*) wireless - updated "kazakhstan" regulatory domain information;
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
Ixander
Re: v6.47.7 [stable] is released!
Thu Oct 29, 2020 4:48 pm
On the version 6.47.7 command repartition (e.g. "/partitions repartition partitions =2") causes the router's cyclic reboot (about every 10 seconds). On versions 6.47.x situation the same.
On the version 6.46.7 this command works correctly
model: 951Ui-2HnD
revision: r2
firmware-type: ar9344
factory-firmware: 6.46.1
current-firmware: 6.47.7
upgrade-firmware: 6.47.7
Is the company going to correct this error?
Chupaka
Thu Oct 29, 2020 5:14 pm
Did you write to support with that problem?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Ixander
Thu Oct 29, 2020 5:45 pm
This is not a problem of a single device but a stable branch 6.47.X At 6.46.X works correctly
951Ui-2HnD models - cyclic reboot
SUP-32199
RB2011UiAS-2HnD - show "ether boot" on LCD
krafg
Forum Veteran
Forum Veteran
Thu Oct 29, 2020 10:01 pm
Updated all my devices successfully (3x BaseBox 2 + 1x BaseBox 5 + 1x PowerBox Pro + 1x LtAP).
Regards.
If you want to know my network, you can find it here.
Running ROS 6.49.7, Kali Linux 2022 & Windows 11.
Telegram: @krafgrgi
Kindis
Thu Oct 29, 2020 11:22 pm
SUP-32199
Regardless you should contact support.
Mikhalich
Fri Oct 30, 2020 10:29 am
HEX PoE with a 48V power supply did not immediately load the connected equipment, nor does it. It takes 3 to 5 minutes to determine whether to turn on power.
pe1chl
Fri Oct 30, 2020 5:02 pm
SUP-32199
He mentions a SUP id so clearly he contacted support.
I think it is good to warn users about such a potentially fatal bug on the forum even after having contacted support.
I use several devices with partitioning but they have been partitioned on older RouterOS versions and still work fine.
But I really like to know when that kind of fatal problem would happen before I initialize partitioning on a remote device.
(I have not yet tested if it really is a common problem or "only" happens for him)
anav
Re: v6.47.7 [probably stable] is released!
Fri Oct 30, 2020 5:31 pm
ref: v6.47.7 probably stable is released!
Hmm, seems rather a small list of improvements and no mention of making hot chocolate and routing simultaneously.
It should be a MT trademark to include at least one juicy sexy update item per version.........................
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
PS. I only scratch the surface!
Tubeorange667
Sun Nov 01, 2020 3:19 pm
Update went butter smooth,all in all everything works fine. System didn't reset itself this time as it was the case with 6.47.2 and 6.47.3.
Hap Ac. Updated from 6.47.3 to 6.47.7
Jotne
Sun Nov 01, 2020 5:13 pm
Upgraded from 6.45.7 to 6.47.7 on an 750Gv3 with lots of configuration. All seems to work fine.
Use Splunk> to log/monitor your MikroTik Router(s). See link below. :mrgreen:
MikroTik->Splunk
jvanhambelgium
Forum Veteran
Forum Veteran
Sun Nov 01, 2020 8:37 pm
I took the plunge and updated my RB3011 from 6.46.6 (Testing) to this latest "stable"
Upgrade process without any issues, now I will be looking out for "interface resets/flaps" that have plagued me over the latest span of releases. It seemed the 6.46.6 (Testing) proved stable concerning these interface "flaps"
bda
Sun Nov 01, 2020 11:46 pm
SUP-32199
Hi, this problem exists on RB3011 eventually... Have near 20 devices and 5 of them have bug with repartition. Solving only with netinstall...
God bless UNIX!
rushlife
Mon Nov 02, 2020 9:52 am
Not so successful. CRS354 is STILL useless.
I can't count on this unit at all. I am waiting for fix couple of months and honestly I am starting be a little bit disappointed.
Can actually someone really do something about it ?
It is about time.
astrocrab
Tue Nov 03, 2020 4:14 am
after update to 6.47.7 there is no more access to web configuration of the device if it in bridge mode.
CAP ac
what to do?
owsugde
Tue Nov 03, 2020 12:43 pm
For what it's worth, my w60G link of two 60G wAPs at ~205m is still considerably less stable on 6.47.7 (with the apparent improvements from 6.47.6) than it was on 6.45.9.
Sure the range is basically maxed out here and it's not supposed to work perfectly anyway, but 6.45.9 really seemed to cope with that much better.
Update: It's seems to only have gotten less stable on 58GHz channel, 60GHz one has improved somewhat. Looking better right now than 58 on old firmware. Better beamforming patterns of phased array maybe? Will keep monitoring in next weeks.
erlinden
Tue Nov 03, 2020 1:01 pm
CAP ac
what to do?
Assuming you have a Windows machine available...have you tried using Winbox? Or, SSH?
First the problem, then the solution
astrocrab
Tue Nov 03, 2020 1:15 pm
CAP ac
what to do?
access point itself do not get IP address as it did it before firmware update. mobile app recognizes it as 0.0.0.0 but just can’t login
erlinden
Tue Nov 03, 2020 1:39 pm
Might want to connect using the MAC address instead of IP.
