Are you planning to add the ability to subscribe and not only publish?MQTT documentation: https://help.mikrotik.com/docs/display/ROS/MQTT
very nice!...are there any plans for enabling a MQTT action type for logging events?MQTT documentation: https://help.mikrotik.com/docs/display/ROS/MQTT
same hereLooks like advanced-tools package for arm is broken...
I cannot confirm. Looks pretty good on my end.RB4011iGS+5HacQ2HnD-IN = installation of advanced-tools-6.48.3 failed: broken package
Looks a lot better now. Thanks!Advanced-tools package for ARM should be fixed now. Please try upgrading again.
Should be fixed by now as well.Oh, please fix all_packages-arm-6.48.3.zip with the new file. Thanks!
It's like discovering that your front door can be opened in a few minutes with the right lockpick,Kindis, what is missing from the blog? All serious security issues are in there.
We will add Frag, but in my opinion, it is not serious at all.
I have also confirmed doing an upgrade on both my hAPac2's from 6.47.9 to 6.48.3 that advanced tools in the standard package is installed ok on both units and the same advanced tools on 6.48.3 on my RB3011-UiAS-RM is installed ok, no errors.I cannot confirm. Looks pretty good on my end.RB4011iGS+5HacQ2HnD-IN = installation of advanced-tools-6.48.3 failed: broken package
Well it is up to you but I follow many vendors and I do not really care if the risk is low to high but I would like an update to see if a security update has been deployed.Kindis, what is missing from the blog? All serious security issues are in there.
So here is the thing. I do not care where the problem comes from I care when it affects me. In this case the vulnerabilities are both design errors but also implementation with is on MT not design.It's like discovering that your front door can be opened in a few minutes with the right lockpick,Kindis, what is missing from the blog? All serious security issues are in there.
or it's like putting a security door in the main entrance and leaving a "simple" glass door in the back ...
Is NOT MikroTik problem...
Here we are in full agreement. The issues are not that bad at all, especially the design issues. Have not heard how exploits of implementations issue are progressing but those are more serious but still low in risk.I'm not good at explaining, English is not my mother language.
What I wanted to explain is that these so-called vulnerabilities are nonsense in comparison to other past and actual problems.
(Non-RouterOS related)
Ok works now. Thx.Advanced-tools package for ARM should be fixed now. Please try upgrading again.
21:32:53 system,error,critical router was rebooted without proper shutdown by watchdog timer
SEEMS HAVING BEEN A DOA RB912!RB912 r3 w LTE
Upgrade from default 6.45.9 to 6.48.3, change SIM slot: LTE gone.
Reset to default config -> change SIM slot: gone LTE
Dwongrade to 6.48.2: fine again!
My CAP AC got bricked as well. Situation: CRS328-24P-4S+ with a few CAPs connected and one CAP ac. Upgraded and reboot the CRS328 to 48.3 --> OK. After reboot CAPs came alive, however CAP ac kept missing. What I see in the CR328 log: CAP ac eth port interface goes up, connect 1GBps, and after exactly 40 seconds interface down, and it starts over again and again. On the CAP ac , power on led and user led are on, eth1 blinking, no wifi activity at all (LEDs are off, no wireless network advertised). Tried to reset the CAP ac, first in CAPSMAN mode (power off, power on and immediately push reset for 10 sec (hold while blinking, release when solid green led), and because nothing changed also to default settings (immediately after power on hold reset button, release when blinking). Nothing happens! The CAP ac keeps showing same behaviour, no wireless activity at all. Please advice on next steps.This totally bricked my cAP AC. Not even Netinstall can save it!
It was running on 6.48 (february release), just like the switch . The CAP ac was running in CAPSMAN mode, so I don't have a config for the CAP ac. It is directly connected to the switch. I'm gonna try netinstallWhat version were you running before? Do you have your configuration backup by any chance? Can you describe the configuration? You will have to try to reinstall the device using Netinstall utility to bring it back. Try installing an older version instead of 6.48.3.
You are referencing RBcAPGi-5acD2nD here? I am running tree of these (with different age) and all did upgrade to 6.48.3 without issues.meensb could you please check your CAPsMAN logs if cAP ac joined it after the upgrade to 6.48.3?
