That's not a flaw in concept of fasttrack. A typically configured firewall without fasttrack behaves just like that anyways- checks the initial handshake, applies policies, accepts everything else. You need to understand that a firewall is NOT a traffic scanner, i.e. it does not (and should not) behave like antiviruses do. Once connection is established there's very little firewall can check in the following packets.I am thinking about a potential flaw at the conceptual level. Imagine a convoy of delivery trucks arriving at my University gate, using a metaphor. The gatekeeper checks the first few trucks and then allows the rest of the convoy to go through. To speed up traffic of course.
The implied assumption is the rest of the convoy carries the same thing as the first few trucks.
or ever? Isn't fastpath/fasttrack using hardware specific capabilities? And for x86, why do you even need it?No fastpath or fasttrack on x86 for now...
Same on RB750G 6.33.3, fasttrack filter rule counter is ticking butip/firewall/filter
chain=forward action=fasttrack-connection connection-state=established,related log=no log-prefix=""
chain=forward action=accept connection-state=established,related log=no log-prefix=""
Only a test in RB750g, no result...
IPv4 Fasttrack Active Yes
IPv4 Fasttrack Packets 0
IPv4 Fasttrack Bytes 0 B
I can't speak for Mikrotik, but it seems like the natural direction for CHR.or ever? Isn't fastpath/fasttrack using hardware specific capabilities? And for x86, why do you even need it?
1) mark-connection work exactly the same way.fasttrack is indeed a cool feature, but it's current implementation is confusing and misleading. it also breaks the "normal" rule behavior.
when you place a "fasttrack connection" rule in your fw, then packets matched with this rule may or may not be fasttracked. that means, not all matching packets are consumed by this rule, therefore you need an "accept" rule right after the fasttrack rule.
this is not how rules behave. also, you cannot just replace your "accept" rules with "fasttrack", you have to add them.
so to correct this, the "fasttrack connection" action SHOULD utilize fallback to accept:
then and only then all matched packets are consumed, so no need for additional accept rule and no more "broken behavior".
- if fasttrack can be applied on a packet, then it is fasttracked.
- if fasttrack can not be applied on a packet, then it is accepted.
looks like you're talking about FastPath, not FastTrack. FastTrack is supported by RouterOS, not by hardwareI read RB4xx don't supports FastTrack. But why Winbox it showing this option on the Firewall action ?
IMHO, Winbox should detect this and the fastrack option should not appear.
What do you mean by "IPTV HLS"? can you be more precise? i have no issues with my IPTV and Fastpath? If you use Fasttrack then this traffic is NATed??New ISSUE: Fasttrack causes errors with IPTV HLS. If is used Fasttrack , IPTV does not Work.... in all versions.of RoS vhere is it
thats what i try to solve, today i was searching ipTV problems in forum cause i also have a problem at iPTV....New ISSUE: Fasttrack causes errors with IPTV HLS. If is used Fasttrack , IPTV does not Work.... in all versions.of RoS vhere is it
However, both OS CLI and WinBox happily allow to enable Fasttrack on RB850Gx2. Filter rule with action=fasttrack-connection is also OK on RB850Gx2.RB850Gx2 is not supported.
https://wiki.mikrotik.com/wiki/Manual:I ... d_hardware
FastTrack will help keep CPU utilization low. It's configured by default so you might as well leave it on. Local connections will only be FastTracked if you are doing inter-VLAN routing on the LAN side. If you have a single flat network on the LAN your traffic will be "switched" at line rate with or without FastTrack.Good Morning!!!
A few days ago I bought an RB750GR3 for my home.
In my house I have internet connection of 30 megs of downhill and 3 megs of climb.
My query is if it is worth using fasttrack for this speed ???
Fasttrack is only for WAN-LAN or does it also affect LAN-LAN ???
On the other hand, the configuration that comes by default has everything activated or you have to do some particular configuration but ???
Thank you very much already.
Greetings.
Thanks for your answer!!! Greetings.FastTrack will help keep CPU utilization low. It's configured by default so you might as well leave it on. Local connections will only be FastTracked if you are doing inter-VLAN routing on the LAN side. If you have a single flat network on the LAN your traffic will be "switched" at line rate with or without FastTrack.Good Morning!!!
Greetings.
I use a RB750Gr3 on my LAN and have tested with and without FastTrack and it definitely won't limit you if you turn it off on a 30Mb/3Mb connection as far as accessing the Internet is concerned with a single flat network behind the Internet.
