emils
v6.49beta [testing] is released!
Wed Feb 03, 2021 2:48 pm
Version 6.49beta11 has been released.
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 6.49beta11 (2021-Feb-3 08:42):
Changes in this release:
*) chr - improved stability when changing "flow-control" settings on interfaces with e1000 drivers;
*) crs312 - fixed missing SwOS firmware on revision 2 devices;
*) crs3xx - fixed packet duplication when multiple bonding interfaces are created for CRS317, CRS309, CRS312, CRS326-24S+2Q+ and CRS354 devices;
*) crs3xx - fixed packet transmit in 5Gbps link rate for CRS312 device;
*) crs3xx - fixed port-isolation on bonding interfaces for CRS317, CRS309, CRS312, CRS326-24S+2Q+ and CRS354 devices;
*) crs3xx - fixed port-isolation on ether37-ether48 ports for CRS354 device;
*) crs3xx - improved LACP linking between CRS3xx series switches;
*) crs3xx - improved QSFP+ linking and mode changing for CRS326-24S+2Q+ and CRS354 devices;
*) crs3xx - improved load balancing on bonding interfaces for CRS317, CRS309, CRS312, CRS326-24S+2Q+ and CRS354 devices;
*) crs3xx - improved packet transmit on SFP+ interfaces;
*) crs3xx - improved system stability when bonding and IGMP snooping is used (introduced in v6.48);
*) defconf - fixed minor typo in configuration description;
*) dot1x - fixed "reject-vlan-id" for MAC authentication (introduced in v6.48);
*) dot1x - fixed MAC authentication fallback (introduced in v6.48);
*) ethernet - fixed cable-test for some devices (e.g. RB2011, RB951G-2HnD);
*) fastpath - fixed IP packet receive on bridge and bonding interfaces when destination MAC address match with slave port MAC;
*) hotspot - fixed "idle-timeout" usage with RADIUS authentication;
*) hotspot - fixed special character parsing in "target" variable (CVE-2021-3014);
*) ike2 - added support for ASN.1 DN "my-id" value setting for initiators;
*) ike2 - fixed EAP MSK length validation (introduced in v6.48);
*) ike2 - fixed phase 2 rekeying with enabled PFS (introduced in v6.48);
*) ike2 - improved stability when invalid certificate is configured (introduced in v6.48);
*) ike2 - properly register packet time after expensive CPU operations;
*) interface - fixed pwr-line interface linking (introduced in v6.48);
*) ipsec - improved stability when processing IPv6 packets larger than interface MTU;
*) led - fixed default LED configuration for RB911-5HnD;
*) netinstall - improved bootp packet handling on Linux netinstall-cli version when multiple NIC's are present;
*) ntp - use correct IPv6 multicast group for SNTP client;
*) package - always allow to uninstall package even if there is no free disk space left;
*) package - do not include multiple The Dude packages in HDD installer;
*) sfp - added "sfp-rate-select" setting (CLI only);
*) sfp - fixed GPON module linking (introduced in v6.47);
*) sfp - improved cable length monitoring as defined per SFF-8472 and SFF-8636;
*) snmp - fixed "send-trap" functionality (introduced in v6.48);
*) snmp - fixed SNMP trap agent address;
*) switch - fixed interface toggling for devices with multiple QCA8337, Atheros8327 or RTL8367 switch chips (introduced in v6.48);
*) switch - improved packet transmit between CPU and 98PX1012 for CCR2004-1G-12S+2XS device;
*) tr069-client - added "X_MIKROTIK_LinkDowns" parameter for interface "link-downs" value reporting;
*) upgrade - fixed free space checking on flash type memories when installing new packages;
*) webfig - fixed new interface addition;
*) winbox - do not show empty "CPU Frequency" parameter under "System/Resources" menu;
*) winbox - fixed enable/disable button presence for "Bridge/Hosts" menu;
*) winbox - renamed IP protocol 41 to "ipv6-encap";
*) wireless - renamed "macedonia" regulatory domain information to "north macedonia";
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as expected or after crash.