Can you please share the config (/export hide-sensitive file=anythingyoulike) of this cAP ac?
pe1chl
Wed Nov 04, 2020 11:23 am
There still is a "bad user experience" due to the wireless changes in the 6.47.x version.
I got a new "wAP ac" to use as an access point. Unpacked it, connected to it, immediately updated it from the 6.44 it came with to 6.47.7
Now want to do the wireless settings. It is set to "manual-txpower" and "no_country_set".
So I want to change that to "regulatory-domain" and "netherlands", but the device won't let me make that change because "the antenna gain value 0 is not valid".
However, there no longer is an antenna gain input field so there is no way to correct that.
This can only be fixed by going to the command line mode and setting the antenna gain to 2. Not user friendly, the GUI should offer the option to make that change and store the settings.
mkx
Wed Nov 04, 2020 12:14 pm
... the GUI should offer the option to make that change and store the settings.
Actually, if MT are insisting on proper setting of antenna gain with internal antennae, then that setting should be set automatically right after configuration reset or initial device setup. After all, antenna gain (and Tx power budget calculations requiring this information) doesn't make much of influence if one is running device with "no_country_set" as ROS then doesn't know about country regulation and can let wireless Tx with full power the chip is capable of without EIRP considerations.
Setting antenna gain from GUI does not really go had-in-hand with requirement to stick to country regulations ... if device knows better.
BR,
Metod
pe1chl
Wed Nov 04, 2020 2:27 pm
Maybe it would have gone better when I had reset to defaults AFTER installing the new software (as I always recommend to others...) but as this AP was going to run only as a simple bridge internal to an existing LAN I did not do that (I just removed all firewall rules).
The 6.44 factory software apparently did not set the correct antenna gain, and the 6.47 software refuses to change the country when antenna gain is set incorrectly.
But as this is a common occurrence for new devices out of the box, the software should handle this.
mkx
Wed Nov 04, 2020 3:39 pm
Indeed. If previous to upgrade setting was above minimum level, then the setting should stay. If setting was below minimum value, then it should be automatically adjusted.
BR,
Metod
Kraken2k
Wed Nov 04, 2020 4:37 pm
Strange CPU overload after router attempts to connect to MikroTik cloud :( since then, "unclassified" process in Profile gets 60-65% all the time even if there is literally no traffic going through the RB1100AHx4 router.
According to external SNMP monitoring tool and router output chain in firewall, issue started after router attempt to connect to 159.148.172.251:15252 via UDP (MikroTik cloud) - but the cloud feature is deactivated in the configuration since the very beginning.
This issue still exists - the issue is (thanks r00t for suggestion) the turned off cloud settings and time zone autodetect turned on:
Make sure you also disable "time zone autodetect" in System/Clock, otherwise router will still contact cloud for that.
Imho this configuration should not cause the (one core) CPU overload.
mikeeg02
Wed Nov 04, 2020 9:44 pm
deleted. Forgot a dependency
untersucher
Thu Nov 05, 2020 9:55 am
same here with hex PoE and 24HPOW in "auto on" poe-out mode. "forced on" poe-out works fine.
downgrading to 6.47.6 resolves the issue with the powering delay completely.
on the wire with tech support.
revan
Thu Nov 05, 2020 2:44 pm
I'm tired of asking to fix snmp in the 6.47 branch. This is how it works in the 6.46.8 branch:
snmpwalk -v 2c -c public 10.160.0.24 .1.3.6.1.2.1.31.1.1.1.1
IF-MIB::ifName.1 = STRING: ether1
IF-MIB::ifName.2 = STRING: ether2
IF-MIB::ifName.3 = STRING: ether3
IF-MIB::ifName.4 = STRING: ether4
IF-MIB::ifName.5 = STRING: ether5
IF-MIB::ifName.6 = STRING: sfp1
IF-MIB::ifName.7 = STRING: bridge
snmpwalk -v 2c -c public 10.160.0.24 .1.3.6.1.2.1.17.7.1.2.2.1.2
SNMPv2-SMI::mib-2.17.7.1.2.2.1.2.0.0.24.174.88.110.130 = INTEGER: 6
And this is how it works in 6.47.7:
SNMPv2-SMI::mib-2.17.7.1.2.2.1.2.0.0.24.174.88.110.130 = INTEGER: 5
Why the hell do several versions in the" stable " branch incorrectly give the mac-table?!
Why even in the latest Long Term 6.46.8 snmp works correctly?! Your left hand doesn't know what your right hand is doing?
stereomind
Fri Nov 06, 2020 8:47 pm
Will the webfig skin issue be addressed soon?
I'm unable to select skins on a hAP ac3. I can create them in webfig skin editor, and the file gets saved under the skins/ folder, but the new skin is not selectable under user group properties or skin editor. Default is still the only option.
Any hints?
Thank you!
Jotne
Fri Nov 06, 2020 10:24 pm
You have sent this to support?
