I have a problem to add ipv6 pool in From Pool field when i add ::/64 ipv6 Addresses.
I make a ipv6-pool in DHCPv6 client but this pool cant display at From Pool filed when i add ::/64 ipv6 Addresses.
When i load a backup from previous ROS, all work ok.
When i make reset configure add configure the router from beginning, i have the above problem.
In addition i have always connect/disconnect when i make pppoe client connections with ipv6 enable.
With previous backup file i dont have the same problem.
The configuration is exactly same.
The only different is I make reset configuration.
I have CRS109-8G-1S-2HnD-IN and the old board is RB951G-2HnD.
The problem is the same with this:
http://forum.mikrotik.com/viewtopic.php?t=61976