Paternot
Forum Veteran
Forum Veteran
Re: v6.49beta [testing] is released!
Wed Feb 03, 2021 2:55 pm
Wow! That's a big list of fixed bugs! Hope this version goes better than 6.48...
Kindis
Wed Feb 03, 2021 2:58 pm
Great news but is there a fix for the interface issues with 3011 in here but 3011 is not just mentioned in the changelog?
Edit: I'm just blind. It is this one!
sjoukes
Wed Feb 03, 2021 3:01 pm
The RB3011 has 2 QCA8337 chips.
markonen
Wed Feb 03, 2021 3:07 pm
This sounds like a fix to the CCR2004 packet loss issue. Would someone from Mikrotik like to give a bit more detail about what was done here? Thank you!
hatred
Wed Feb 03, 2021 3:36 pm
No fix for DoH memory leak yet?
Aerowinder
Wed Feb 03, 2021 3:37 pm
Can you elaborate on the packet loss issue? I have ~15 of these in service, but I didn't know about any packet loss issues. However, 6.48 did seem to resolve the issue that was causing my CCR2004s to reboot at random.
markonen
Wed Feb 03, 2021 3:49 pm
Here's the thread about it:
viewtopic.php?f=3&p=842145#p842145
Kindis
Wed Feb 03, 2021 4:00 pm
Also please MT update the Security blog
https://blog.mikrotik.com/security/
Either keep this blog up to date (which is not what is happening now) or shut it down.
shavenne
Wed Feb 03, 2021 4:04 pm
6.48 is the same as rc1 I guess? So this =>
Tried to update my switches at home (CRS112-8P-4S, CRS112-8G-4S, CRS309-1G-8S+, CRS328-24P-4S+) to 6.48beta40 yesterday (6.47.4 before).
For some reason all clients stopped getting IPv6 addresses from my RB4011 (with 7.1beta2) then.
I started downgrading the firmware on the CRS328-24P-4S+ (to which the RB4011 is also connected) and all clients connected to it were getting IPv6 addresses again.
I still had to downgrade the other switches too to obtain IPv6 there also.
I find it quite strange as I'm not using any routing or firewall functions on the switches. Actually just VLANs (all IPv6 clients are in a seperate vlan) and nothing else.
Any idea what's going wrong?
Tried the same with 6.48rc1 today. Still the same problem :(
Downgraded to 6.47.8 and it works again immediately.
will remain, right??
This is my config:
# dec/24/2020 14:59:11 by RouterOS 6.47.8
# software id = 76F0-EZPJ
# model = CRS328-24P-4S+
# serial number = A1A10A614FF6
add admin-mac=74:4D:28:D3:63:6B auto-mac=no comment=defconf igmp-snooping=yes \
    name=bridge vlan-filtering=yes
set [ find default-name=ether1 ] comment=pi.home
set [ find default-name=ether2 ] comment="Kamera Hof"
set [ find default-name=ether5 ] comment="Deep-Thought Intel-Karte"
set [ find default-name=ether6 ] comment=Slow-Thought
set [ find default-name=ether11 ] comment=TV
set [ find default-name=ether13 ] comment=HTPC
set [ find default-name=ether14 ] comment=AV-Receiver
set [ find default-name=ether22 ] comment="Freifunk Hotspot (Hof)"
set [ find default-name=ether23 ] comment=\
    "Unifi AP + plastikschleuder.home (RPi)"
set [ find default-name=ether24 ] comment="WAN LTE"
set [ find default-name=sfp-sfpplus1 ] comment="Zum Keller"
set [ find default-name=sfp-sfpplus2 ] comment="Deep-Thought 10G"
/ip hotspot profile
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,passw\
    ord,web,sniff,sensitive,api,romon,dude,tikapp"