If anyone else has experienced an issue with cAP ac not booting after the update to 6.48.3 please write to support.
https://mikrotik.com/support
Same here. I have 4 of these and they all upgraded without issues and 2 of them where upgraded when this was released and they all are stable so far.You are referencing RBcAPGi-5acD2nD here? I am running tree of these (with different age) and all did upgrade to 6.48.3 without issues.meensb could you please check your CAPsMAN logs if cAP ac joined it after the upgrade to 6.48.3?
After a few tries I was able to flash routeros-arm-6.48.3 onto the cap ac using netinstall. It now works as expected! Thanks!It was running on 6.48 (february release), just like the switch . The CAP ac was running in CAPSMAN mode, so I don't have a config for the CAP ac. It is directly connected to the switch. I'm gonna try netinstallWhat version were you running before? Do you have your configuration backup by any chance? Can you describe the configuration? You will have to try to reinstall the device using Netinstall utility to bring it back. Try installing an older version instead of 6.48.3.
I don't have the log available anymore as I rebooted the cr s328 switch several times but I'm sure it was missing in the logs. Unlike the CAPs , the CAP AC didn't generate a [xxxxx] joined, provides radio(s):[yyyyyyy] statement in the log.meensb could you please check your CAPsMAN logs if cAP ac joined it after the upgrade to 6.48.3?
Fine, but I'm wondering...The issues are not that bad at all, especially the design issues. Have not heard how exploits of implementations issue are progressing ......these so-called vulnerabilities are nonsense in comparison to other past and actual problems.
minor problem ipv6 nd reachable time (this also happen in previous version)
[admin@router] /ipv6 nd> set 0 reachable-time=30ms
Warning: value of value was rounded down to 0s
Yup can confirm its cosmetics error at winbox and web interfaceminor problem ipv6 nd reachable time (this also happen in previous version)
Seems to me that it's (esthetic) problem of winbox ... on my 6.47.9 default setting is "unspecified" and if I try to set it to "30ms", I get
Code: Select all[admin@router] /ipv6 nd> set 0 reachable-time=30ms Warning: value of value was rounded down to 0s
You can try to set it via command line and see if you can actually set it to milliseconds and if yes, what does winbox then display.
You must work in the documentation department:)I'm not good at explaining, English is not my mother language.
Works fine here!I am not able to login to webfig on Firefox. Anyone else with the same problem?
30ms for RA lifetime?????? That does not seem sane.minor problem ipv6 nd reachable time (this also happen in previous version)
But 30ms really seems to be over the top for this value.
I confused reachable time and lifetime... still, a unit of seconds seems to be reasonable for this time.Screenshot in post #51 above shows winbox UI displaying "ms" as unit for that field.
I have not - I would suggest creating a new thread and posting your cap and capsman configs along with a brief network layout so this can be looked at by others.Not so much a stability issue per se, but I have had issues with CAPsMAN and hAPac2's maintaining stable connections with drop outs happening every ~10 to 15mins, this has been a problem for the last few releases.
Anyone else seen similar issues?
As soon as I get a chance to i'll pull configs from the hAPac2's (theyre essentially the same bar hostname and IP address) and post my CAPsMAN config. At the moment everythings working fine with the 6.46.8 on the hAPac2's. I might pull supout's from them running both the current stable and the older long term release and see if thats of any help to the Mikrotik community.I have not - I would suggest creating a new thread and posting your cap and capsman configs along with a brief network layout so this can be looked at by others.Not so much a stability issue per se, but I have had issues with CAPsMAN and hAPac2's maintaining stable connections with drop outs happening every ~10 to 15mins, this has been a problem for the last few releases.
Yes, for some reason FFox becomes picky with some specific devices and doesn't log in anymore. With Chrome or FFox "Private Window" no problems.I am not able to login to webfig on Firefox. Anyone else with the same problem?
