normis
Newsletter 62
Mon Oct 27, 2014 9:40 am
Newsletter is here!
Some exciting topics:
• cAP2n
• RB850Gx2
• Radome for mANT
• FTC
• RB911G-5HPacD
• MUM
http://download2.mikrotik.com/news/news_62.pdf
java016
Re: Newsletter 62
Mon Oct 27, 2014 12:39 pm
cAP 2n looks sweet.
Just curious about the possibility of switching off and on the leds of signal and power to completely blend with the environment?
doneware
Trainer
Trainer
Re: Newsletter 62
Mon Oct 27, 2014 1:29 pm
cAP 2n looks sweet.
would it have an extra mpcie slot for a second radio... it would look a lot sweeter :-)
btw: what happened in Bucharest? i'm dead curious about those "*) Never before seen hardware announcements"
#TR0359
normis
Re: Newsletter 62
Mon Oct 27, 2014 1:37 pm
Not sure where you saw that, but we anounced a few new CRS models
normis
Re: Newsletter 62
Mon Oct 27, 2014 1:39 pm
cAP 2n looks sweet.
ALL leds can be customized, or turned off. the leds are a very weak green color, not very annoying :)
java016
Re: Newsletter 62
Mon Oct 27, 2014 4:23 pm
cAP 2n looks sweet.
As normis just mentioned annoying, is here some body to whom blue laser diode on RB1100AHx2 is also very eye burning? :shock:
honzam
Re: Newsletter 62
Mon Oct 27, 2014 5:21 pm
cAP 2n looks sweet.
+1
LAN, FTTx, Wireless. ISP operator
doneware
Trainer
Trainer
Re: Newsletter 62
Mon Oct 27, 2014 6:56 pm
got it straight from the HQ via email :-)
We would like to remind you that the first ever MikroTik User Meeting in Romania is only two weeks away - October 21, Bucharest!
http://mum.mikrotik.com/2014/RO/info
The official MUM Romania language will be Romanian.
Registration is FREE! Also, we will provide FREE wireless AP to ALL currently registered participants and the next 50 attendees to register. You will receive the product at registration -- you must attend the MUM to receive it. Hurry up and register now to get Your FREE Wireless AP:
http://mum.mikrotik.com/register.php?section=73
*) Free Wireless AP to attendees
*) Exhibitors showing antennas and routers!
*) Case studies and presentations by long time RouterOS experts
*) Lottery and Evening drinks at the end of MUM!
btw, is there a chance that the remaining US mum presentations will be accessible on the wiki?
#TR0359
mindaugasr
Re: Newsletter 62
Mon Oct 27, 2014 8:23 pm
Why no info about new CRS switches?
http://gregsowell.com/wp-content/upload ... G_6510.jpg
http://gregsowell.com/wp-content/upload ... G_6509.jpg
http://gregsowell.com/wp-content/upload ... G_6508.jpg
We are interested in CRS212-1G-10S-1S+ does mikrotik have some release date?
ostinato
Re: Newsletter 62
Tue Oct 28, 2014 7:11 am
Hi
can cAP 2N do roaming with easy like Unifi ?
normis
Re: Newsletter 62
Tue Oct 28, 2014 8:29 am
RouterOS has always been capable of roaming, this is not related to product model. So yes, cAP and any other MikroTik device, is capable of seamless roaming
blingblouw
Re: Newsletter 62
Tue Oct 28, 2014 10:32 am
I believe the part you missed was "can cAP 2N do roaming with easy like Unifi ?"
I guess that impliess their "zero-handoff". Marketting is awesome (/sarcasm).
No, Mikrotik does not do SCA or zero handoff, but so what? Plan your channels better and you will have success. Rather mikrotik can support 802.11r or even better 802.11k to assist with roaming.
Even meru are moving away from single channels.
uldis
Re: Newsletter 62
Tue Oct 28, 2014 11:51 am
RouterOS doesn't support zero-handoff, but the client roaming between the APs should work ok.
normis
Re: Newsletter 62
Tue Oct 28, 2014 11:55 am
Our routers have been used in high speed trains, where they connect to AP devices nearby tracks, and change the AP very often. They have also been used for VOIP phones in moving cars. The voice connection is not interrupted when the device changes APs.
ste
Re: Newsletter 62
Tue Oct 28, 2014 12:17 pm
What is the mechanism to roam between APs seamless. The laptops I use need some time to check signal is to low to do a good connection and decide to change ap and then they need some time to switch to another AP even using the same SSID on a bridged network.