add name=prometheus policy="read,winbox,api,!local,!telnet,!ssh,!ftp,!reboot,!wr\
    ite,!policy,!test,!password,!web,!sniff,!sensitive,!romon,!dude,!tikapp"
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=ether11
add bridge=bridge comment=defconf interface=ether12
add bridge=bridge comment=defconf interface=ether13
add bridge=bridge comment=defconf interface=ether14
add bridge=bridge comment=defconf interface=ether15
add bridge=bridge comment=defconf interface=ether16
add bridge=bridge comment=defconf interface=ether17
add bridge=bridge comment=defconf interface=ether18
add bridge=bridge comment=defconf interface=ether19
add bridge=bridge comment=defconf interface=ether20
add bridge=bridge comment=defconf interface=ether21
add bridge=bridge comment=defconf interface=ether22 pvid=31
add bridge=bridge comment=defconf interface=ether23
add bridge=bridge comment=defconf interface=ether24
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=sfp-sfpplus2
add bridge=bridge comment=defconf interface=sfp-sfpplus3
add bridge=bridge comment=defconf interface=sfp-sfpplus4
/interface bridge vlan
add bridge=bridge comment="IPv6 only" tagged=sfp-sfpplus1,ether5 vlan-ids=66
add bridge=bridge comment="WAN Freifunk" tagged=\
    sfp-sfpplus1,ether23,ether24,sfp-sfpplus2,ether13,ether10 vlan-ids=12
add bridge=bridge comment="Freifunk Hotspot" tagged=sfp-sfpplus1,ether5 \
    untagged=ether22 vlan-ids=31
add bridge=bridge comment=VoIP tagged=sfp-sfpplus1,ether23,ether24 vlan-ids=21
add bridge=bridge comment="WAN FTTH1" tagged=sfp-sfpplus1,ether17 vlan-ids=4001
add bridge=bridge comment="WAN FTTH2" tagged=sfp-sfpplus1,ether17 vlan-ids=4002
add bridge=bridge comment="WWW \FCber bridge-pi" tagged=sfp-sfpplus1,ether17 \
    vlan-ids=4050
add bridge=bridge comment="Freifunk Hotspot (Balkon)" tagged=\
    sfp-sfpplus1,ether5 vlan-ids=32
add bridge=bridge comment="IPv6 Pool 2" tagged=sfp-sfpplus1,ether5 vlan-ids=67
add bridge=bridge comment="WAN LTE" tagged=sfp-sfpplus1,ether24 vlan-ids=4010
add bridge=bridge comment=IceCC tagged=ether5,sfp-sfpplus1 vlan-ids=530
add address=192.168.90.7/24 interface=bridge network=192.168.90.0
set servers=192.168.90.1
add action=accept chain=output
add action=accept chain=input
add distance=1 gateway=192.168.90.1
/system clock
/system identity
set name=SW_WohnungOben
/system ntp client
set enabled=yes primary-ntp=62.108.36.235 secondary-ntp=46.165.221.137
/system package update
set channel=testing
/system routerboard settings
set boot-os=router-os
/system swos
set address-acquisition-mode=static allow-from-ports="p1,p2,p3,p4,p5,p6,p7,p8,p9\
    ,p10,p11,p12,p13,p14,p15,p16,p17,p18,p19,p20,p21,p22,p23,p24,p25,p26,p27,p28\
    " identity=SW_WohnungOben static-ip-address=192.168.90.7
(exported from v6.47.8)
Tested it now with the final 6.48. Problem still persists. Sniffed with wireshark now: The only packets I'm getting are the MNDP from my router.
Can somebody tell me if it's a bug or not? Or is it just working 'by accident' with old versions and I have misconfigured something?! Doesn't seem like that actually.
/edit: It begins to work again if I disable IGMP snooping. So something is wrong with IGMP/MLD snooping I guess??