# jun/03/2021 18:28:53 by RouterOS 6.48.3
# model = RBcAPGi-5acD2nD
set 0 default-vlan-id=1 vlan-mode=secure
set 2 default-vlan-id=0 vlan-mode=secure
add name=local-eth-secure
/interface wireless
# managed by CAPsMAN
# channel: 2452/20/gn(15dBm), SSID: test, local forwarding
set [ find default-name=wlan1 ] ampdu-priorities=0,1,2,3,4,5,6,7 \
antenna-gain=5 band=2ghz-onlyn bridge-mode=disabled country=greece \
disabled=no frequency=2452 mode=ap-bridge radio-name=test-ap-1 \
rate-set=configured scan-list=2412-2484 security-profile=test-iot \
ssid=test-iot station-roaming=enabled supported-rates-a/g=\
6Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=1Mbps vlan-id=15 vlan-mode=\
use-tag wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
# SSID: test-guest, local forwarding
add disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wlan1 name=\
wlan2 security-profile=test-guest ssid=test-guest vlan-id=14 \
vlan-mode=use-tag wps-mode=disabled
# channel: 5180/20-Ceee/ac/P(23dBm), SSID: test5, local forwarding
set [ find default-name=wlan2 ] ampdu-priorities=0,1,2,3,4,5,6,7 \
antenna-gain=0 band=5ghz-n/ac bridge-mode=disabled channel-width=\
20/40/80mhz-Ceee country=no_country_set disabled=no installation=indoor \
mode=ap-bridge name=wlan2-5 radio-name=test-ap-1 scan-list=5200-5900 \
security-profile=test ssid=test5 station-roaming=enabled \
tx-power-mode=all-rates-fixed vlan-mode=use-tag wireless-protocol=802.11 \
# SSID: test-iot, local forwarding
add default-forwarding=no disabled=no mac-address=XX:XX:XX:XX:XX:XX \
master-interface=wlan1 name=wlan3 security-profile=test-iot ssid=\
test-iot vlan-id=15 vlan-mode=use-tag wps-mode=disabled
add mac-address=XX:XX:XX:XX:XX:XX master-interface=wlan1 name=wlan4 \
security-profile=test-iot ssid=test-iot1 vlan-id=15 vlan-mode=\
add mac-address=XX:XX:XX:XX:XX:XX master-interface=wlan1 name=wlan5 \
security-profile=test-iot ssid=test-iot1 vlan-id=15 wps-mode=\
disabled
/interface wireless nstreme
set wlan1 enable-polling=no
set wlan2-5 enable-polling=no
add independent-learning=no ports=ether1,switch1-cpu switch=switch1 vlan-id=1
add independent-learning=no ports=ether1,switch1-cpu switch=switch1 vlan-id=\
14
15
add interface=ether2 list=local-eth-secure
add interface=vlan1 list=local-eth-secure
/interface wireless cap
set caps-man-addresses=192.168.0.1 certificate=request enabled=yes \
interfaces=wlan1,wlan2-5 lock-to-caps-man=yes static-virtual=yes
add address=192.168.0.6/24 interface=vlan1 network=192.168.0.0
set servers=192.168.0.1
/ip firewall address-list
add address=192.168.0.0/24 list=test
add action=fasttrack-connection chain=forward connection-state=\
established,related
add action=accept chain=forward connection-state=established,related
/ip firewall mangle
add action=set-priority chain=postrouting comment="Set priority for WMM" \
new-priority=from-dscp-high-3-bits passthrough=yes
add distance=1 gateway=192.168.0.1
add disabled=yes distance=1 dst-address=192.168.49.0/32 gateway=vlan14
add disabled=yes distance=1 dst-address=192.168.50.0/24 gateway=vlan15
It could also be caused by the recent changes to Firefox "to prevent unwanted tracking" etc. I have also seen discussions about people no longer being able to use their bank website recently, and it may well be that some websites are misdetected and stuff is blocked that really should not be.Yes, for some reason FFox becomes picky with some specific devices and doesn't log in anymore. With Chrome or FFox "Private Window" no problems.I am not able to login to webfig on Firefox. Anyone else with the same problem?
I can login with FFox in other same model devices.
The problem isn't specific to v6.48, I've had it since some releases ago (I checked it now on a CHR v6.47.9).
I suspect some CSS/JS caching issue. I've made some cache cleanup (FFox "forget about this site") but the problem remains.
I'm using Firefox 78.10.0esr (with AdBlock), and didn't see any problems. You may well be right about it.It could also be caused by the recent changes to Firefox "to prevent unwanted tracking" etc. I have also seen discussions about people no longer being able to use their bank website recently, and it may well be that some websites are misdetected and stuff is blocked that really should not be.
Try what happens on another computer, preferably with an older Firefox version (e.g. ESR version).