MikroTik->Splunk
manish
Sun Nov 08, 2020 9:39 am
10G Links,
We had few 10G links with CCR, after upgrading all these went down randomly, SFP+ port 2, and they would not come back up, tried to roll back but no luck, changed SFP, finally did Hard reboot and the port came up.
StephaneC
Tue Nov 10, 2020 9:34 am
Perfect I was waiting so far for a stable update.
valemal
Wed Nov 11, 2020 5:01 pm
New firmware after device hAP ac reboot no longer detects SFP port.
nescafe2002
Forum Veteran
Forum Veteran
Wed Nov 11, 2020 6:35 pm
valemal, if you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device.
Maggiore81
Trainer
Trainer
Thu Nov 12, 2020 11:23 pm
I think that a lot of people ask on the forum, dont write to support (the only official contact), and threatens to migrate thousand of devices every time...
eventually they stick with MT because it is cheap and they cannot afford something more expensive... :D
Dr. Elia Spadoni
Network Administrator
MTCRE, MTCTCE, MTCINE, MTCWE, MTCSE, MikroTik Certified Trainer
Spadhausen Internet Provider
Ravenna, ITALY
https://www.spadhausen.com
pe1chl
Fri Nov 13, 2020 12:17 pm
Well, the point of these release topics is that people who experience new issues in a new release report them here so others
can read about it and MikroTik can gather information about the unexpected problems that larger groups of people get on upgrade.
What is the point when they do not read these topics and do not make their own support tickets for problems observed here but
not yet reported to support?
When everyone would report a common issue to the support system (where you cannot see eachothers tickets!) support would
be more heavily loaded because they need to join all those tickets in groups that are about the same issue, and inform everyone
about its status. The forum is a more efficient way of handling that. So would be a searchable ticket system like bugzilla.
vecernik87
Forum Veteran
Forum Veteran
Fri Nov 13, 2020 1:58 pm
I often ask on forum, when I suspect trouble but I am not sure. I don't want to bother support guys with every single issue because half of them are my fault. Feels like a common sense, right?
If you find me posting too many replies, I am either procrastinating on some really important task, or just drunk. Roll D20 to find out which one it is.
Maggiore81
Trainer
Trainer
Fri Nov 13, 2020 2:46 pm
Yes, I wasnt talking about you specifically, but in general about a lot of posts we see on the forum.
Dr. Elia Spadoni
Ravenna, ITALY
valemal
Fri Nov 13, 2020 10:26 pm
I also wrote in support and am waiting for an answer
narith2020
Mon Nov 16, 2020 10:25 am
After upgrade the firmware to 6.47.7, the wifi connection shows the sign padlock to all computers. The computers can access the Internet as normal, but the wifi printer cannot print, it shows printer offline. As I trust the Mikrotik I missed to backup the configuration. How can I downgrade to 6.47.4 (before upgrade)? My router is Mikrotik RB2011UiAS-2HnD
Is there anyone out there can help me on this? or I have to wait for the next firmware upgrade.
Thanks in advanced,2HnD
pe1chl
Mon Nov 16, 2020 11:09 am
Better find out what is going wrong with the printer. Maybe some WiFi option that has been set that it does not support.
It may help to update the printer.
Anyway, you can download 6.47.4 for your router (MIPSBE version), upload the file to the router, and then select "downgrade" under system->packages.
danunjaya123
Mon Nov 16, 2020 12:36 pm
10G Links,
Now links are up in New version or old version?
narith2020
Thu Nov 19, 2020 5:44 am
Thank you pe1chl,
Now I found the problem and fixed. After upgrade the wifi setting is automatic select the user access list (ACL), that caused of wifi connection to devices. I deselect it and it works now.
Thanks,
pachy
Fri Nov 20, 2020 8:22 am
Hi... no problem during 5 months in version 6.47, i updated ac2 to 6.47.7, intel computer and other devices (chrome cats,...) cannot connect in 5.8 .
If i downgrade to 6.47 again, it works...
I try to find something to change in te release note and on the fourm, but nothing seems to solve my problem...
I can stay in 6.47, i don't know if the issue is only in 6.47.7 or also in versions between 6.47 and 6.47.7
The ROS log was "received disassoc: sending station leaving (8)", i had looking for this in the forum, and i try forum's solutions :
- deactivate tkip in security profiles
- change "bridge port/learn=auto" to No and Yes
Nothing works...
regards
makstex
Wed Nov 25, 2020 6:29 am
Again the old problem got out.
There was a quick disconnect, all VPN tunnels were terminated,
but the IP addresses were not automatically deleted. I use l2tp
and OpenVPN. I waited about 5 minutes and removed it by hand,
since the router is in production.
m3trackboy
Wed Nov 25, 2020 8:35 pm
I've just upgraded to Version 6.47.7 and now can't login, username is admin and left password blank. Tried a reset but still no luck.
emils
Thu Nov 26, 2020 9:29 am
New version 6.47.8 has been released in stable RouterOS channel:
viewtopic.php?f=21&t=169553
Users browsing this forum: eworm and 7 guests