Still the same problem. Posting this for .. 3 or 4 versions now?!
zelthian
Can't upgrade on my CRS312. Automatic and manual upgrade process results in the same error:
"installation of routeros-mipsbe-6.49beta11 failed: broken package"
emils
Wed Feb 03, 2021 4:20 pm
From which version are you trying to upgrade? Can you send a supout.rif file to support@mikrotik.com?
msatter
Wed Feb 03, 2021 4:45 pm
Many thanks. My IKEv2 download speed increased by over 100 Mbps to almost the maximum download speed I have. It was lower in 6.48 than the previous versions of ROS.
zelthian
Wed Feb 03, 2021 5:03 pm
I was running a version provided by support to fix the SwOS issue (6.49beta4). After downgrading to 6.47.8, the upgrade to 6.49beta11 succeeded.
mjezierski
Wed Feb 03, 2021 6:05 pm
I can confirm this particular issue is resolved on a CRS-210 mipsbe switch.
icsterm
Wed Feb 03, 2021 6:44 pm
I agree, I was also waiting for a DoH memory leak fix.
dannym
Wed Feb 03, 2021 7:08 pm
Same behavior on RB4011 like v6.48
Causing no port working, connects only through wifi.
6.46.8 works flawlessly and versions bellow
Jotne
Wed Feb 03, 2021 9:16 pm
I am waiting for a DoH memory fix for 6.48 not a new beta. Also waiting for 7.x release not a new 6.49beta
Fix what is broken before a sending out a new beta release for a new train.
This version does nearly not containing any new function, so why a new train.
List of new stuff???
BartoszP
Wed Feb 03, 2021 9:58 pm
Fixes for 6.48 probably are tested with 6.49 ...
Real admins use real keyboards.
To quote or not to quote, there is the topic: viewtopic.php?f=2&t=168474
nevolex
Wed Feb 03, 2021 10:55 pm
That's great guys, but maybe 6.50 can be the last 6.x ros and the development can be fully switched over to 7.x ?
thanks
Chupaka
Wed Feb 03, 2021 11:15 pm
Even v2.9.x had at least 2.9.51, so don't let v6.x stop at v6.50 :D
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
redskilldough
Thu Feb 04, 2021 1:17 am
Yes, I would think that this would have top priority, but it's still not fixed since it was introduced in 6.47
nevolex
Thu Feb 04, 2021 2:28 am
LOL, oh well let 6.50.1 happen then!
roshkovanv
Thu Feb 04, 2021 9:41 am
Same here, If I am enabling 'IGMP Snooping' my 'IGMP Proxy' behave strangely, randomly works only few of channels, after disabling 'IGMP Proxy' everything stat to work but flood all other ports... I've configured everything from the beginning, thought something is wrong with my configs.
I've tried almost any config combination from 'IGMP snooping' tab but nothing works flawless as few versions before...
server8
Thu Feb 04, 2021 10:30 am
Emils can you confirm that this fix helps to avoid packets loss on CCR2004?
thank You
kidi
Thu Feb 04, 2021 7:01 pm
whoopsie, i guess?
jumped back to 6.48 - everything is fine, jumped back to 6.49beta11 and i get this again
hAP lite
dadaniel
Thu Feb 04, 2021 9:26 pm
What GPON modules are supported as of now? The Mikrotik one is not available anymore?
Guscht
Fri Feb 05, 2021 12:51 am
Will be there no further V6.48.XX versions?
From the doomed V6.48 straight to V6.49?
Kindis
Fri Feb 05, 2021 9:32 am
I would guess we will get a 6.48.1 today.
mkx
Fri Feb 05, 2021 9:35 am
Yup. At around 16 hours EET (which is 14 hours UTC, do the maths for your own time zone yourselves).
nescafe2002
Forum Veteran
Forum Veteran
Fri Feb 05, 2021 11:10 am
Check the version numbering schema: https://wiki.mikrotik.com/wiki/Manual:U ... _numbering
Changes (fixes) from 6.49beta/rc can be merged to 6.48.x.
Mett
Thu Feb 11, 2021 11:12 am
This version broke pppoe dial in through my GPON-SFP on the RB4011.
mhugo
Sat Feb 13, 2021 12:11 am
After upgrading a 2004 to test for the packetloss issue we got issues with one of the links going up and down rapidly. The SFP with issue was original mikrotik bidi 1G but we had no issues with any of the 6 other ports all using FS.com optics 10 and 1G or a 10G DAC.