When that fixes it, consider reporting the bug to Firefox maintainers.
management 2 29.5%
unclassified 2 65.5%
/iot mqtt brokers
add address=91.109.xx.yy client-id=jLtAP-LTE6 name=xxy.yzz.org password=XXyyZZxx username=rosXXyZ
:global trackerisrunning
:global trackerfailcount
:if ([:typeof $trackerisrunning]="nothing") do={
:set trackerisrunning false
:if ([:typeof $trackerfailcount]="nothing") do={
:set trackerfailcount 0
# might not be running after all \o/
:if ($trackerfailcount>10) do={
:log info "tracker failed too much to be honest with me, restarting it"
if ($trackerisrunning = false) do={
:set $trackerisrunning true
:global gpsts
:global gpslat
:global gpslon
:global gpsalt
:global gpsspd
:global gpsbdst
:global gpsbtru
:global gpsbmag
:global gpsval
:global gpssats
:global gpsqual
:global gpshdop
/system gps monitor once do={
:set $gpsts $("date-and-time")
:set $gpslat $("latitude")
:set $gpslon $("longitude")
:set $gpsalt [:pick $("altitude") 0 [:find $("altitude") "m"]]
:set $gpsspd [:pick $("speed") 0 [:find $("speed") " "]]
:set $gpsbdst [:pick $("destination-bearing") 0 [:find $("destination-bearing") " "]]
:set $gpsbtru [:pick $("true-bearing") 0 [:find $("true-bearing") " "]]
:set $gpsbmag [:pick $("magnetic-bearing") 0 [:find $("magnetic-bearing") " "]]
:set $gpsval $("valid")
:set $gpssats $("satellites")
:set $gpsqual $("fix-quality")
:set $gpshdop $("horizontal-dilution")
:if ($gpsval = true) do={
:global gpsmqttdata
:set gpsmqttdata ("{\"ts\":\"" . $gpsts . " GMT\", \"lat\":" . $gpslat . ", \"lon\":" . $gpslon . ", \"alt\":" . $gpsalt . ", \"spd\":" . $gpsspd . ", \"bdst\":\"" . $gpsbdst . "\", \"btru\":\"" . $gpsbtru . "\", \"bmag\":" . $gpsbmag . ", \"sats\":" . $gpssats . ", \"qual\":" . $gpsqual . ", \"hdop\":" . $gpshdop . "}")
/iot mqtt publish broker=xxy.yzz.org topic=lte6track message=$gpsmqttdata
# :log info "lte6track via mqtt sent: $gpsmqttdata"
} else={
:global gpsmqttdata
:set gpsmqttdata ("{\"ts\":\"" . $gpsts . " GMT\", \"msg\":\"nofix\"}")
# :log info "lte6track via mqtt not sent, no GPS fix"
} else={
:log info "lte6track already running"
:set trackerfailcount ($trackerfailcount+1)
Yes, I observe something like this. Only a small CAPsMAN network with 3 APs and two of them being hAPac2. To me it feels I only have that issue since 6.48.3 really but not absolutely sure. I also changed something else recently and I have difficulties to find out what's happening. The devices are losing connections and get them back sometimes only after a noticable interruption.Have others had the problem? I have two hAPac2 units configured with CAPsMAN and found the problem on both, resolving it with 6.46.8 on the hAPac2's, the main CAPsMAN / gateway software version doesnt seem to affect it, currently running 6.48.3 on (originally a an RB750Gr3 now a RB3011-UiAS-RM) even running 7.1beta6 with the hAPac2's on 6.46.8 ran perfectly stable for the CAPs.
set allow-remote-requests=yes cache-max-ttl=5m cache-size=8192KiB max-udp-packet-size=2048 use-doh-server=https://dns.google/dns-query verify-doh-cert=yes
/ip dns static
add address=8.8.8.8 name=dns.google
add address=8.8.4.4 name=dns.google
verify-doh-cert=no...
Yes, I brought the config above.verify-doh-cert=no
you trust dns.google, not?
I live in Russia, the provider sticks its nose where it is not necessary.Please, you can explain why you use DoH? Thanks.
Thx. But it is not clear to me how memory leaks should depend on the DNS used.
Ok, but probably you gain attention when you try to circumvent this, than leave the things as-is...I live in Russia, the provider sticks its nose where it is not necessary.
No, I haven't tried it, but I would like to use all the available functionality, including control.>>>Yes, I brought the config above.
sorry, I'm explain better, have you try verify-doh-cert=no?