You need special wifi-clients or software to make this seamless?
normis
Re: Newsletter 62
Tue Oct 28, 2014 12:33 pm
You can implement access list where the laptop will be kicked off, if the signal falls below a defined value. Laptop will then immediatelly connect to the strongest SSID.
uldis
Re: Newsletter 62
Tue Oct 28, 2014 12:40 pm
Windows wireless clients usually switch to a AP with better signal seamlessly. Also on some wireless drivers there is a roaming aggressiveness settings.
jp
Long time Member
Long time Member
Re: Newsletter 62
Tue Oct 28, 2014 3:01 pm
That new fiber media converter looks interesting. I'd like to see one with the SFP and patch cable installed. Looks like not much room for slack or fastening the drop cable. I'd really like it if that had even some basic management/remote abilities. I'm sure it'll all happen in good time, but I'm impatient.
angboontiong
Re: Newsletter 62
Tue Oct 28, 2014 6:45 pm
is there new version of cap manager?
the one i test when the cap manager offline, then all cAP is not working.
or, how can we make the cAP auto downloand the configuration to itself, when CAPman is offline, CAP will run by itself?
infused
Re: Newsletter 62
Wed Oct 29, 2014 8:06 am
Why did you make them look like smoke alarms? That's not a selling point. Look is half the reason we use the Unifi gear.
normis
Re: Newsletter 62
Wed Oct 29, 2014 8:39 am
for many people it is. if you don't wan a smoke-alarm looking device, but something nice, we will have those too. mAP is a good start, but we will also have other good looking indoor APs
jarda
Re: Newsletter 62
Wed Oct 29, 2014 9:21 pm
Really promising. What we should be prepared for? Please be more specific.
jaykay2342
Location: /Vigor/LocalGroup/Milky Way/Earth/Europe/Germany
Re: Newsletter 62
Wed Oct 29, 2014 9:58 pm
i'm really curious about new mikrotik indoor APs. i recently bought some unifi APs. And i'm disappointed regarding the possibility in terms of configurations. With routeros i've so much more options.
9-5 Job: Securityanalyst at a major MSSP.
Free time volunteer: Networkadmin and founder at a small non-profit WISP.
Certifications: ITILv3, GCIA
infused
Re: Newsletter 62
Thu Nov 27, 2014 6:00 am
Is there a full sfp+ switch/router coming out soon?
normis
Re: Newsletter 62
Thu Dec 11, 2014 10:33 am
We will soon release the CCR1072 which has all SFP+ ports
nz_monkey
Re: Newsletter 62
Thu Dec 11, 2014 10:42 am
Hooray :)
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
43north
Re: Newsletter 62
Sun Dec 14, 2014 1:58 am
Any idea of a price point for the CCR1072??
gotsprings
Forum Veteran
Forum Veteran
Re: Newsletter 62
Sun Dec 14, 2014 6:07 pm
Bring on the DualBand AP. I am sick to death of taking over UniFi installs.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
payday
Re: Newsletter 62
Sun Dec 14, 2014 10:44 pm
Take price of any competitor device with same specification, divide by 5 and you have a price point. :)
jzzo
Re: Newsletter 62
Mon Dec 15, 2014 3:45 pm
Hello...
can't find the performance test results on the new RB850Gx2.. or better yet a comparison of eg. RB750 / RB800 / RB450 / RB1100AHx2
Regards Jan Eriksen
ofca
Re: Newsletter 62
Tue Dec 16, 2014 8:19 am
So how about this 24x SFP + 2x SFP+ device?
IPANetEngineer
Trainer
Trainer
Re: Newsletter 62
Tue Jan 20, 2015 10:11 pm
Looking forward to the next newsletter. Hope to see the next one soon!
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
keefe007
Re: Newsletter 62
Tue Jan 27, 2015 5:26 am
I like to see a CRS with more than 2 SFP+ ports.
Users browsing this forum: No registered users and 4 guests