The only thing I noted was that this 1G port was the only one connected to another 2004 on 1G. The others are either 10G or to 10xx series. Other side is running 6.47.9.
It was not possible to generate supout from the system.
/Mikael
Mett
Sun Feb 14, 2021 10:23 am
Entering the command on CLI solves the problem:
/interface ethernet set sfp-sfpplus1 sfp-rate-select=low
bajodel
Long time Member
Long time Member
Tue Feb 16, 2021 5:25 am
Nice to know, but what does that setting really do?
In the mikrotik interface wiki I read:
sfp-rate-select (high | low; Default: high)	Allows to control rate select pin for SFP ports.
..witch is not really enough for me to understand
r00t
Tue Feb 16, 2021 3:02 pm
RATE SELECT is specific pin of the SFP slot interface that can be used to change operating rate of the SFP module.
Low/High are actual voltage levels Mikrotik sets this pin to.
If it actually does anything and what it does depends on the specific SFP.
So check your SFP module specification...
mikeeg02
Tue Feb 16, 2021 3:05 pm
What if your sfp module is a mikrotik?
I too am curious. I haven't seen anything in the documentation about this.
bajodel
Long time Member
Long time Member
Tue Feb 16, 2021 11:06 pm
Low/High are actual voltage levels ..[cut].. depends on the specific SFP.
Nice, thanx
yo3gjc
Thu Feb 18, 2021 7:34 pm
backup restore for RB450 is partially working. If reset to factory default than restore .bckup file is not preserving LAN IP, users and password. workaround after factory reset is to downgrade to 6.48, restore backup than going up to 6.49.11
OndrejHolas
Sat Feb 20, 2021 9:44 pm
According to this post viewtopic.php?t=172321#p842428 the version 6.49beta11 contains fix for SIP phone communication problems (Gigaset phones were heavily reported) that started after upgrade to 6.48, but I cannot find any relevant line in the changelog above. Could someone from inside explain here, what is the exact cause of the problem and how it was fixed in 6.49? Thanks.
We have several Gigaset IP bases and I tried in lab some of them (A540, A690) with 6.48 on many routers (750GL, 951G, 941, 2011, 3011), using different sets of discovery protocols enabled and everything in lab worked well with 6.48 in all tested situations. I'd like to know what exact combinations are problematic, otherwise we need to stay at 6.47.x. The advice to disable MNDP seems weird to me, since MNDP uses UDP port 5678, that is not used by affected IP phones and should be silently ignored, so I cannot imagine how it can disrupt communication with the phone.
Ondrej
EdPa
Mon Feb 22, 2021 9:23 am
The reported SIP phone issue is fixed with this change:
The suggestion to disable MNDP is because in the 6.48 version MNDP had some changes and it now uses an individual slave port MAC address instead of bridge/bond MAC. The same thing is done with other neighbor protocols, but MNDP is the only one that uses IP packets. It turns out, this can affect the ARP table on certain devices and they might start to use this other MAC from MNDP as a destination. On the RouterOS side with an active bridge/bond fast-path, these packets were dropped.
You might not notice the issue because MNDP is sent only once in a minute, the bridge did not use a fast-path or your phone simply ignored the MNDP.
OndrejHolas
Mon Feb 22, 2021 10:01 am
Thanks EdPa, I appreciate your detailed answer. Now the conditions of the problem are clear and the mechanism makes sense. I haven't yet observed those communication drops due to the active hardware acceleration (all bridges I've tried so far were running inside switchchips with HW accel left on), which effectively disables fast path on the bridge.
Ondrej
gsbiz
Mon Feb 22, 2021 2:34 pm
+1 on the DoH memory leak. The reality is that should be called as a CVE. Mikrotik RouterOS v6.47+ "DNS Request flood causes cache overflow and DNS server failure, if DoH is enabled" Status=Current.
Users browsing this forum: Kindis and 19 guests