Yes, in general, no, this is normal https, I just want to protect against spoofing.Ok, but propably you gain attention when you try to circumvent this, than leave the things as-is...I live in Russia, the provider sticks its nose where it is not necessary.
If I work for K-_ the first thing I search are users than try to circumvent this.... guaranted!
It's like here on Italy...You shouldn't think that smart people work in this department. They are trying to shift everything to providers.
Finally. After many months of having to use scripts to disable/wait 2seconds/enable SFP port to work around link establishment/MTU issues this is very welcome.*) rb4011 - fixed SFP+ port MTU setting after link state change;
*) rb4011 - improved SFP+ port stability after boot-up
I have RB2011 (the one with wifi) and I don't have this issue. I think I posted in the last stable thread as well. I'm at 13 days uptime and still sitting around 97mb of used memory according to winbox (it's right around that after reboot). I have mind set up with Cloudflare using DoH with verify on. My config is pretty basic. Basically just defaults with small tweaks to the firewall (just disabling rules to make it even more restrictive) and wifi settings. Also have strict RP filtering enabled. The only other difference is I'm using the extra NTP package not the built in SNTP.DoH causes memory leak!
I also checked versions 6.47.9, 6.47.10 - the same thing.
Checked for rb2011 and rb951G.
I tried to change the cache and TTL parameters - it does not help.
Code: Select all/ip dns set allow-remote-requests=yes cache-max-ttl=5m cache-size=8192KiB max-udp-packet-size=2048 use-doh-server=https://dns.google/dns-query verify-doh-cert=yes /ip dns static add address=8.8.8.8 name=dns.google add address=8.8.4.4 name=dns.google
So far I solved the problem like this: verify-doh-cert = no---skip---
Still suffering here. Meanwhile I have some indications what happens but still not why.That makes four of us as I have described in an earlier post within this thread, probably since the cAP AC shares the same architecture & CPU with hAP ac2 ... By the way, the Mikrotik support ticket I have opened is SUP-51317
Exactly the same as in my case, which I described in a post earlier! The ARM unit (cAP AC) keeps on disconnecting from CAPSMAN whereas the MIPS one (cAP Lite) is, by far, stable!Still suffering here. Meanwhile I have some indications what happens but still not why.That makes four of us as I have described in an earlier post within this thread, probably since the cAP AC shares the same architecture & CPU with hAP ac2 ... By the way, the Mikrotik support ticket I have opened is SUP-51317
Currently it also seems it just affects one of my two hAP ac2. That one loses connection to CAPsMAN (RB2011) quite often as I can see from the log.
"CAP sent max keepalives without response" -> disconnects, selects, trying to connect, fail to connect a a few times before finally joining again
I just have no explanation to why that could happen. I just know it started quite recently (therefore might be version specific) and that the physical connection between that hAP and CAPsMAN is more or less the most important wire (let's call it the "backbone" in the house) because it bundles almost all traffic. In addition the machine I'm working on all day is connected with a cable to that hAP and I do not see any connectivity issues from there.
Fun fact, the other CAP also runs via cable through the failing one to reach CAPsMAN and seems stable.
Still puzzled.
Just read your earlier posts and you mentioned massive resource consumption (which I cannot see directly; maybe it only happens quickly shortly before it dies) and unexpected reboots. I do not see those. All what I can find in the CAP logs is that it runs into timeouts, closes the connection, tries to reconnect which typically fails a few times before it eventually works again.Exactly the same as in my case, which I described in a post earlier! The ARM unit (cAP AC) keeps on disconnecting from CAPSMAN whereas the MIPS one (cAP Lite) is, by far, stable!
I assume that the memory consumption observed is directly linked with the continuous (every 15-20 minutes or so) disconnections with the CAPSMAN manager. This in turns generates some kind of memory links in the ARM unit, which grinds it to a halt with kernel panic messages. I might be wrong but it is a direct relation, CAPSMAN disconnections with increasing memory consumption (CPU stays low)... OR, some kind of bug/memory leak causes the CAPSMAN disconnections.. if I wanted to bet, I'd bet on the first assumption (CAPSMAN disconnections -> memory leak -> autoreboot of device)...Just read your earlier posts and you mentioned massive resource consumption (which I cannot see directly; maybe it only happens quickly shortly before it dies) and unexpected reboots. I do not see those. All what I can find in the CAP logs is that it runs into timeouts, closes the connection, tries to reconnect which typically fails a few times before it eventually works again.Exactly the same as in my case, which I described in a post earlier! The ARM unit (cAP AC) keeps on disconnecting from CAPSMAN whereas the MIPS one (cAP Lite) is, by far, stable!
But still it's probably similar enough. Others seem to have downgraded to 6.47.latest. I might try the same and hope that everything works with CAPsMAN still on 6.48.3
12:53:11 dhcp,info Internet assigned 10.65.193.219 to D4:CA:6D:55:11:09
12:53:26 system,info,account user admin logged out from 10.0.13.101 via telnet
13:01:02 system,info,account user admin logged out from 10.0.13.101 via winbox
13:04:06 lte,async,event lte1: +CPAS: 2
13:04:07 lte,async,event lte1: +CIREPI: 0
13:04:07 lte,async,event lte1: *COPN:0,Orange
13:04:07 lte,async,event lte1: *COPN:1,Orange
13:04:07 lte,async,event lte1: +ZNITZ: 2021,06,15,13,04,07,32,0
13:04:07 lte,async,event lte1: +NITZ: 1,+8,21/06/15,11:04:07
13:04:07 lte,async,event lte1: +CIREPI: 1
13:04:07 lte,async,event lte1: +CPAS: 0
13:04:08 lte,async,event lte1: *COPN:0,Orange
13:04:08 lte,async,event lte1: *COPN:1,Orange
13:04:08 lte,async,event lte1: +ZNITZ: 2021,06,15,13,04,08,32,0
13:04:08 lte,async,event lte1: +NITZ: 1,+8,21/06/15,11:04:08
13:14:45 lte,async,event lte1: +CPAS: 2
13:14:46 lte,async,event lte1: +CIREPI: 0
13:14:46 lte,async,event lte1: *COPN:0,Orange
13:14:46 lte,async,event lte1: *COPN:1,Orange
13:14:46 lte,async,event lte1: +ZNITZ: 2021,06,15,13,14,46,32,0
13:14:46 lte,async,event lte1: +NITZ: 1,+8,21/06/15,11:14:46
13:14:46 lte,async,event lte1: +CIREPI: 1
13:14:46 lte,async,event lte1: +CPAS: 0
13:14:47 lte,async,event lte1: *COPN:0,Orange
13:14:47 lte,async,event lte1: *COPN:1,Orange
13:14:47 lte,async,event lte1: +ZNITZ: 2021,06,15,13,14,48,32,0
13:14:47 lte,async,event lte1: +NITZ: 1,+8,21/06/15,11:14:48
13:15:25 lte,async,event lte1: *COPN:0,Orange
13:15:25 lte,async,event lte1: *COPN:1,Orange
13:15:25 lte,async,event lte1: +ZNITZ: 2021,06,15,13,15,25,32,0
13:15:25 lte,async,event lte1: +NITZ: 1,+8,21/06/15,11:15:25
13:15:26 lte,async,event lte1: *COPN:0,Orange
13:15:26 lte,async,event lte1: *COPN:1,Orange
13:15:26 lte,async,event lte1: +ZNITZ: 2021,06,15,13,15,26,32,0
13:15:26 lte,async,event lte1: +NITZ: 1,+8,21/06/15,11:15:26
13:25:05 lte,async,event lte1: +CPAS: 2
13:25:06 lte,async,event lte1: *COPN:0,Orange
13:25:06 lte,async,event lte1: *COPN:1,Orange
13:25:06 lte,async,event lte1: +ZNITZ: 2021,06,15,13,25,06,32,0
13:25:06 lte,async,event lte1: +NITZ: 1,+8,21/06/15,11:25:06
13:25:06 lte,async,event lte1: +CIREPI: 1
13:25:06 lte,async,event lte1: +CPAS: 0
13:25:30 lte,async,event lte1: *COPN:0,Orange
13:25:30 lte,async,event lte1: *COPN:1,Orange
13:25:30 lte,async,event lte1: +ZNITZ: 2021,06,15,13,25,30,32,0
13:25:30 lte,async,event lte1: +NITZ: 1,+8,21/06/15,11:25:30
13:27:03 lte,async,event lte1: +CPAS: 2
13:27:04 lte,async,event lte1: +CIREPI: 0
13:27:11 lte,info lte1: not registred, state: 0
13:28:11 lte,error failed to register on network
13:28:11 lte,account lte1 session: 2101s 69592135/25829482 bytes 66827/52948 packets
13:28:11 lte,async lte1: sent AT+CFUN=4
13:28:11 interface,info lte1 link down
13:28:11 dhcp,info dhcp deassigned 10.65.193.219 from D4:CA:6D:55:11:09
13:28:11 lte,async,event lte1: +CGEV: ME DETACH
13:28:11 lte,async,event lte1: +CGEV: NW PDN DEACT 5
13:28:11 lte,async,event lte1: +CPAS: 5
13:28:11 lte,async lte1: rcvd OK
13:28:11 lte,async lte1: sent AT+EEMOPT=1
13:28:11 lte,async,event lte1: *RADIOPOWER: 0
13:28:11 lte,async lte1: sent AT*MRD_SN?
13:28:11 lte,async lte1: rcvd *MRD_SN:AE39039ECE8F
13:28:11 lte,async lte1: sent AT+CPIN?
13:28:11 lte,async lte1: rcvd +CPIN: READY
13:28:15 lte,async lte1: sent AT+CPMS="SM","SM","SM"
13:28:15 lte,async lte1: rcvd +CPMS: 10,25,10,25,10,25
13:28:15 lte,async lte1: sent AT+CFUN?
13:28:15 lte,async lte1: rcvd +CFUN: 4
13:28:15 lte,async lte1: sent AT*ICCID?
13:28:15 lte,async lte1: rcvd *ICCID: 8948032152116734560
13:28:15 lte,async lte1: sent AT+CNUM
13:28:15 lte,async lte1: sent AT+CIMI
13:28:15 lte,async lte1: rcvd 260032111673456
13:28:15 lte,async lte1: sent AT+CPIN?
13:28:16 lte,async lte1: rcvd +CPIN: READY
13:28:16 lte,async lte1: sent AT*BAND?
13:28:16 lte,async lte1: rcvd *BAND: 5, 78, 147, 480, 50923735, 0, 2, 2, 0
13:28:16 lte,async lte1: sent AT*BAND=5,78,147,480,50923735,0,2,0
13:28:16 lte,async lte1: rcvd OK
13:28:16 lte,async lte1: sent AT*lteband=3,7,1,20,12,17,2,25,26,5,8,38,41,40,39
13:28:17 lte,async lte1: sent AT+ZGDCONT=5,"IP","internet",0
13:28:17 lte,async lte1: rcvd OK
13:28:17 lte,async lte1: sent AT+ZGPCOAUTH=5,"","",0
13:28:17 lte,async lte1: sent AT+COPS=0
13:28:17 lte,async lte1: sent AT+COPS=3,0
13:28:17 lte,async lte1: sent AT+CFUN=1
13:28:17 lte,async,event lte1: +CPAS: 2
13:28:17 lte,debug lte1: config ok
13:28:17 lte,async,event lte1: *RADIOPOWER: 1
[admin@LHG] > /interface lte print
0 R name="lte1" mtu=1500 mac-address=AC:50:43:1A:EE:FD pin="****"
apn-profiles=Internet allow-roaming=no network-mode=lte
Remember that the same RouterOS is also used on other router models that do not have wireless, you can choose to not install it.It is weird. First time have seen a WiFi router/bridge which is not updating the wireless section and is putting it as an extra.
Maybe:I see a some issues with scripts that are launched by scheduler. Log is showing "not enough permissions".
*) console - require "write+ftp" permissions for exporting configuration to file;
Yes, I checked that. All my scripts have already ( by default anyhow) all permissions, including write and ftp.Maybe:I see a some issues with scripts that are launched by scheduler. Log is showing "not enough permissions".*) console - require "write+ftp" permissions for exporting configuration to file;
I would say the programmer assigned to the DNS resolver is not the best.I had a strange issue tonight. All DNS resolving stopped.
Have a look at this: viewtopic.php?f=7&t=176086Silently removed 66960 Mhz channel support. Why?
No info in the changelog just nothing :-(
Create an interface list and add the interface you want to enable discovery on to the list. Then select the interface list under neighbor discovery.hello, can anyone tell me how to enable discovery on only one interface in the new version if all interfaces are static?
/interface list add name=example-list
/interface list member add list=example-list interface=ether5
/ip neighbor discovery-settings set discover-interface-list=example-list
Sure, on my own routers. But I tend to not hack myself.@eworm you are an authenticated remote user? :P
